Flash IMPOSSIBLE avec mon X10
Sa fais déjà depuis plus d'une semaine que je tente de flasher mon X10 mais a chaque fois sa me mes :
Soit (pour le bootloader unlock):
14/024/2012 18:24:45 - INFO - <- This level is successfully initialized
14/024/2012 18:24:45 - INFO - Flashtool Version 0.8.0.0 built on 2012-05-27 21:57:12
14/024/2012 18:24:45 - INFO - You can drag and drop ftf files here to start flashing them
14/024/2012 18:24:52 - INFO - Device connected with USB debugging on
14/024/2012 18:24:53 - INFO - Connected device : X10
14/024/2012 18:24:53 - INFO - Installed version of busybox : BusyBox v1.19.0 (2011-08-14 23:46:58 CDT) multi-call binary.
14/024/2012 18:24:53 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-00054-g5f01537
14/024/2012 18:24:53 - INFO - Root Access Allowed
14/025/2012 18:25:01 - INFO - Please connect your device into flashmode.
14/025/2012 18:25:06 - INFO - Device disconnected
14/025/2012 18:25:49 - INFO - Device connected in flash mode
14/025/2012 18:25:50 - INFO - Opening device for R/W
14/025/2012 18:25:50 - INFO - Flashing loader
14/025/2012 18:25:50 - INFO - Ending flash session
14/025/2012 18:25:50 - WARN - Cancelled
14/025/2012 18:25:50 - INFO - Device connected in flash mode
14/025/2012 18:25:58 - INFO - Please connect your device into flashmode.
14/025/2012 18:25:59 - INFO - Opening device for R/W
14/025/2012 18:25:59 - INFO - Reading device information
14/026/2012 18:26:06 - INFO - Flashing loader
14/026/2012 18:26:06 - INFO - Ending flash session
14/026/2012 18:26:06 - WARN - Cancelled
14/026/2012 18:26:07 - INFO - Device disconnected
14/026/2012 18:26:15 - INFO - Device connected with USB debugging off
14/026/2012 18:26:15 - INFO - For 2011 devices line, be sure you are not in MTP mode
Soit (pour n'importe quelle flash):
14/039/2012 18:39:57 - INFO - <- This level is successfully initialized
14/039/2012 18:39:57 - INFO - Flashtool Version 0.8.0.0 built on 2012-05-27 21:57:12
14/039/2012 18:39:57 - INFO - You can drag and drop ftf files here to start flashing them
14/040/2012 18:40:03 - INFO - Device disconnected
14/040/2012 18:40:04 - INFO - Selected X10_2.3.3_DooMKernel-v06-1113-BootManager-v2.0.ftf
14/040/2012 18:40:04 - INFO - Preparing files for flashing
14/040/2012 18:40:04 - INFO - Please connect your device into flashmode.
14/040/2012 18:40:16 - INFO - Device connected in flash mode
14/040/2012 18:40:16 - INFO - Opening device for R/W
14/040/2012 18:40:16 - INFO - Reading device information
14/040/2012 18:40:16 - INFO - Phone ready for flashmode operations.
14/040/2012 18:40:16 - INFO - Start Flashing
14/040/2012 18:40:16 - INFO - Flashing loader
14/040/2012 18:40:16 - INFO - Ending flash session
14/040/2012 18:40:16 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="SECURITY_CLASS";ERR_DYNAMIC="SIN header verification failed"�
14/040/2012 18:40:16 - ERROR - Error flashing. Aborted
14/040/2012 18:40:17 - INFO - Device connected in flash mode
14/040/2012 18:40:18 - INFO - Device disconnected
14/040/2012 18:40:19 - INFO - Device connected in flash mode
Voila mon phone est Rooter et dispose de android 2.3.3
Help
Modifié par Liace
voila.
moi j y suis arriver en flashant le
firmware Officiel 2.3.3
en suivant ce tuto
il m a fallu tout refaire heureusement que j avais fait une sauvegarde
bon je ne suis pas fort dans se domaine aussi :)
voila si sa peu t aider Newbie
a plus
