How debug a Android project (Eclipse) on Asus TF101?
I ordered an Asus EEE Pad TF101 tablet to run Android application. I use Eclipse on Windows XP.
What are the instructions to connect the tablet to PC (Windows XP)?
I just need to install the driver found on the ASUS site or the plugin on Eclipse is enough?
Oui, tu as besoin des drivers de ton appareil si tu veux l'utiliser pour développer/debugger des applications, ceci afin que Eclipse puisse le reconnaitre. Et il te faut aussi bien évidemment le plugin Eclipse et le SDK Android
(Hello,
You need both. Drivers are needed in order to be able to developp/debug your own applications on your device, as otherwise Eclipse will not see it. And you also need the Eclipse plugin as well as the Android SDK)
