[7D-501U] B006 CUSTOM, Kitkat 4.2.2, EMUI 2.0
Je signale cette ROM pour le 7D-501U (chinois, 3G):
http://www.needrom.com/download/x1-7d-501u-2/
ROM Huawei 7D-501u – ROM Android 4.2.2
Version Unicom : Based on version EMUI_B006
1 This package applies to the glory X1 models
2 This package is based on China Unicom version of the official EmotionUI 2.0 B006 JB4.2.2 customization
3 Join Full Root permissions and Busybox command support
4. The introduction of more than 60 exclusive enhancements ROM Advanced Settings
5. All the new features through inline code and applications to achieve self-written ToolBox_fte9k.apk
6 directly into any third-party applications to increase the functionality of absence
7.ToolBox_fte9k.apk gadget at least three times more numerous reconstruction and optimization
8. Streamlined promote the use of all official and some built-in system application
9 Adjust the default application Sort Home
10 Join full Google services, but also can be customized switch, delete Google services
11 added since the preparation ToolBox_fte9k.apk program, integrating the advanced settings, widgets and a key lock screen function
12. Supports virtual back button navigation bar Left Right Custom
13 This ROM has a high degree of [mention d'application hors charte] to customize settings feature for those who like to toss oil
Gapps include – Rooted
Language support: Multi Lang
ROM install :
1 – Download and unrar ROM
2 – phone is in "USB Debugging"
3 – cell phone connection to the computer in the initialization state
4 – Run the file "flash_all.bat " and tap 1 —> Enter —–> 4
5 – End of the brush, press and hold the volume up on the phone and computer by pressing any key
       Phone automatically restarts when you see the Huawei logo, release the phone volume + key
6 – The phone will automatically pair of clear, double clear finished restart automatically and start the system
Normalement la non release des sources par Huawei devrait être un frein aux ROM custom. En espérant qu'elles fleurissent neanmoins, à partir de maintenant!
  • 4 weeks later...
