sebastien djaout Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 (modifié) Lien XDA : http://forum.xda-dev...d.php?t=1643692 Bricked-Kernel One X (endeavoru) The first 100% stable kernel for the HTC One X (endeavoru) (thx HTC for the screwed source btw, fixed it ^^) Features: Based upon HTC source Fixed all stability issues from the HTC source Fixed all section mismatches Various other fixes Sweep2wake More to come... Changelog @ bricked.de What is sweep2wake? How to install? !!!!IMPORTANT!!!! Since the htcdev unlock prevents us from flashing the boot partition from recovery, the installer will ONLY INSTALL THE MODULES & disable the HTC screenshot! (needed as a fixup for sweep2wake, use the AOSP screenshot pwr+vol.down instead) _YOU_ will need to flash the boot.img within the zip (folder: kernel) yourself! (extract it to your desktop so you can use the commands given to you here) I can't stress enough how important this is. _YOU_ will need to flash it. How to do that (full guide, if you use the reboot option given to you by the installer you will only need steps 1 & 4-7) 1. Install HTC drivers (how to do that is explained a hundred times all over the web) 2. Reboot 3. in the boot animation, connect your phone to your computer and do: adb reboot-bootloader 4. You should now see "FASTBOOT USB", if that is the case: fastboot flash boot %USERPROFILE%\Desktop\boot.img 5. fastboot reboot 6. check with: adb shell uname -a if it says bricked. 7. enjoy ofc these steps can also be done before the installer is executed from recovery. Just be sure to complete both. Where to complain about errors/bugs? Please use the Issuetracker for bugs/errors/feature wishes! Issuetracker @ https://code.google....ed/issues/entry showp1984@googlemail.com IRC Chat: Freenode IRC #bricked Download: No Guarantees! If it kills your grandmother or your device, I am NOT responsible! If you understand this: (If you download, please hit Thanks below my post! Thank you!) *v0.7* [STABLE] Click me *betas* [Possibly unstable, for testing only.] Click me Lien XDA : http://forum.xda-dev...d.php?t=1643692 Modifié 4 janvier 2013 par poggus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CastleRoad Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 Bonjour, J'ai modifié le titre et ajouté la source ;) Ca serait bien que l'un d'entre vous puisse faire la traduction. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebastien djaout Posté(e) 9 mai 2012 Auteur Share Posté(e) 9 mai 2012 Désolé si j ai mal fait. moi je comprend les grosses lignes mais traduction minutieuse sa va etre compliqué Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Psyko44 Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 Merci des retours sur ce kernel pas encore eu le temps de le tester je suis pressé celui la je l'attendait avec impatience Envoyé depuis mon HTC One X avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
S0ULP0W3R Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 C'est quoi la différence entre une rom et un kernel? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xaroks Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 le kernel gère les pilotes, l'interaction entre le software et le hardware,... en gros c'est le composant principal de la rom ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
S0ULP0W3R Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 En gros, c'est pour modifier à la source du téléphone alors que la rom permet de modifier la couche "visible" d'Android. Le kernel, c'est l'équivalent du Bios sur windows. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebastien djaout Posté(e) 9 mai 2012 Auteur Share Posté(e) 9 mai 2012 (modifié) Instaler sur evo hd 5.2 marche nikel . je voit pas vraiment de difference avec le stock a part verouiller deverouiller l ecran d un geste sur l ecran.pas plus fluide non plus. pas d overclock. attention l instalation flasher le boot.img via fastboot et ensuite le zip via le recovery. comme toute les roms en ce moment Modifié 9 mai 2012 par tit1313 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xaroks Posté(e) 9 mai 2012 Share Posté(e) 9 mai 2012 En gros, c'est pour modifier à la source du téléphone alors que la rom permet de modifier la couche "visible" d'Android. Le kernel, c'est l'équivalent du Bios sur windows. non pas vraiment c'est l'équivalent du noyau sur windows^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienCaïazzo Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 (modifié) Tenez, Cadeau! Tout n'est pas parfaitement traduit mais je pense avoir fait du bon boulot. Bricked-Kernel One X (endeavoru) Le premier Kernel 100% stable pour HTC One X (endeavoru) (Merci à HTC… ^^) Infos: Basé sur celui de HTC Résolution des problèmes cités par HTC source sont réglés Et ceux de non-adaptation ( ?) Ainsi que d’autres problèmes variés Sweep2wake (Glisser pour Sortir du mode veille) D’autres ajouts sont à venir... Changelog @ bricked.de Qu’est-ce que sweep2wake? Comment Installer? !!!!IMPORTANT!!!! Le system de déblocage via HTC Dev nous empêche de Flasher le Boot depuis le Recovery. Ca ne fera que installer le module et empêchera le screenshot « à la manière d’HTC » (il reste néanmoins la méthode Android via le bouton Power et le volume - ). _VOUS_ devrez flasher vous même le Boot à partir du zip (Dossier: Kernel) (l'extraire sur votre bureau afin d’ utiliser les commandes fournies). Je vous rappelle qu’il est réellement important de flasher le boot ! Comment faire (Guide complet, Si vous choisissez l’option de redémarrage propose par l’installeur, vous n’aurez besoin que de l’étape 1 puis les étapes 4 à 7) 1. Installer les drivers HTC (Si vous ne savez pas comment faire, jetez un coup d’œil sur Internet) 2. Redémarrez 3. Pendant l’animation de démarrage, connectez votre téléphone à votre ordinateur et faites: adb reboot-bootloader 4. Vous devriez voir "FASTBOOT USB", si c’est le cas tapez: fastboot flash boot %USERPROFILE%\Desktop\boot.img 5. Redémarrez le fastboot 6. Testez avec: adb shell uname -a si il dit bricked. ( ?) 7. Enjoy file:///C:\DOCUME~1\Adrien\LOCALS~1\Temp\msohtml1\01\clip_image001.gif NdA : Ces étapes peuvent aussi être effectuées avant que l’installeur soit exécuté du Recovery. Mais soyez sûrs de compléter les deux. Où envoyer les plaintes et bugs ? Utilisez l’Issuetracker (détecteur de bug) pour les bugs /erreures /et souhaits! Issuetracker @ https://code.google....ed/issues/entry showp1984@googlemail.com IRC Chat: Freenode IRC #bricked Liens: Aucune garantie! Si ca fait décéder votre mamie ou votre téléphone, je ne suis pas responsable! Pensez à remercier l’auteur sur sa page XDA par un clic sur « Thanks » *v0.21* [sTABLE] Click me *betas* [Peut être instable seulement à l’état de test.] Click me Modifié 10 mai 2012 par Zokaï Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xaroks Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 niveau autonomie ça donne quoi? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacko57 Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 D'après ce que j' ai compris il faut mettre le boot.img via fastboot puis aller dans le recovery et installer le zip aussi ??? Après avoir fait l'instal, on dois remettre la rom ou alors on ne perd rien ??? Merci. ^_^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CastleRoad Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 Merci à toi Zokai :) Je laisse le soin à tit1313 de modifier le premier post si il veut bien Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Samoht59 Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 D'après ce que j' ai compris il faut mettre le boot.img via fastboot puis aller dans le recovery et installer le zip aussi ??? Après avoir fait l'instal, on dois remettre la rom ou alors on ne perd rien ??? Merci. ^_^ Tu le fais dans l‘ordre que tu veux. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
philos64 Posté(e) 10 mai 2012 Share Posté(e) 10 mai 2012 (modifié) D'après ce que j' ai compris il faut mettre le boot.img via fastboot puis aller dans le recovery et installer le zip aussi ??? Après avoir fait l'instal, on dois remettre la rom ou alors on ne perd rien ??? Merci. ^_^ Normalement non, car cela peut entrainer des bugs. La logique voudrait que l'on flashe en premier le fichier boot.img via fastboot de la rom à installer Ensuite sans rebooter, aller dans le recovery (toujours dans le bootloader), installer la rom et rebooter, pour finaliser l'installation., Ensuite, retourner dans le bootloader, flasher via fastboot, le fichier boot.img du kernel. Ne pas rebooter, retourner dans le recovery et flasher les modules afin qu'ils soient pris en charge par la rom. Seconde solution: Flasher le boot.img du kernel choisi via fastboot dans le bootloader, sans rebooter, aller dans le recovery, installer la rom sélectionnée (ne pas installer le kernel proposé dans la rom si install avec Aroma installer) Flash de la rom effectué, toujours sans rebooter, installer les modules complémentaires du kernel choisi via le recovery, puis une fois que tout est installé on reboot (boot qui peux prendre un certain temps) C'est ce qu'il est conseiller de faire pour l'heure tant que l'on ne pourra pas passer S-OFF. Il fonctionne bien avec la CoreDroid, puisque je le teste actuellement avec la version V3 (en approche finale). Sinon, concernant le flash de ce kernel ou même pour d'autres opérations via fastboot: Télécharger ce fichier "Fastboot" que vous installez à la racine de C:\fastboot Vous le dézippez et vous devez obtenir 3 fichiers: - adb - AdbWinApi.dll - fastboot (qui est l'application) Une fois le fichier dézippé dans le dossier "fastboot", vous n'avez qu'à insérer le fichier boot.img que vous voulez flasher via le fastboot en utilisant les commandes adb => exemple : c:\fastboot flash boot boot.img vous validez la commande par Entrée. Le fichier des modules sera à installer sur votre carte mémoire de votre One X pour le flasher via le recovery CWM. Modifié 28 mai 2012 par philos64 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
resaik Posté(e) 3 septembre 2012 Share Posté(e) 3 septembre 2012 bonjour a tous peut on installé le kernel seul apres avoir installé la rom svp ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
