problème hard reset
coxinette
Mon père m'a passé sa tablette suite à un soucis de bloquage... elle était bloquée sur le logo sony au démarage... J'ai donc fait un hard reset qui n'a pas l'air de fonctionner...
Je commence par le menu sur lequel apparait
E: Fail to read boot logo flag
E: Can't open /dev/block/mmcblk0p5
(No such file or directory)
E: failed to mount /cache (No such file or directory)
E: Can't mount /cache/recovery/command
E: filed to mount /cache (No such file directory)
-- Wiping data...
Formatting /data...
E: format_volume: make_extf4fs failed on /dev/block/mmcblk0p10
Formating /cache...
E: format_volume: maike_extf4fs failed on /dev/block/mmcblk0p4
Formatting /stating...
E: format_volume: make_extf4fs failed on /dev/block/mmcblk0p6
Formatting /log...
E: format_volume: make_extf4fs failed on /dev/block/mmcblk0p9
E: failed to mount /datapp (No such file or directory)
E: Can't mount /datapp/app
Data wipe complete.
E: Fail to write boot logo flag
E: Can't mount /cache/recovery/log
E: Can't open /cache/recovery/log
E: Can't mount /cache/recovery/last_log
E: Can't open /cache/recovery/last_log
E: Can't mount /cache/recovery/last_install
E: Can't open /cache/recovery/last_install
En gros ça sent le truc foireux... que puis-je faire?
  • 1 month later...
