[ROM] [S4 I9505] [26 Mars ] (TW LOLLIPOP) The Echoe Rom V47 - Echoe Pop 7
Liens :
http://echoerom.com/...pic.php?f=2&t=1
Boot Animations :
Derniers Firmware:
10891701_10152712365939317_5055534367612
:excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:  :excl:
-26 mars 2015 Echoe Rom V47 (9505ZHUHOC3)
Changes compared to v46:
-25 Mars 2015 S4 Echoe Rom V46 (9505VJUHOC1)
Changes compared to v45:
Anciens firmware /
-18 Mars 2015 S4 Echoe V45 Officiel base I9505XXHOB8
Spoiler:
FULL FEATURE LIST:
INSTALLATION INSTRUCTIONS:
- YOU DO NOT NEED TO FLASH ANYTHING STOCK!!
IT DOESNT MATTER WHAT BOOTLOADER OR MODEM YOU HAVE JUST FLASH N' GO
- CLEAN FLASH IS STRONGLY RECOMMENDED (wipe data/factory reset BEFORE installing the Rom)
- AFTER YOU DOWNLOAD PLEASE CHECK THE MD5 OF THE ZIP
md5: 095a369afd06d5203993ecf780441629
- THE 1ST BOOT WILL TAKE AT LEAST 15-20 MINUTES !! BE PATIENT
(It's because it boots in art- no more dalvik)
15 Mars 2015 S4 Echoe V44 Officiel base I9505XXXUHOB7
Spoiler:
Changes and Additions compared to Echoe v43:
(08 February 2015) S4 Echoe Rom v40 (Echoe Pop- Lollipop Port)
Quote:
- Based on the following Unofficial Lollipop Leak for the Chinese S4 variant I9508
ro.build.version.incremental= I9508ZMUJOA1
ro.build.version.release= 5.0.1
ro.build.changelist= 3847825
ro.build.date= Mon Jan 12 18:23:00 KST 2015
- Ausdim's TW Lollipop kernel
(wifi and storage work!!)
[Please 1st go over here and thank ausdim for his great work but please also read about any potential bugs]
- Deodexed
- Prerooted with latest SuperSu, busybox
- Rom Init.d support (does not depend on the kernel!!)
- Call Recording
- 5 Way reboot
- Stock S4 Lollipop TW Launcher with Theme Option and 7 additional themes!!
- Enabled Ambient Screen Display
- Enabled Toolbox
- Enabled Easy Side Key
- Enabled Private Mode
- Enabled the following additional lockscreen effects:
. Abstract Tiles
. Geometric Mosaic
. Popping Colors
. Ink Effect
. WaterColor
- Enabled Grey Scale in Power Savings
(Note: even though you also get the option for UPSM, it is not functional yet)
- Added network meter in status bar
- 3minit battery mod
- TorchLight (Settings/Display)
- Echoe Customization Portal (accessible in Settings)
(with access to the Echoe Kitchen for OTA downloads of mods i will be adding shortly)
- No SMS/MMS in Call Logs
- Removed most if not all of Chinese bloatware
- Added stock International Bootanimations and Bootsounds
(you really dont wanna hear the creepy one the rom cam with lol)
- Enabled Quadview in Mutiwindows
- Many more apps enabled in Multiwindow
- Fixed ext sd card read and writing block
- Fixed Screen Mirroring
- All the little csc mods
(i,e, call icons in logs list, colored splanner, exit and home options in sbrowser,
folder view in sms app), shutter sound on/off in camera, etc., etc., etc.)
- Stock Keyboard with theme option
- Minimal gapps are pre-included
(for more go here: http://forum.xda-developers.com/para...-apps-t2943900)
Quote:
- NO NEED TO FLASH ANYTHING STOCK BEFOREHAND
- CLEAN FLASH IS A NECESSITY UNFORTUNATELY
- THE 1ST BOOT WILL TAKE AT LEAST 10 MINUTES !! BE PATIENT
- Have Daydream enabled in settings. It will help with the reboots you may have because of the kernel
(21 January 2015) The Echoe Ported Chinese Lollipop Experiment :excl:  :excl:
- Deodexed mouahahahaha!!
- Call Recording
- 5 Way reboot
- I know im forgetting stuff but you can tell me when you try it
- You can flash a gapps package from here.
BUG:
Quote:
- NO WIFI!!!
(but amazing 3g/lte reception lol)
(I promise that if there's a solution that does not depend on lollipop kernel sources,
I will find it!!)
- THE 1ST BOOT COULD TAKE UP TO 10 MINUTES !!
(12 December 2014) S4 Echoe Rom v39.1 S5 Port- Part XIII
Quote:
-- Obviously the new base (I9505XXUNGNK4)
Model name: GALAXY S4 LTE
Country: Germany
Version: Android 4.4.2
Changelist: 3423977
Build date: Thu, 27 Nov 2014 09:11:03 +0000
Product Code: DBT
PDA: I9505XXUGNK4
CSC: I9505OXAGNK4
-- Brand New AEL Mainline Kernel v6.5
-- Everything else from previous Echoe S5 Ports
*** NOTE: If you are coming from v37.1 or another S5 Port then
chances are you will be ok with a dirty flash. However, I strongly recommend
a CLEAN WIPE!! (This means wipe system, and wipe data/factory reset
BEFORE flashing the Rom- dont do it afterwards because you will
erase the data folder that is flashed with the rom) ***
(11 December 2014) S4 Echoe Rom v39 (NK4)
Quote:
- Updated to Latest Samsung 4.4.2 Base I9505XXUGNK4
Country: Germany
Changelist: 3423977
Product Code: DBT
PDA: I9505XXUGNK4
CSC: I9505OXAGNK4
- NEW AEL Kernels v6.5 Mainline and Superlative
(available as Aroma options)
- Note: This is the "pure" S4 version of Echoe Rom with the full aroma installer
with countless mods. It DOES NOT contain the UPSM MOD. If you want a S5 Port Rom
Echoe v39.1 will be released tomorrow mornign
Installation:
- This is a 4.4.2 Rom so you will only need the newest modems ONLY if you want to
use stock kernel
- A CLEAN WIPE (wipe data/factory reset and system) is NECESSARY for everyone
(01 December 2014) S4 Echoe Rom v37.1 S5 Port - Part XII
Quote:
-- Obviously the new base (I9505XXUNGNK2)
Changelist: 3308645
Build date: Mon, 17 Nov 2014 00:48:26 +0000
Product Code: PHE
PDA: I9505XXUGNK2
CSC: I9505PHEGNK3
-- Repacked AEL Mainline Kernel v6.3 with the NK2 ramdisk
-- 5x5, 5x5, 6 hotseat modded for speed S5 Launcher
-- Fully working One-Hand function
-- Fully working S5 Browser
*** NOTE: If you are coming from v35.1 or another S5 Port then
chances are you will be ok with a dirty flash. However, I strongly recommend a CLEAN WIPE!!
(This means wipe system, and wipe data/factory reset BEFORE flashing the Rom- dont do it afterwards
because you will erase the data folder that is flashed with the rom) ***
Firmware plus ancien:
(28 November 2014) S4 Echoe Rom v37
(10 November 2014) S4 Echoe Rom v36.1 S5 Port - PART XI
(15 October 2014) S4 Echoe Rom v35.1 S5 Port - PART X
(11 October 2014) S4 Echoe v34 (ANDROID 4.4.4)
 DOWNLOAD LINKS (NO MIRRORS PLEASE!!!)
ECHOE DEVELOPMENT DOWNLOAD CENTER
1. Données mobiles (3G, 4G, LTE, etc) est entièrement fonctionnel TANT QUE VOUS flashez le dernier MODEM STOCK . Obtenez-le ici : http://echoerom.com/echoe-kitchen/s4/
lien pour l'instalation :http://forum.frandro...alaxy-s4-i9505/
Si vous ne voulez pas faire cela, alors:
Spoiler
2. Très mineur: La première fois que vous vous connectez au playstore, il faut un certain temps pour montrer vos applications ... revenir en arriere puis cliquez à nouveau sur playstore. Tout sera à nouveau rapidesmile.gif
:excl: Je serais surpris si quelqu'un parcourant cette discussion ne se rendent pas compte que:
Flashez cette ROM annule la garantie. Et comme avec n'importe quel Rom custom il est livré avec les dangers habituels / effets secondaires tels que, mais sans s'y limiter, les explosions, les guerres, la combustion spontanée, votre animal oublier , l'amnésie rétrograde et antérograde, l'aliénation interpersonnelle, un certain nombre de plaintes psychosomatiques, neurologiques et métaphysique, et en général une perturbation globale de l '«ordre des choses». Ayant dit tout cela, NOUS NE SOMMES PAS RESPONSABLE de ce qui arrive à votre téléphone comme un résultat du flash de cette Rom ...
:excl:
        Echoe Rom OFFICIAL WEBSITE :
        http://echoerom.com/phpbb/viewtopic.php?f=2&t=1
                                 Un recovery mod très intéressant regroupant different recovery à jour, présent sur ce forum :) :
        http://forum.frandro...aller-09112014/
Modifié par herveonex
  • Like 3
Je suis passé à la ECHOE v5, rien à redire, c'est une TW. L'avantage, c'est qu'elle est rooté, deodex, zipaligned et qu'elle est moins encombrante que l'odex que j'avais. J'ai bien gagné 200 Mo dans le système, impeccable pour faire un dual boot. Sous Android 4.3 of course.  En rapport au message du dessus, le mode 1/100ème de batterie est inclus de base, il y a juste à le cocher dans /Système/Batterie, c'est pas identique mais existant sous une autre forme.
EDIT:
Ah si, à mon gout, il manque l'Extend Power Menu car je trouve que sur le Recovery Philz, le 3BC pour le recovery est assez difficile à mettre en oeuvre, mon téléphone démarre facilement sans passer par le recovery. Un manque d'habitude peut être, je ne sais pas si c'est le cas de tous les recovery(s), pas encore assez d'expérience sur le S4. Si quelqu'un a un lien pour un mod comme ça, ce serait plutôt cool!
EDIT 2:
Les liens Hotline pour les mods du dessus n'ont pas un débit ultra rapide, un mirror serait aussi le bienvenu.
Modifié par franzyroy
Yes pour l'édit 2 quand ils seront dispo .
L'extension de power menu n'est pas possible pour le moment de ce que j'ai comprit ...dû au 4.3 .
Pour philz faut pas rester longtemps sur les 3 touches sinon tu bascule direct
Envoyé depuis mon dualbooboot
yo,on m'a glissé dans l'oreillette que l'xposed wanam propose le 4 ways reboot ;) le recovery c'est facile,après la vibration de démarrage du phone tu appuis volume haut jusqu'au bootsplash et voila :)(peut importe le recovery)
Modifié par chkoon
  • Like 2
OK!
Tiens j'ai un petit souci, celui-là.
Quand je sors de veille, mon téléphone m'affiche pas de réseau. En général, ça revient après déverrouillage. Je dis bien en général. Cependant, quand je reçois des appels ou sms pendant la veille ça fonctionne.
Est ce que quelqu'un a constaté ça sur ECHOE v5? Et si oui, as une solution!
Perso non la dessus tout va bien depuis le modem MJ5 , je perdais le data et le réseau lors de veille avec le MH8.
Peut être ton souci serrait résolu avec la v5+ et son nouveau kernel .
Par contre j'ai un souci de wifi , si je sort de la porté du réseau wifi  , ou je relance  la box  , le s4 ne veux plus se reconnecter dessus avec la v5.
Dans tous les bons coups le huggy  :P
C'est vrai! ;)
Je suis sur le 5.18.2  :) .
Philz il va trop vite dans c'est upgrade  ^_^
Comme moi, j'ai téléchargé la dernière, je vais voir pour l'installer avec SGS4 Flasher, c'est rapide. Et comme j'ai aussi la 5.18.2, je pourrais toujours y revenir si problème.
Edit:
Je viens de passer à la 5.18.5, comme ça a été remonté sur XDA, il y a bien un souci de root mais je l'ai à peine vu car j'ai redémarré en Recovery avec Xposed wanam (lien donné par Chkoon plus haut). J'avais encore le root pour cause. En voulant reboot le system depuis le recovery, j'ai eu la question de savoir si je voulais fixer le root, ce que j'ai fait. Redémarrage et tout à l'air OK.
Edit2:
A chaque démarrage dans le recovery, ça te demande de refixer le root, même si tu reviens sur 5.18.2 qui n'avait pas ça. Que tu le fixes ou non, le root est toujours là.
Bâ ce matin j'ai test la hellybean donc repartie a zéro , j'avais pas ce message .
Je vire la rom, réinstalle la slim V5 , reboot sans cette demande, retourne dans le recovery , reboot et la le message est revenu.....
Envoyé depuis mon GT-I9505 avec Tapatalk
Non jamais tester la 5.18.5 de mémoire.
Ouaip bizarre mais :** post 6182**
Citation:
*Posté par nfribeiro Voir le message
Yat-il un moyen de corriger cette racine FIX ennuyeux lors du redémarrage de la récupération?*
Cela apparaît avec une TWRP (seulement?) Parce qu'il ne reconnaît pas votre vieille racine et se veut donc fixer le dos. Vous devez toujours appuyer Ne fixez pas quand clignotant roms prerooted comme ils l'ont déjà racine. Au moins dans les versions précédentes, il a demandé une fois seulement. Pourrait se demander à nouveau si vous flashez certains mods cependant, pas sûr. Mais juste presse ne fixent pas. Je sais que ça devient ennuyeux, mais il ne devrait demander à ce sujet une fois, et non d'autres moments comme quand vous faites nandroids. Envoyé de mon GT-I9505 utilisant Tapatalk
Galaxy S4 i9505
Ce que je comprend c'est que le root est vieux et dépassé..
Je viens de mettre un Recovery TWRP, pas eu de problème, je suis repassé après en Recovery Philz 5.18.2, et là re-problème. Pour moi, c'est un problème en rapport à ce Recovery.
Quoi que je me demande car je n'avais pas ce souci avec TW 4.2.2 officielle de mon phone et le recovery Philz 5.18.2.
