[ROM]|4.2.2/4.4.2|D802|Pardus HD RoMs™ /\ Classic 7.7/\ Sensation Black V3.2
skithor
Salut tout le monde je regroupe ici les Roms de Pendroz
à savoir
Les G-Flex Volume 1 à 3 qui sont en 4.2.2 et arrêtées
Les HD Rom Reborn et Classic Volumes I en 4.2.2 et Volume II à 7.7 en 4.4.2
La ProKat restera au stade Beta en 4.4.2
et Les Sensation Black V1 à 3.2 en 4.4.2
●●●●●●●●●●●●● Pardus HD RoM™ Sensation Black v3.2 ●●●●●●●●●●●●●
● Ported From G Flex Official D955 20A & G2 20F Mixed @OptimusRs
● Dorimanx 7.1 Kitkat Kernel
● Deodexed ( Thanks @JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support @Cloudyfa
● Busybox Support
● Tweaks for Battery life
● Tweaks for Smoothness
● Tweaks for less lag
● Remove All Bloatware
● SuperSU 2.0.2
● Knock Code
● Split Window
● Customizable Nav Bar Hide Features
● FM Radio
● 4K And 120FPS With Working Magic Focus Cam
● Enable Dolby Digital EQ ( Stock Music Player ) @aznrice2k4
● Xposed Framework 2.6.1
● G2 TweaksBox 2.4 @P_Toti
● Transparent LG Stock and Flex Weather @RocketSauce83 ( Don't Lock Screen Support )
● Disabled Boot sound
● 3 Way Reboot
● Update Gapps and libs ( inverted )
● ViPER4Android Audio Effects (FX v2.3.3.0)
● Nexus 5 Sounds
● G3 Sounds
● Custom Bootanimation
● G3 Keyboard @Cloudyfa Android L keyboard Theme @ingoljosh
● [ External Mode ] 3minit Battery Mod 2.0 @gharrington
● AdAway Host @Cloudyfa
● Dalvik Tweaks and Disable ART
● And many more
● @dorimanx Kernel 7.1
● Update Gapps files Material design ( 11.08.2014 )@
● Update G3 Keyboard v5.0.18 @Cloudyfa
● Update SuperSU 2.0.2
-This mod allows you to view an increasing 1,070 battery types, from different users. With a single click, the battery will download and set itself on to the status bar.
● Update Tweaks Box 2.5
● Added Android L keyboard Theme @ingoljosh
● Some System improvements
● Etc.
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.7 20F ●●●●●●●●●●●●●
● Based on D802 20F OPEN ITALY Base
● Zipalinged
● Rooted
● Busybox Support
● Tweaks for less lag & Dalvik Performance Tweaks
● SuperSU 2.0.2
● Some features from G Pro 2 * @Cloudyfa
- Buttons Combination
- Brightness and Volume toggle
- Split Window
● Knock Code
● Stock + G Flex Theme @RocketSauce83
● FM Radio
● Xdabbeb's Cam 3.2.0 ( 4K + MF + SM )
● G2 TweaksBox 2.5 @P_Toti
● 3 Way Reboot
● Unlock All Lock Secreen Effects + Tab & Hold @rastigo
● 3minit Battery Mod @gharrington
● Material Design Gapps and Libs
● Fix No write access to SD card @Chainfire
● Nexus 5 sounds
● G3 sounds
● G3 Keyboard @Cloudyfa & Android L keyboard Theme @ingoljosh
● And many more
● Etc.
●●●●●●●●●●●● Pardus HD RoM™ G-Flex Volume III ●●●●●●●●●●●●●
4.2.2
● Based on G-Flex Rom ( Big Thanks @bigfau )
● Dorimanx 2.4 Kernel
● Deodexed
● Rooted
● init.d Support
● Busybox Support
● SuperSU 1.93
● %1 Battery Mod
● G-Flex Theme ( Thanks @
Milan84 )
● Transparent LG Wheater & LG Launcher ( Removed Flex Launcher )
● Improved Virtual Memory
● Removed volume slider
● Slim Navigation Bar ( 30x30 )
● 3 Way Reboot menu
● FM Radio ( Available Hub )
● Front and Back Led Active
● Black Color Fix ( Launcher Calender etc. Thanks @
tangjun269 and @Cloudyfa )
● Simple Black Keyboard Themes v2 ( Thanks @
AyDee )
● Call Record
● Custom ROM Image in Settings ( Big thanks @
iamareebjamal )
● Custom HUB ( Big Thanks @
mikrosmile )
● Added Nexus 5 sounds
● Xposed framework 2.4.1
● Extended kernel info in settings ( Thanks @
P_Toti & @bigfau )
● And many more.
●●●●●●●●●●●● Pardus HD RoM™ Classic ●●●●●●●●●●●●●
4.2.2
● Based on 10G
● Dorimanx Kernel 2.6
● Deodexed
● Zipalinged
● Rooted
● init.d Support
● Busybox Support
● SuperSU 1.93
● KitKat Statusbar icons
● FM Radio
● Xposed Framework 2.4.1
● Gravity Box 2.9.7
● Custom HUB
● 3 Way Reboot
● Enable Dolby Digital EQ ( Stock Music Player ) Thanks @
aznrice2k4
● And many more.
●●●●●●●●●●●● Pardus HD RoM™ Classic Volume II●●●●●●●●●●●●●
4.4.2
● Based on 20B ( Big Thanks @Cloudyfa )
● Savoca Custom Recovery Support Kitkat Kernel
● Deodexed
● Zipalinged
● Rooted
● init.d Support
● Busybox Support
● SuperSU 1.93
● ReDesign Statusbar icons
● FM Radio
● G-Flex Lockscreen
aznrice2k4
● Xposed Framework 2.5
● Gravity Box 3.0.0
● Custom HUB
● 3 Way Reboot
P_Toti Hissing Fix patch
● Slow Motion & 4K video
● And many more.
●●●●●●●●●●●● Pardus HD RoM™ Classic Volume III●●●●●●●●●●●●●
4.4.2
● Based on 20B ( UK SIM Free D802 20B A6GBWH )
JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support
● Busybox Support
● SuperSU 1.94
● FM Radio
● G-Flex Lockscreen
aznrice2k4
● Gravity Box 3.0.0
● Custom HUB
● 3 Way Reboot
● Fix No write access to SD card ( Thanks @
Chainfire )
● And many more.
●●●●●●●●●●●● Pardus HD RoM™ Classic Volume IV ●●●●●●●●●●●●●
4.4.2
● Based on 20B D802 UK Free Sim
JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support
● Busybox Support
● SuperSU 1.94
● FM Radio
● G-Flex Lockscreen
aznrice2k4
● Gravity Box 3.0.0
● Custom HUB
● 3 Way Reboot
● Fix Hissing Sound @
P_Toti
Chainfire )
● And many more.
●●●●●●●●●●●● Pardus HD RoM™ Classic Volume V ●●●●●●●●●●●●●
4.4.2
JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support ( Thanks @
Cloudyfa )
● Busybox Support
● SuperSU 1.94
● FM Radio
● G-Flex Lockscreen ( Big Thanks @
Cloudyfa Great Guide )
aznrice2k4
● Gravity Box 3.0.1
● Custom HUB
● 3 Way Reboot
P_Toti
Chainfire )
● And many more.
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 6.0 ●●●●●●●●●●●●●
● Update Based on D802 Vodafone 20B ( UnBranded + Knock Code )
● Update Dorimanx 4.0.1 Kitkat Kernel
JustArchi Kitchen )
● Zipalinged
● Rooted
Cloudyfa )
● Busybox Support
● SuperSU 1.94
● FM Radio
● Update 4K Camera Thanks @
Cloudyfa
● G-Flex Lockscreen ( Big Thanks @Cloudyfa Great Guide )
aznrice2k4
● Update Xposed Framework 2.5.1
● Update GravityBox v3.0.3
● 3 Way Reboot
P_Toti
● Update ViPER4Android Audio Effects (FX v2.3.3.0)
Chainfire )
● AdAway Host Thanks @
Cloudyfa
● And many more
La V6 ayant tendance à faire perdre le root, du au fait, de la présence du kernel Dorimanx dans la Rom
un petit flash de " l'update SuperSu " disponnible ici http://download.chainfire.eu/396/SuperSU/UPDATE-SuperSU-v1.94.zip
un reboot et tout rentre dans l'ordre    :)
source : http://forum.xda-developers.com/showpost.php?p=52075163&postcount=1428
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 6.1 ●●●●●●●●●●●●●
● Based on D802 Vodafone 20B ( UnBranded + Knock Code )
● Update Dorimanx 4.3.1 Kitkat Kernel
JustArchi Kitchen )
● Zipalinged
● Rooted
Cloudyfa )
● Busybox Support
● SuperSU 1.94
● Update Some features from G Pro 2 * Thanks @
Cloudyfa
● FM Radio
● 4K Camera Thanks @
Cloudyfa
aznrice2k4
● Xposed Framework 2.5.1
● Update GravityBox v3.1.0
● 3 Way Reboot
● G-Flex Theme Thanks @
RocketSauce83
● Simple Black Keyboard Theme Thanks @AyDee
P_Toti
Chainfire )
● Custom Hub
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.0 ●●●●●●●●●●●●●
● Based on D802 20D OPEN UK Base
● Dorimanx 4.4 Kitkat Kernel
JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 1.94
Cloudyfa
● Knock Code
● Hid3rs Flat UI 1.1 @
Hid3rs
● G3 with Moonshine v0.3 Theme @RocketSauce83
● FM Radio
● Xdabbeb's Cam 3.0.0 ( 4K + MF )
● G-Flex Lockscreen @
Cloudyfa
● G2 TweaksBox 2.2 @
P_Toti
● 3 Way Reboot
AyDee
Chainfire
● Custom Hub
● AdAway Host @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.1 ●●●●●●●●●●●●●
● Dorimanx 4.6 ( Remastered Verison ) Kitkat Kernel
JustArchi Kitchen )
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 1.94
Cloudyfa
● Knock Code
Hid3rs
● G3 with Moonshine v0.5 + G Flex Theme @RocketSauce83
● FM Radio
● Xdabbeb's Cam 3.1.0 ( 4K + MF )
Cloudyfa
P_Toti
RocketSauce83
● 3 Way Reboot
AyDee
Chainfire
● Custom Hub
● One Handed Mode @
hamzahrmalik
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.2 ●●●●●●●●●●●●●
● Dorimanx 4.9 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 1.94
Cloudyfa
● Knock Code
● Hid3rs Flat UI 1.1 and G3 Original SystemUI Mixed @Hid3rs
● G3 v1.1 + G Flex Theme @RocketSauce83
● FM Radio
Cloudyfa
● G2 TweaksBox 2.3 @
P_Toti
RocketSauce83
● 3 Way Reboot
Chainfire
● Nexus 5 sounds
● G3 sounds
● Custom Hub
● G3 Launcher
● G3 Optimus Theme
● G3 Keyboard Thanks @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.3 ●●●●●●●●●●●●●
● Dorimanx 5.0 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 1.94
Cloudyfa
● Knock Code
Hid3rs
● FM Radio
Cloudyfa
P_Toti
RocketSauce83
● 3 Way Reboot
Chainfire
● Nexus 5 sounds
● G3 sounds
● G3 Optimus Theme
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.4 Final 20D ●●●●●●●●●●●●●
● Dorimanx 5.2 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 1.94
Cloudyfa
● Knock Code
Hid3rs
● FM Radio
Cloudyfa
P_Toti
RocketSauce83
● 3 Way Reboot
Chainfire
● Nexus 5 sounds
● G3 sounds
● G3 Optimus Theme
● G3 Keyboard @
Cloudyfa
● G3 LG Health @AyDee
● Dalvik Tweaks
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.5 20F ●●●●●●●●●●●●●
● Dorimanx 5.8 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0.1
Cloudyfa
- Split Window
● Knock Code
RocketSauce83
● FM Radio
aznrice2k4
P_Toti
RocketSauce83
● 3 Way Reboot
Chainfire
● Nexus 5 sounds
● G3 sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Classic Volume 7.6 20F ●●●●●●●●●●●●●
● Dorimanx 6.2 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0.1
Cloudyfa
- Split Window
● Knock Code
RocketSauce83
● FM Radio
aznrice2k4
P_Toti
RocketSauce83
● 3 Way Reboot
Chainfire
● Nexus 5 sounds
● G3 sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Sensation Black v1 ●●●●●●●●●●●●●
● Ported From G Flex Official D959 20H & G2 20D Mixed Thanks @OptimusRs
● Dorimanx 5.5 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0
● Knock Code
● Split Window
● FM Radio
aznrice2k4
P_Toti
● 3 Way Reboot
● Nexus 5 Sounds
● G3 Sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Sensation Black v2 ●●●●●●●●●●●●●
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0
● Knock Code
● Split Window
● FM Radio
aznrice2k4
P_Toti
● 3 Way Reboot
● Nexus 5 Sounds
● G3 Sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Sensation Black v3 ●●●●●●●●●●●●●
● Ported From G Flex Official D959 20H & 20A & G2 20F Mixed @OptimusRs @Cloudyfa
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0.1
● Knock Code
● Split Window
● FM Radio
aznrice2k4
P_Toti
● 3 Way Reboot
● Nexus 5 Sounds
● G3 Sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●●● Pardus HD RoM™ Sensation Black v3.1 ●●●●●●●●●●●●●
● Ported From G Flex Official D955 20A & G2 20F Mixed @OptimusRs@Cloudyfa
● Dorimanx 6.7 Kitkat Kernel
● Zipalinged
● Rooted
● init.d Support @
Cloudyfa
● Busybox Support
● SuperSU 2.0.1
● Knock Code
● Split Window
● FM Radio
aznrice2k4
P_Toti
● 3 Way Reboot
● Nexus 5 Sounds
● G3 Sounds
● G3 Keyboard @
Cloudyfa
● And many more
●●●●●●●●●●●● Pardus HD RoM™ ProKat ●●●●●●●●●●●●●
4.4.2
● Based on G Pro 2 Leak ( Big Thanks @Cloudyfa G ProII )
● Deodexed
● Zipalinged
● Rooted
● Busybox Support
● Xdabbeb's Camera/Video 2.2.0 [4kUHD | 120fps | MagicFocus]
● SuperSU 1.93
● Re Design Statusbar icons
● FM Radio
● Custom HUB
● 3 Way Reboot
● Adaway
aznrice2k4
● Disable ART Support
● And many more.
Source :
 Thread développement des "Classics" http://forum.xda-developers.com/showthread.php?t=2582398
 Thread développement des "Sensation Black" http://forum.xda-developers.com/showthread.php?t=2796044
Thread Questions / Réponses de xanthrax http://forum.xda-developers.com/showthread.php?t=2739328
Site de Pendroz : http://www.pendroz.com/
Downloads & Mods
Roms & Mods
https://s.basketbuild.com/devs/pendroz
Liens MEGA Pardus
https://mega.co.nz/#F!eM1UFCxb!JIJC5sDLQsvpO8ThliHt9A
KitKat BaseBand
http://forum.xda-developers.com/devdb/project/dl/?id=5234
Md5 : 280dc56fd2ed2434291104cd92b71d50
Pour les soucis de root, flasher l'update supersu
http://forum.xda-developers.com/showthread.php?t=1538053
SoftKey Pardus
https://www.dropbox.com/s/yv4bipgfxmd0os2/SoftKey_Pardus_Rom_GB.apk
merci à "VuongDZ" http://forum.xda-developers.com/showpost.php?p=54207015&postcount=42
Installation 3Minit Battery Mod
* Install 3Minit apk
* Reboot to recovery Flash 3minit.zip
* Reboot device
Style UI G3
Don't Forget Back-up !!!
LG Launcher G3 Theme apk + G3 System Theme Flashable ZIP
Known Issues
* Quiet Mode Doesn't work
Mise en gardes :
Il est impératif que vous soyez sûr, avant d'entamer toutes procédures de flash,
de vous assurer d'avoir en votre possession, tous les fichiers nécessaire,
pour éviter ainsi d'avoir des messages " je suis dans le caca! à l'aide!!!! "
Merci de votre compréhension   :)
● Mettre à jour votre recovery custom
● Faire un Nandroid Backup, au cas où comme toujours    :)
● Full Wipe ("Clean to Install a New ROM" sur Philz) ou
Dalvik + Cache + System + Data
● Installer Pardus HD Rom .zip
● Installer la BaseBande KitKat (seulement si vous venez de Jelly Bean ou d'une AOSP)
● Pour HD Classic 7.7 :
- Redémarrez en Recovery
 - Installer le BatteryPatch.zip
● Reboot system
Si vous perdez le Root, direction partie Downloads et Flasher UpdateSU
* Premier Reboot assez long mais c'est normal
TIPS
Ajouter LTE
3845#*802#
1. Aller sur LTE-Only
2. Modem Settings
3. RAT Selection
4. Select GSM / WCDMA / LTE auto
Only for 4G users
Download Build Prop Editor
* Open build.prop and Changing Line and Restart Device
ro.telephony.default_network=10(11 ou 13, essayer ces valeurs)
Problèmes tactiles,
une solution parmi tant d'autres
3845#*802#,
puis settings,
et enfin update touch firmware,
attends quelques secondes
HD Classic Volume 7.7
Pardus HD Rom™ Sensation Black V3.1
Wanam , _Sale_ , Kryten2k35 , Cloudyfa , Robbie Hood , criscan , IganKuhz , raffaele88 , manikant_009 , Hardcore , Amarullz , AndroidGX , pglmro , LegendK95 , Turkbey , Agabey_42 , CQNSTANT!NE , mike1986 , soroush0313 , indie , raubkatze , _JKay_ , mythtrandyr , anbech , PartimusPrime , anukilimanoor , Chainfire , Winterlove , gh.rohit , Fenhyks , tangjun269 , bigfau , Jank4AU , Jishnu Sur™ , xdabbeb
Merci @ :
Et d'autres
Modifié par skithor
Salut je l ai installé hier soir et j ai eu un gros souci, au moment du boot ça m à mis security error j ai flippé
Heureusement j avais gardé la LRS sur le tel et j ai pu redemarrer en recovery avec les touches
J ai bien envie de réessayer ;mais est ce que ca vaut vraiment le coup par rapport a la LRS
Modifié par loki97231
salut, écoute moi j'en suis pleinement satisfait, à la manière d'une neatrom sur s2 qui est allégé, cette pardus est allégé comparé à une stock ou aux autres flex, apres quel est la version de ton G2? car cette Rom est pour le 802, apres moi première installation déroulé sans problème fullwipe, avec un recovery philz et kernel dorimanx.
Regarde à partir de quel base tu es partis pour voir si il n'y aurait pas une incompatibilité.
il faut que je test cette LRS car je vois que beaucoup sur ce forum ne jure que par elle  :P
LRS G-Flex en download...
Modifié par skithor
Bonjour à tous en ce magnifique dimanche !
Bon alors cette LRS 1.2 eh bien, première instal, un message me parlant de mot de passe me renvoyant sur le dialer et tout sa en allemand ou du moins sa y ressemble  :P et pas moyen d'en sortir !
Deuxième instal, la sa passe niquel  :) (heureusement)
Première impression c'est fluide sa passe bien, un petit bug niveau affichage du theme flex, pas bien grave, ensuite rendez vous dans les options de developpement
pour y baisser les échelles d'animations, et la le tel commence à me sortir des micro lags, je remets les échelles d'animations a 1 et impeccable.
Bref, petit tour des applis systèmes, y'en a un peu de trop à mon gout.
Pour moi cette LRS est bien mais je préfère la Pardus Flex plus légère et aussi fluide
voir un peu plus que la LRS  B)
(sa c'est juste pour embêter les fans de la LRS  :P )
Du coup retour sur Pardus Flex  :)
A ton tour d avoir des soucis d install mdr
Envoyé de mon Nexus 7 en utilisant Tapatalk
C'est [color=red]qd[/color] même étrange que d un appareil à l autre, qu il y ait des soucis d installation
ouai c'est clair c'est vraiment bizarre, mais la sa ressemblais plus à un souci de détection de carte sim sauf que c'était incompréhensible, je ne connais pas l'allemand  :P ! Mais bon, go recovery fullwipe réinstallation et tout tournait rond! ou presque  :P
plus rapide !  :P
Est-ce que vous souhaité un topic sur cette fameuse LRS ?
car la on est sur la Pardus mais on en parle pas trop  :P
Modifié par skithor
Je suis aussi maintenant sur la pardus et par rapport à la LRS, il y a moins de fioritures et ça c'est cool.
Au fait, skithor tu as aussi le playstore en noir et bleu ?
Envoyé de mon g2 flex en utilisant Tapatalk
Oui je trouve sa pas mal, sa nous change un peu :P ! Le clavier LG avec le thème black est sympa aussi  :)
Nickel ca fonctionne c est parti pour le test
Bon je te l accorde elle envoie du lourd
Ah sa fait plaisir que tu es enfin réussi  :P (j'déconne bien sur)
Bon test alors  :)
Quand je 'linstalle je ne peut pas lancer le play store sa bug
Aucun souci de playstore de mon côter, essaie de vider le cache de l'applis, wipe cache wipe dalvik, tu peux tenter aussi un fix permission...
voila apres si rien ne marche, tente une installation propre.
A part ça je ne vois pas d'autre pistes
