J'essaie d'unlocker le bootloader de mon x10 avec flashtool:
20/039/2012 16:39:33 - INFO - Please connect your device into flashmode.
20/039/2012 16:39:43 - INFO - Device connected in flash mode
20/039/2012 16:39:44 - INFO - Opening device for R/W
20/039/2012 16:39:44 - INFO - Reading device information
20/039/2012 16:39:44 - INFO - Phone ready for flashmode operations.
20/039/2012 16:39:44 - INFO - Flashing loader
20/039/2012 16:39:50 - INFO - Loader : S1_Loader_Root_f851 - Version : R4A024 / Bootloader status : UNROOTABLE
20/039/2012 16:39:50 - INFO - Start Reading property
20/039/2012 16:39:50 - INFO - Reading TA finished.
20/039/2012 16:39:50 - INFO - Ending flash session
20/039/2012 16:39:50 - INFO - Found semcSL
20/039/2012 16:39:50 - INFO - You can now unplug and turn on device, then plug it again
20/039/2012 16:39:50 - INFO - Waiting for device
20/039/2012 16:39:50 - INFO - Device connected in flash mode
20/039/2012 16:39:52 - INFO - Device disconnected
20/039/2012 16:39:53 - INFO - Device connected in flash mode
20/040/2012 16:40:14 - INFO - Device disconnected
20/040/2012 16:40:15 - INFO - Device connected with USB debugging off
20/040/2012 16:40:15 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/041/2012 16:41:15 - INFO - Device disconnected
20/042/2012 16:42:01 - INFO - Device connected with USB debugging on
20/042/2012 16:42:04 - INFO - Pushing C:\Flashtool\custom\features\UnlockBL\files\qsd825 0\qsd8250bootwrite_semcSL to /data/local/tmp
20/042/2012 16:42:08 - INFO - Pushing C:\Flashtool\custom\features\UnlockBL\files\qsd825 0\mapper_2.6.29-00054-g5f01537.ko to /data/local/tmp
20/042/2012 16:42:08 - INFO - Pushing C:\Flashtool\custom\features\UnlockBL\files\qsd825 0\fixPart to /data/local/tmp
20/042/2012 16:42:09 - INFO - Running runfixPart as root thru sysrun
20/042/2012 16:42:10 - INFO - Successfully applied fixPart. Rebooting
20/042/2012 16:42:12 - INFO - Waiting for device
20/042/2012 16:42:12 - INFO - Device disconnected
20/042/2012 16:42:26 - INFO - Device connected with USB debugging off
20/042/2012 16:42:26 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/042/2012 16:42:30 - INFO - Device disconnected
20/042/2012 16:42:33 - INFO - Device connected with USB debugging on
20/042/2012 16:42:55 - INFO - Running runbootwrite as root thru sysrun
20/042/2012 16:42:56 - INFO - Successfully applied unlock. Rebooting
20/042/2012 16:42:57 - INFO - Running runClean as root thru sysrun
20/042/2012 16:42:59 - INFO - Device disconnected
20/043/2012 16:43:12 - INFO - Device connected with USB debugging off
20/043/2012 16:43:12 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/043/2012 16:43:19 - INFO - Device connected with USB debugging on
20/043/2012 16:43:19 - INFO - Connected device : X10
20/043/2012 16:43:19 - INFO - Installed version of busybox : BusyBox v1.19.3-Stericson (2011-11-01 20:22:18 CDT) multi-call binary.
20/043/2012 16:43:19 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-00054-g5f01537
Est ce que mon bootloader est bien déverrouillé ?
Car je n'arrive pas à le vérifier avec s1tool (pas de détection)
Pas sûr du tout, car d'après cette ligne il semblerait que tu ne puisses pas déverrouiller
M'enfin après c'est cette ligne
Donc ptet bin qu'oui, ptet bin qu'non :P
Modifié par desspil
J'ai donc tenter de flasher le kernel :
21/044/2012 11:44:35 - INFO - Selected X10_CUSTOM.ftf
21/044/2012 11:44:35 - INFO - Preparing files for flashing
21/044/2012 11:44:35 - INFO - Please connect your device into flashmode.
21/044/2012 11:44:48 - INFO - Device connected in flash mode
21/044/2012 11:44:48 - INFO - Opening device for R/W
21/044/2012 11:44:48 - INFO - Reading device information
21/044/2012 11:44:48 - INFO - Phone ready for flashmode operations.
21/044/2012 11:44:48 - INFO - Start Flashing
21/044/2012 11:44:48 - INFO - Flashing loader
21/044/2012 11:44:52 - INFO - Loader version : r4A024 / Bootloader status : ROOTED
21/044/2012 11:44:52 - INFO - Flashing kernel.sin
21/044/2012 11:44:54 - INFO - Flashing finished.
21/044/2012 11:44:54 - INFO - Please wait. Phone will reboot
21/044/2012 11:44:54 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
21/044/2012 11:44:54 - INFO - Device connected in flash mode
21/044/2012 11:44:56 - INFO - Device disconnected
21/044/2012 11:44:56 - INFO - Device connected in flash mode
21/045/2012 11:45:17 - INFO - Device disconnected
21/045/2012 11:45:21 - INFO - Device connected with USB debugging off
21/045/2012 11:45:21 - INFO - For 2011 devices line, be sure you are not in MTP mode
21/046/2012 11:46:57 - INFO - Device disconnected
21/046/2012 11:46:59 - INFO - Device connected with USB debugging on
21/046/2012 11:46:59 - INFO - Connected device : X10
21/046/2012 11:46:59 - INFO - Installed version of busybox : BusyBox v1.19.3-Stericson (2011-11-01 20:22:18 CDT) multi-call binary.
21/046/2012 11:46:59 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-FXP
21/046/2012 11:46:59 - INFO - Root Access Allowed
21/049/2012 11:49:33 - INFO - Device disconnected
Le flash s'est bien passé ?
