[ROM] Jiayu.de Bêta Lollipop 5.1.1 Jiayu S3
Clems6
[ROM] Jiayu.de RC2 Lollipop  5.1.1  Jiayu S3
CHANGELOG DE LA RC2 (principaux changements)
  • Google security fixes from November ( all CVE's are patched, and in-line with mainstream)
  • Better support for layers themes :
    - Settings dashboard are fully themed now
    - Notifications are now themed ( don't reboot anymore)
    - Powermenu is theamable now
    - And a lot of fixs on rom side, to make it compatible with several ( broken ) layers, that don't follow the native behavior.
    ( We shouldn't fix this on ROM side , but the persons who made those themes, but hey, we like to see you happy, so we had this extra work.)
    (Layers application from the Play is required)
  • New Launcher (new icon packages are in play, but after "icon pack" search)
  • Battery statistics will be retained after reboot
  • NFC notification can be swiped away
  • NFC re-worked and removed bad code, that broke NFC for some users/services
  • Backup & Restore application added
  • "Frameworks" updated to Android 5.1.1 release 26
  • Performance optimizations (only draw pictures / backgrounds, if there is a change, ...)
  • ZRAM kernel reactivated (which provides compressed memory available)
  • "Documents" file has managerial skills received (copy, cut, paste)
  • Some applications adapted to the material design
  • optimized "scroll"
  • Performance optimization of the "last used applications" overview
  • Speed ​​Dial for Phone application added (Sorry, no translations entered)
  • More and faster exchange of (automatic) brightness
  • SmartWake reworked and revamped (doubletap is lightning fast now)
  • More translations added
La RC1 est une version SPFlashTools.
La RC2 est une version recovery.
Télécharger la version Release Canditate 1 (RC1) datant du 30.10.2015 (Version SPFlashTools)
LIEN MEGA: https://mega.nz/#!FQlQiKKK!XvLFK3CGDDceHAoECWSLt44AujgTU3Mwb_V8VhXXz0o
Télécharger la version Release Canditate 2 (RC2) datant du 16.12.2015 (Version Recovery)
LIEN MEGA: https://mega.nz/#!xBFXzZhK!CGTMmErEGKpAoPshe91yno27RHuypvWgpQahNfyECYg
Tutoriel d'installation SPFlashTools :
https://forum.frandroid.com/topic/216274-rom-jiayu-s3-advanced/
Télécharger le framework Xposed:
1- Framework Xposed (à flasher dans recovery) : http://forum.xda-developers.com/attachment.php?attachmentid=3499278&d=1444255420
2- Installer l'application Xposed : http://forum.xda-developers.com/attachment.php?attachmentid=3383776&d=1435601440
Source RC (site officiel) : https://jiayu.de/forum/index.php?thread/316-lollipop-5-1-1-rc-1-30-10-2015/&pageNo=1
Merci à @@Fef51 pour les informations sur la ROM
Modifié par Clems6
Je me lance,
installation de la v8 avec le kernel v3 qui doit corriger le bug de batterie.
en cours
pour le moment pour le réseau avec free nickel.
je cherche comment installer le menu ingénieur car il est pas installé dans cette rom.
j'ai trouvé le mode ingénieur, il faut débloquer le menu développeur et la ça fonctionne.
j'ai réussi a supprimer les bands que j'utilise pas et pour le moment que du positif sur la réception meilleur que kitkat
la rom est fluide et le launcher parametrable
Bonsoir,
Le kernel v3 est incorporé à la ROM ? ou il faut le flasher à la suite de l'installation ? Si il faut le récupérer, peut tu en poster le lien ?
Merci, je serais également intéressé par un retour. Bonne soirée
petit retour,
cette nuit perte de 1% de batterie (super)
ce matin j'ai joué à angry 2 pendant 2 heures et perte de 15%
test du gps hier, pas de probleme avec MappyGpsFree (pas de modif de faite avec FasterGps, laissé d'origine).
DeadTrigger 2 fonctionne enfin (pour moi problème avec rom kitkat)
test hier de 4g avec un débit de 65Mega (modem kitkat)
rom tres fluide et aucune erreur pour le moment
je garde par rapport à kitkat car mieux
prochaine étape installation de xposed
Modifié par vazarg
