franco10 Posté(e) 2 août 2012 Share Posté(e) 2 août 2012 salut,, je suis entrain de faire module authentification avec android je travail avec sdk 4.0.3 et mysql pour accéder au base de donnée mysql j'utilise web service la table user contient deux attributs : login,mail et j'ai comme valeur : test,test le code que j'utilise est : package com.android.gd; import java.io.BufferedReader; import java.io.InputStream; import java.io.InputStreamReader; import org.apache.http.HttpResponse; import org.apache.http.client.methods.HttpGet; import org.apache.http.impl.client.DefaultHttpClient; import org.ksoap2.SoapEnvelope; import org.ksoap2.serialization.SoapObject; import org.ksoap2.serialization.SoapSerializationEnvelope; import org.ksoap2.transport.HttpTransportSE; import android.app.Activity; import android.os.AsyncTask; import android.os.Bundle; import android.view.View; import android.widget.TextView; import android.widget.Toast; public class ProjectGDActivity extends Activity { //private TextView textView; private String METHOD_NAME ="authentification"; // our webservice method name private String NAMESPACE ="http://gd.com"; // Here package name in // webservice with reverse // order. private String SOAP_ACTION = NAMESPACE + METHOD_NAME; // NAMESPACE + method // name private static final String URL ="http://192.168.1.98:8082/wsgd/services/gd?wsdl"; // you TextView tv; TextView tv2; /** Called when the activity is first created. */ @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.main); TaskWs task = new TaskWs(); task.execute(); } private class TaskWs extends AsyncTask<String, Void, String> { @Override protected void onPostExecute(String result) { tv.setText(result); } @Override protected String doInBackground(String... params) { String v="addi"; Object result = v ; tv = (TextView) findViewById(R.id.Ch_Login); tv2 = (TextView) findViewById(R.id.Ch_Passwd ); try { SoapObject request = new SoapObject(NAMESPACE, METHOD_NAME); request.addProperty("login", "test"); request.addProperty("mail", "test"); SoapSerializationEnvelope envelope = new SoapSerializationEnvelope( SoapEnvelope.VER11); envelope.dotNet = true; envelope.setOutputSoapObject(request); HttpTransportSE androidHttpTransport = new HttpTransportSE(URL); androidHttpTransport.call(SOAP_ACTION,envelope); result = envelope.getResponse(); //((TextView) findViewById (R.id.txtAddition)).setText("Addition : "+result.toString()); } catch (Exception E) { E.printStackTrace(); //((TextView) findViewById (R.id.txtAddition)).setText("ERROR:" + E.getClass().getName() + ":" + E.getMessage()); } // TODO Auto-generated method stub return result.toString(); } } public void readWebpage(View view) { } } et j'ai dans le projet web qui contient le web service cette methode "authentification" public boolean authentification(String login,String mail){ UsersHome u=new UsersHome(); UsersId us=new UsersId(login, mail); List<Users> listu=u.findByCriteria(us); if(listu.size()>0){ System.err.println("succes"); return true; } else{ System.err.println("echec"); return false; } } mais je trouve des problème avec cet exemple puisque il se plante dans l'interface d'authentification merci d'avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bernardvincent Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 Bonjour, je crois simplement que les services web SOAP ne sont pas atteignables depuis un client android. Je bute dessus depuis pas mal de temps, j'ai écumé le web et jamais trouvé la solution au plantage de la fonction qui appelle le service : androidHttpTransport.call(SOAP_ACTION,envelope); l'erreur est là, mais personne ne sait expliquer. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
