Mik51 Posté(e) 11 mai 2010 Share Posté(e) 11 mai 2010 Well, here it is. Donators-Only for the moment. A little treat to say thank you for their generosity.SuperHero 1.0.0 BETA is the name we went for (originally referred to as VillainLITE). Essentially, it's a HIGHLY stripped down VillainROM, which is made up of an amalgamation of Villain and Vanilla builds. It is geared solely for absolute, 100% performance. It's shit off a shovel quick, folks. It's about 80% Vanilla, but I have included SOME Sense apps in the build for now. This may change at a later date. SO, HERE'S SOME INFO: - JIT Enabled by default, and very stable - The excellent ADW Launcher (Recommended settings are: [drawersettings] New Drawer - NO, Animated Drawer - NO, Fast Drawer - YES) (Use SpareParts to further improve the visuals) - Press Home on Home Screen for Sense style quick select view - Completely customisable home screen - Incredible Live Wallpaper performance - BootCONTROL Widget from CyanogenMod 5 (nice) - Vanilla Camera @ 5mp - Vanilla Keyboard - Vanilla eMail (Multiple Exchange accounts) - Vanilla Music - Vanilla & Sense Diallers (option) - Vanilla Sounds - Apps2SD - Friendstream App working - Widget obviously not as it's SENSE. - Significantly improved performance over Villain (due to JIT + Removed SENSE limitations) - Working Vanilla Alarm & Lockscreen - Gallery 3D MULTITOUCH with rotate fix - VERY Stable - All Hardware working - Perfect OpenGL performance for the build Source : http://www.villainrom.co.uk/viewtopic.php?f=43&t=507 Une villain lite basé sur vanilla avec un sense ? à voir... Lien vers le commentaire Partager sur d’autres sites More sharing options...
elloco054 Posté(e) 11 mai 2010 Share Posté(e) 11 mai 2010 - Gallery 3D MULTITOUCH with rotate fix- VERY Stable - All Hardware working là ca me plait !! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lincoln Six Echo Posté(e) 11 mai 2010 Share Posté(e) 11 mai 2010 retours? =) Lien vers le commentaire Partager sur d’autres sites More sharing options...
rhapsody01 Posté(e) 11 mai 2010 Share Posté(e) 11 mai 2010 là ca me plait !! [HS ON] Dans le monde des moddeurs Android "Very stable" signifie : A fonctionné sans trop de problème pendant 2 heures. Je prend ce genre déclaration avec des pincettes maintenant. La seule vraie rom custom stable pour moi est la Modaco. Même la Kimera sur laquelle je tourne actuellement n'est pas 100% fonctionnelle. [HS OFF] J'attend des retours avec impatience, j'aime bien le principe de la Rom ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Louis62 Posté(e) 12 mai 2010 Share Posté(e) 12 mai 2010 Apparemment il faut être donateur :( Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 12 mai 2010 Share Posté(e) 12 mai 2010 oui mais ça passera public des que c'est stable Lien vers le commentaire Partager sur d’autres sites More sharing options...
