[ROM] WanamLite XXUBMEA V1.1 Android JB 4.2.2 Clean & Stable
Posted in Galaxy S4 LTE By wanam On June 7, 2013
Welcome to the first release of WanamLite Rom for Galaxy S4 I9505.
Thanks to RootGalaxyS4 for the video.
Thanks to Alan-B, Benc88, Fauert, Harise100, Iamnotkurtcobain, Shanume and all my beta tester @xda-developers.
Features :
pic.png Based on the latest FW
pic.png Deodexed & Rooted & Zipaligned & Busybox
pic.png Unlimited SMS recipient list
pic.png Adam Kernel
pic.png Automatic SMS encoding (Arabic and other utf-8 encoding support)
pic.png Tweaked Ondemand Governor for better Battery life
pic.png Disabled scrolling cache
pic.png Removed bloatwares (Available on separate patch)
pic.png Large APN list
pic.png No incremental ringtone
pic.png Enabled Call recording
pic.png Enabled Call button on Contacts list
pic.png 4 Way reboot (Recovery,Download…)
pic.png Clean build.prop for best Market compatibility
pic.png Stock Keyboard with all supported languages enabled
pic.png Kies support
pic.png Hacked Stock Email App
pic.png Latest SuperSu update
pic.png Enabled all supported languages
pic.png Enabled call button on Contacts list
pic.png More Free Ram
pic.png Auto wipe cache & dalvik-cache before flashing
pic.png MultiCSC (145)
pic.png Busybox (installed on “/system/xbin”)
pic.png Disabled NFS Payment
pic.png More to come…
Change-log:
pic.png Based on XXUBMEA
pic.png Updated Root
pic.png Disabled SEAndroid (No Root warning)
pic.png CRT Off Animation (Thanks to Sorg)
pic.png Adam Kernel 1.3.2
pic.png Fixed LTE (4G) support (It should now on both cases: Full Wipe and Without Wipe)
Download:
Mirror1Mirror2(Thanks to Korumera and Romcook for hosting my files).
NB: If you get any LTE issues, you may need to flash a Stock MEA FW trough Odin then flash my Rom with NO Wipe.
Installation steps :
pic.png Copy my Rom to Internal sdcard
pic.png Install a CWM recovery, get it here, (Only if you don’t have it)
pic.png Backup, backup, backup
pic.png Flash my Rom from recovery
pic.png Don’t use the Root option from recovery (you don’t need it)
pic.png Reboot & enjoy
[show as slideshow]
Modifié par Gaulois Power
Bah heuuu j'ai pas teste... Ya pas grand chose a tester et les cartes en exfat ne sont pas supportes pour l'instant sans faire des manips ! Puis la ROM d'origine elle va très bien aussi donc bon !
De toute façon autant sur le S2 je trouvais que c'était la meilleure de loin, mais sur le S3 elle m'a pas du tout convaincue. Elle n'apportait pas grand chose par rapport aux autres, voire rien du tout. J'ai l'impression que c'est pareil ici. Il fait toujours ses petites modif' habituelles et après il se contente de mettre à jour sa ROM en fonction des leaks..
bonjour a tous
sur la video il le test sur le IG-9500 ET NON PAS I9505.
Sa change pas grand chose car le fonctions de la ROM restent les mêmes ! Il y a juste une version pour le 500 et une autre pour le 505.
Plop !
Je n'arrive à trouver beaucoup d'infos la dessus : on perd les fonctionnalités du S4 avec WanamLite ? (la video qui s arret quand tu tournes la tête, survole sans toucher avec le doigt, etc.) ?
J'ai vu que touchwiz avait été porté pour pouvoir etre réinstallé sur n'importe quelle rom JB. c'est ça la solution ?
Merci ! ^^
  • 3 weeks later...
