A retirer merci[30/07]
Leufeudedieu
Bonjour "Amis du G1",
c'est pour avoir un minimum de compréhension et des détails pour les "Amis du G1".
Qualcomm MSM7201 RISC Chipsept
http://pdadb.net/index.php?m=cpu&id=...alcomm_msm7201
Type: MSM7201
Manufacturer: Qualcomm
Year Released: 2008
Predecessor: 32bit Qualcomm MSM7200
Characteristics
CPU Structure (complexity): RISC
Width of Machine Word: 32 bit
Primary (RAM) Data bus: 32 bit
Instruction Set
Supported Instruction Set(s): ARMv6
CPU Core: ARM1136EJ-S
Clock Frequencies
Recommanded Maximum Clock Frequency: 528 MHz
Technology
Semiconductor Technology: CMOS
Minimum Feature Size: 90 nm
Additional Details
Special Features: ARM9 coprocessor, Embedded QDSP4000 and QDSP5000 DSP (GSM, GPRS/EGPRS Multislot Class 12, EDGE, UMTS/WCDMA, HSDPA, HSUPA, MBMS baseband), Embedded gpsOne GPS module, Qcamera, Qtv, Qcamcorder, Qvideophone
MSM7201
Technical Features
* Supports WCDMA/HSUPA and EGPRS networks
* Multimedia Broadcasting Multicast Service (MBMS)
* Integrated ARM11™ applications processor and ARM9™ modem
* QDSP4000™ and QDSP5000™ high-performance digital signal processors (DSP)
* 528 MHz ARM11 Jazelle™ Java® hardware acceleration
* Support for BREW® and Java applications
* Qcamera™: Up to 6.0 megapixel digital images
* Qtv™: Playback up to 30 fps VGA
* Qcamcorder™: Record up to 24 fps QVGA
* Up to 4 million triangles per second, and 133 million depth-tested, textured 3D pixels per second fill rate
* gpsOne® position-location assisted-GPS (A-GPS) solution
* Support for third-party operating systems
* Digital audio support for MP3, aacPlus™ and Enhanced aacPlus
* Integrated Mobile Digital Display Interface (MDDI), Bluetooth® 1.2 baseband processor and Wi-Fi® support
Ont peu lire plus haut :
1) Recommanded:
je vois bien maximum recommandé :roll:
2)528 MHz ARM11 Jazelle™ Java® hardware accélération
L'overclock du Cpu ne se fait que de deux facons la 1er augmenter la fréquence du bus (Pllcc) la 2em augmenter son coefficient multiplicateur,selon les Cpu il y a différentes manières d'opérer.
Ex :
pour un cpu de 300Mhz,cela peu-etre 3 par 100Mhz mais aussi 3.5 par 85Mhz,le processeur qui tourne le plus vite est celui dont le bus est le plus important,ce système a été repris et mis en place par Pentium,lorsqu'il a sortie son pentium2 350,400,450,500Mhz,car il lui suffisez de changer a l'époque sur les cartes mères la position des cavaliers pour modifier le multiplicateur et donc avec le mm Cpu et la mm chaine de fabrication !,vendre des configuration différentes a moindre coup,malin si tu etait,tu achetais un 350Mhz,tu rentrais a la maison,tu ouvrais et modifier les cavaliers tu retrouvais avec un 500Mhz pour le prix d'un 350.
je crois que cette méthode n'a pas changé avec certains !
Pour notre G1,nous avons:
384400,518400,537600,556800,576000,595200,614400,633600,652800,672000
il y a un écart de 192000 entre chaque,c'est sur le multiplicateur que l'on va jouer (2 fois 192=384,ect,ect).
On vous explique ici en Anglais plus dans le détail :
http://forum.xda-developers.com/showthread.php?t=665515
[Overclock]:
Le facteur chance
On dit aussi parfois que des processeurs venant de telle ou telle usine ont plus ou moins de propensions à l’overclocking. Il est vrai en effet que la qualité d’un processeur dépend du wafer dont il est issu et que la qualité ce dernier dépend des conditions environnementales dans lesquelles il est produit. Bref, vous aurez compris qu’il est quasi impossible de déterminer avec certitude que tel ou tel lot de processeurs sera un roi de l’overclocking. Le facteur chance lors de l’achat intervient et c’est en parcourant les forums spécialisés que vous pourrez trouver des informations sur les semaines de production ayant tendance à monter haut en fréquence. Ce n’est que dans ce cas que vous pourrez tenter d’acheter un processeur de telle ou telle semaine pour autant que vous arriviez à en trouver et pour autant que le vendeur vous laisse vérifier la semaine de production. Pour information, la semaine se trouve gravée sur l’IHS du processeur sous la forme de 0415 par exemple. 04 représente l’année (2004) et 15 la semaine de fabrication .
Il y a aussi la stabilité du system d'exploitation qui rentre en compte,de part le passé avec la mm tour (300A celeron),je ne pouvais aller plus que 385Mhz avec Win Me,alors qu'avec mon Win98 Plus,je dépassais les 415Mhz.
Des exemples,ou l'ont constate la différence entre le mm CPU et le mm téléphone :
Alors moi avec la rom envoyée par LFD en MP hier soir (je ne sais pas laquelle c'est, je m'y perds :P ) overclockée à 595 MHz.
sinon:
# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
633600
j'ai pas encore osé pouuser plus loin ...
+1. Je suis limité à une fr&quence maxi entre 585 MHZ et 614 MHZ sur le mien :). Sauf en charge! où le 672 MHz fonctionne ( un peu)...
Le mien avec le cable USB est stable a 672000Mhz,sinon sans cable,no soucis a 633200Mhz avec la Cyanogen,avec ma SlimFast sans Usb,aucuns mal-fonctionnement a 672000Mhz,pourtant le mm G1,donc ca viens bien du system.
C'est peu-etre pour ca que Orange a bloqué a 385000Mhz,pour la pereinité de son system et la batterie.
Pour overclocker son G1,deux méthodes a ma connaissance,le première consiste a trouver le bon le fichier wlan.ko ou le modifier,la deuxième la mm chose mais avec le fichier boot.img (pas dans mes compétences la modification).
OVERCLOCK DE L'ÉVOLUTION ICI :
Méthode 1 :
flash avec le zip ci-dessous et copiez le fichier .txt a la racine de la SD ici et paramétrez sur "performance" et "set on boot",bloqué a 576Mhz :
Fichier txt :
http://www.mediafire.com/?jmzl1qvmh2y
Overclock-576-Evolution-by-Lfd.zip :
http://www.mediafire.com/?owzwj5hj2nz
Méthode 2 :
que je préfère,car l'overclock est fait directement dans le system et non pas par l'intermédiaire d'un soft,d'où la stabilité chez moi a 652800Mhz.
juste aprés la 1er install de la ROM :
Télécharger le boot.img et placer l'image dans le dossier tools du SDK :
http://www.mediafire.com/?ingvnqmdnm1
#!/system/bin/sh
echo 528000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo “echo 528000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq” >> /sd-ext/userinit.sh
adb shell reboot bootloader
fastboot flash boot oc-cm-5.0.7-v2-boot.img
fastboot reboot
tu re-boot et ca :
ici mettre la valeur souhaitée :
(122880, 128000, 245760, 384000, 528000, 537600, 556800, 576000, 595200, 614400, 633600, 652800)
quand vous testez l'overclock,gardez tjrs le mode debug activé,car celui-ci vous permet avant le boot complet de changer la fréquences par adb :
dés que la demande de code pin se fait,ca évite les freezes a l'accueil et d'enlever la batterie (et si vous avez SetCpu que je déconseille évitez de mettre "set on boot" pendant les tests).
8-) C'est Lefeudedieu,
le bench passe de 3.6 a 4.6,
alors quelques test du CPU sur mon G1,a été torturé toute une bonne partie la matinée,une bonne méthode de vieil Overclocker !
Ultime Évolution a 826Mhz :
Évolution 3 avec theme et tout mes apk :
Asta luego :ugeek:
Voila,je voulais récapituler un peu,pour que ceux qui s'y perdent,s'y retrouvent et comprennent mieux le fonctionnement,je ne suis pas du tout Linuxien,donc si certains ont des combines ou autres a ajouter,cela sera bienvenu.
Modifié par Leufeudedieu
Bon pour le App2sd,voila comment je procède pour verifier :
1)ai 55.26mo de libre ok
2)j'installe le jeu Mag3DLite.SF3D.v1.3.1 (7.51mo)
3)me reste 40.59 mo de libre
4)J'active le APpps2SD
5)Je Move :wink:
6)me reste 48.10mo
Il manque donc que le poids de l'application après avoir appliqué le APpps2SD,alors qu'avant il en manquait 15mo !! pour d'autres Applics beaucoup plus légères ca bouge pas :wink:,c'est la meilleure facon de faire que j'ai trouvé et elle marche,ont peu faire par lots,c'est pas classique c'est sur.
il faut REBOOTER et le FC n'est plus !
Je rajoute que mm avec le Apps2SD active ca marche !
Alors comme DAB,mon Ami de Panam est venu a la rescousse LOL !
Ok. Je viens de tester, avec l'appli facebook et ça fonctionne.
avant de mover, en tapant la commande
Code:
ls /sd-ext/app/
sur le téléphone, rien n'apparait.
En revanche avec
Code:
ls /data/app/
j'ai bien
Code:
com.facebook.katana.apk
Après le "move", la commande
Code:
ls /data/app/
ne fait plus apparaitre l'apk de FaceBook, en revanche il apparait avec la commande
Code:
ls /sd-ext/app/
l'appli a donc bien été transférée.
Elle se lance sans soucis.
si je déplace les applis en utilisant la commande "mv" comme elle est donnée sur le
wiki de cyanogen, je suis obligé de redemarrer pour que les applis fonctionnent.
Après, il faut voir si les gens qui ont des FC ont bien employé ces méthodes !
S'ils ont déplacé en utilisant le menu de la recovery par exemple ça ne marchera pas.
maharajadhiraj a dit.
Et Lefeudedieu dit merci.
Vu que je sais même pas ce que c'est que cette 1.86 je sent que je vais souffrir (je suis en 1.6 de base sfr)...
Mais bon, je vais regarder ça cet aprem, après m'être motivé à faire mes CV...
Déjà faut que je fasse fonctionner le sdk ^^
salut LFD
bon apres un apres midi a voir pour installer toutes mes applis , hourra celas marche nickel ,toutes mes applis installer et aucune force close,
par contre j'ai installer la rom d'origine , telecharge sur xda-developers.com,compend pas pourquoi je ne pouvais pas installer sur la sd ext en passant par app2sd,,
tout est fonctionnel ,le wifi ,mail, clavier azerty, tv orange et tv mobile ,l'appareil photo et la camera ,
j'ai installer home++,
a voir l'overcloock demain
Pour la batterie,
From cyanogen's wiki:
Battery recalibration
If you're experiencing higher than normal battery drain, try the following:
1. Charge the phone to full battery; power off and let it keep charging until the light is green.
2. Boot to recovery mode and go to console (or adb shell) and type:
mount -a
rm /data/system/batterystats.bin
1. Reboot the phone and use it normally, but don't charge until it shuts off.
2. Recharge the phone completely and then use as you normally would.
La commande mount-a,marche pas chez moi ???
merci , je vi[color=red][b]ent[/b][/color] d'installer la Cyanogen "Evolution 2" No jitHack (Apps2SD) :
, sans wipe ,
tres bien le boot animé,
manque plus que l'overcloock , j'ai vu la page meme traduite , j'ai du mal,
en plus mon usb fonctionne pas donc pas de concole sdk,
au moins la rom marche tres bien aucune fc
merci
"On ne pas être au four,au moulin et vendre la baguette"
voudrais tu bosser avec moi sur cette Rom ?
Pourquoi pas =) perso je m'en suit fait une vite fait pour tester et ça tourne super bien =)
Ok ca marche LFD merci
:D
Moi ok aussi, mais je ne suis pas super dispo en ce moment.
Mais j'essairai de passer sur le forum régulièrement pour voir ce que je peux faire :)
Voila,la prochaine sera le travail commun
Salut nero' date='
je te sollicite,car je crois que l'ont peu sortir une trés Rom en bossant ensembles,sachant que Alex et Goldo s'occupe du reste ensemble pour mettre au gout du jour les tutos,no soucis si cela n'est pas a ton gout :wink:
C'est une super idée dans l'ensemble :)[/quote']
Je trouve que c'est une très bonne idée et je suis flatté que tu ais pensé à moi, mais je suis quelqu'un d'overbooké,je n'aurais pas vraiment le temps d'y travailler sérieusement, désolé.
Un serveur Ftp ;)
Merci a nero.
ici Toulouse 8)
Merci a tous ;)
, sans wipe ,
merci
Merci a toi tazbob,
de ta présence,oui elle marche nikel,mais tu ne pourra pas dépasser les 3.0,mm avec l'overclock,comme tu peu le voir plus haut sommes presque au bout de nos peines,le Apps2SD,ca y est,je confirme fonctionne avec le JitHack,ca se peaufine,comme dab ca va tourner grave!
(Tes Mp sur SPF !)
Sauf que la cela sera une Lfd Rousted by maharajadhiraj et Jp :cool:
Salut, petit retour .
Installation aucun problème
Premiere priise en main ,fluide .rapide,pas de force close ,pour le moment 45 applis installé reste 51mo dans la mémoire interne,je vais installé une grosse applis (20mo)pour voir.
Overclock pas effectuer, je ne peux pas dans mon camion,et par le terminal du dream je n,ai pas les codes.
Petit problème après la prise et l'enregistrement d'une photo l'application camera se ferme ?????
Ou sinon merci a vous tous super rom
merci tazbob,
d'avoir testé ma ROM,moi aussi petit retour :
l'application photo ne ce ferme pas chez moi comme toi,mais âpres avoir pris la photo l'écran vacille gris 1s et la photo est prise correctement (vérifié),la vidéo nikel.
La batterie semble,le point faible car,la consommation varie mm en veille,hier a consommé dans la nuit 32% et ce matin 72% (test fait avec 1600/2200mha) et :roll: hier dans la journée rien quasiment,cyano précise que ce ne sont pas tous les G1,qui sont concernés,âpres un wipe batterie et le patch,ca va mieux.
Après installation des Applics aucuns soucis concernant le Apps2SD,tout marche bien,le Market,mise a jour,Google,Gmail,ect.
Je suis a 652Mhz depuis hier,sans l'utilisation de Setcpu et elle tourne a merveille,chacuns trouvera la fréquence d'overclock approprié a son G1,puisque nous savons que cela ne fonctionne aléatoirement,voici une liste des possibilitées 528000, 537600, 556800, 576000, 595200, 614400, 633600, 652800 et surtout,je préconise l'overclock sans Setcpu qui crée des Freeze qui ne sont pas sans le soft.
Voila,le seul Blem,c'est que lorsque mon G1 re-boot il repasse seul en 3G,je ne sais si cela vient du theme que j'ai installé ou de la ROM ou mon G1,sachant que cela fonctionne très bien avec mes autres ROMS,ce n'est pas une panne.
J'espère que ce retour vous sera utile pour votre choix
:wink:
EDIT : En fait je crois que ca vient du fait que je suis en tethering mais je suis pas certain.
Sinon j'ai une autre question pourquoi faire un zip supplémentaire pour les appli plutot que de les integrer directement dans la rom ? Et enfin a quoi sert : AmbientTime ?
je mets de liens Mediafire,sinon AmbientTime est un écran de veille en screen,il est le 3em ou l'heure est affichée.
Sinon,pourquoi deux ?
1)car tu peu,si cela n'est pas a ton gout,te passer du pack que j'ai fait et telecharger celui de cyanogen sur le Xda et tu aura la ROM en français avec le JitHack et le Helix launcher et toutes les Applics Google.
2)c'est plus simple,si il y a des MAJ pour moi et pour vous a telecharger et plus rapide a installer.
3)Chacuns a la possibilité de ce faire sa ROM a son gout,thèmes,overclock,applications avec ma base
Edit :4)je ne voulais d'une ROM avec Orange tv integré :twisted: pour les liens seul nero pourra nous répondre.
:roll:
salut LFD apres installation de l'Ultime1 Evolution by Lfd-signed
un petit retour rapide
installation sans wipe , tres bien passé, toute,
toutes mes aplications pesente et sans fc, sauf la gallerie disparue ?
sans trop chercher j'ai installé (maj-cam-music-signed et Ultime-pack-signed) la gallerie revenu et fonctionnelle,
52 apps installé toutes fonctionnent,
overcloock a 614 Mhz pas de ralentissement, avec limpack MFLOPS:4.123 ,time 1.31 ,norm res 3.36
wifi , sms , alarme (reveil),tv mobile :RAS
autonomie pas teste
donc rom tres rapide , fiable , stable ,
pour pas changé,
bravo LFD et merci
autonomie pas teste
pour pas changé,
bravo LFD et merci
Merci tazbob,
désolé des mises a jour cette nuit donc une v1.2 :rolleyes:
