[ROM] [4.4.2] [21 Sept] | BlackBox™ 3.2.3 | Samsung/AOSP Hybrid
ATTENTION. Cette manipulation est sous votre responsabilité, et ni FrAndroid ni moi-même ne saurons être tenu responsable en cas de fausses manipulation
Source:http://forum.xda-developers.com/showthread.php?t=2429072
 Screenshots:
Screenshot_2014-01-04-21-20-03.pngScreenshot_2014-01-04-21-20-14.pngScreenshot_2014-01-04-21-20-21.pngScreenshot_2014-01-04-21-21-07.pngScreenshot_2014-01-04-21-21-15.pngScreenshot_2014-01-04-21-21-35.pngScreenshot_2014-01-04-21-21-48.pngScreenshot_2014-01-04-21-21-58.pngScreenshot_2014-01-04-21-22-20.png
Changements:
BlackBox 3.0
Changes:
Initial release
Deodexed
Rooted
Zipaligned
Brightness fix
Massive amounts of framework tweaks
Themed
Removed blocking mode icon
Official device status
Reworked settings app
CRT enabled (No dodgy code)
Quad resizable multiwindow
New animations
Hacked launcher (With rotation)
Improved ripple effect on ripple lockscreen
Improved shutdown/reboot speed
Enabled native App Ops (Settings-Security)
Build.prop tweaks
Added Note 3 incoming call pop up (Activate in settings)
Added call recording
Deboloated
Inverted apps
AOSP Mms.apk with working MMS messages
AOSP contacts and dialer
AOSP Browser
AOSP Calculator
AOSP Calendar
G.E 4.4 AOSP Gallery & Camera
AOSP Clock
AOSP Email
AOSP File Manager
AOSP sounds etc
Bash etc
Disabled signature check
BlackBox Bootanimation
Auto EFS folder backup
init.d support
Sysro/Sysrw
Sysctl Tweaks
Sqlite3
Extended Power Menu
Powermenu Toggles
Knox removed
Rom Control with:
-K Tweaker control
-Power Menu Toggles
-Full Battery Notification Toggle
-Home Button Wake Toggle
-SuperSU
-CPU Tool Stats
-Statusbar Clock Mods
-Statusbar Battery Mods
-Statusbar Internet Traffic Mods
-Statusbar Icon Toggles
-Statusbar Color Mods
-PIE Control
AOSP Lockscreen Toggle
-cLock Settings
Loads of other stuff i cant remember
Alliance Team (Control App etc)
hello00 (Mms.apk)
bxv1993 (Framework animations)
Team Blackout (Inverted apps)
BlackBox 2.2.1
Changes:
Reworked settings app;
Fixed settings-volume-volume levels fc
Fixed settings-display-brightness fc
Fixed settings-display-wallpaper-lockscreen fc
Fixed settings-bluetooth-bluetooth pairing dialog pop up fc
Fixed bluetooth share fc
Disabled scrolling cache (Dramatically improves responsiveness)
Added GearManagerStub.apk in
Added AllShare apk/libs in
Added Pie in (Rom Control)
Added traffic counter to statusbar
Added traffic counter toggle to rom control
Added any color/transparency traffic counter to rom control
Updated email app
Possible fix for MMS messages
Updated KT kernel
Updated Philz recovery
Added IME icon switcher in statusbar toggle (Rom control)
Added menu long press kills apps toggle (Rom control)
Added notification panel settings back into settings-display
Some re-working of rom control app
Removed Xposed recents apps/Ram bar module
Updated supersu (1.93)
Reverted systemui back to samsung version (Themed), fixes;
Condensed statusbar in flip cover view
Auto screen unlock/wake up (Flip cover)
Notifications fc with motion turned on
Fc for non international users
Any other little niggles that were present
Dzol Cp (Traffic meter)
Goldie (Color mods/Ripple effect)
noname81 (Pie)
BlackBox 2.2
Changes:
BETA ROM
Rom is 664mb
Updated Contacts.apk - Fixes daler not showing in launcher app drawer
- Working call logs
- Working adding events to contacts
Updated Rom Control icons
Added Multiple new mods into Rom Control;
- Any color/transparency statusbar
- Any color/transparency notification icons
- Bluetooth icon toggle
- Sound/Vibrate icon toggle
- AOSP Lockscreen toggle
- Torch Power menu toggle
- Screenshot Power menu toggle
- Statusbar Toggle Control
- Music Control (Volume keys skip music track)
- Temp removed sound/vibrate Power Menu toggle
Complete Mms.apk overhaul - multiple mods added;
- Enabled group messaging
- Enabled save/restore
- Enabled scheduled messaging
- Enabled umlimited sms recipients
- Disabled auto sms to mms conversion
- Modded time stamp to show original time
- Increased sms limit per hour
- Enabled split view mode on/off toggle
- Increased Mms max size & Mms image size
- Disabled all crappy/un-needed logs
- Enabled screen on/off toggle
- Disabled msm to mms auto conversion for emojis
- Enabled folder view mode
NOTE: Add contact button is causing fc (Even before i did mods) - just add another contact underneath the previous one for now
Ported G.E 4.3 AOSP Gallery & Camera (BETA)
- Working Photosphere
- Working video recording
There may be bugs, need feedback
Flashing script overhaul
Fixed quick search fc
Ported S4 G.E SystemUI - Full AOSP layout with Toggle Control (BETA)
Swapped keyboard for 4.4 CM (Working Swipe)
Updated Kernel and Recovery in Aroma
Removed ext4 tweaks option in Aroma
Updated Browser
Swapped Myfiles for CM File Manager (Working root access)
Updated DropBox
Updated Calendar
Updated Gmail
Updated Play Store
Added Inverted YouTube
Updated Google Play Services
Updated SuperSU (1.91)
Removed Notification Panel settings from Settings-Display
Added full screen caller and call recording with settings (Rom Control)
Hacked Multiwindow - All apps available
Build.prop tweaks
Improvement on speed/smoothness
Added unlimited pages/widgets on lockscreens
Removed stock Kernel choice from Aroma (Now just KTSGS4 & dont flash)
Updated About Phone section (Rom information)
Improved some code
Removed Torch toggle from Settings (Interferes with music mod)
Added Recents/Clear all and Ram bar Xposed module
Tidied up lib folder
Added some missing binary files in
Fixed some background errors in log
Added Flash player
Removed some redundant scripts/mods
Bootanimation included in rom as default, removed flashing procedure
Streamlined ROM package
More i cant remember
NOTE: Settings - Motions/Gestures - Motion - Turn Over (Mute/Pause) - Leaving this enabled will cause an fc when you get a message or missed call notification (has no other negative effect), disable it to fix (Being investigated)
This is because of the aosp systemui, i will improve it over time and add in as much as i can
PLEASE REMEMBER, THIS IS A BETA ROM WHILE I TRY AND FINISH OFF THE SYSTEMUI PORTING ETC
THERE WILL BE BUGS/MISSING CODE, THEY WILL BE FIXED IN TIME - NONE OF THE EXISTING PROBLEMS STOP YOU FROM USING THE ROM AS A DAILY DRIVER
Pikachu01 (sqlite script)
Slaid480(sqlite script)
Carotix (Full screen caller)
Mythtrander (Note 3 Popup)
jovy23 (Mms.apk mods)
loserskater (Updated code)
blchinezu (Xposed module)
TeamBlackout (Inverted apps)
BlackBox 2.1
Changes:
Rom is 725mb
Fixed changing keyboards
Fixed Settings-Accessibility-Screen Timeout fc
Settings-Security-Sim Change Alert is still fc'ing, even with a fully stock settings app and framework so i need to look further into that
Tidied up framework theming
Removed Flashlight shortcut from power menu as its available via the volume up key when the screen is locked
Added Accessibility power menu shortcut back into Settings-Accessibility
Tidied up CRT mod cod
Fixed some incorrect showing text
Themed some more stuff AOSP
Running faster smoother than initial release
BlackBox 2.0
Initial 4.3 Release
BlackBox 1.0.2
Changes:
Rom is 632mb
Fixed overlapping 4g statusbar icons
Fixed 3g icon disappearing after connecting/disconnecting Wifi
Fixed Lux adjustment for auto brightness
Fixed incorrect text in statusbar ime switcher
Fixed Personal Text on Lockscreen
Fixed lockscreen wallpapers
Fixed Battery transparency FC
Added some system .apks back in for stability
Reverted Camera/Gallery back to Samsung versions
Updated Mms.apk – some new options in settings
Sending mms messages – possible fix in place – need verification
Updated Xposed Framework – 2.2 – Can now browse modules through app
Updated App Settings (Per App DPI) – 1.5
Swapped Trebuchet for Apex Launcher
Tidied up framework
Removed shutdown animation
Removed Density Changer from Rom Control
Fixed some icons in Rom Control
Notification panel is now semi transparent
Enabled Lockscreen rotation
Other small mods i cant remember
Aroma:
Updated Aroma Installer – 2.70RC2
- Fixed ICS Theme
- Much more responsive
Updated Philz Recovery – 5.14.5
Updated KT Kernel
Stock Kernel/Dont Flash – Updated Performance Control
CPA Poke
GoldieKing
MBQ
BlackBox 1.0.1
Changes:
Rom is 632mb
Can now set lockscreen wallpaper
Updated Device Status code to show full official
Removed Recents shortcut from Statusbar dropdown header
Fixed dropdown header layout
Any color/transparency dropdown date
Any color/transparency signal
Any color/transparency wifi
New Bootanimation
New Feature:
Full Statusbar battery mod;
11 variants to choose from
Any colour/transparency
Lost the name of the creator for the bootanimation - will update when found
Aou
BlackBox 1.0
Model: GT-I9505 (4.2.2)
MODEM: Removed
PHONE: XXUBMGA
CSC: Removed
Kernel: KT – SGS4
Samsung Build Date: 11.07.2013
Changelist: 1081224
Changes:
Rom is 594mb
Option to wipe in Aroma
Cache/Dalvik Cache/preload cleaned during flash
Rooted
Deodexed
Ziplaligned
Call Recording
1% Battery mod (AOKP Square style)
Fixed NFC
Photosphere Camera/Gallery
Ext4 Tweaks
BusyBox
Enabled 4G
AOSP Email is hacked (Ignore pop up if you get it)
4 Way Rotation
Disabled ‘Unplug from USB wakes screen’
Removed Carrier info from lockscreens
Removed Carrier info from StatusBar dropdown handle
Nexus 7 animations
And more..
Graphic:
Vertumus’ JB Domination AOSP Theme (Blacked, with full AOSP StatusBar layout)
Shutdown animation from SII
Google SE Bootanimation
Themed AOSP Keyboard
Added:
init.d support
Sysro/Sysrw
Sysctl Tweaks
Zip Align On Boot
GPU Rendering
Sqlite3
SuperSU 1.55
Modded Hosts File
Better GPS Find/Fix
Updated APN List
Google Music
Customized BlackBox Settings
OTA for Rom updates
More free ram
Device Status Shows As Normal
Extended Power Menu
Powermenu Toggles (All can be toggled on/off apart from volume tab)
Multiple framework tweaks
AOSP:
Contacts
Dialer
Lockscreen
Theme
Calculator
Calendar
Email
Gmail
Mms.apk
Browser
Rom Control
Clock Control
Bash
Battery Bar
Most Audio Sounds (UI/Ringtones Etc)
Many background system files
Inverted Apps:
Contacts
Dialer
Calculator
Calendar
Clock
Email
Gmail
Mms.apk
YouTube (Modded – *720p HD -over WiFi & 3G, Screen Off Playback)
Music Player
Play Store
DropBox
ES File Explorer
Removed:
Removed Bloat
Removed Touchwiz
Samsung TTS
Un-Needed Lib Files
Kies
Lots of Samsung system apps
Low Battery etc notifications
Blocking Mode Icon
Call settings from settings (available via phone app settings)
Torch shortcut from Settings (Interferes with Music Control)
Other stuff i cant remember
Rom Control:
System/Kernel Mods:
K-Tweaker or Performance Control depending on Kernel choice
Xposed Framework
Per App DPI;
Ability to set different DPI’s for individual apps
Tablet Mode etc
Density Changer;
In addition to Per App DPI:
Ability to change density of whole UI (NOT 240dpi COMPATIBLE)
PowerMenu Toggles
Toggle for Menu Button – Long Press Kills Apps
Secret Codes
SuperSU
CPU Tool Stats
UI Mods:
Customizable statusbar:
Any Colour (With Color Preview Box);
StatusBar
Clock
Dropdown Date
Battery Bar
Keyboard Icon Toggle
Alarm Icon Toggle
Center the clock in statusbar
Move the clock to stock location
Remove clock completely
Remove AM/PM
Change AM/PM to small size
Change AM/PM to large size
Add abbreviated day of week to status bar – small size
Add abbreviated day of week to status bar – large size
Remove abbreviated day of week from the status bar
Battery Bar;
Enable/Disable
Style
Thickness
Animation
Customize 2nd Row StatusBar Toggles
Lockscreen Settings:
Music Control (For when screen is locked);
Toggle On/Off
Timeout
Volume Up Action
Volume Down Action
AOSP/TW Lockscreen Toggle
AOSP Lockscreen Vibration Toggle
CRT/Fade Toggles
cLock Settings
Extra Mods:
Wifi Settings
Faster Fix (GPS)
Download All
OTA Settings
Option to restart Phone
GoldieKing
Didact74
CyanogenMod
Rovo89
ktoonsez
Vertumus
Team Blackout
MyLifeRocks10
j4velin
theos0o
DvTonder
Wanam
Chainfire
KNOWN ISSUES:
Call Logs – Same as S3 – unknown numners arent stored correctly (Being investigated)
Things To Note:
The ability to wake the phone using the home button is disabled by default, change it in Rom Control
PowerMenu toggles are disabled by default, change it in Rom Control
Torch shortcut Settings interferes with Music Control, so option currently removed (do not repeatedly ask about it)
:ph34r: Avec cette TW de 650mo environ tu sera plongé du coté obscure d'android. Viens bascule de notre coté :ph34r:
Problèmes connus
MMS.apk-Ajout de raccourcis de contact (sera corrigé dans la prochaine version)
ajustement Lux sur luminosité automatique (concernant le code de CRT)
Am / pm pour l'option barre d'état de l'horloge dans rom
 contrôle ne change pas (lié à systemui thème de Davey)
Lien de téléchargement :"ICI"
XDA:DevDB Information
BlackBox™ Hybrid ROMs, a ROM for the Samsung Galaxy S 4
Contributors
DSA
ROM OS Version: 4.3.x Jellybean
Based On: Samsung/AOSP/AOKP/CyanogenMod
Version Information
Status: Beta
Current Beta Version: 2.2.1
Beta Release Date: 2013-09-01
Created 2013-09-02
Last Updated 2014-02-11
Modifié par chkoon
  • Like 2
Il existe des versions instable du patcher (pas diffusé sur l'op)qui veullent bien la patcher MAIS on se retrouve avec un fc dans /parametre/rom control.
Il est publique le lien des versions debug du patcher,tu peux diffuser le comme tu veux mais la version 4.0.2 "officielle" qui inclut tous les derniers changements est sortie cette nuit.
FC de rom control dû au fait qu'elle soit patchée? Ça m'étonne, j'essaierai de voir si je peux.
Merci pour le sujet :)
-Ah autant pour moi je pensais qu'il était perso (donateurs)car pas vu dans l'op.
-C'est quasi sure car c'est un autre membre qui me l'a signalé du coup patch de la blacbox 2.2 et 2.2.1 et même résultat alors qu'en primaire c'est ok.
-De rien j'ai kiffé la ROM alors  B)
Modifié par chkoon
  • 1 month later...
La 4.4.2 avait pour moi un problème avec l'APN,contrairement a la version antérieure 4.3 qui n'en avait pas(de problèmes)donc oui stable.
je tourne sous çà https://forum.frandroid.com/topic/154003-centralisation-avis-toutes-les-roms-xda-quelle-est-votre-rom-preferee-i9505/page-5#entry2979211 avec ce mode a jour ,contrairement au sujet https://forum.frandroid.com/topic/186307-vrthemetw-kitkataromadethumbed-allbacksblack-s44-2014-03-15/ en multiboot avec cette ROM en version stablehttp://forum.xda-developers.com/showthread.php?t=2556227
  • 3 months later...
Moi,les deux première avait des problèmes avec phone.apk,réglé depuis. Pour le reste rien n'a plus retenu mon attention,je l'ai quitté pour une bonne vieille stock odex 4.2.2 pour les vacances car besoin de flash player(video streaming)et de tenue de batterie
Flash player fonctionne sans dolphin browser ;)
Modifié par chkoon
  • 1 month later...
Salut,bonne nouvelle .Le sujet réouvre,enfin...! une version3.2.3 est dispo bon flash.
Note: pour ceux comme moi qui partent d'un BL 4.2.2,je vous conseil vivement de prévoir un kernel type Adam(donc patcher pour...) pour que votre wifi fonctionne!
Edit:Flash player fonctionne sans dolphin browser  ;)
ben sujet refermer profitez vite du lien de dl....http://forum.xda-developers.com/showpost.php?p=55580700&postcount=716 (la rom fait 702 mo)
:ph34r: MP moi pour un upload sauvage
Modifié par chkoon
Un peu idiot cette histoire, parce qu'il fait parti d'une team, il ne peut pas sortir une de son côté. Ou alors, elle en a des similitudes.
Je la télécharge, je verrais si je dois l'installer ou pas. Après tout, une TW plus légère serait un plus car je n'ai plus trop place sur la partition système. J'ai même du virer quelques applis TW pour pouvoir mettre AOSB + full PA Gapps. Car les systèmes ont toujours tendance à évoluer en taille.
Bon et bien, PAC MAN rom a repris la release de leurs nightlies donc je suis reparti temporairement sur celle-là le temps qu'AOSB règle le souci de smartcover. J'ai bien essayé par moi même de régler le problème dans src/com/android/incallui/incalluiactivity.java. Normalement, c'est dans l'appli dialer.apk, il y a un fichier qui y ressemble mais qui malgré tout n'est pas lui, smali/com/android/incallui/incalluiactivity.smali. Je ne sais pas trop où je peux encore chercher. J'ai bien pensé à flasher juste le dialer des dernières Nightlies sur AOSB, mais ça, je sais qu'en général, ça ne fait pas bon ménage. Je pense donc attendre plus sur PAC MAN qui a un look un peu similaire à AOSB plutôt qu'une énième rom. Par contre de PAC MAN, j'aime pas trop leur côté trop radical de t'imposer un choix ou l'autre mais surtout pas les deux. Genre les touches de la navbar ou les touches physiques, ou encore l'affichage des applis récentes que tu ne peux qu'avoir ou Omniswitch ou slim... peut être une chose qui pourrait me tourner vers une autre... et pourquoi pas BlackBox. ;)
