Jump to content
[ROM] Criskelo's ICS V11.2 << LRK 4.0.4>> ICS 15 togg TW*S3*-AROM <<<SIM-Lock FIX>>>
Video By parthpatels007 TKS
CriskeloRom ICS Note V11.2 LRK
LINK
CriskeloRomNOTE.vICS-V11.2-MD5-7FEDC9597F42C0E9CA2AE4673E84798B.zip
MIRROR 1
MIRROR 2
MIRROR 3
V11.2
• ADD option in Aroma FullWipe
• Fix Sony Bravia that was not installed
• Fix Sony PlayStation that was not installed
• Fix USB mode now works as it should to return to MTP from Aroma MOD options
• Note 11.1 Updated kernel G
• Add stock theme SIP
• Add stock CRT off in theme
• Now you can apply mods, themes, kernels and modems without complications, should only select what you want
• Several minor tweaks
CriskeloRom ICS Note V11.1 LRK Base No WIPE
LINK
CriskeloRomNOTE.vICS-V11.1-MD5-E69E443254694198E29F0B2FA8C98259.zip
Mirror 2
Mirror 3
Mirror 4
V11.1
• Some adjustments build.prop TKS Petking
• Added options in aroma
• Select from HTC or Stock DigitalClock
• Select Sony PlayStation Games Library Certified On / Off
• Sony Bravia Engine Library Select On / Off
• Select Sony Walkman Music Pleasure On / Off
• Delete SIM Block protection
• Added language selection to Aroma Installer (English / Spanish)
• And more
CriskeloRom ICS Note V11 LRK Base No WIPE
MD5 = 84ECFC782FAD7041408C4CF98718425D
LINK
CriskeloRomNOTE.vICS-V11-MD5-.zip
Mirror 1
Mirror 2
Mirror 3
Mirror 4
CriskeloRomNOTE.vICS-V11-MD5-.zipTKS bangsti
Mirror 5
CriskeloRomNOTE.vICS-V11-MD5-.zip TKS BetoNL
Changelog V11
• Base LRK
• LRK MODEM
• Kernel CF-Root LRG
• Multi CSC
• Deodex
• ADD Superuser.apk
• No incremental volume in ringtones
• 4 Way Extended Restart Menu
• Stock AccuweatherWidget (Transp.)
• Stock DigitalClock (style HTC)
• Fixing CRT-Off thanks Tungstwenty
• Camera ICS MOD (configurable Volume keys and Camera VideoRec - save internal memory / SD card and more)
• ADD Swype Keyboard
• ADD Chinese Keyboard (on request)
• Start up sound S3 by Syps
• Add TouchWiz launcher-UX S3 (5x6) completely fix all errors (Select wallpapers / widgets etc.) TKS @Smando
• LiveWallpapers Galaxy S3
• New Status Bar 15 toggles (Add Spanish Frech)
• QuickPanel settings now also in Fr y Spanish
• ICS Color Icons in statusbar
• Everything you need to run VPN (not tested) Thanks to ookba
• SMS are not logged in CallLog
• Several tweaks Framework-res.apk
• Mod Settimgs.apk Version Rom /Fast Dormancy/ QuickPanel shortcut / CPU Spy/Working CPU/Select CSC/Samsung Secret Code.
• Roletube (download videos from youtube SD-Card/downloads)
• Host updated to Avoid ads
• Add stock ICS BrowserPlus Browser
• ICS keyboard AOSP
• ICS keyboard Samsung
• ADD AppWidgetPicker (Groups the same application widgets)
• More HD Wallpapers AppStock, and CriskeloGallery
• Themed Dialpad, statusbar and other
• SMS 100 contacts and no convert to MMS
• Add SGSIII MusicPlayer tks grgsiocl
• New CallRec LRK
• SIP working completely
• Improved Cache SD-Card
• Auto BackUp EFS / sdcard / efs.autobackup.img
• Patched services.jar for using supercharger scripts
• And other improvements more
Quote: Aroma
Themes:
• Clock Center
• Clock Right
• Theme Stock
MODS:
• [MOD]Modified DSP Manager with BEATS audio.(only GoogleMusic) TKS ...Awesome...
• On/Off Auto Mass Storage
Kernels:
CF-Root LRG
SpeedMod k3-11
GL-Notecore v9
GL-Notecore EX
MODEMs:
LB1
LP6
LPB
LPK
Mini tutorial pour désimlocker le mobile en LRG / LRI / LRK. Remerciements à mike1986. NOD SGSIII
1:
Téléchargez ce fichier CriskeloRom-Fix-Network-Lock-InstallCWM.zipHERA
2:
Installez CriskeloRom-Fix-Network-Lock-InstallCWM.zip avec CWM
reboot...
3:
Téléchargez Galaxy s Unlock sur Google Play
Lien
https://play.google.....h5c3VubG9jayJd
4:
Suivez les étapes pour déverrouiller.
C'est prêt.
TKX SYPS
Edited by gaja
Link to comment
Share on other sites
Et bien voilà un job qui ne ressemble pas à notre ami Criskelo... Il a voulu faire quoi? Nous pondre une Rom avec un superbe thème ICS, ce qui n'est pas dans ses habitudes, mais il a certainement voulu nous donner un pack complet avec jkay inclus, et le tout avant tout le monde. Résultat, faut balancer un ancien Kernel alors qui lui il livre sa Rom avec un Speedmod de test avec à la clé une avalanche de bootloop pour pas mal de monde.
La checkrom V4 tourne à merveille, Gadgetcheck voulait aussi inclure le pack Jkay deluxe avec sa Rom, ce dernier est encore en développementet il a fait le bon choix de ne pas l'inclure.
Criskelo nous a habitué à bien mieux que cela (même si je ne partageais pas sa charte graphique) et j'attends aussi quelque chose de plus abouti!
Link to comment
yop... ben moi j'instale cette Criskelrom v2 je trouve parfait exactement entre romow et rocket juste le look bien sur ..! apres effectivement le kernel ne permet pas un overclock 1.7 ghz mais bon vu que je down a 1 ghz sans voir de difference c'est pas un soucil pour moi. Sinon premiere impression positive sauf le setdeluxe partielement accesible peut etre avez vous une soluce ..?
Link to comment
Ben pour moi cette CriskeloRom c'est la plus fluide et le meilleur equilibre batterie fonctions etc .... a decouvrir pour ceux qui hesitent encore ..! j'ai vire tout les fichiers rom du tel sauf celle la tiptop ...!
Link to comment
Quelqu'un pourrais expliquer comment il la installé, car que ce soit la v1 v2 ou v3 imposible de demarrer mon note, l'animation de demarrage tourne en rond, meme sur xda il prend pas la peine de l'expliquer alors qu'on est plein a connaitre ce soucis?
J'ai tout formaté avant mais rien.
Edit: je repond a mon soucis, en faite il ne fautsurtout pas faire de wipe, c'est tres curieux car en deux ans de flashage intensif je n'ai jamais vue cela.
Mais sinon cette rom est fluide mais elle m'inspire pas, je la trouve mal finis, le theme ics est pas aussi bien fait que le theme ics dispo pour la rocket et le mod jaykay a peut etre des options interessantes mais les icones dans la barre de statut sont vraiment grossiere, vue la resolution du note il pourrais faire plus fin.
Je resterais sur la rocket ou la chekrom parce que tout ceka me semble pas tout a fait au point, et de pas pouvoir faire de wipe avant le flash me semble curieux.
Edited by kefane
Link to comment
  • 4 weeks later...
  • 2 months later...
CriskeloRom ICS Note V3 LPY Base No WIPE
<<<VERY STABLE>>>
LINK
NOTE CriskeloRom ICS V3
• Base LPY
• Kernel LPY CWM CF-Root
• LPT Modem
• Deodex
• Superuser ADD apk
• Added ApexLauncher
• Fixes Status Bar (GPS icon, Direct access to settings, new icons, agrandad date, Button is now clear a cross, Operator at the bottom, and some other tinkering)
Battery% • On / Off Stock (configurable setting)
• Transparent Background SamsungWidget_WeatherClock.apk
• Style DigitalClock HTC
• CRT TV off effect
• Host updated to avoid propaganda
• Added new "S Note" premium pack of Samsung
• ICS keyboard AOSP
• AppWidgetPicker (APP Widgets groups the Same
• Enabled the option CallRec Phone
• Many more things I can not remember
Link to comment
que vaut cette ROM comparé à la stock, la CM9, la Asylum ?
Le lien vers le topic xda
http://forum.xda-dev...d.php?t=1609252
moi elle m'intéresse, ne serait-ce que pour le S Note et la Base LPY qui intègre quand même des appli que j'utilise au quotidien (horloge, radio, mass storage)
pas trop d'infos pour l'install :huh:
Je vais tenter un full wipe + install direct
Sinon merci Gaja :D
Edited by VTR
Link to comment
  • 3 weeks later...
Vivement une mise à jour car cette rom est vraiment superbe, réactive et pas gourmande en batterie :P
Juste 2 bugs pour moi :
- écran qui se fige tout noir de temps en temps, avec juste la barre de notification visible (quand je sors d'une application par exemple) et qui revient apres une dizaine de secondes.
- impossible de mettre une note en widget en étant sur "Apex Launcher" (le Note revient sur le launcher d'origine à ce moment la).
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
 Share
  • Create New...
