Informations mises à jour
Je suis curieux d'avoir ton retour sur le honor. Après je sais que c'est pas le thème du forum, mais je suis curieux de la comparaison. Merci à toi pour ton retour.
Honor reçu, décision finale dans quelques jours !
Merci de continuer cette conversation en privé ;)
Hello !
Bon, c'est pas la mise à jour du siècle, mais elle fait  voir qu'il y a encore quelqu'un chez Asus ^^
V2.20.40.139
1        Improve screen turn into black during phone call issue.
2        Fix Miracast frame rate drop issue.
3        Fix NFC connect issue.
4        Fix network data warning notice don not come up issue
5        FixWi-Fi conncet issue
6        Fix 3G cannot camp to H plus in Laos and Paraguay issue.
7        Fix the coming call issue when using bluetooth earphone.
8        Fix Unlock Tool issue.
9        Improve service stability of modem
10        Fix the charging issue of roaming to LTE when data roaming option disabled
11        Fix boost stability issue
12        Fix the issue that user would still receive the notifications from Auto start denied Apps
13        Fix ASUS Mobile Manager data usage restriction issue
14        Fix ZenMotion Shake Shake screenshot issue
15        Fix URL recognition issue in Messages
16        Modify HK Chinese strings
17        Fix IME issue when open Yahoo PC version webpage by ASUS Browser
18        Fix countdown alarm issue after set in Snap View
19        Fix string issue in Theme Apps
20        Fix charge remained time display issue when quick charging
21        Fix SIM PIN lock issue in Cover View
22        Modify Quick charge notification UI layout
23        Fix System UI stability issue
24        Fix Power saver settings issue
25        Fix JP FlipFont issue
26        Fix Battery Simplified Chinese string issue
27        Fix ASUS Mobile Manager data usage calculation issue
28        Improve Auto Start Manager stability
29        Remove BookLive from JP SKU
30        Fix Documents UI stability issue
31        Fix Snap View UI issue and improve its performance when install 3rd party apps
32        Improve Hand Writing accuracy
33        Fix flashlight turn-off issue when double tap power key
34        Fix Power Saver Ultra saving mode notification settings issue
#        New Features
1        Add phone number editing function in Dual SIM settings
2        Add 128G SD card turn into Power Saver mode function.
3        Add Latvian and Lithuanian languages
En français :
1 Améliorer son tour d'écran en noir pendant question de l'appel téléphonique.
2 Fix Miracast cadre baisse de taux question.
3 Fix NFC connecter question.
4 Fix avertissement de données de réseau préavis don pas venu question
5 FixWi-Fi question de Conncet
6 Fix 3G ne peut pas le camp de H plus au Laos et au Paraguay question.
7 Fixer la question de l'appel entrant lorsque vous utilisez des écouteurs bluetooth.
Unlock Outil 8 Fix question.
9 Améliorer la stabilité du service de modem
10 résoudre le problème de charge de l'itinérance au LTE lorsque les données l'option d'itinérance désactivées
11 Fix problème de stabilité de suralimentation
12 résoudre le problème que l'utilisateur serait toujours recevoir les notifications de démarrage automatique nié les applications
13 Fix de l'utilisation des données du gestionnaire ASUS mobile question de la restriction
14 Fix ZenMotion Shake Shake question de la capture d'écran
15 Fix URL question de la reconnaissance dans les messages
16 cordes Modifier HK chinois
d'émission d'IME 17 Fix lorsqu'il est ouvert Yahoo version PC page Web par le navigateur ASUS
18 Fix question d'alarme du compte à rebours après ensemble Snap Voir
19 Fix problème de chaîne dans le thème Applications
20 frais de Fix resté problème d'affichage de temps lorsque charge rapide
21 Fix SIM PIN problème de verrouillage dans Cover Voir
22 Modifier notification de charge rapide UI mise en page
23 Fix problème de stabilité de l'interface utilisateur du système
24 Fix paramètres d'économie d'énergie question
25 Fix question JP FlipFont
Batterie 26 Fix simplifié chaîne chinoise question
27 Fix ASUS mobile utilisation de données de Gestionnaire d'émission de calcul
28 Améliorer Auto Start Gestionnaire stabilité
29 Retirer BookLive de JP SKU
30 Documents Fix stabilité de l'interface d'émission
31 Fix question Vue instantanée interface utilisateur et d'améliorer sa performance lors de l'installation 3e partie apps
32 Améliorer Hand Writing précision
33 Fix torche turn-off question lors d'un double pouvoir du robinet touche
34 Fix Power Saver Ultra économie paramètres de notification de mode question
# Nouvelles fonctionnalités
1 Ajout de la fonction d'édition de numéro de téléphone dans les paramètres Dual SIM
2 Ajouter 128G carte SD tour en fonction du mode d'économie d'énergie.
3 Ajouter letton et lituanien langues
Han cool merci pour l'info ! Pas la maj du siècle peut-être mais tout de même une MAJ à 170Mo quasi, c'est pas rien :)
On peut noter les seuls points vraiment intéressants :
Les 8 premiers points si on avait ce genre de soucis et :
Après ça reste de la correction de bugs mineurs, mais c'est toujours ça ;)
sauriez vous où on peut telecharger les mises à jour OTA ?..... moi je ne les reçois pas et donc je dois flasher la ROM complète à chaque fois !!! //// donc 170 Mo au lieux de 1.2Go je suis preneur !! :)
merci
Sur le site Asus:
https://www.asus.com/Phone/ZenFone_2_ZE551ML/HelpDesk_Download
Driver & tools > OS > Android > Firmware > Version WW_2.20.40.139 > Download from > Global
Lien direct : (copié collé)
http://dlcdnet.asus.com/pub/ASUS/ZenFone/ZE551ML/UL-Z00A-WW-2.20.40.139-user.zip
Je viens de voir que c'est aussi le fichier de 1,2 Go
Donc désolé je vois pas. :-(
Si je trouve la solution, je partage.
Modifié par seboune
Voila l'adresse pour télécharger le fichier de la dernière mise à jour de 165 M:
http://fota.asus.com/delta_package/phone/WW_Z00A/formal/WW_2.20.40.97_20150917_1572_user_rel-user-WW_Z00A-WW_2.20.40.139_20151104_2652_user_rel-user-WW_Z00A-20151105/WW_551_0917_1104_20151105.zip
Et le site de téléchargement OTA d'Asus:
http://www.asus-zenfone.com/p/fota-center.html
Modifié par Civet
Sur le site Asus:
Merci quand même, c'est pas grave
merci beaucoup
selon journaldugeek.com cela serait entre fin 2015 et début 2016
que doit on en penser ? Fake ?
Asus : PadFoneS, ZenFone2, ZenFone2 Deluxe / Special Edition, ZenFone2 Laser et ZenFone Selfie, entre fin 2015 et début 2016
Modifié par seboune
