[ROM] [XXUAMF8] [I9505][root] maj 25-06-2013
Je vous recommande cette rom http://forum.xda-dev...d.php?t=2250824
Perso j'ai pris la slim , elle marche à la perfection .. elle est rootée et supporte les Maj officielle . Donc apparaît comme officielle au BOOT
Main benefits of using this method are:
- FULLY PRE-ROOTED
- NO REBOOTS
- WRITABLE SYSTEM
- Complete, Odin flashable Packages.
- Can be used on Non-Rooted devices.
- No need for Insecure Kernels.
- Binary Flash Counter will NOT increase
- System status will stay NORMAL/OFFICIAL.
- Fully working KIES & OTA updates (FYI: root will be lost after software update)
- Only 1 file and you have a complete firmware including Root permission.
GT-I9505 Official Stock Packages:
- Pre-Rooted
- Unbranded
- No other modifications
- Device Status - OFFICIAL
- Fully working OTA and KIES updates
Model: GT-I9505 (4.2.2)
PDA: XXUBMF8
PHONE: XXUBMF8
CSC: OXABMF8 (8 codes)
Kernel: 3.4.0-917495 (19.06)
Build Date: 19.06.2013
Changelist: 917495
Original Stock ROM: Download: <<< Hotfile >>>
Stock KERNEL: Downloads: <<< Android Host >>>
Stock RECOVERY: Downloads: <<< Android Host >>>
Pre-Rooted ROM: Downloads: <<< Android Host >>>
NOTE:
I've prepared a special package for all who are using ODEX version (ORIGINAL) and decided to try DEODEX instead...
You need to install Custom Recovery first and then flash ZIP from SD card:
"DEODEXED Apps+Framework" package (THIS IS NOT ROM!!!) - CWM flashable - Downloads: <<< Android Host >>>
PDA: XXUBMF4
PHONE: XXUBMF4
CSC: OXXBMF2 (29 codes) (NOTE: KIES will NOT recognize this FW due to CSC mismatch..)
Kernel: 3.4.0-779953 (10.06)
Build Date: 10.06.2013
Changelist: 779953
Stock KERNEL: Downloads: <<< Hotfile >>> or <<< Android Host >>>
Stock RECOVERY: Downloads: <<< Hotfile >>> or <<< Android Host >>>
Pre-Rooted ROM: Downloads: <<< Hotfile >>> or <<< Android Host >>>
NOTE:
PDA: XXUBMF5
PHONE: XXUBMF5
Kernel: 3.4.0-768421 (11.06)
Build Date: 11.06.2013
Changelist: 768421
NOTE:
PDA: XXUBMEA
PHONE: XXUBMEA
CSC: OXABMEA (MultiCSC - 8 codes)
Kernel: 3.4.0-768421 (30.05)
Build Date: 29.05.2013
Changelist: 768421
Original Stock ROM: Download (Hotfile)
NOTE:
GT-I9505 Modified Stock Packages:
- Pre-Rooted
- Unbranded
- DeOdexed
- DeBloated
- Zipaligned
- Super-SLIM (1.1GB)
- Patched NfcNci.apk - working NFC Payment / NFC Tags
- Patched SecPhone.apk - No Increasing Ringtone + Call Recording
- Patched SecEmail.apk + SecExchangeServices.apk - working HOTMAIL and all other Accounts
PDA: XXUBMF8
PHONE: XXUBMF8
Changelist: 917495
Deleted apps (XXUBMF8 - DEODEXED) - Downloads: <<< Android Host >>>
PATCHED SecPhone.apk (Call Recording + NO increasing ringtone) - Download: <<< Dev-Host >>>
PDA: XXUBMF4
PHONE: XXUBMF4
Changelist: 779953
Deleted apps (XXUBMF4 - DEODEXED) - Downloads: <<< Android Host >>>
Original SecPhone.apk - Download: <<< Dev-Host >>>
PDA: XXUBMF5
PHONE: XXUBMF5
Changelist: 768421
Deleted apps (XXUBMF2/MF5 - DEODEXED) - Downloads: <<< Android Host >>>
PDA: XXUBMEA
PHONE: XXUBMEA
Changelist: 768421
PATCHED ExchangeServices.apk - DOWNLOAD
Use file manager, mount system as WRITABLE (rep /system/app) and copy/paste SecPhone.apk into /system/app
DONE!!
Maj
La MF5 plus ancienne (dans changelog) que MF4 et la MF8 est la dernière ..oui c'est etrange mais c'est comme ça :)
toujours la même méthode:
INSTALLATION D'UN PACKAGE
PRE-REQUIS :
  • - Avoir installé les drivers USB.
  • - Télécharger et décompresser le fichier Odin3_v3.04.zip
  • - Télécharger et dézippez un package ROM Stock modifiée ci-dessus
NSTRUCTIONS POUR LE FLASH VIA ODIN PC :
  • Éteignez votre mobile.
  • Appuyez simultanément sur les touches Volume Bas + Home + Power puis Volume Haut pour redémarrer votre mobile en download.
  • Connectez votre mobile à votre ordinateur.
  • Lancez le fichier Odin3_v3.04.exe contenu dans le dossier dézippé.
  • Sélectionnez le fifchier .TAR (obtenu via la décompression du package téléchargé) et placez-le dans le champPDA.
  • Cliquez sur Start pour lancer l'installation.
  • Patientez pendant l'installation et ne touchez à rien. Votre mobile va redémarrer.
  • Voilà, la nouvelle rom pré-rootée est installée. Pour visualiser, les nouvelles configurations de votre mobile, rendez-vous dans Paramètres > A propos de votre téléphone.
    L'application SuperSU a du faire son apparition dans votre liste d'applications. Vous pouvez également utiliser l'application Root Checker pour contrôler vos accès root.
Modifié par crackerbelin
La version dont tu parles , la slim m'intéresse fortement !
Apparemment basé sur le dernier FW et en plus rootée et compatible mise à jour officielle que demander de plus!!
Seul hic, ils ont apparemment retiré Shealth et Chaton que j'aimais pas trop mal encore.....ça doit pourvoir se réinstaller héhé
Sinon ont-ils laisser toutes les fonctionnalités du S4 comme air view, air gesture, défilement ect...??
Merci pour le partage en tout cas!
http://www.samsung.c...ty/samsung-knox
Samsung KNOX™ is the comprehensive enterprise mobile solution for work and play. With the increasing use of smartphones in businesses, Samsung KNOX addresses the mobile security needs of enterprise IT without invading the privacy of its employees.
cela semble etre une solution de crypto à activer .. mais qui pose pb [color=red]qd[/color] tu veux rooter le tel (logique) ... et qui fou le souk!!
fluidité
Meilleure que la F
Bien meilleur que la M
identique à la N (si tu as tout supprimé avec titanium backup)
Le bon en avant est sur la reception des appels et 3G. Le bug 2/3/4G qui n'est plus présent ... et l'autonomie qui me semble meilleure...
Perso j'ai viré aussi dans options de développement :
echelle d'animation fenetre, transition et animateur : desactivée
j'aime avoir un tel reactif :)
bon allez je flash!! et je fais un piot retour après test minimum!
Flashage fait!
Je suis bien repasser en status officiel donc les mises à jour ok!
En revanche , j'ai formater ma mémoire interne avant de lancer le flashage via odin et au redémarrage tout est comme avant ( en apparence ) j'ai toujours mon launcher Nova, tout mes icones, mes jeux , mes applications ect....
Mais je suis bien en ME2 !
Pas compris mais tant mieux tout à l'air fonctionnel et elle est effectivement plus fluide et réactive et je suis passer de 1.1go de ram à 850 au démarrage et même 670 après avoir killer les apps!
Vraiment du tout bon en somme au poil!
PS : j'ai toujours watchon entre autre bizarre je croyais que c'était retiré...
Modifié par bioboss
Tu n'as pas fait de wipe avant ?
Peut être pour ca que tu as encore des applications dedans.
Je test à mon tour dans la soirée
Installé de mon côté, avez vous fait des wipes avant ?
Modifié par Heldwin
Bonsoir à tous,
J'ai actuellement un Galaxy S4 avec la surcouche opérateur Orange et je pense donc flasher mon téléphone avec la ROM officielle qui se trouve sur le lien présenté ici même :)
C'est la 1ère fois que je vais flasher mon téléphone donc j'ai quelques questions svp :
Je suppose que ceux qui ont fait le flash avec cette ROM ont également des S4 français donc il n'y a aucun risque de compatibilité ?
Et est-il possible de flasher le téléphone sans faire de wipe avant ? Je n'ai pas trop envie de devoir tout réinstaller et reconfigurer mais bon s'il le faut vraiment je le ferai :)
Et dernière question, j'ai rooté mon S4 avec le CF-AutoRoot ça ne pose aucun souci de flasher directement le téléphone ou faut-il annuler d'abord le root ?
Voilà je pense que c'est tout ce à quoi je pense pour le moment, merci à tous :)
Modifié par AzizF11
@ azizf11 tu peux flasher par dessus ... et faire un factory reset apres (c'est le wipe integré à l'os ...) par contre tu perdras tout ce qui n'est pas sur la µsd . donc pense à mettre photos, zic, download sur votre sd externe.
sinon pour @heldwin c'est normal que tu ne perdes rien ... tu écrases seulement les applis intégrées à la souche 4.2.2 présente dans system/app (ou se situe les APK tagés system )
Par contre à chaque fois on a 3 choix pour avoir la rom rooter avec le suivi màj on doit prendre laquelle ? La dernière ?
Stock Recovery: Downloads: <<< Hotfile >>> or <<< Android Host >>>
Pre-Rooted Stock ROM: Downloads: <<< Hotfile >>> or <<< Android Host >>>
Merci pour ta réponse Crackerbelin :)
Mais du coup est ce que le wipe est obligatoire ou est ce que je peux flasher et ne pas du tout faire de wipe pour conserver toutes mes données ?
Et pour les 3 ROMs j'avoue que ce n'est pas très clair pour moi... J'aimerais prendre la ROM officielle avec Touchwiz en intégralité, mais j'aimerais aussi qu'elle soit rootée... Puisque j'ai déjà rooté mon téléphone est ce qu'il vaut mieux que je prenne la Original Stock ROM ?
Désolé je n'ai pas trop compris les différences entre les 3 ROMs en fait...
