Original Xperia S Rom V7 & music edition for Arc
Salut la communauté !
Je suis intéressé par cette ROM : http://forum.xda-dev...d.php?t=1565990
mais j'ai quelques souci de compréhension (même en utilisant google translate) :
1) Flash ICS 4.0.3_562 ftf Rom as base Rom using flashtool , Flash every thing that is in ftf package, and then turn on your phone after fully start power off it
2) Now download the kernel V22 from here and flash it in your phone using fastboot.
3) start your phone go into recovery
3.1) do a factory reset
3.2) wipe cache partition
3.3) wipe delvic cache
04) Now flash the main rom
05) Those who have Arc-S they should also Flash Patch for Arc-S.Zip
06) now flash the kernel modules
07) Now reboot your phone after successfully start power it off and flash Baseband 64 with fota files .
be sure when you are going to flash baseband 64 into your phone did not flash the vendor.sin file, please exclude vendor.sin file from baseband 64 before flashing
08) now enjoy latest Rom with great battery life
Je ne comprends pas l' étape 7.
Quelqu'un aurait l'amabilité de m'expliquer ?
Modifié par trapua
  • 1 month later...
