harmakhis Posté(e) 7 septembre 2012 Share Posté(e) 7 septembre 2012 (modifié) utilisée ce matin pour voir si l'adb reconnaissait bien ma tablette (adb device) et pour faire le crack du bootloader et flasher le recovery CWM http://forum.xda-developers.com/showthread.php?t=1661324 [PROGRAM] Acer A510 AIO Toolbox ************************** Acer A510 Iconia Tab AIO Toolbox ************************** By: marlopainter I posted this here because there isn't an A510 Forum yet. All the A510 people come to the A500 Forum. Delete this if it's a problem. Not all options are specific to the A510. UPDATED 5/23/2012 : v2.3.0 COMPLETE OVERHAUL OF GUI AND COMMAND ISSUANCE See Changelog at the bottom. Inspired by: Bay_wolf's AIO Vibrant Toolbox 2.5 THIS IS INSTALLED ON YOUR PC, NOT YOUR MOBILE DEVICE DISCLAIMER: This is a Work In Progress. I'm distributing this program as-is and make no guarantee that it will not hurt your device. So, use at your own risk and don't blame me for bricking your device. I am to not be held liable for any outcome of the use of this program. Options are tested personally on my A510. It is written in VB2010, NOT C, and you will need the Framework from MS. I use Windows 7 - 64 bit, so that's why. What is this: This program will do many of the tasks in a few clicks rather than opening command prompts, etc. The routines are ALL visible and OPEN for inspection. -IMPORTANT- This program uses the SendKeys commands available in VB. This means a window will open and the info will be "auto-typed" for you. You will clearly see all the commands I am sending to your device. DO NOT CLICK YOUR MOUSE AND CHANGE FOCUS DURING A ROUTINE! The function doesn't care where the info is sent, it just sends it. Allow the function to finish before attempting to do something else. The functions take less than a minute, you will NOT be waiting long. Setup Your Device: USB Debugging MUST be ENABLED Connect the USB cable to your PC and Tablet Some options require root Use this program to root your device What can You do: At the moment, there are 9 tabs of options. They are divided up by functions. Similiar functions are grouped. **///NEW\\\** *** Menu Stip across the top for quick access to commands/tabs. *** Access Google, XDA, AcerTabletForum, and this thread with 1 click *** Send me an email *** Donate Tab 1 : Drivers : ONLY A510 *** Download the USB Drivers directly from Acer. *** To save program weight, I removed the drivers from the package. *** Most people will have them already, or only need them once. *** You can also open the "Device Manager" from this screen if there *** are difficulties seeing your device with ADB. Tab 2 : ADB Connection : Any ADB Enabled device with USB Debugging Enabled *** Use this tab to check your ADB connection. *** It is recommended to do this before most operations. *** A link is provided with more info on ADB Tab 3 : Command Prompts : Any ADB Enabled device with USB Debugging Enabled; Root *** Open Command Prompts quickly *** Two options: Shell with SU; Raw CMD prompt *** Links for more info on Shell and SU also provided Tab 4 : Misc Tools : Any ADB Enabled device with USB Debugging Enabled; Root *** Mount /system/ RW with 1 click *** Clear dalvik cache with 1 click *** Link for dalvik info provided Tab 5 : Reboot Controls : Any ADB Enabled device with USB Debugging Enabled *** Reboot device into 1 of 3 modes *** Normal, Recovery, Bootloader *** Links for info on Recovery and Bootloader provided Tab 6 : Root : A10x and A5xx with ICS; USB Debugging Enabled *** Root your A10x and A5xx with the ICS Simple Method *** Link to ZeroNull's post and info on Root provided *** 'Unroot' All thanks go to ZeroNull for the exploit and to Jesse6749 for discovering it works on the A510 ATTENTION! Don't install Busybox! It is already installed and established! If you reinstall it, some programs will become unable to access root permissions! Tab 7 : Bootloader : Any Device in which "fastboot oem unlock" is acceptable *** Unlock your Bootloader and Reboot Out *** READ CAREFULLY Tab 8 : Backup : Any ADB Enabled device with USB Debugging Enabled *** Pull files and APKs *** Buttons to Pull from: ****** build.prop ****** /data/app/ ****** /data/app-private/ ****** /system/app/ ****** /system/vendor/app ****** Custom Pull : Just type the file's address and click Tab 9 : Install : Any ADB Enabled device with USB Debugging Enabled *** Mass install APKs *** Simply place the APKs in the 'APK' folder in this app's directory and click. *** A list of APKs will appear, click to install the list. *** The list isn't 'choose-able' It's there more for debugging, make sure it sees them. Possible Additions in the future: Custom Push Options Choose-able list for Mass APK install To INSTALL the Program on your PC: *** Download the zip file [LESS THAN 3MB] *** Most of the weight is Superuser.apk and the Root Package *** Extract to desired folder *** Leave the file structure intact. *** Click Acer_A510_AIO_Toolbox.exe *** Version Number is shown on the Title Bar of the program *** Have fun! DOWNLOAD HERE: BakedPickle.com Screenshots available at the site. Please hit the Like/Thanks Button! Please leave comments/suggestions/bugs in the thread! Changelog: v2.3.0 *** Fixed Error preventing Bootloader options *** from activating v2.2.5 *** Fixed Typo in Unroot Function *** Line was: /data/tools/local *** Should be: /data/local/tools v2.2.0 *** Replaced Root Files as a Precaution *** Added 'Unroot' *** Removed UAC Access v2.0.0 *** Overhauled GUI *** Redid how functions deliver commands to the device *** Needed UAC Access *** Fixed Crash that occured if certain options cancelled via prompts *** Pull APK Directories should be working now *** Updated the root files to latest as provided by ZeroNull (5/16/2012) *** Added 'Clear dalvik' *** Added Info Links *** Added more information for newer people *** Added Custom Pull Options *** Added prompts to ensure proper operation *** Removed Drivers from install package v1.2.5 *** Changed execution of CMD windows for Reboots *** CMD window no longer appears v1.2 *** Fixed ROOT issue. Replaced typo where app looked for *** non-existent apk file instead of Superuser.apk *** Fixed CMD window hang on mount R/W button v1.0 - Release Candidate "There is no such thing as TMI on the internet." Acer A510 AIO Toolbox @ XDA: Updated 5/23/2012 (Has many universal Android functions) www.ninjabuild.net ======================== T-mobile Samsung Galaxy S3 Date on box: 6/16/2012 CM10 Preview 7/29/2012 Flash Count: >9 ACER A510 Rooted Stock -RETIRED- T-mobile Samsung Vibrant T-mobile HTC G1 Modifié 7 septembre 2012 par harmakhis Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
