dev_android Posté(e) 20 août 2012 Share Posté(e) 20 août 2012 Bonjour à tous, j'affiche des videos dans un framelayout, mais il y a que la premiere video qui s'affiche, les deux videos se superposent mais je ne sais pas comment resoudre ce probleme, car quand je fais videoview.start() pour les deux videoview le son des deux demarre, mais il y a que la premiére video qui s'affiche, quelqu'un sait comment eviter cette superposition svp?? voila mon code : public class VideoPlayerActivity extends Activity { /** Called when the activity is first created. */ VideoView videoView; VideoView videoView2; public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); this.requestWindowFeature(window.FEATURE_NO_TITLE); this.getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN); setContentView(R.layout.question); String newVidPath= "file:///"+Environment.getExternalStorageDirectory()+"/projet/01.mp4"; LayoutInflater inflater = (LayoutInflater)getSystemService(Context.LAYOUT_INFLATER_SERVICE); FrameLayout videoFrame = (FrameLayout)findViewById(R.id.videoFrameLayout); LinearLayout.LayoutParams layoutParams = new LinearLayout.LayoutParams(840, 960); layoutParams.gravity = Gravity.CENTER; videoFrame.setLayoutParams(layoutParams); videoView = (VideoView) inflater.inflate(R.layout.video, null); MediaController mediaController = new MediaController(this); mediaController.setAnchorView(videoView); videoView.setMediaController(mediaController); videoView.setVideoURI(Uri.parse(newVidPath)); videoFrame.addView(videoView); String newVidPath2= "file:///"+Environment.getExternalStorageDirectory()+"/projet/02.mp4"; LayoutInflater inflater2 = (LayoutInflater)getSystemService(Context.LAYOUT_INFLATER_SERVICE); FrameLayout videoFrame2 = (FrameLayout)findViewById(R.id.videoFrameLayout); LinearLayout.LayoutParams layoutParams2 = new LinearLayout.LayoutParams(840, 960); layoutParams2.gravity = Gravity.CENTER; videoFrame2.setLayoutParams(layoutParams2); videoView2 = (VideoView) inflater2.inflate(R.layout.video, null); MediaController mediaController2 = new MediaController(this); mediaController2.setAnchorView(videoView2); videoView2.setMediaController(mediaController2); videoView2.setVideoURI(Uri.parse(newVidPath2)); videoFrame2.addView(videoView2); } } et le XML: <?xml version="1.0" encoding="utf-8"?> <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" android:layout_width="fill_parent" android:layout_height="fill_parent" android:background="#FFFFFF" android:orientation="vertical" > <LinearLayout android:id="@+id/LayoutVideos" android:layout_width="fill_parent" android:layout_height="wrap_content" android:background="#FFFFFF" android:orientation="vertical" > <FrameLayout android:id="@+id/videoFrameLayout" android:layout_width="fill_parent" android:layout_height="wrap_content" android:background="@android:color/transparent" android:paddingTop="200dp" > </FrameLayout> </LinearLayout> </LinearLayout> Lien vers le commentaire Partager sur d’autres sites More sharing options...
dev_android Posté(e) 21 août 2012 Auteur Share Posté(e) 21 août 2012 Quelqu'un a une idée svp, je suis vraiment bloqué et je ne sais pas quoi faire? Lien vers le commentaire Partager sur d’autres sites More sharing options...
chpil Posté(e) 21 août 2012 Share Posté(e) 21 août 2012 Vu que tu ne définis qu'une seule FrameLayout dans ton XML pour recevoir les vidéos, et que insères ces 2 vidéos au même endroit, c'est normal qu'elles se supperposent. Il te faudrait définir dans ton XML deux zones distinctes, une pour chacune de tes vidéos Lien vers le commentaire Partager sur d’autres sites More sharing options...
dev_android Posté(e) 22 août 2012 Auteur Share Posté(e) 22 août 2012 Merci chpil pour ton aide, j'ai reglé le problème avec un bouton next pour naviguer entre mes videos. ce qui m'envoie vers un autre problème, mon bouton s'affiche partout même si je n'ai pas de video, comment je pourrai faire pour afficher le bouton que s'il y a des videos?? Lien vers le commentaire Partager sur d’autres sites More sharing options...
chpil Posté(e) 22 août 2012 Share Posté(e) 22 août 2012 Tu peux jouer programmatiquement avec la visibilité de ton/tes boutons. Tu peux faire quelque chose comme cela buttonNext.setVisibility(View.INVISIBLE); // pour rendre invisible ton bouton, ou View.VISIBLE pour le rendre visible Lien vers le commentaire Partager sur d’autres sites More sharing options...
dev_android Posté(e) 22 août 2012 Auteur Share Posté(e) 22 août 2012 Merci beaucoup ça marche. Lien vers le commentaire Partager sur d’autres sites More sharing options...
