Mik51 Posté(e) 5 juin 2010 Share Posté(e) 5 juin 2010 (modifié) VanillaEclair 3.3 RC1 What's new: - fixed battery drain - actually now the battery life is excellent - improved kernel - button lights - no more graphical glitches - improved overall performance and stability What has been done to the kernel: - pre-OC @691MHz on / 176MHz off -> you can still use OverclockingWidget/SetCPU to set your own desired frequencies, but I suggest you use it as it is. - enhanced scheduler - better usage of CPU resources - battery life tweaks - EXT2/3 are supported; my suggestion would be to use EXT2 - enabled button lights - other minor enhancements to improve overall system performance and stability What works: - GPS, A-GPS - camera - calls - bluetooth file transfer - tested with another phone and my BT printer - trackball - Facebook sync - google sync, mail, everything related to google - 2G/3G - busybox, su - A2SD - auto enabled - Dalvik-Cache moved to SD - WiFi - accelerometer(10x heyodee) - youtube HD from froyo ...the list is pretty long, so I'll skip to the part I really hate writing What doesn't work: - auto brightness(as in other AOSP ROMs) -> I will fix it soon - A2DP - now that I have a BT headset(thanks again Mark!) I can work on it Included soft(among the usual ones): - 2D Gallery - Spare Parts - google stuff(maps too) - Cyanogen's launcher, as it is better than the buggy vanilla one - terminal emulator Notes: 1. PLEASE PERFORM A NANDROID BACKUP 2. PLEASE WIPE EVERYTHING 3. At the first boot, you will be asked which of the following you would like to start: com.android.provision.DefaultActivity or Setup Wizard. Choose setup wizard. After you have finnished setting it up, the setup will run again. Just press home and reboot. Everything will be fine afterwards. If you have any issues, please post your logcat too. Pastebin links prefered. http://roms.pxmedia.nl/VanillaEclair_3.3RC1_NAS_signed.zip Modifié 5 juin 2010 par Mik51 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
NeB Posté(e) 5 juin 2010 Share Posté(e) 5 juin 2010 Honnetement , perso je préfererais que tu mettes la version originale anglaise , que j'aurais beaucoup moins de mal à comprendre que la traduction approximative de google ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dezerd Posté(e) 5 juin 2010 Share Posté(e) 5 juin 2010 Je me suis fait la même remarque ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mik51 Posté(e) 5 juin 2010 Share Posté(e) 5 juin 2010 j'avou mdr que les expressions reste vague :D Voilà en plus nouvelle version RC1 with NAS :p Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
NeB Posté(e) 5 juin 2010 Share Posté(e) 5 juin 2010 Merci ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mik51 Posté(e) 7 juin 2010 Share Posté(e) 7 juin 2010 VanillaEclair 3.3 RC2 RC1 to RC2 changelog: - A2DP should work properly with newer headsets -> please confirm - sound is now louder - WiFi sleeps properly - GPS fixed, allthough this would need further testing - improved overall system speed(new kernel) - you will feel it - kernel to work @ 691/160 or @576/245 - download the one you want - included modules: tun, cifs, loop, cryptoloop, wlan -> ramzswap is attached - optimized boot speed - you can now connect via wifi to AdHoc networks NAS 691/160 : http://roms.pxmedia.nl/VanillaEclair_3.3RC2_NAS_signed.zip NAS 576/245 : http://roms.pxmedia.nl/VanillaEclair_3.3RC2_LOFQ_NAS_SIGNED.zip Peux tu mettre à jour ton topic STP ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gp4004 Posté(e) 10 juin 2010 Share Posté(e) 10 juin 2010 dommage que ce post ne soit plus maintenu... la RC4 est sortie hier : RC3 to RC4 changelog: - AutoBrightness(enable from settings) - Compcache can be enabled via SpareParts (apparently this works only with an alternative launcher) -- confirmation needed - fixed GSM PRL issue - fixed notification LED(still to work on trackball led) - fixed APN-list - old sounds are now included - optimized boot process(~35s now) avec au choix : - un kernel @691/122 par défaut - un Kernel @245/576 à télécharger en cas de freeze du bigophone (le mien ne supporte pas 691Mhz par ex) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cthu Posté(e) 10 juin 2010 Share Posté(e) 10 juin 2010 (modifié) Installée sur mon hero, avec le kernel 576, elle est propre, rapide et stable. Modifié 10 juin 2010 par Cthu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 10 juin 2010 Share Posté(e) 10 juin 2010 @Cthu,ou autre testeur : -L apn fonctionne en 5 mpx,et l autofocus ? -La galerie 3D n a pas de bug ? -il n y a pas d icones dans le launcher ? juste le carré du Nexus (j aime pas les nouveaux launchers!) Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leimi Posté(e) 10 juin 2010 Share Posté(e) 10 juin 2010 Le launcher de base est une version modifiée du launcher original avec la "languette" (qui vient de cyanogen je crois). Si tu veux un launcher comme le Nexus tu peux test Helix Launcher sur le market. Perso aucun problème avec l'apn en 5 megapixels. Sur la RC2 (et celles d'après je crois pas que ça change) c'est la gallerie 2D qui est mise par défaut et non la 3D car celle ci ne fonctionne pas très bien sur la ROM. Voila ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 10 juin 2010 Share Posté(e) 10 juin 2010 Merçi Leimi. Justement je ne veux pas de launcher amélioré,juste le carré ou la languette. Pour la gallery, c est pas grave,j ai l Apk 3d en mémoire. PS : j ai méme 2 gallery 2d (un autre dossier photos,pour avoir le détail des dossiers : famille,gag,matos...etc) Ce qui me fait 3 Gallery :/ ya un screen du menu d acceuil qui pourrait etre vu ? Remerci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 18 juin 2010 Share Posté(e) 18 juin 2010 peut on mettre la status bar en noir sur cette ROM et y à t il des thèmes sinon ça tourne bien pour moi j arrive juste pas à changer la couleur du pourcentage de batterie spar part ne prend pas en compte mes changements Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
battosai_62 Posté(e) 18 juin 2010 Share Posté(e) 18 juin 2010 Bonjour =) Apparemment une V4 viens d'arriver : http://www.vanilladroid.com/forum/viewtopic.php?id=16 Sinon, est-ce que quelqu'un aurait des retours sur la RAM dispo après flashage et quelques applications installées ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cthu Posté(e) 19 juin 2010 Share Posté(e) 19 juin 2010 peut on mettre la status bar en noir sur cette ROM et y à t il des thèmes sinon ça tourne bien pour moi j arrive juste pas à changer la couleur du pourcentage de batterie spar part ne prend pas en compte mes changements il faut redémarrer le mobile pour activer les changements effectués dans spare parts Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 19 juin 2010 Share Posté(e) 19 juin 2010 j'ai essayé plusieurs fois chtu et ça ne fonctionne pas tant pis c'est juste un petit détail sinon pour répondre à battosai après installation de la Vanillaeclair4.0 NAS je suis à 108mo de RAM dispo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 20 juin 2010 Share Posté(e) 20 juin 2010 Avec un kernel façon Turbo ! 768 Mhz :P http://forum.xda-developers.com/showthread.php?t=704974 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 20 juin 2010 Share Posté(e) 20 juin 2010 (modifié) je teste avec ce kernel je vous tiens au courant je suis repassé sur lokernel avec oc à 691ca tourne très bien avec le kernel boosté j arrivai pas à oc à plus de 513 avec oc widget Modifié 20 juin 2010 par tiago Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
battosai_62 Posté(e) 20 juin 2010 Share Posté(e) 20 juin 2010 Super, merci tiago pour les infos. Je vais tester cette ROM sous peu je crois, elle à l'air bien sympa :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 21 juin 2010 Share Posté(e) 21 juin 2010 Ben,j ai un bug de l agenda. Toujours le bug du gps et de la galerie. Rapide,mais sans plus..........surtout que le kernel a 768 Mhz ne fonctionne pas.Donc pour ma part,le verdict est = bof. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 21 juin 2010 Share Posté(e) 21 juin 2010 moi j ai mis la galerie 3d donc pas de pb t utilises quelle ROM funk ? par contre avec ADW c était pas très fluide avec launcher pro nickel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 21 juin 2010 Share Posté(e) 21 juin 2010 Non,j avais la 4.0,tant qu a faire,autant prendre la toute derniere ;) Mais il y a toujours un truc qui m**** sur les rom custom sans Sense. J avais fait un Nandroid backup avant.........heureusement ! Ca saoule tellement que j ai remis Behero 1.3.2 et tout est impeccable. J ai mes deux galeries,toutes mes applis fonctionnent.Et avec ADW launcher,j attends que le bug widgets sur 5 icones/colonne soit résolu. La : j ai l arme ou le Hero top niveau (a 690 Mhz) et une GROSSE journée d utilisation. Vive le Hero libre............. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leimi Posté(e) 26 juin 2010 Share Posté(e) 26 juin 2010 Up o/ Des gens sur bouygues arrivent à envoyer des MMS avec l'application SMS native sur cette ROM (en version 4) ? Si oui vous pourriez partager vos apns ? Merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 27 juin 2010 Share Posté(e) 27 juin 2010 je cherche un thème metamorph pour cette ROM je voudrais la barre de notification noire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tiago Posté(e) 19 juillet 2010 Share Posté(e) 19 juillet 2010 la version 5.0 est sortie http://forum.xda-developers.com/showthread.php?t=728275 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
