forum FrAndroid
Change
hitech regie
[ROM][ICS 4.0.3] AOKP - BUILD 28 [20.03.12]
  • Vous ne pouvez pas répondre à ce sujet
1318 réponses à ce sujet
#1
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
AOKP¨- Android Open Kang Project
!!! BUILD 28 !!!
http://forum.xda-dev...d.php?t=1524108
Screenshots:
Image IPBImage IPBImage IPBImage IPBImage IPB
Installation:
- Faites un Nandroid Backup!!!
- Wipe Data/Factory Reset
- Flasher la Rom
- Flasher les GAPPS
- Reboot
!!! ENJOY !!!
Téléchargements:
- BUILD 28
- Mirroir
- Mirroir 2
- Gapps 20120317
Caractéristiques:
  • Android 4.0.3 -- ITL41F
  • Unsecure boot.img (stock AOSP kernel)
  • Superuser & Busybox preinstalled
  • Deodexed
  • 180 Degree rotation
  • Built in performance/init.d configuration (Thanks Kejar & company)
  • CM Launcher/ Power Menu
  • CM Brightness slider
  • Custom color for anything in RC
  • Clock Color/Location: Right, Center, Disable
  • Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
  • Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
  • Nav Bar Transparency
  • Nav Bar Button Reorder: Back-Home-Search-Menu
  • Nav Bar Color Picker
  • Nav Bar Button Glow Duration: Off, Fast, Slow
  • Nav Bar: Long press to Search button
  • Nav Bar Hide on Lockscreen
  • Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
  • LCD Density (Careful with this)
  • Menu Button location: Right, Left, both, Remove
  • Menu Button Visability: Always show, Always show Invisible Icons
  • Lockscreen Style: Quad, Octo, Stock
  • Lockscreen SMS customizable shortcut
  • Lockscreen Horizontal Option
  • Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
  • Unlock Sceen with Legacy Menu Icon
  • Volume Key to Wake Screen
  • Volume Key to Skip Tracks
  • Long-press back button to kill process
  • Disable CRT off animation
  • LED pulse settings (time on/off)
  • ICS ringtones/notification sounds
  • Customize carrier text to whatever.
  • Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
  • Facebook contact sync integration (must wipe to get this)
  • Disable Boot animation
  • Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
  • Long press home for recent apps (thanks brucekey)
Changelogs:
BUILD 28
  • Added lockscreen color changer
  • Added 'traditional' toggle layout [where the toggles are on the very top] (Stevepear426) -- find in RC > Statusbar General > Layout
  • Added AOSP lockscreen style (Whitehawkx)
  • Added extra volume slider options (Stevepear426, tmoskowite on gummy)
  • Added lockscreen calendar options (!!!) (sethyx)
  • Removed any trackball support the ROM had, was only throwing errors, not properly implemented
  • Improved brightness slider under toggles, doesn't jump anymore
  • Improved brightness slider (when sliding your finger across the statusbar if enabled). MUCH more responsive now
  • Added fast charge toggle for maguro/toro for kernels that support it (Zaphod-Beeble)
  • Added ability to set custom lockscreen image for targets. Click picture in RC to set.
  • Also increased size of custom lockscreen images to more match the normal icons
  • Improved
  • Including AppWidgetPicker to help organize widgets
  • Added digital clock widget to desk clock
  • battery bar should no longer disappear when in the navigation bar
Milestone 4
  • Weather panel updates (sethyx, Zaph, tgwaste, and many more!)
    • new more compact layout that fits at the top of your screen
    • ability to hide it in your statusbar
    • added lockscreen weather to tablets
  • Added statusbar transparency (rob43)
  • Added alternate notification drawer layout (toggles/date on bottom instead of top)
  • Added day of the week before clock style option (rob43)
  • Signal text reading improvements (Zaph)
  • Added option to show lockscreen before secure unlock
  • Simplified nav bar hide/show code => should be working on all devices properly
  • Added PhaseBeam alongside UnicornPorn
  • Fixed all weird tablet FCs (was caused by that messy nav bar code Image IPB)
  • p4: 3G should now be working on the 3G 10.1" tab samsung tab
  • stingray: Data should be working now! Thanks travp for helping me debug this
  • added fascinatemtd
  • added a500
  • vzwtab renamed to galaxytab7c, also now using MTD instead of BML. No m4 for it yet.
  • tenderloin: working HD video, ie: Netflix, YouTube HD, updated with other CyanogenMod fixes.
Add-Ons:
Black Infinitum: http://forum.xda-dev...d.php?t=1445647
Blue Infinitum: http://forum.xda-dev...d.php?t=1517501
Deux thèmes juste magnifiques, à tester sans hésiter les p'tits loulous ;o)
Credits to:
XDA
TeamHackSung
sixstringsg
CyanogenMod
Team AOKP
Stratosk
BHuvan goyal
Slaid
Romann
Razer(x)
Ma Team naturellement B)
Si j'en oublie...... :o
Un p'tit cadeau pour vous les p'tits loulous ;o)
Tuga's B28 Final
Changelog
!!! Bon flash @ vous tous et bonne découverte !!!
Modifié par Tuga_Droid, 25 March 2012 - 23:33.
#2
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
Pas de problème merci anyway, juste une question 'un peut bete peut étre' mais j'ai pas vue ou c'est motionner SGS sur le XDA'
Modifié par Tuga_Droid, 10 February 2012 - 02:53.
#3
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
Bon en cours de dl et j'en profite poiur lire les premiers retours sur XDA et ça donne vraiment envie!!! Ils en sont contents apparemment: fluidité, stabilité, customisation, batterie, etc...... Mes retours dès demain et je verrai par la suite si il y aurait pas possibilité de faire une version typée MyUI eheheheeh.........
Bon, installation sans soucis (après un wipe total en passant par la MySam), la rom est waouh!!! Je suis sous le charme, vraiment ;o) ICS m'a conquis et cette rom par la même occasion. J'espère qu'il en sera de même pour vous.......
#4
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
Ok mon ami le FrAndroid compte sur toi lol
#5
hic87
hic87
    Membre régulier
  • Membres
  • 100 messages
  • Modèle:Samsung Galaxy S i9000
Pour mes premiers impressions sur la Rom rien a dire with a NO COMMENT, mais dite moi moi je n’arrive tjr pas a lire la musique sur mon sd carte ?
#6
chkoon
chkoon
    Android des montagnes
  • Membres
  • 500 messages
Merci d avoir ouvert ce sujet Tuga_Droid je n aurais plus a faire de HS testé cette nuit je suis fan je te laisse nous faire ton retour :P
Modifié par chkoon, 10 February 2012 - 06:33.
Gti9000: Ics Glitch JW4 Mixer Apex
#7
hic87
hic87
    Membre régulier
  • Membres
  • 100 messages
Apres plus de 2h de test je confirme le problème de lecture de musique a partir de la carde SD, méme sur le XDA on a évoqué ce problème, réste la batterie après 2h elle est a 97% avec 10 sur le net donc je verrai bien ça au cours de la journée, pour ça fluidité bin elle est comme une plume lol
#8
benoitkmn
benoitkmn
    RdS Galaxy S
  • Responsables de section
  • 4411 messages
Ah super Tuga, merci d'avoir ouvert ce topic ! J'avais hésité mais je pense que je ne le tiendrais pas à jour trop longtemps ...
Elle a l'air vraiment super, les retours sur XDA sont très bons (juste un problème de lecture des musique sur la carte SD externe, d'ailleurs essayez avec un autre lecteur).
Depuis ICS j'ai vraiment l'impression que le Galaxy S revit, on a de nombreuses bêta d'ICS toutes plus stables les unes des autres !
Responsable de Section - Galaxy S i9000
Samsung Galaxy S - CyanogenMod 9 "nightly" - Android 4.0.4
Image IPB
#9
bejda
bejda
    Grand Android
  • Membres
  • 762 messages
Je passerai bien de la codename à celle ci vite fait,plus d'options mais plus la reconnaissance sd ext des applis stock Music et gallerie c'est pas bien grave ça peut valoir le coup pour la journée...par contre c'est bien kernel glitch?Parce que le glitch sans ordi sous la main moi c'est galère assurée,personne n'a perdu l'accès recovery trucs comme ça?
Modifié par bejda, 10 February 2012 - 08:07.
#10
Kovard
Kovard
  • Membres
  • 22 messages
  • Modèle:Galaxy S
Oui le 14 b3 et pas de mauvaise surprise<br /><br />Sent from my GT-I9000<br />
Modifié par Kovard, 10 February 2012 - 08:31.
#11
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
Merci @ vous les gars pour votre enthousiasme ;o) Ca fait plaisir. Pour le problème de carte sd ext je ne l'avais pas lu sur les tout premiers retours....De plus je n'en ai pas donc pas ce soucis eheheheheh Pour le reste c'est juste magique!!!! Je suis envouté par cette rom!!! Personnalisation, stabilité, rapidité, beauté, etc.....Tout y est, reste plus que la batterie à tester mais ça me semble pas trop et puis on a accès direct à un battery saver via le menu dans les paramètres!!! C'est juste fou ;o) Désolé si je m'emballe mais là je pense que c'est justifié.
#12
vincesonata
vincesonata
    Grand Android
  • Membres
  • 775 messages
  • LieuMarseille
  • Marque:Samsung
  • Modèle:Galaxy S
Le dev' est en train de corriger le problème de la SD externe (normalement
Citation
"Today"
) ainsi que les FC de l'appli Super User (certaines personnes ont ce soucis)
Modifié par vincesonata, 10 February 2012 - 12:01.
Dropbox : Wallpaper - Dock - Icônes - Toi aussi, ouvre une dropbox, c'est gratuit : Clic clic :)
- Onecosmic ICS 4.2 - Kernel DEVIL 14.2 BLN ---- - ICS 4.0.3 - AOKP Build 23 - Release 2.02 - Kernel Semaphore 0.8.1
- AOSP 4.0.4 "Elite V11" - Devil 2 ---- MyICS Ultimate Fusion b4
#13
Tuga_Droid
Tuga_Droid
    Android sauvage
  • Membres
  • 1261 messages
  • LieuIle de France
Et en plus il est réactif eheheheh Que voulez vous de plus ;o) Sachant quand même que le dév qui fait le portage pour nos GS, a déjà sévi en tant que dév. Bref c'est pas un novice ;o)
@chkoon: oui effectivement tu m'as fait douté quand j'ai lu que tu parlais de la build 22 sur un autre topîc ahahahah
@benoit: de rien, j'ai été sous le charme dès que je l'ai vu et j'ai voulu partager cette excitation avec vous.........hum hum entendons nous hein ;o)
#14
JCdu74
JCdu74
    Android no-life
  • Membres
  • 2129 messages
Cette rom est magnifique, seul soucis, impossible de lancer le wifi :(
Le toggle wifi s'excite entre le on et le off à la vitesse de la lumière...
#15
sk4c
sk4c
    Grand Android des plaines
  • Membres
  • 908 messages
  • Lieu92
  • Modèle:un S2 I9100P Cityzi et 2 G's I9000 (jig usb)
@JCdu74
j ai eu le meme probleme avec le build 15 de la CM9, apres une reinstalle avec full wipe a partire de ce meme build le probleme c est regler tout seul
vous me donner envie meme si j aime pas trop la licorne facon kikoo
GsII I9100P Rom : CM9 Nightly 23.05.2012 / android 4.0.4 / B.Bande test LPR / Kernel 3.0.32
Gs I9000 Rom : (Base JVU)
CM9 Nightly 17.05.2012 / android 4.0.4 / B.bande JVU / Kernel 3.0.8
Gs I9000 Rom : (Base JW1)
CM7 Nightly Kang 20.05.2012 / android 2.3.7 / B.Bande JVK / Kernel Stock
#16
Timakine
Timakine
    Newbie
  • Membres
  • 1 messages
Salut à tous, rom testée avec succès en ce qui me concerne.Rapide, légère et stable. Par contre, l'application musique se ferme constamment alors que ma musique se trouve sur carte SD externe. Mais avec poweramp, pas de soucis particulier...bizarre.
En tout cas, belle rom dont je suis devenu adepte autant sur Galaxy S que sur Galaxy Tab 10.1.
#17
chkoon
chkoon
  • Membres
  • 500 messages
@Benoitkmn
Je plussois B)
@tuga droïd
tu me rassure, je croyais etre le seul a être exité comme dans la pub renault"c'est mon kadoooo" :P
@bejda
malheureusement pour la CodeName celle ci met la barre haute ^_^
@Tous fallait pas dire qu'on aurai pas ICS pour nos SGS car les sanctions (différentes ROM)n arrêtent pas de tombées pour notre plus grand plaisir héhé bon flash ;)
Edit : Ah oui mes applis market se reinstalle d elle meme ca aussi c'est bon
Modifié par chkoon, 10 February 2012 - 14:15.
#18
kikir9
kikir9
    Grand Android
  • Membres
  • 744 messages
  • Lieuessonnes
des que la music fonctionne et la sd, je teste... cool encore une... B)
et bien pour un tel qui ne devait pas faire tourner correctement ICS d apres Samsung.... enfin bref sans commentaire.. :emo_im_lips_are_sealed:
(--Galaxy s I9000--)
-ROM ICS 4.0.4 CodeName Android v2.0.0 RC Avec Aroma du 24/04
-Kernel devil v2
- http://forum.frandro...03-iml74k-aosp/
#19
Elurenger
Elurenger
    Android à poil vert
  • Membres
  • 409 messages
  • LieuBelfort (90)
  • Modèle:Galaxy S GT-I9000
De même ! Dés que le 3g+/music/sd fonctionnent je me mets sur cette rom !
Image IPBImage IPB
Freemobile illimité 19.99€
#20
phil2nice
phil2nice
    Android à poil vert
  • Membres
  • 364 messages
Je regarde cette rom pour le galaxy nexus depuis 15 jours (j'ai acheté un GN, mais la poste l'a perdu en chemin... ma patience est à bout de nerf...) donc content voir cette rom sur le SGS, ça me permettra de patienter!
Galaxy S ICS 4.0.3, Rom AOKP, Glitch kernel et Nova launcher
Galaxy Nexus 4.0.3, Rom AOKP "odex" réglé sur 280 dpi, Minimalistic Kernel et Nova launcher
