[ROM][DEV][ICS][23 May - b36] AOKP builds for Vision [unofficial]
je viens vers vous pour savoir si l'un de vous a testé cette ROM (android 4.0)?
Elle a de bon échos sur xda et j'hésite entre celle ci et l'Andromadus test builds.
Vous trouverez les détails de cette ROM ici:
http://forum.xda-dev...d.php?t=1642443
Aller, un petit edit pour une présentation plus propre ;-) :
Introduction:
I would like to present you Android Open Kang Project builds for HTC Vision.
Rom is based on Android 4.0 (ICS) and have a lot of customization options.
It's also DEV thread, so if you have a some problems with rom, first, try to find fix by yourself. If you can't - add post with description of your problem and LOGCAT.
I don't do this for any purposes, I just want to learn something new, so if you want to thanks thnk about AOKP Team and/or Andromadus Team smile.gif
Special thanks goes to AOKP dev team (Team Kang) and Andromadus Team!
Github: github.com/adamz667
What's working:
- everything should be fine
What's not working:
- in build 36:
-- Start-up tweaks - WIP
If you're installing it for first time (coming from other rom) do FULL WIPE.
How to install:
1) Put rom and GApps on your sd card.
2) Go to CWM (or other) Recovery.
3) Do a nand backup.
4) Do a full wipe (fist installation - coming from other rom) or just wipe cache/dalvik cache (update).
5) Flash rom.
6) Flash GApps.
7) Reboot (first boot can take a while).
Changelog:
23-05-2012 / build 36
- System hang-ups on opening app setting menu or other - fixed
- Volume +/- (short press) when Volume Music Controls enabled not working - fixed
- Added Trackpad Wake switch
- Possibly faster WiFi/2G/3G switch
- Some other merge stuff/fixes
16-05-2012 / build 36
- Fixed Recent App switcher (Sense 4 style/WebOS/Stock)
- Fixed WiFi Tether toggle causing SystemUI crash
- Added USB Tether Toggle
- Fixed keyboard backlight in right way
- Enabled tile rendering for tests
------ build 36 changes -----------------------
- updated Mms emoji code from CM
- added delayed ring feature to Phone
- fixed a bug when hiding sender information, photo would still show
- default ICS wallpapers have returned
- added SwagPapers (AOKP Wallpapers)
- updated theme engine from CM
- fixed volume slider showing incorrect volume in a voice call (making it look like it wasn't full)
14-05-2012 / build 35
- Cleaned all mess
- Everything should be faster and smoother
- Added Trebuchet launcher, Speech Recorde, Movie Studio
- Added 2g/3g, Mobile Data, Tether AP etc toggles
- Themes are working now
- Other stuff from AOKP build 35
11-05-2012:
- Fixed Camcorder
- Fixed Camera led flash (only in AUTO mode)
8-05-2012:
- Initial release
- Camcorder is not working right now (will be fixed)
- Camera led is not working right now (will be fixed)
- Keyboard backlight works only with autobrighntess (will be fixed)
Voila !!
Modifié par jophilo
Cool. Fais nous un petit retour de test si tu as le temps...... J'en ferais également un si j'ai le temps de l'installer et la tester ce week-end end. Oui, finalement je vais commencer par celle ci et selon le résultat je testerais l'Andromadus test builds :P .
