écran bleu après code pin
Je viens de le faire, c'est 0.3GB pour Flashtool mais c'est toujours pareil, pourtant ca à l'air de tout s'installer comme il faut:
16/026/2012 22:26:16 - INFO - <- This level is successfully initialized
16/026/2012 22:26:16 - INFO - Flashtool Version 0.8.0.0 built on 2012-05-27 21:57:12
16/026/2012 22:26:16 - INFO - You can drag and drop ftf files here to start flashing them
16/026/2012 22:26:22 - INFO - Device disconnected
16/026/2012 22:26:35 - INFO - Device connected with USB debugging on
16/026/2012 22:26:37 - INFO - Connected device : X10
16/026/2012 22:26:37 - INFO - Installed version of busybox : N/A
16/026/2012 22:26:37 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-00054-g5f01537
16/026/2012 22:26:38 - INFO - Root Access Allowed
16/026/2012 22:26:44 - INFO - Installing Recovery to device...
16/026/2012 22:26:44 - INFO - Pushing C:\Flashtool\.\devices\X10\busybox\1.19.0\busybox to /data/local/tmp/busybox
16/026/2012 22:26:45 - INFO - Remounting system read-write
16/026/2012 22:26:48 - INFO - Installing chargemon feature / kernel bootkit to device...
16/026/2012 22:26:48 - INFO - Pushing C:\Flashtool\.\devices\X10\busybox\1.19.0\busybox to /data/local/tmp/busybox
16/026/2012 22:26:49 - INFO - Remounting system read-write
16/026/2012 22:26:50 - INFO - Pushing C:\Flashtool\.\devices\X10\bootkit\bootkit.tar to /data/local/tmp
16/026/2012 22:26:50 - INFO - Running installbootkit as root thru sysrun
16/026/2012 22:26:51 - INFO - bootkit successfully installed
16/026/2012 22:26:51 - INFO - Pushing C:\Flashtool\.\devices\X10\recovery\0.3GB\recovery.tar to /data/local/tmp/recovery.tar
16/026/2012 22:26:52 - INFO - Running installrecovery as root thru sysrun
16/026/2012 22:26:52 - INFO - Recovery successfully installed
16/026/2012 22:26:58 - INFO - Rebooting into recovery mode
16/026/2012 22:26:58 - INFO - Running rebootrecovery as root thru sysrun
16/026/2012 22:26:59 - INFO - Phone will reboot into recovery mode
16/027/2012 22:27:00 - INFO - Device disconnected
Modifié par 2dede
Je viens de remettre ma carte sim dans mon xperia (on sait jamais), ca n'a pas marché mais j'ai eu une amélioration:
Après avoir entré mon code pin je n'ai pas eu un écran bleu mais le téléphone c'est allumé normalement sauf que j'ai eu la carte sim barré dans la barre de notifications. Mais:
-dans le menu principal j'ai la boite a outils sim (orange +) qui va avec ma carte sim, et je peux entrer dedans mais quand je clique sur, par exemple: mon compte puis suivi conso j'ai un carré qui apparait avec dans son coin supérieur droit le dessin d'une carte sim avec un rouage.
-par contre je peux paramétrer ma carte, par exemple j'ai pu enlever mon code pin.
Donc j'ai enlever mon code pin, puis j'ai rallumé mon téléphone:
-plus de sim barré mais quand je vais dans la boite a outils sim j'ai toujours la même chose.
-quand je vais dans réseaux mobiles puis opérateur de réseau et que je sélectionne orange, en bas de l'écran il y a écrit: votre carte sim ne vous autorise pas à vous connecter à ce réseau.
Je comprend plus rien ca marche à moitié, le téléphone reconnait la carte sim, je peux l'utiliser pour tout faire sauf téléphoner :rolleyes:
Quelqu'un a une idée ?
Modifié par 2dede
J'y avais pensé, mais sur un samsung wave 575 elle marche correctement, est-ce que ca serait possible que le vendeur est mal fait le désimlockage ?
Modifié par 2dede
Effectivement, je pense que je vais aller retourner voir le vendeur, en espérant qu'il ne me refasse pas payer <_< , et lui demander si il peut faire quelque chose; sinon je garderais mon ancien téléphone.
En tout cas merci quand même de vous être intéressés à mon problème et d'avoir été patient :D
Modifié par 2dede
