ROM CUSTOM: [703L, 702L, 701L] Kangvip Slim B230, android 6, EMUI 4.0.3 28/12/19
Ajsmsg78 nous propose  une rom custom basée sur la récente rom officielle B230 du 703L, et avec le module de paramétrage avancé Kangvip. Installable sur tout X2 avec une ROM B2xx :
** modifs:
4-in-1 Reboot Menu
AdAway
Dark Huawei Boot Animation
My dark X2 Default Theme
Debloated
Deodexed
Double tap to wake
Extra EMUI Themes
Google Calendar Sync
Google Chrome
Google Contacts Sync
GBoard
Google Play Store
Init.d Support
No Forced Encryption
KangVIP Tools
Pre-Rooted with Magisk or SuperSU
Viper4Android
** Téléchargement:
https://www.androidfilehost.com/?fid=4349826312261687052 (version avec Magisk pour le root)
https://androidfilehost.com/?fid=4349826312261687047 (version avec SuperSU pour le root)
(à flasher avec TWRP Recovery, comme toute rom custom)
** Conseils:
- To remove the Chinese writing on the statusbar and lockscreen go into settings-->K-settings-->Lockscreen and desktop settings and turn off Lunar calendar & Desktop weather lunar, then go back and into Notification settings and turn off Show statusbar lunar
- You may have to open SuperSU and allow KangVIP Tools if K-settings doesn't open
- Set the DPI to 325 or higher or else Chrome tabs won't work and YouTube will force close when going into subscriptions
- To stop background apps from closing after 1-2 minutes freeze or delete HwPowerGenieEngine from system/app.
** Source:
https://forum.xda-developers.com/t/rom-6-0-kangvip-slim-b230-12-28-19.3215851
