Juste un petit post pour dire qu'un portage d'ICS a commencé sur XDA par notre bien aimé Zdzihu !
Lien : http://forum.xda-dev...d.php?t=1356580
Apparemment c'est qu'une ébauche mais ça commence à sentir bon !!
Wait and see !
Xperia X10 - Android 4.0.1 - Ice Cream Sandwich - ALPHA!!!!
Xperia X10 running on ice cream sandwich
Pour ceux qui souhaiteraient tester :
Téléchargement :
Alpha1 ROM (for CWM5) + corresponding kernel (flashtool) is here:
http://www.mediafire...ht6p6tbpj2988d4
Installation (non traduite) :
1. Get the latest FlashTool from the FlashTool thread. (http://forum.xda-dev...ad.php?t=920746)
2. Download zdzihu's ICS package from the dev thread (http://forum.xda-dev.....php?t=1356580) and extract it.
3. Copy update_es209ra_ICS_alpha1_CWM5.zip to your SDcard.
4. Turn off phone and unplug the USB cable if it was connected.
5. Start FlashTool, go to Advanced > Bundle Creation and choose zdzihu's kernel.sin. (See the Links section for a quick tutorial)
6. Press flash and choose "Flash Mode".
7. Search for the newly created firmware (the one you've created earlier) and click OK.
8. Hold down the BACK button and plug in the USB cable. FlashTool should begin to flash it.
9. When FlashTool finises flashing, turn on your phone. When you see the trollface press VOLUME DOWN continuously, CWM5 should start.
10. Wipe Data, wipe Cache and wipe dalvic cache.
11. Flash update_es209ra_ICS_alpha1_CWM5.zip from your SDcard.
12. Reboot, and wait until it boots.
Différents liens :
The dev thread: http://forum.xda-dev.....php?t=1356580 (Big thanks to zdzihu, aZuZu and everyone else who helped)
The post on XDA-Portal: http://www.xda-devel....gets-ics-port/ (Thanks to egzthunder1)
Video of the Alpha 1 port: (Thanks to X10B)
Tutorial on how to create a FlashTool bundle for Alpha 1: (Thanks to X10B)
Another video of the Alpha 1 port: (Thanks to sopdogg)
Review of Galaxy Nexus and ICS:
Je n'ai personnellement pas encore testé, mais apparemment pas encore au point !
Modifié par desspil, 23 November 2011 - 18:32.
Retour en haut
