[ROM] [20 mai 2010] SuperHero 1.1.0 Public Release [20 mai 2010]
Lincoln Six Echo
http://www.villainrom.co.uk/viewtopic.php?f=43&t=648
DESCRIPTION
Essentially, it's a HIGHLY stripped down VillainROM, and is geared solely for absolute, 100% performance. It's shit off a shovel quick, folks.
It's about 80% Vanilla, but I have included SOME Sense apps in the build for now. This may change at a later date.
Changelog :
- The excellent ADW Launcher 0.7 (Recommended settings are: [drawersettings] New Drawer - NO, Animated Drawer - NO, Fast Drawer - YES)
(Use SpareParts to further improve the visuals)
- OTA Updater software installed
- All streaming issues fixed
- Press Home on Home Screen for Sense style quick select view
- Completely customisable home screen
- SIM Contacts can be disabled (and groups are fixed)
- Incredible Live Wallpaper performance - They don't stick for long though. Nice to show off with, that's about it.
- Boot CONTROL Widget
- Vanilla Camera @ 5mp (green tint exists, although, we're working on this)
- Vanilla Keyboard
- Vanilla eMail (Multiple Exchange accounts) (includes corcal and corgal)
- Vanilla Music
- Vanilla & Sense Diallers (option)
- Apps2SD
- Friendstream App working - Widget obviously not as it's SENSE.
- Significantly improved performance over Villain (due to JIT + Removed SENSE limitations)
- Working Vanilla Alarm & Lockscreen
- Gallery 3D MULTITOUCH with rotate fix
- VERY Stable
- All Hardware working
- Perfect OpenGL performance for the build
Problèmes connus :
Aucuns
Patches :
UPDATES:
Optional
HTC IME Keyboard with Voice Input will be available as an OTA update later.
JIT On/Off
At long last. Presenting the new JIT on/off files for SuperHero 1.1.0
You MUST change the homescreen wallpaper to a picture (ie, not default one) before enabling JIT. Else it won't boot. Flash the disabler if you do this
Enable JIT:
Click Here for ENABLER
Disable JIT:
Click Here for DISABLER
By using these, you agree to download both, and keep them to hand on your SD card root folder. JIT is not stable on 2.1 ROMs, although it works fine on SuperHero. If you use it, be sure to keep the disable file just in case you are out and it breaks, then you can flash disable and be back to normal.
Téléchargement : http://www.villainrom.co.uk/releases/Super1.1.0/download.php
Screenshoots :
Aucuns
URL de l
Aucunes
Tiens : http://lmgtfy.com/?q=JIT+android
Bonne recherche/lecture :)
[HS]
Trop fort ce site ;) Merci de me l'avoir fait connaître, c'est vraiment une super bonne idée.
Dans le même genre de 'bidouille' Google, j'aime bien ce que l'on voit quand on tape 'Trouver Chuck Norris' et que l'on clique sur le bouton "j'ai de la chance"
[/HS]
Modifié par Ast2001
[HS]
[/HS]
Pour voir tous les "easters eggs" de Google c'est ici : http://www.pcworld.com/article/142620/googles_top_17_easter_eggs_gags_and_hoaxes.html [/HS]
REMOVE SIM PIN UNLOCK CODE BEFORE FLASHING (as it causes boot problems)
il faut éviter de mettre l'option sécurité avec code pin y'a un soucis essai de mettre une rom custom autre que celle-ci désactive le code pin et réessai.
Modifié par Mik51
Pas vraiment mieux ... je ne dépasse même pas le logo coloré, qui reste figé (après wipe - flash aHero - désactivation du déverrouillage SIM - flash superHero).
Je crois que mon expérience avec la superHero va s'arrêter là .... !
tu as re-wipe entre la aHero et la superHero?
perso j'ai mi ma carte sim dans un autre tel pour enlever le code pin et c'est passé par contre ça me bloque au même niveau que toi quand j'essai d'activer le JIT?
pour la suite des retours, on verra plus tard ;)
on est d'accord il n'y a pas sense ? y'a certains widget dont je ne pourrais me passer donc je préfère poser la question je vois nul part où c'est marqué merci
merci usoska j'ai du loupé le passage ...
Apparement JIT pour le moment n'est pas assez optimisé. Je pense qu'il vaut mieux attendre que ça soit au point ou au moins d'avoir quelques retours.
Edit : je me suis lancé flash en cours mais sans JIT
Modifié par lolob45
Non, je n'ai pas re-wipe entre les deux, sinon le fait de désactiver le déverouillage SIM ne sert à rien ...
et non, je n'ai pas flashé le JIT !
Fais un Wipe entre les deux, pour moi ça a marché.
En résumé, je l'utilise depuis une semaine et j'adore car stable, légère, rapide, et j'ai enfin récupéré de l'autonomie coté batterie.
Mais alors pourquoi ne pas prendre une AOSP . La raison est simple, cette ROM a des restes de sense comme la synchro Facebook avec le carnet d'adresse, le tethering USB, Friendstream.
J'ai pu installer l'appli mail de HTC (extraite d'une ROM HTC), la caméra..
Donc épuré comme une AOSP mais possibilité de récupérer le meilleur de Sense (sauf les Widgets).
Quant au JIT, c'est ultra rapide (X2 par rapport à cette ROM qui est déjà rapide sans), mais instable.
A vous de Voir
Modifié par lebartman
