Loader de fichier .obj
Bonjour à tous.
En voulant compiler le code suivant une erreur que je n'arrive pas à réparer survient...
Voici le code :
package com.example.objLoader;
import android.app.Activity;
import android.opengl.GLSurfaceView;
import android.os.Bundle;
import android.os.Debug;
import android.os.Handler;
import android.os.Message;
import android.telephony.CellLocation;
* The initial Android Activity, setting and initiating
* the OpenGL ES Renderer Class @see Lesson02.java
* @author Savas Ziplies (nea/INsanityDesign)
public class ObjLoaderApp extends Activity {
/** The OpenGL View */
* Initiate the OpenGL View and set our own
* Renderer (@see Lesson02.java)
@Override
protected void onCreate(Bundle savedInstanceState) {
Debug.startMethodTracing("calc");
super.onCreate(savedInstanceState);
setContentView(new MyRenderer(this));
* Remember to resume the glSurface
@Override
protected void onResume() {
super.onResume();
* Also pause the glSurface
@Override
protected void onPause() {
Debug.stopMethodTracing();
super.onPause();
@Override
protected void onDestroy(){
import java.io.BufferedReader;
import java.io.FileInputStream;
import java.io.IOException;
import java.io.InputStreamReader;
import java.util.Vector;
import android.content.Context;
import android.util.Log;
public class OBJParser {
int numVertices=0;
int numFaces=0;
Context context;
Vector<Short> faces=new Vector<Short>();
Vector<Short> vtPointer=new Vector<Short>();
Vector<Short> vnPointer=new Vector<Short>();
Vector<Float> v=new Vector<Float>();
Vector<Float> vn=new Vector<Float>();
Vector<Float> vt=new Vector<Float>();
Vector<TDModelPart> parts=new Vector<TDModelPart>();
Vector<Material> materials=null;
public OBJParser(Context ctx){
context=ctx;
public TDModel parseOBJ(String fileName) {
BufferedReader reader=null;
String line = null;
Material m=null;
try { //try to open file
reader = new BufferedReader(new InputStreamReader(new FileInputStream(fileName)));
} catch(IOException e){
try {//try to read lines of the file
while((line = reader.readLine()) != null) {
Log.v("obj",line);
if(line.startsWith("f")){//a polygonal face
processFLine(line);
else
if(line.startsWith("vn")){
processVNLine(line);
else
if(line.startsWith("vt")){
processVTLine(line);
else
if(line.startsWith("v")){ //line having geometric position of single vertex
processVLine(line);
/*else
if(line.startsWith("usemtl")){
try{//start of new group
if(faces.size()!=0){//if not this is not the start of the first group
TDModelPart model=new TDModelPart(faces, vtPointer, vnPointer, m,vn);
parts.add(model);
String mtlName=line.split("[ ]+",2)[1]; //get the name of the material
for(int i=0; i<materials.size(); i++){//suppose .mtl file already parsed
m=materials.get(i);
if(m.getName().equals(mtlName)){//if found, return from loop
break;
m=null;//if material not found, set to null
catch (Exception e) {
// TODO: handle exception
else
if(line.startsWith("mtllib")){
materials=MTLParser.loadMTL(line.split("[ ]+")[1]);
Material mat=materials.get(i);
Log.v("materials",mat.toString());
System.out.println("wtf...");
if(faces!= null){//if not this is not the start of the first group
parts.add(model);
TDModel t=new TDModel(v,vn,vt,parts);
t.buildVertexBuffer();
Log.v("models",t.toString());
return t;
private void processVLine(String line){
String [] tokens=line.split("[ ]+"); //split the line at the spaces
int c=tokens.length;
for(int i=1; i<c; i++){ //add the vertex to the vertex array
v.add(Float.valueOf(tokens));
private void processVNLine(String line){
vn.add(Float.valueOf(tokens));
private void processVTLine(String line){
vt.add(Float.valueOf(tokens));
private void processFLine(String line){
if(tokens[1].matches("[0-9]+")){//f: v
if(c==4){//3 faces
Short s=Short.valueOf(tokens);
s--;
faces.add(s);
else{//more faces
Vector<Short> polygon=new Vector<Short>();
for(int i=1; i<tokens.length; i++){
s--;
polygon.add(s);
faces.addAll(Triangulator.triangulate(polygon));//triangulate the polygon and add the resulting faces
if(tokens[1].matches("[0-9]+/[0-9]+")){//if: v/vt
if(c==4){//3 faces
Short s=Short.valueOf(tokens.split("/")[0]);
s--;
faces.add(s);
s=Short.valueOf(tokens.split("/")[1]);
s--;
vtPointer.add(s);
else{//triangulate
Vector<Short> tmpFaces=new Vector<Short>();
Vector<Short> tmpVt=new Vector<Short>();
s--;
tmpFaces.add(s);
s--;
tmpVt.add(s);
faces.addAll(Triangulator.triangulate(tmpFaces));
vtPointer.addAll(Triangulator.triangulate(tmpVt));
if(tokens[1].matches("[0-9]+//[0-9]+")){//f: v//vn
if(c==4){//3 faces
Short s=Short.valueOf(tokens.split("//")[0]);
s--;
faces.add(s);
s=Short.valueOf(tokens.split("//")[1]);
s--;
vnPointer.add(s);
else{//triangulate
Vector<Short> tmpVn=new Vector<Short>();
s--;
tmpFaces.add(s);
s--;
tmpVn.add(s);
vnPointer.addAll(Triangulator.triangulate(tmpVn));
if(tokens[1].matches("[0-9]+/[0-9]+/[0-9]+")){//f: v/vt/vn
if(c==4){//3 faces
s--;
faces.add(s);
s--;
vtPointer.add(s);
s=Short.valueOf(tokens.split("/")[2]);
s--;
vnPointer.add(s);
else{//triangulate
//Vector<Short> tmpVt=new Vector<Short>();
s--;
tmpFaces.add(s);
//s=Short.valueOf(tokens.split("/")[1]);
//s--;
//tmpVt.add(s);
//s=Short.valueOf(tokens.split("/")[2]);
//s--;
//tmpVn.add(s);
vtPointer.addAll(Triangulator.triangulate(tmpVn));
public class RGBColor {
float R;
float G;
float B;
public RGBColor(float r, float g, float B) {
super();
R = r;
G = g;
B = b;
public float getR() {
return R;
public void setR(float r) {
R = r;
public float getG() {
return G;
public void setG(float g) {
G = g;
public float getB() {
return B;
public void setB(float B) {
B = b;
public String toString(){
String str=new String();
str+="R:"+R+" G:"+G+" B:"+B;
return str;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
import java.nio.FloatBuffer;
import javax.microedition.khronos.opengles.GL10;
public class TDModel {
Vector<Float> v;
Vector<Float> vn;
Vector<Float> vt;
Vector<TDModelPart> parts;
FloatBuffer vertexBuffer;
public TDModel(Vector<Float> v, Vector<Float> vn, Vector<Float> vt,
Vector<TDModelPart> parts) {
super();
this.v = v;
this.vn = vn;
this.vt = vt;
this.parts = parts;
str+="Number of parts: "+parts.size();
str+="\nNumber of vertexes: "+v.size();
str+="\nNumber of vns: "+vn.size();
str+="\nNumber of vts: "+vt.size();
str+="\n/////////////////////////\n";
for(int i=0; i<parts.size(); i++){
str+="Part "+i+'\n';
str+=parts.get(i).toString();
str+="\n/////////////////////////";
return str;
public void draw(GL10 gl) {
gl.glVertexPointer(3, GL10.GL_FLOAT, 0, vertexBuffer);
gl.glEnableClientState(GL10.GL_VERTEX_ARRAY);
TDModelPart t=parts.get(i);
Material m=t.getMaterial();
if(m!=null){
FloatBuffer a=m.getAmbientColorBuffer();
FloatBuffer d=m.getDiffuseColorBuffer();
FloatBuffer s=m.getSpecularColorBuffer();
gl.glMaterialfv(GL10.GL_FRONT_AND_BACK,GL10.GL_AMBIENT,a);
gl.glMaterialfv(GL10.GL_FRONT_AND_BACK,GL10.GL_SPECULAR,s);
gl.glMaterialfv(GL10.GL_FRONT_AND_BACK,GL10.GL_DIFFUSE,d);
gl.glEnableClientState(GL10.GL_NORMAL_ARRAY);
gl.glNormalPointer(GL10.GL_FLOAT, 0, t.getNormalBuffer());
gl.glDrawElements(GL10.GL_TRIANGLES,t.getFacesCount(),GL10.GL_UNSIGNED_SHORT,t.getFaceBuffer());
//gl.glDisableClientState(GL10.GL_VERTEX_ARRAY);
//gl.glDisableClientState(GL10.GL_COLOR_ARRAY);
gl.glDisableClientState(GL10.GL_NORMAL_ARRAY);
public void buildVertexBuffer(){
ByteBuffer vBuf = ByteBuffer.allocateDirect(v.size() * 4);
vBuf.order(ByteOrder.nativeOrder());
vertexBuffer = vBuf.asFloatBuffer();
vertexBuffer.put(toPrimitiveArrayF(v));
vertexBuffer.position(0);
private static float[] toPrimitiveArrayF(Vector<Float> vector){
float[] f;
f=new float[vector.size()];
for (int i=0; i<vector.size(); i++){
f=vector.get(i);
return f;
import java.nio.ShortBuffer;
public class TDModelPart {
Vector<Short> faces;
Vector<Short> vtPointer;
Vector<Short> vnPointer;
Material material;
private FloatBuffer normalBuffer;
ShortBuffer faceBuffer;
public TDModelPart(Vector<Short> faces, Vector<Short> vtPointer,
Vector<Short> vnPointer, Material material, Vector<Float> vn) {
super();
this.faces = faces;
this.vtPointer = vtPointer;
this.vnPointer = vnPointer;
this.material = material;
ByteBuffer byteBuf = ByteBuffer.allocateDirect(vnPointer.size() * 4*3);
byteBuf.order(ByteOrder.nativeOrder());
normalBuffer = byteBuf.asFloatBuffer();
for(int i=0; i<vnPointer.size(); i++){
float x=vn.get(vnPointer.get(i)*3);
float y=vn.get(vnPointer.get(i)*3+1);
float z=vn.get(vnPointer.get(i)*3+2);
normalBuffer.put(x);
normalBuffer.put(y);
normalBuffer.put(z);
normalBuffer.position(0);
ByteBuffer fBuf = ByteBuffer.allocateDirect(faces.size() * 2);
fBuf.order(ByteOrder.nativeOrder());
faceBuffer = fBuf.asShortBuffer();
faceBuffer.put(toPrimitiveArrayS(faces));
faceBuffer.position(0);
if(material!=null)
str+="Material name:"+material.getName();
else
str+="Material not defined!";
str+="\nNumber of faces:"+faces.size();
str+="\nNumber of vnPointers:"+vnPointer.size();
str+="\nNumber of vtPointers:"+vtPointer.size();
return str;
public ShortBuffer getFaceBuffer(){
return faceBuffer;
public FloatBuffer getNormalBuffer(){
return normalBuffer;
private static short[] toPrimitiveArrayS(Vector<Short> vector){
short[] s;
s=new short[vector.size()];
s=vector.get(i);
return s;
public int getFacesCount(){
return faces.size();
public Material getMaterial(){
return material;
public class Triangulator{
public static Vector<Short> triangulate(Vector<Short> polygon){
Vector<Short> triangles=new Vector<Short>();
for(int i=1; i<polygon.size()-1; i++){
triangles.add(polygon.get(0));
triangles.add(polygon.get(i));
triangles.add(polygon.get(i+1));
return triangles;
public class Material {
String name;
float[] ambientColor; //ambient color
float[] diffuseColor;
float[] specularColor;
float alpha;
float shine;
int illum;
String textureFile;
public Material(String name){
this.name=name;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public float[] getAmbientColor() {
return ambientColor;
public FloatBuffer getAmbientColorBuffer(){
FloatBuffer f;
ByteBuffer b = ByteBuffer.allocateDirect(12);
b.order(ByteOrder.nativeOrder());
f = b.asFloatBuffer();
f.put(ambientColor);
f.position(0);
return f;
public void setAmbientColor(float r, float g, float B) {
ambientColor = new float[3];
ambientColor[0]=r;
ambientColor[1]=g;
ambientColor[2]=b;
public float[] getDiffuseColor() {
return diffuseColor;
public FloatBuffer getDiffuseColorBuffer(){
FloatBuffer f;
f.put(diffuseColor);
f.position(0);
return f;
public void setDiffuseColor(float r, float g, float B) {
diffuseColor = new float[3];
diffuseColor[0]=r;
diffuseColor[1]=g;
diffuseColor[2]=b;
public float[] getSpecularColor() {
return specularColor;
public FloatBuffer getSpecularColorBuffer(){
FloatBuffer f;
f.put(specularColor);
f.position(0);
return f;
public void setSpecularColor(float r, float g, float B) {
specularColor = new float[3];
specularColor[0]=r;
specularColor[1]=g;
specularColor[2]=b;
public float getAlpha() {
return alpha;
public void setAlpha(float alpha) {
this.alpha = alpha;
public float getShine() {
return shine;
public void setShine(float shine) {
this.shine = shine;
public int getIllum() {
return illum;
public void setIllum(int illum) {
this.illum = illum;
public String getTextureFile() {
return textureFile;
public void setTextureFile(String textureFile) {
this.textureFile = textureFile;
str+="Material name: "+name;
str+="\nAmbient color: "+ambientColor.toString();
str+="\nDiffuse color: "+diffuseColor.toString();
str+="\nSpecular color: "+specularColor.toString();
str+="\nAlpha: "+alpha;
str+="\nShine: "+shine;
return str;
public class MTLParser {
public static Vector<Material> loadMTL(String file){
Vector<Material> materials=new Vector<Material>();
String line;
Material currentMtl=null;
reader = new BufferedReader(new InputStreamReader(new FileInputStream(file)));
if(reader!=null){
if(line.startsWith("newmtl")){
if(currentMtl!=null)
materials.add(currentMtl);
String mtName=line.split("[ ]+",2)[1];
currentMtl=new Material(mtName);
else
if(line.startsWith("Ka")){
String[] str=line.split("[ ]+");
currentMtl.setAmbientColor(Float.parseFloat(str[1]), Float.parseFloat(str[2]), Float.parseFloat(str[3]));
else
if(line.startsWith("Kd")){
currentMtl.setDiffuseColor(Float.parseFloat(str[1]), Float.parseFloat(str[2]), Float.parseFloat(str[3]));
else
if(line.startsWith("Ks")){
currentMtl.setSpecularColor(Float.parseFloat(str[1]), Float.parseFloat(str[2]), Float.parseFloat(str[3]));
else
if(line.startsWith("Tr") || line.startsWith("d")){
currentMtl.setAlpha(Float.parseFloat(str[1]));
else
if(line.startsWith("Ns")){
currentMtl.setShine(Float.parseFloat(str[1]));
else
if(line.startsWith("illum")){
currentMtl.setIllum(Integer.parseInt(str[1]));
else
if(line.startsWith("map_Ka")){
currentMtl.setTextureFile(str[1]);
return materials;
import javax.microedition.khronos.egl.EGLConfig;
import android.opengl.GLU;
import android.opengl.GLSurfaceView.Renderer;
import android.view.KeyEvent;
import android.view.MotionEvent;
public class MyRenderer extends GLSurfaceView implements Renderer {
/** Triangle instance */
private OBJParser parser;
private TDModel model;
/* Rotation values */
private float xrot; //X Rotation
private float yrot; //Y Rotation
/* Rotation speed values */
private float xspeed; //X Rotation Speed ( NEW )
private float yspeed; //Y Rotation Speed ( NEW )
private float z = 50.0f;
private float oldX;
private float oldY;
private final float TOUCH_SCALE = 0.4f; //Proved to be good for normal rotation ( NEW )
private float[] lightAmbient = {1.0f, 1.0f, 1.0f, 1.0f};
private float[] lightDiffuse = {1.0f, 1.0f, 1.0f, 1.0f};
private float[] lightPosition = {0.0f, -3.0f, 2.0f, 1.0f};
private FloatBuffer lightAmbientBuffer;
private FloatBuffer lightDiffuseBuffer;
private FloatBuffer lightPositionBuffer;
public MyRenderer(Context ctx) {
super(ctx);
parser=new OBJParser(ctx);
model=parser.parseOBJ("C:/Documents and Settings/p-naegelen/Bureau/export.obj");
this.setRenderer(this);
this.requestFocus();
this.setFocusableInTouchMode(true);
ByteBuffer byteBuf = ByteBuffer.allocateDirect(lightAmbient.length * 4);
lightAmbientBuffer = byteBuf.asFloatBuffer();
lightAmbientBuffer.put(lightAmbient);
lightAmbientBuffer.position(0);
byteBuf = ByteBuffer.allocateDirect(lightDiffuse.length * 4);
lightDiffuseBuffer = byteBuf.asFloatBuffer();
lightDiffuseBuffer.put(lightDiffuse);
lightDiffuseBuffer.position(0);
byteBuf = ByteBuffer.allocateDirect(lightPosition.length * 4);
lightPositionBuffer = byteBuf.asFloatBuffer();
lightPositionBuffer.put(lightPosition);
lightPositionBuffer.position(0);
* The Surface is created/init()
public void onSurfaceCreated(GL10 gl, EGLConfig config) {
gl.glLightfv(GL10.GL_LIGHT0, GL10.GL_AMBIENT, lightAmbientBuffer);
gl.glLightfv(GL10.GL_LIGHT0, GL10.GL_DIFFUSE, lightDiffuseBuffer);
gl.glLightfv(GL10.GL_LIGHT0, GL10.GL_POSITION, lightPositionBuffer);
gl.glEnable(GL10.GL_LIGHT0);
gl.glShadeModel(GL10.GL_SMOOTH);
gl.glClearColor(0.0f, 0.0f, 0.0f, 0.5f);
gl.glClearDepthf(1.0f);
gl.glEnable(GL10.GL_DEPTH_TEST);
gl.glDepthFunc(GL10.GL_LEQUAL);
gl.glHint(GL10.GL_PERSPECTIVE_CORRECTION_HINT, GL10.GL_NICEST);
* Here we do our drawing
public void onDrawFrame(GL10 gl) {
//Clear Screen And Depth Buffer
gl.glClear(GL10.GL_COLOR_BUFFER_BIT | GL10.GL_DEPTH_BUFFER_BIT);
gl.glLoadIdentity();
gl.glEnable(GL10.GL_LIGHTING);
gl.glTranslatef(0.0f, -1.2f, -z); //Move down 1.2 Unit And Into The Screen 6.0
gl.glRotatef(xrot, 1.0f, 0.0f, 0.0f); //X
gl.glRotatef(yrot, 0.0f, 1.0f, 0.0f); //Y
model.draw(gl); //Draw the square
xrot += xspeed;
yrot += yspeed;
* If the surface changes, reset the view
public void onSurfaceChanged(GL10 gl, int width, int height) {
if(height == 0) { //Prevent A Divide By Zero By
height = 1; //Making Height Equal One
gl.glViewport(0, 0, width, height); //Reset The Current Viewport
gl.glMatrixMode(GL10.GL_PROJECTION); //Select The Projection Matrix
gl.glLoadIdentity(); //Reset The Projection Matrix
//Calculate The Aspect Ratio Of The Window
GLU.gluPerspective(gl, 45.0f, (float)width / (float)height, 0.1f, 500.0f);
gl.glMatrixMode(GL10.GL_MODELVIEW); //Select The Modelview Matrix
gl.glLoadIdentity(); //Reset The Modelview Matrix
@Override
public boolean onTouchEvent(MotionEvent event) {
float x = event.getX();
float y = event.getY();
//If a touch is moved on the screen
if(event.getAction() == MotionEvent.ACTION_MOVE) {
//Calculate the change
float dx = x - oldX;
float dy = y - oldY;
//Define an upper area of 10% on the screen
int upperArea = this.getHeight() / 10;
//Zoom in/out if the touch move has been made in the upper
if(y < upperArea) {
z -= dx * TOUCH_SCALE / 2;
//Rotate around the axis otherwise
} else {
xrot += dy * TOUCH_SCALE;
yrot += dx * TOUCH_SCALE;
//A press on the screen
} else if(event.getAction() == MotionEvent.ACTION_UP) {
//Remember the values
oldX = x;
oldY = y;
//We handled the event
return true;
@Override
public boolean onKeyUp(int keyCode, KeyEvent event) {
if(keyCode == KeyEvent.KEYCODE_DPAD_LEFT) {
} else if(keyCode == KeyEvent.KEYCODE_DPAD_RIGHT) {
} else if(keyCode == KeyEvent.KEYCODE_DPAD_UP) {
z -= 3;
} else if(keyCode == KeyEvent.KEYCODE_DPAD_DOWN) {
z += 3;
} else if(keyCode == KeyEvent.KEYCODE_DPAD_CENTER) {
return true;
Et voici la liste d'erreurs que m'affiche le logcat :
06-04 13:00:19.563: E/AndroidRuntime(27399): FATAL EXCEPTION: main
06-04 13:00:19.563: E/AndroidRuntime(27399): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.objLoader/com.example.objLoader.ObjLoaderApp}: java.lang.NullPointerException
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1748)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1764)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.app.ActivityThread.access$1500(ActivityThread.java:122)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1002)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.os.Handler.dispatchMessage(Handler.java:99)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.os.Looper.loop(Looper.java:132)
06-04 13:00:19.563: E/AndroidRuntime(27399): at android.app.ActivityThread.main(ActivityThread.java:4025)
06-04 13:00:19.563: E/AndroidRuntime(27399): at java.lang.reflect.Method.invokeNative(Native Method)
06-04 13:00:19.563: E/AndroidRuntime(27399): at java.lang.reflect.Method.invoke(Method.java:491)
06-04 13:00:19.563: E/AndroidRuntime(27399): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:841)
06-04 13:00:19.563: E/AndroidRuntime(27399): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:599)
06-04 13:00:19.563: E/AndroidRuntime(27399): at dalvik.system.NativeStart.main(Native Method)
06-04 13:00:19.563: E/AndroidRuntime(27399): Caused by: java.lang.NullPointerException
06-04 13:00:19.563: E/AndroidRuntime(27399): at com.example.objLoader.OBJParser.parseOBJ(OBJParser.java:42)
06-04 13:00:19.563: E/AndroidRuntime(27399): at com.example.objLoader.MyRenderer.<init>(MyRenderer.java:50)
06-04 13:00:19.563: E/AndroidRuntime(27399): at com.example.objLoader.ObjLoaderApp.onCreate(ObjLoaderApp.java:29)
Si quelqu'un à une idée du problème qu'il fasse signe. :)
Merci d'avance.
Modifié par lucho9
