[ROM] MoDaCo Gr6 (v20o) stock+vanilla
Invité El-Demoniiiak
Voici une ROM basée sur la stock 2.3.4 LG V20o pour le 2X, elle a été créée par PaulOBrien.
La MoDaCo Gr6 (v20o) stock+vanilla ^_^
- Pour utiliser cette ROM, vous devez avoir installé un recovery ClockworkMod.
(La ROM doit être installée en utilisant ClockworkMod).
- Le baseband 0725 V20l est recommandé (utilisez GetRiL pour le RIL correspondant).
- Le ROM est installée à vos risques et périls. "Une lingette est fortement recommandée". :P
Changelog:
  • Rebuilt, compressed and optimised with the MCR build system
  • Stock Kernel and MoDaCo Custom kernel options (pending new kernel source release)
  • Removed OTA update notificatoin (saving a lot of RAM)
  • Spoofed fingerprint (for maximum items listed in market)
  • All Google components are running the latest release including Google Talk with video / voice chat
  • Superuser application and su binary from ChainsDD for SAFE root functionality
  • Multitouch Optimisations
  • SD card speed optimisations
  • Status bar clock size fix
  • CyanogenMod APN list
  • Boot sound removed
  • SQLite performance patch
  • init.d support
  • terminfo support (for nano etc.)
  • Semi transparent notification pulldown
  • Custom boot animation
  • Alternative frameworks to disable toggle buttons / music controls on notification pulldown
  • Stock (AOSP style) lockscreen
  • Stock Google apps including Contacts, Calendar, Desk Clock, Gallery, MMS, Keyboard and much more
  • Amazon Appstore, GetJar and SlideME Markets now in the kitchen (I use SlideME as the only place to buy Quadrant Advanced!)
  • Stock Gingerbread theme
  • Settings-integrated Toggle2G by TheMasterBaron
  • Camera application with no camcorder sound
  • Not odexed
  • On demand odex app
  • Touch Key Lights brightness configuration utility
  • Reboot to recovery utility
  • Many system sounds can be disabled
  • Remove battery full popup
  • Market Access application
  • Button Backlight Alert compatibility
  • Much much much more!
Pour installer cette ROM:
* Téléchargez le fichier .zip de votre choix (Gr6 core + LG ou vanilla ) à partir des liens du forum MoDaCo copiez-les sur votre carte SD (/ sdcard / _ExternalSD) - vous devez utiliser une carte microSD physique!
* Redémarrez votre appareil en recovery ClockworkMod (restez appuyé sur la bouton power et le bouton de volume bas),
* Wipe data / cache,
* Wipe cache,
* Wipe dalvik cache,
* Sélectionnez l'option "install zip from sd card" et sélectionnez le fichier "Back2toext3" (http://tinyurl.com/76kultt )
* Effectuer une sauvegarde Nandroid (facultatif mais recommandé),
* Sélectionnez l'option "install zip from sd card", et sélectionnez le fichier .zip que vous avez copié sur votre carte mémoire (Gr6 core)
* Sélectionnez l'option "install zip from sd card", et sélectionnez l'autre fichier .zip que vous avez copié sur votre carte mémoire (Gr6 option pack stock ou vanilla).
* Revenez à la racine du recovery et sélectionnez "reboot system now" :lol:
Topic MoDaCo de la ROM: http://www.modaco.co...n-stockvanilla/
Bonus:
  • LG 2X Recovery boot (pour reboot en mode recovery sans s'énerver) :ph34r:
  • LG 2X Touch Key Brightness (pour régler la luminosité des 4 boutons tactiles du 2X) :ph34r:
Téléchargement des bonus: http://www.modaco.co...pps-for-the-2x/
Quelques screenshots:
"Enjoy! biggrin.gif"
Modifié par El-Demoniiiak
Je ne permettrai pas de juger le travail de Paul Obrien, mais j'ai l'impression de faire un bond dans le passé en regardant les screenshots ;-)
Je me souviens des ROM Modaco sur mon HTC Hero, c'était pas loin d'être le top à l'époque !
En attendant, je reste sur CM9 ;-)
Cette rom n'est certes pas récente mais elle est en 2.3.4, et l'interface vanilla gingerbread n'est pas si dépassée ^_^
Oui. À part CyanogenMod et les MoDaCo, on n'a pas de rom AOSP :)
(La gueste 2x est hybride CM / Stock LG aussi).
D'un coté faire du AOSP quand le téléphone est suivi par la CM team c'est un peu une perte de temps...
Mais Modaco, c'est du miam miam incroyable, de mémoire c'est Paul Obrien qui a le premier porté le recovery sur o2x et qui a rendu l'utilisation d'une rom stock utilisable (via ces tweaks et correction). Il a l'air sympa (le genre d'anglais qu'on ne peut qu'aimer, et sa femme à l'air adorable ! (son twitter est tellement drôle parfois!)
