forum frandroid - android et tablette
  • Connectez-vous avec Facebook Connectez-vous avec Twitter Connexion avec Google Connexion
  • Créer un compte
Change
[Kernel][JB] ANARKY -- LEAN -- NYAN -- ZEN
1288 réponses à ce sujet
#1
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
  • Modèle:Tuna Maguro
KERNEL ANARKY
* Works on:
CM Based ROMs + AOSP Based ROMs
Linux 3.0.51+
Based on JB Stock Kernel
All the CM10 Advanced interfaces Implemented
Ramdisk Compatible CM and AOSP
Compiled with New Linaro 4.7.3-2012.10-20121024
* Governor loaded by defualt:
Interactive (Default)
InteractiveX, Ondemand, Sakuractive, Lazy, Wheatley, Performance, Intellidemand
* Governor can be loaded as module by "insmod":
Nothing for now
* Scheduler:
Deadline (Default and Optimized)
Cfq, Bfqv5, Noop, Sio
* Cpu Freqs:
350Mhz (Default Min) -
1200Mhz (Default Max)
+ 1400Mhz
+1600Mhz
+ Mpu LiveOC
+ Core LiveOC
* Gpu Freqs:
307Mhz (Default)
+ 384Mhz
+ 512Mhz
* TCP Congestion:
Westwood (Default)
Bic, Cubic, Htcp, Hstcp, Hybla, Vegas, Scalable, Lp, Veno, Yeah, Illinois, Reno
* Others Features:
Wifi Drivers from 3.4.x Kernel
Interactive Governor from 3.4.x Kernel
CPU Topology
SGS Color palette
Content Adaptive Brightness
GPU OC sysinterface
OTG Host Mode On Charge
zRam support
Ksm support
TouchWake
Fsync Control
Voltages Control (Core, Iva, Mpu and more ...)
Blx control
Fastcharge control
High performance audio
Sound Boost control
Temp control
Thermal throttle control
Vibrator control
Color Control
Gamma Control
Trinity Contrast
Wifi PM with Proximity Support
Live OC
... ecc .. ecc ...
Lien XDA pour download:   http://forum.xda-dev...d.php?t=1883298
KERNEL LEANKERNEL
FEATURES
  • Patched to latest in Linux 3.0.x branch: 3.0.52.
  • All unnecessary kernel components removed to make kernel lean and fast!
  • OC to 1.65ghz. Boot speed is maxed at 1.2ghz within kernel (in addition to ramdisk) for stability.
  • User voltage control
  • InteractiveX V2 (screen-off hotplug of cpu1) added. Select it using setcpu if you want to use it.
  • Ramdisk tweaks (sysctl, vm, filesystem speed, etc.)
  • SWAP & zram (next generation compcache) support. Run "zram enable" in terminal.
  • init.d support in ramdisk.
  • lk.conf for basic kernel configuration.
  • HotplugX governor (Hotplug optimized and modified for screen-off suspend).
  • wakelock tweaks for wlan and lte modem
  • lkflash - script to flash latest versions of leanKernel from Terminal (type "su" without quotes, hit enter, then type "lkflash" without quotes and then hit enter)
  • checkv - voltage checking script (for custom undervolting) - detailed at bottom of this post.
  • checkt - script that displays 1) your current temp, 2) # of times you were throttled due to temp "recently", 3) CPU trim type, and 4) CPU silicon type, etc. (sample output)
  • Fast USB charge (by chad0982) and "ffc" toggle script by me. (Open terminal, and type "ffc" without quotes then enter)
  • ColorControl from both CM9 and Ezekeel (compatible with all ROMs). Helpful posts: 1and 2.
  • TempControl - sysfs interface to control the CPU temp threshold. Read these two posts: 1 and 2.
  • Variable GPU OC - sysfs interface to select GPU max speed between 307MHz (stock), 384MHz and 512Mhz. The changes take effect immediately. Check FAQ for more info and how to use it.
  • Custom SR Tuning - override kernel default minimum voltage for SR calibration. More info hereand here. V2
  • SoundControl
  • Gamma Control
Lien Rootzwiki pour download:   http://rootzwiki.com...-jb-450-102412/
KERNEL NYAN KERNEL TUNA
Features
Bold = Default
CPU Governors
PegasusQ - A mix of performance and battery life that hotplugs the cpu at low use
Interactive - Boosts frequency based on load put on by the user. Modified to also boost on touch of the screen.
Ondemand - Basic scale on demand governor with no hotplugging
HotplugX - Ondemand modified to hotplug at low use and screen off
Wheatley - Basically ondemand (scales depending on demand) that is modified for performance
Lazy - Basically conservative (scales gradually depending on load) that is modified for performance
Schedulers
SIO - A mix of NOOP and Deadline made for flash memory, like the GNex has
BFQ - Currently experimental. For heavy IO load
CFQ - Attempts to distribute the disk fairly among processes
Deadline - Imposes a deadline on processes to prevent lack of resources
NOOP - Simplest scheduler. Good for flash memory.
CPU Frequencies (MHz)
230, 384, 729, 1030, 1228, 1305, 1420, 1536, 1612, 1728, 1804
GPU Frequencies (MHz)
Set by running: echo # > /sys/devices/system/cpu/cpu0/cpufreq/gpu_oc
echo 0 = 308MHz
echo 1 = 384
echo 2 = 512
If you don't like using command lines, you can edit the gpu_oc file with es file explorer and change it from 0 to 1 or 2
Misc Features
Feature - Default Setting
Max Screen Off - 384000
Read Ahead Buffer Size - 2048
TCP Congestion Control - cubic
Wifi High Performance - off
Fast Charge - off
High Performance Sound - off
Vibrator Strength - 1400
Battery Life Extender - 100
FSYNC Control - off
Temperature Limit - 64
SmartReflex - All options ON
Voltage Control (too much to list, just screenshot before changing)
Gamma Control - -10
Contrast Control - 6
Color Settings - Default preset
Compiled with Linaro's GCC 4.7
Fixes, speed enhancements, security enhancements, Linux updates, and battery enhancements
Lien XDA pour download:  http://forum.xda-dev...d.php?t=1844793
KERNEL ZEN SERIES
Two Versions:
ZenSERIES Kernel v16 4.2
ZenSERIES Kernel v16 4.1
All Major Kernel App Controllers Compatible
384/1230Mhz CPU - ZenX/Row Default
384MHz GPU Clock Speed Default
PGM Supported
  • Available CPU Steps
  • Overclocking/Undervolting/Overvolting
  • 218-1804
  • Available GPU's
  • 307/384/512
  • Available Governors
  • ZenX - Default
  • Interactive
  • Pegasusq
  • Ondemand/OndemanndX
  • Performance
  • Conservative
  • Intellidemand/IntellidemandX
  • Adaptive/AdaptiveX
  • Available I/O Schedulers
  • Deadline
  • SIO/Noop
  • Row/Fiops
  • Cfq/Bfq
  • Available Schedulers
  • Deadline
  • SIO/Noop
  • Row/Fiops
  • Cfq/Bfq
LIEN XDA POUR DOWNLOAD:  http://rootzwiki.com...6-sanity-check/
Ces kernels sont a utilisés avec TRICKSTER MOD, lien:
http://forum.xda-dev...d.php?t=1768315
Réglage manuel du kernel:
a utiliser avec terminal émulator
ou avec script réalisé par-iNSiGhT-
a placer dans etc/init.d avec un explorateur root.
les modifications sont a faire en éditant le texte.
lien script:   http://forum.frandro...-configuration/
Modifié par bArbAc™, 30 December 2012 - 15:37.
MAGURO -- Jelly Beer 4.16 -- ANARKY kernel -- TWRP 2.5.0.0
#2
Diaruga
Diaruga
    Android sauvage
  • Membre
  • 1235 messages
  • Modèle:Galaxy Nexus
Intéressant ! Quelle version utilises-tu en ce moment ?
Image IPB
Catactlysm, AK PGM
"S" By Muzzano
Image IPB
ParanoidAndroid
Ghub case
#3
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
 Diaruga, le 22 September 2012 - 17:50, dit :
L'expérimental 70 et ça tourne comme une horloge.
depuis mon Nexus Prime ANARKIA
Modifié par BARBAC, 22 September 2012 - 19:02.
#4
aureldelp
aureldelp
    Android des montagnes
  • Membre
  • 599 messages
  • LieuLille
  • Modèle:Nexus S / Nexus / Nexus 7
Rrrhhhoooo des infidélités a tinitry barbac ????
Du coup je vais tester
Envoyé depuis mon Galaxy Nexus avec Tapatalk:lol:
#5
Diaruga
Diaruga
    Android sauvage
  • Membre
  • 1235 messages
Je testerai dans peu de temps, merci de ton retour. ;)
Image IPB
Catactlysm, AK PGM
"S" By Muzzano
Image IPB
ParanoidAndroid
Ghub case
#6
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
 aureldelp, le 22 September 2012 - 18:03, dit :
Et oui, je crois avoir trouvé mieux......
Test et tiens au courant.
#7
Emic37
Emic37
    Android no-life
  • Membre
  • 2284 messages
  • LieuTours (37)
  • Modèle:Galaxy Nexus i9250
Mieux que Trinity?! Pas possible! :P
Ce kernel a une appli de réglage?! Ou tu utilises tkt?! Ramdisk modifié ou non (pour les jeux EA...)?!
Image IPB
AOKP Kang JBean 4.2.1 - leanKernel StableV5.3 - XXLH1 - TWRP Recovery
#8
AirOne70
AirOne70
    Android 1337
  • Membre
  • 1404 messages
  • LieuEst
  • Marque:LG
  • Modèle:Nexus 4
@Emic: "Kernel a utilisé avec TRICKSTER MOD, lien:  http://forum.xda-dev....php?t=1768315"
Image IPB
ROM: Xylon // V2.7.7  | Kernel: Motley+ B5 | Team XYE
#9
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
 Emic37, le 22 September 2012 - 19:00, dit :
comme l'a dit airone Trickster mod, sinon pour la ramdisk je sais pas.
Test tu verra..... ;)
Modifié par BARBAC, 22 September 2012 - 19:05.
#10
rachid596
rachid596
    Grand Android
  • Membre
  • 743 messages
je teste ce soir, je fais confiance à barbac :-) :-)
Galaxy Nexus using Android 4.1.1 :-)
#11
papi11on
papi11on
    Android à poil bleu
  • Membre
  • 219 messages
oula oui il a l'air sympa. A flasher normalement ?
Galaxy Nexus Rom AOKP + Kernel Franco
B&You 19.99€
#12
Emic37
Emic37
    Android no-life
  • Membre
  • 2284 messages
  • LieuTours (37)
Lol merci les gars en effet c'est écrit. Quand j'ai posté, toutes balises étaient visibles dans le premier post donc je me suis pas trop attardé... bref! Je testerai ça quand je flasherai...
Image IPB
#13
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
@papi11on
Oui comme d'hab.
#14
Diaruga
Diaruga
    Android sauvage
  • Membre
  • 1235 messages
Convaincu ! ;)
Merci du partage !
Image IPB
Catactlysm, AK PGM
"S" By Muzzano
Image IPB
ParanoidAndroid
Ghub case
#15
Billouetaudrey
Billouetaudrey
    Android no-life
  • Membre
  • 2192 messages
Merci ! J'avais vue vite fait sans sauter le pas...
#16
-iNSiGhT-
-iNSiGhT-
    Android sauvage
  • Membre
  • 1128 messages
  • LieuMontpellier
"fonctionne sur ROMs basée sur CM10"
La Codenamedroid est basé sur CM10 ? Car, il y a juste l'indication AOSP...
Merci.
Envoyé depuis mon Nexus 7
4,7"
Nexus 4 16Gb
ROM : ParanoidAndroid 3.5 alpha
Kernel : Harsh
7"
Nexus 7 16Gb noire
ROM : ParanoidAndroid 3+
Kernel : Stock
Thème : Stock
10"
Retina iPad 32Gb
#17
Billouetaudrey
Billouetaudrey
    Android no-life
  • Membre
  • 2192 messages
Voir le message-iNSiGhT-, le 22 September 2012 - 20:32, dit :
Merci.
Je l'ai mise sur xenonhd et pas de soucis...
#18
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
Merci.
CNA est basée sur CM et AOKP donc pas de prob
Bon petit retour, les images parlent d'elles mêmes
Image IPBImage IPB
4h d'écran allumé et encore 28% de batterie.
Ma config
Image IPB
Avec fsync on.
#19
Billouetaudrey
Billouetaudrey
    Android no-life
  • Membre
  • 2192 messages
Voir le messageBARBAC, le 22 September 2012 - 21:18, dit :
CNA est basée sur CM et AOKP donc pas de probBon petit retour, les images parlent d'elles mêmes
Image IPBImage IPB
Ma config
Image IPB
Avec fsync on.
Gpu oc ? 0 1 2 3?
#20
bArbAc™
bArbAc™
    Android no-life
  • Membre
  • 2934 messages
  • LieuEast coast
  • Marque:Google
Voir le messageBillouetaudrey, le 22 September 2012 - 21:20, dit :
Gpu oc ? 0 1 2 3?
Ah oui GPU a 384 donc 1, oublié.....
2 utilisateur(s) li(sen)t ce sujet
0 membre(s), 1 invité(s), 0 utilisateur(s) anonyme(s)
    Google (1)
Skimlinks
