bin Posté(e) 14 mai 2012 Auteur Share Posté(e) 14 mai 2012 (modifié) Hello Matzpx8709, Yes the amery kernel version got two march directory one for sun4i an other for sun3i, i just see here friday, so i see my memory map is not good But conceptually, u-boot is in my oppinion the right way. Yes you get right but if you ever play with, you known you need essentials parameters to build it, so before going to this "last" step, i try to inject a small peace of code to validate the parameters. After it's a "kid game" to adjuste u-boot to compile & work. I already try a lot with uboot on this device, not working, but when i look into kernel sun3i and sun4i memory map and u-boot memory map i understand why... i did not find any f20(=sun3i) inserts in u-boot too. (like you did not). Yes, this is what i'm try to say, u-boot can do the job, but only for a sun4i (a10) yet, and for sun3i(f20) the map register, device register, is bit different...we need to adjusts config... Typically, when we need to do this, we try a more simple peace of code that typically "blinking a led", but the pin of F20 are not exposed, i find some pin can probably do the job, but i already found the serial port so i try to use it... If this way dont work i comeback to "blinking led" way... But my friend you get rigth, all of this is to finally build and use u-boot. I found all information i need now, so today or tonight :), i try to confirm my theorie. if i got time i also show you the behavior differents with or without mmc i come back quickly Modifié 14 mai 2012 par bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 14 mai 2012 Auteur Share Posté(e) 14 mai 2012 (modifié) Salut, Pour éviter la pollution linguistique sur ce thread, et n'ayant pas reçu de réponde du modérateur, j'ai publié mes infos ici http://www.sysfwlab.com comme ça plus de problème...regardez dans la section MIDCF43 Bin Hello, To dont break the board languages rules, and without moderator reply i publish informations here http://www.sysfwlab.com, look into MDCF43 section. Bin Matzpx8709, I going to do mmc try this nigth, i publish bad or good result as soon as possible... And dont heard TV show at the moment...Ich liebe die deutsche.... Bin Modifié 14 mai 2012 par bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matzpx8709 Posté(e) 15 mai 2012 Share Posté(e) 15 mai 2012 (modifié) :P :P :P :P :P :P :P :P Means: with the parameter rootdelay=<~10-12> (seconds), this kernel is also able to boot from mmc. could someone verify this for the polaroid mid ? matz@intel:~/installationen/Android/tmp$ adb shell # l / -rw-rw-rw- root root 4 2012-05-06 16:58 mmc drwxr-xr-x root root 2012-05-15 09:41 rootfs lrwxrwxrwx root root 2011-11-21 10:23 cache -> /data/root-cache -rw-r--r-- mount mount 288 2011-11-18 07:59 ueventd.goldfish.rc lrwxrwxrwx root root 2011-11-21 10:23 vendor -> /system/vendor lrwxrwxrwx root root 2011-11-21 10:23 etc -> /system/etc drw-rw-rw- system root 2012-05-13 11:33 old_root -rw-rw-rw- root root 15563 2012-05-06 19:53 matz.rc -rw-rw-rw- root root 15925 2012-05-06 13:32 init.rc drwxrwx--x system system 2012-05-12 19:09 data drwxr-xr-x mount mount 2011-11-18 07:59 sun3i_conf drwxr-xr-x mount mount 2011-11-18 07:59 drivers -rw-rw-rw- root root 15830 2012-03-04 18:03 init.rc.original -rw-r--r-- mount mount 1677 2011-11-18 07:59 init.goldfish.rc -rwxr-xr-x mount mount 522240 2011-11-18 07:59 initlogo.rle.original -rwxr-xr-x mount mount 98264 2012-05-06 14:21 matz dr-x------ root root 2011-11-21 10:23 config drwxr-xr-x mount mount 2012-05-06 14:59 system lrwxrwxrwx root root 2011-11-21 10:23 sdcard -> /mnt/sdcard lrwxrwxrwx root root 2011-11-21 10:23 d -> /sys/kernel/debug -rwxr-xr-x mount mount 98264 2011-11-18 07:59 init -rw-r--r-- mount mount 3868 2011-11-18 07:59 ueventd.rc drwxrwxrwx root root 2012-04-04 15:14 root drwxr-xr-x root root 2011-11-21 10:23 acct drwxr-xr-x root root 2012-05-15 09:42 dev drwxrwxr-x root system 2012-03-04 17:47 mnt drwxrwxrwx root root 1970-01-01 01:00 boot dr-xr-xr-x root root 1970-01-01 01:00 proc drwxr-xr-x mount mount 2011-11-18 07:59 sbin drwx------ root root 2011-11-18 07:59 lost+found drwxr-xr-x root root 2012-05-15 09:41 sys drwxr-xr-x root root 2012-05-04 20:34 lib -rw-r--r-- mount mount 118 2011-11-18 07:59 default.prop # cat /proc/cmdline root=/dev/mmcblk0p1 rootdelay=15 rw init=/matz # Modifié 15 mai 2012 par matzpx8709 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matzpx8709 Posté(e) 15 mai 2012 Share Posté(e) 15 mai 2012 Hello bin and all who are interested in theese technical details of the polaroid mid and the touchlet pmt43-wifi: Another good news: painting (drawing text) is possible: !!!! and in BOOT it seems to be esentially !!!! when analyzing the logos, and playing around with them, i could see, that if you have no logo, display stays black and no kernel can run ! the logos seem to be organized as 4-Byte sequences, starting with ff and then blue, green and red (tested). so, if you want to get out something out of the device, it seems that you have to write 480x272x4 Bytes onto /dev/graphics/fb0 or the corresponding address range for the display. Good luck, bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 15 mai 2012 Auteur Share Posté(e) 15 mai 2012 Hello Matzpx8709, Thanks a lot for this very usefull information, but my nanda is broken... i couldnt boot anything now, only boo0 and boot1 (app_demo.axf) start. So i focus on mmc load, because i dont find any baserom to try to adjust... i'm not desesperated ;), i'm going to find a non broken device to follow you, be it seem we are only the two crazy guy does work on this device :).... Bin Thanks for you comments too ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matzpx8709 Posté(e) 15 mai 2012 Share Posté(e) 15 mai 2012 hello bin, thats a bad news. how do you see, that app_demo is starting ? can you describe, how your nanda was broken ? ( i looked at many roms of onda ftp server, but there is definitifely no compatible rom). did you try my [matz] - section tip ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 16 mai 2012 Auteur Share Posté(e) 16 mai 2012 Hallo matzpx8709, thats a bad news. Yes but i know how to find an other...dont be affraid i dont abadon you. how do you see, that app_demo is starting ? I can see output from the serial port hack, look at here : http://www.sysfwlab.com/?p=214 You can see different comportement of "app_demo.axf" and "boot0" - Bootlog 1 "standard" : is a normal boot (without kernel :) ) - Bootlog "flash mode" : is the jump to FE (also know as "livesuit mode" you known) - Bootlog 3 : Vol+ push and released - Bootlog 4 : Vol+ pressed continusly (You can see for 3 and 4 just only a number printed by app_demo.afx change ) I disasm the app_demo.axf previously, and i can found all the strings printed on serial port. can you describe, how your nanda was broken ? Yes, i forgot to remove unused picture on nand before copying some files so i go over limit 16 M. I got an error message, and shortly after a simple ls the device reboot automatically...without unmounting, etc.... So i think i crash a part of the FAT, it seem to be a common problem when you overflow the FAT16...yes...i'm a "cinderblock"... ( i looked at many roms of onda ftp server, but there is definitifely no compatible rom). Yes me too... did you try my [matz] - section tip ? Yes, sorry i forgot to return, yes this seem to work, before loosing my nanda i compile a small deadloop and i can boot on with Vol+ or on the kernel if i do nothing but i not do any video or screenlog.... Bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 16 mai 2012 Auteur Share Posté(e) 16 mai 2012 Hello Matzpx8709, Good news ! I can confirm and demonstrate does F20 can boot a minimal peace of code that blinking a led connected to an UART port from the SD/MMC slot. This mean that we can now work on u-boot to adapt it to sun3i configuration..this is nice... Here is the demonstation More info here : http://www.sysfwlab.com/?p=242 Let go to u-boot limb....i become quickly hope i can start your debian image... Guten tag Bin 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 18 mai 2012 Auteur Share Posté(e) 18 mai 2012 (modifié) Salut, Pour info j'ai trouvé de sérieuses différences entre le F20 et le A10, ce qui explique pourquoi u-boot ne démarre pas sur le F20 et il n'existe pas de portage actuellement. Je vais donc m'y coller, je fais déjà un peu de doc histoire d'y voir plus clair et attaquer l'initialisation des horloges du F20 pour essayer de valider un transfert par le port série. Par exemple ici les différences de registres F20/A10 et ici les différences d'horloges F20/A10 que je met en évidences Pour terminer une première synthèse de l'étude de l'initialisation des horloges de u-boot pour le A10 pour essayer de la reproduire sur le F20 OSC24 : 24 MHz // Cadence la totalité de la chaîne en directe ou au travers de PLL0 ├PLL0 : 504 MHz // Multiplie la fréquence de OSC24 et cadence la suite de la totalité de la chaine | └CPU : 504 MHz // U-Boot ne fait pas tourner le A10 à fond, c'est plus sage... | └AXI : 252 MHz | └AHB : 126 MHz | └APB0 : 63 MHz ├─APB1 : 24 MHz // Cadence l'UART0 | └UART0 : 24 MHz // On trouve de nombreux clone 8250 cadencé à 24 MHz pour du 1.5Mbps, c'est cohérent ├─PLL5 : 360 MHz // Cadence la SDRAM | └─SDRAM : 360 MHz // FIXME: Pas d'info sur la SAMSUNG KGA08U0E pour le moment └─NAND : 24 MHz // FIXME: Pas d'info sur la Elixir 1208 pour le moment (Plus d'info ici Initialisation des horloges du A10 par uboot) Bin Modifié 18 mai 2012 par bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 19 mai 2012 Auteur Share Posté(e) 19 mai 2012 (modifié) Salut à tous, J'ai le plaisir de vous annoncer que la procédure d'initialisation des horloges du F20 est en partie reversée. Je suis désormais capable de transmettre des données par le port série à une vitesse cohérente ce qui valide la compréhension de la chaîne d'horloge, la position de la stack et une partie de la carte des registres. Mais cela permettra surtout de créer des macros pour utiliser le port série et ainsi debugger plus facilement le portage u-boot. Voici ce que ca donne lorsqu'on insert la SD avec le "dummy sun3i bootloader v0.04" La video, ou je montre un boot normal, sans la SD, on obtient les messages a 115200 bps de "app_demo.axf" puis avec la SD, mais il faut paramétrer le port série à 56200 bps comme prévu lors de la pré-étude... Bin Modifié 19 mai 2012 par bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratboutgris Posté(e) 24 mai 2012 Share Posté(e) 24 mai 2012 Bonjour, je viens de faire l'acquisition du polaroid MIDCF43. Mon soucis, je ne trouve pas comment mettre L'OS en français. Je suis bien loin de vos travaux, lol mais une tite aide la dessus serais sympa :) . Merci à vous.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bin Posté(e) 25 mai 2012 Auteur Share Posté(e) 25 mai 2012 (modifié) http://forum.frandro...e-vie-du-forum/ Modifié 25 mai 2012 par bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Michael REMY Posté(e) 29 juin 2012 Share Posté(e) 29 juin 2012 bonjour, quel article ! quel temps passé tu as du y mettre ! bravo ! Pour ifnos (si je reprends ton post originale), cette tablette est la même que la Pearl à 59€ ! http://forum.hardwar...jet_24167_1.htm Je pense que ce modèle est une tablette en marque blanche que bcp exploite sous leur marque... Pearl Polaroid, qui d'autres....? si tu pouvais juste mettre une photo du dos, pour voir si les références sur le couvercle sont les mêmes que : Model: PMT-43.wifiItem-No : PX-8709-675 Rating : 5V / 500 mAh WEEE-Reg.-Nr.: DE 60771113 Los-Nr.: 97621-PEARL Importiert von : PEARL Agency GmbH PEARL-Strasse 1-3 D-79426 Buggingen Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
VonOx Posté(e) 30 juin 2012 Share Posté(e) 30 juin 2012 (modifié) Je ne possèdes pas ce jouet mais bin et matz je vous ai lu avec plaisir , merci pour le partage ( je m'abonne pour suivre l'aventure ;) et bookmark ton site au passage ) Dégouté de pas pouvoir vous aider :( Modifié 30 juin 2012 par VonOx Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kenygia Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 (modifié) salut, j'ai un problème j’essaie d’accéder avec adb à la tablette pour la root-complete parce que elle n'est que semi-root (on n'a pas acess aux permissions de fichier). est-ce que Bin ou quelqu'un d'autre pourrait m'aider merci le google play marche mais j'ai pas les acess root sur les permission de fichier sur la tablette avec astro ou le gestionnaire deja installer sur la tablette mais j'ai reussis a avoirs acess avec l'adb :) Modifié 13 juillet 2012 par kenygia Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skiper Posté(e) 24 juillet 2012 Share Posté(e) 24 juillet 2012 (modifié) J'ai obtenu cette mini-tablette après que mon père ai commandé des fournitures de bureau et l'ai reçue gratuitement. Il possède un des CPUs les plus faibles du marché, et vraisemblablement une ROM Android peu adaptée (bêtement compilée, avec des boutons ajoutés à la barre de notification et quelques applications en plus, au moins ils ont inclu ADW Launcher). Antutu Benchmark peine à donner 400 points à cette machine. Angry Birds ramme et Game Dev Story est assez lent (mais très jouable). En revanche, la mini-tablette permet tout de même d'aller sur Internet, d'installer des applications (avec [mention d'application hors charte]) et regarder des vidéos en définition standard ne pose pas le moindre souci. Pour une petite bestiole à 40€/$ (on sait tous que 1 dollar = 1 euro n'est-ce pas :P ), ça ne craint rien et peut servir à n'importe qui de fauché ou pour apprendre à trifouiller ces appareils. Cela fait que j'ai bien envie de m'initier à la création d'une ROM pour cet appareil, en me basant sur Cyanogenmod7 et en essayant de l'optimiser pour rendre le fonctionnement de l'appareil plus fluide (et fournir un accès au Market légal). Les boutons tactiles ne sont pas adaptés et prennent de l'espace sur l'écran alors qu'il y a les boutons physiques. Il n'y a qu'une accélération logicielle pour OpenGL ES (absence d'une puce vidéo apparemment). L'affichage des couleurs apparaît être du 16 millions de couleurs et non en 24 millions de couleurs. A ce prix, je pense qu'il mérite quand même une meilleure ROM et qu'il y a moyen de la rendre plus fluide et utilisable. Je suis donc ce fil avec intérêt. Modifié 24 juillet 2012 par Skiper Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jijiques Posté(e) 13 août 2012 Share Posté(e) 13 août 2012 Bonjour je cherche un pro de cette tablette, j'ai eu cette tablette en cadeau et elle est bloque au démarrage sur le logo POLAROID , et impossible de sortir de cela, même après un reset rien ne change. Y a t-il moyen viale port usb de charger recharger un soft afin qu'elle démarre tout simplement. Merci de prendre le temps de me repondre Cdlt Jiji Bonjour Bin je cherche un pro de cette tablette, j'ai eu cette tablette en cadeau et elle est bloque au démarrage sur le logo POLAROID , et impossible de sortir de cela, même après un reset rien ne change. Y a t-il moyen via le port usb de charger recharger un soft afin qu'elle démarre tout simplement. Merci de prendre le temps de me repondre Cdlt Jiji Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jonathan Cucchiaro Posté(e) 7 janvier 2013 Share Posté(e) 7 janvier 2013 J'ai obtenu cette mini-tablette après que mon père ai commandé des fournitures de bureau et l'ai reçue gratuitement. Il possède un des CPUs les plus faibles du marché, et vraisemblablement une ROM Android peu adaptée (bêtement compilée, avec des boutons ajoutés à la barre de notification et quelques applications en plus, au moins ils ont inclu ADW Launcher). Antutu Benchmark peine à donner 400 points à cette machine. Angry Birds ramme et Game Dev Story est assez lent (mais très jouable). En revanche, la mini-tablette permet tout de même d'aller sur Internet, d'installer des applications (avec [mention d'application hors charte]) et regarder des vidéos en définition standard ne pose pas le moindre souci. Pour une petite bestiole à 40€/$ (on sait tous que 1 dollar = 1 euro n'est-ce pas :P ), ça ne craint rien et peut servir à n'importe qui de fauché ou pour apprendre à trifouiller ces appareils. Cela fait que j'ai bien envie de m'initier à la création d'une ROM pour cet appareil, en me basant sur Cyanogenmod7 et en essayant de l'optimiser pour rendre le fonctionnement de l'appareil plus fluide (et fournir un accès au Market légal). Les boutons tactiles ne sont pas adaptés et prennent de l'espace sur l'écran alors qu'il y a les boutons physiques. Il n'y a qu'une accélération logicielle pour OpenGL ES (absence d'une puce vidéo apparemment). L'affichage des couleurs apparaît être du 16 millions de couleurs et non en 24 millions de couleurs. A ce prix, je pense qu'il mérite quand même une meilleure ROM et qu'il y a moyen de la rendre plus fluide et utilisable. Je suis donc ce fil avec intérêt. Je suis très intéressé par ce sujet et je me demandais si Skiper avait réussit sa rom custom Cyanogen. Ce serait vraiment top. J'aimerai connaitre les bases pour commencer à "cuisiner" et peut être en faire un sur cette petite tablette (ou même sur un autre appareil). Je suis ça de près ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Savrik Posté(e) 17 janvier 2013 Share Posté(e) 17 janvier 2013 Good day! I have Polaroid MIDCF43. I have problem.. I calibrate the screen and then it stops responding to touch .. In addition, drivers are not installed - in Device Manager "Android" with ID vid_18d1 & pid_0002. What do I do now? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skiper Posté(e) 29 mars 2013 Share Posté(e) 29 mars 2013 Je suis très intéressé par ce sujet et je me demandais si Skiper avait réussit sa rom custom Cyanogen. Ce serait vraiment top. J'aimerai connaitre les bases pour commencer à "cuisiner" et peut être en faire un sur cette petite tablette (ou même sur un autre appareil). Je suis ça de près ;) Malheureusement non. Par manque de temps surtout, mais aussi parce qu'il existe spùe tout assez peu d'informations sur cet appareil. Cela nécessite aussi vraisemblablement d'effectuer un travail bas-niveau que ne je sais pas encore faire. Seul des programmeurs déjà initiés peuvent à mon avis toucher à ce truc. Or, il n'y en a quasiment pas qui sont tombés sur cet appareil. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elvis Yao Posté(e) 12 juin 2013 Share Posté(e) 12 juin 2013 Salut, Pour ceux que ça intéresse, voici les dumps des partitions d'origine de la Polaroid MIDCF43 Android 2.3 ORIGINAL POLAROID MIDCF43 ANDROID 2.3 (F20 BOXCHIP) : NANDA - BOOT (Fat16) - b67d9fb7fc5aaf3d0f358359b0288928 - 16,8 Mo je l'ai téléchargé. mais comment faire pour l'installer sur la tablette.? http://www.binbones....tock/nanda.dump NANDB -ROOTFS (Ext2) - a689dc51763072e7cf1af52f4c59ac7e - 16,8 Mo http://www.binbones....tock/nandb.dump NANDC - SYSTEM (Ext4) - ab6a407a72d6fa0335a96a9370cbacbd - 268,4 Mo http://www.binbones....tock/nandc.dump NANDD - DATA (Ext4) - cd3eb54f15d84632f5e1104105b3f9c0 - 536,9 Mo NANDE - SDCARD (Fat32) - 082703878efad148092c854cde4bd984 nande.dump 1,2 Go Bin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Najihel Posté(e) 16 août 2014 Share Posté(e) 16 août 2014 Bonjour, Désolé pour le dé-terrage de topic ^_^ Y a t'il des nouvelles concernant le reverse engineering de cette mini tablette ? Avertissement: En aucun cas je ne pourrai être tenu pour responsable en cas de brick de votre tablette ! Pour ceux désirant utiliser le root sur la tablette, il suffit de : Installer le SDK d'Android pour obtenir le driver générique ADB Modifier le fichier : C:\Program Files (x86)\Android\android-sdk\extras\google\usb_driver\android_winusb.inf : En ajoutant dans les sections [Google.NTx86] et [Google.NTamd64] : ;Polaroid %SingleBootLoaderInterface% = USB_Install, USB\VID_18D1&PID_D00D %SingleAdbInterface% = USB_Install, USB\VID_18D1&PID_0002 %CompositeAdbInterface% = USB_Install, USB\VID_18D1&PID_0002&MI_01 Télécharger et extraire le package suivante : http://cjoint.com/?DHqp2FOs0Wc Lancer les commandes suivantes dans le dossier d'extraction du package : adb remount adb push su /system/bin adb push su /system/xbin adb push busybox /system/xbin/busybox adb shell chmod 4755 /system/bin/su adb shell chmod 4755 /system/xbin/su adb shell chmod 755 /system/xbin/busybox adb install Superuser.apk adb install BusyBox.apk adb shell cd /system/xbin ./busybox --install . sync reboot Vous devriez maintenant avoir les applications SuperSU et BusyBox ainsi que l'accès au root pour les applications :P Bon weekend Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 16 août 2014 Share Posté(e) 16 août 2014 Merci pour la contribution, mais cela correspond à peu près (en moins bien, car il est infiniment préférable d'installer Superuser.apk dans /system/app et que l'installation de Busybox.apk est inutile voire nuisible) à ce qui est expliqué ici : https://forum.frandroid.com/topic/151525-tuto-finalisation-du-root-sur-tablette-pr%C3%A9-root%C3%A9e/ En plus il y a un script pour l'automatiser :) Plus ici pour ce qui est d'ADB : https://forum.frandroid.com/topic/143999-tuto-installation-adb/ C'est vrai que si ce sujet était vaguement dans la bonne section (cela n'a rien à voir avec un portage) tu l'aurais peut-être vu. Il aurait dû être déplacé depuis longtemps. Je le fais, et je modifie le titre pour être conforme aux standards de la section Polaroid. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Najihel Posté(e) 18 août 2014 Share Posté(e) 18 août 2014 Effectivement, merci pour le lien je le garde sous le coude du coup :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
