[Problème]pourquoi mon appli se ferme soudainement ?
Guillaume Gille
bonjour a tous,
voila je fait parti d'une webradio et j'aimerais créer une appli pour l'écouter (la webradio :P ) donc je débute avec eclipse.
voici le code du MainActivity.java:
import android.app.Activity;
import android.os.Bundle;
import java.io.IOException;
import android.media.MediaPlayer;
import android.media.MediaPlayer.OnBufferingUpdateListener;
import android.media.MediaPlayer.OnPreparedListener;
import android.util.Log;
import android.view.View;
import android.view.View.onclickListener;
import android.widget.Button;
import android.widget.ProgressBar;
public class MainActivity extends Activity implements onclickListener {
private ProgressBar playSeekBar;
private Button buttonPlay;
private Button buttonstopPlay;
private MediaPlayer player;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
 super.onCreate(savedInstanceState);
 setContentView(R.layout.activity_main);
 initializeUIElements();
 initializeMediaPlayer();
private void initializeUIElements() {
 buttonPlay = (Button) findViewById(R.id.buttonPlay);
 buttonPlay.setonclickListener(this);
 buttonstopPlay = (Button) findViewById(R.id.buttonstopPlay);
 buttonstopPlay.setEnabled(false);
 buttonstopPlay.setonclickListener(this);
public void onclick(View v) {
 if (v == buttonPlay) {
	 startPlaying();
 } else if (v == buttonstopPlay) {
	 stopPlaying();
private void startPlaying() {
 buttonstopPlay.setEnabled(true);
 buttonPlay.setEnabled(false);
 playSeekBar.setVisibility(View.VISIBLE);
 player.prepareAsync();
 player.setOnPreparedListener(new OnPreparedListener() {
	 public void onPrepared(MediaPlayer mp) {
		 player.start();
private void stopPlaying() {
 if (player.isPlaying()) {
	 player.stop();
	 player.release();
 buttonPlay.setEnabled(true);
 playSeekBar.setVisibility(View.INVISIBLE);
private void initializeMediaPlayer() {
 player = new MediaPlayer();
 try {
	 player.setDataSource("http://listen.radionomy.com/enchantedradio");
 } catch (IllegalArgumentException e) {
	 e.printStackTrace();
 } catch (IllegalStateException e) {
 } catch (IOException e) {
 player.setOnBufferingUpdateListener(new OnBufferingUpdateListener() {
	 public void onBufferingUpdate(MediaPlayer mp, int percent) {
		 playSeekBar.setSecondaryProgress(percent);
		 Log.i("Buffering", "" + percent);
@Override
protected void onpause() {
 super.onpause();
	 player.stop();
le code du activity_main.xml :
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<Button
 android:id="@+id/buttonPlay"
 android:layout_width="wrap_content"
 android:layout_height="wrap_content"
 android:layout_alignParentLeft="true"
 android:layout_alignParentTop="true"
 android:layout_marginLeft="30dp"
 android:layout_marginTop="68dp"
 android:text="BT1" />
<Button
 android:id="@+id/buttonstopPlay"
 android:layout_marginLeft="200dp"
 android:text="BT2" />
</RelativeLayout>
et celui du manifest:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.package a moi"
android:versionCode="1"
android:versionName="1.0" >
<uses-sdk
 android:minSdkVersion="8"
 android:targetSdkVersion="15" />
<uses-permission android:name="android.permission.INTERNET"></uses-permission>
<application
 android:icon="@drawable/ic_launcher"
 android:label="@string/app_name"
 android:theme="@style/AppTheme" >
<activity android:name=".myMain"
		 android:label="@string/app_name">
 <intent-filter>
	 <action android:name="android.intent.action.MAIN" />
	 <category android:name="android.intent.category.LAUNCHER" />
 </intent-filter>
</activity>
</application>
</manifest>
donc eclipse ne m'indique aucune erreur, je l'export et le signe pour le tester sur mon telephone, mais lorsque je le lance j'ai a chaque lancement l'erreur " Fermeture soudaine de l'application .... merci de réessayer"
quel en serait la cause ??? ya-t-il une erreur dans mon code ??
je vous remercie d'avance amis développeurs :P :lol:
Modifié par tic&tac
Si ton application plante sans raison "apparente", c'est quand même sûrement qu'il y a une erreur dans ton code ;)
Mais pour qu'on puisse t'aider, il va falloir d'abord nous aider à y voir plus clair
Que se passe-t'il exactement ? As tu regardé les traces qui apparaissent dans le LogCat ? Y vois tu la trace d'une exception ? laquelle ?
Il est vrai qu'avoir le message affiché sur catlog faciliterait la tache, mais en regardant ton code, voici plusieurs pistes qui t'aideront à faire marcher ton application :D
1- Nul part je ne vois playSeekBar qui est initialisé.
Du coup ton application risque de planter avec un beau 'nullPointerException' :P
Pense donc à l'initialiser.
2- Dans ton manifeste, il faut que tu changes package="com.package a moi" par le nom de ton package. Pour rappel il ne faut pas qu'il y-ai d'espace, par exemple: package="com.package.amoi"
3- Aussi remplace <activity android:name=".myMain" par
<activity android:name=".MainActivity"
Avec tout ça je pense qu'à la fin ça devrait au moins ne pas planter dès le lancement.
Tiens nous au courant B)
lool oui dimach c'est moi qui l'est enlever pour pas le mettre sur le net :P
sinon ça y est j'ai résolu le problème mais actuellement j'ai un deuxieme problème, et sur le logcat je n'ai aucune erreur :/
donc j'ai changer mon code sur le MainActivity.java, j'ai un bouton play et un bouton stop, mon bouton play fonctionne et quand je rajoute pour le bouton stop j'ai plein d'érreur, faut il rajouté un }?? a quel endroit ? car lorsque je le met pour fermé le bouton 1 j'ai d'autre erreur qui apparaisse :/
voici le code en question:
import android.view.Menu;
public class MainActivity extends Activity {
@Override
@Override
public boolean onCreateOptionsMenu(Menu menu) {
 getMenuInflater().inflate(R.menu.activity_main, menu);
 return true;
@Override
protected void onstart() {
 Button btnop=(Button) findViewById(R.id.button1);
 btnop.setonclickListener(new View.onclickListener()
 protected void onstop() {
	 Button btnop=(Button) findViewById(R.id.button2);
	 MediaPlayer mediaPlayer = new MediaPlayer();
		 try {
		 mediaPlayer.setDataSource("http://streaming208.radionomy.com/EnchantedRadio?group=55&countrycode=FR");
		 mediaPlayer.prepare();
		 mediaPlayer.start();
		 Log.v("AUDIOHTTPPLAYER", e.getMessage());
 super.onDestroy();
Modifié par tic&tac
Salut!
C'est Eclipse qui ne compile pas là non?
Ta méthode onstart() n'est pas claire...il manque des choses j'ai l'impression lol
Essaie plutôt un truc dans le genre :
private MediaPlayer mediaPlayer;
private Button btStart;
private Button btStop;
@Override
 btStart=(Button) findViewById(R.id.button1);
 btStart.setonclickListener(new onclickListener(){
  @Override
   if (mediaPlayer.isPlaying() == false) {
 try {
 btStop =(Button) findViewById(R.id.button2);
 btStop.setonclickListener(new onclickListener(){
  @Override
   if (mediaPlayer.isPlaying()) {
 mediaPlayer.stop();
@Override
 super.onpause();
  mediaPlayer.stop();
Modifié par eridsan
merci pour ton aide, je l'ai un peu modifier car eclipse m'indiquai des erreurs
mon appli fonctionne presque maintenant :P je dit presque parce que bon je lance lance, la tout va bien, donc je fait play la musique marche donc tou va bien, je fait stop la musique s'arrete c'est bien... le probleme c'est que si je veu refaire play ba j'ai une fermeture soudiane de l'appli, voici le logcat si vous souhaitez m'aider ^_^
10-28 03:24:12.226: E/JBtlAgHandler(280): JBtlAg context is disabled
10-28 03:24:14.484: E/AudioHardwareALSA(9721): RE-OPEN AFTER STANDBY:: took 94 msecs
10-28 03:24:17.343: E/JBtlAgHandler(280): JBtlAg context is disabled
10-28 03:24:23.812: E/MediaPlayer(16147): setDataSource called in state 64
10-28 03:24:23.820: E/AndroidRuntime(16147): FATAL EXCEPTION: main
10-28 03:24:23.820: E/AndroidRuntime(16147): java.lang.IllegalStateException
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.media.MediaPlayer.setDataSource(Native Method)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at com.radiodclub12200989.MainActivity$1.onclick(MainActivity.java:35)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.view.View.performClick(View.java:2586)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.view.View$PerformClick.run(View.java:9262)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.os.Handler.handleCallback(Handler.java:587)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.os.Handler.dispatchMessage(Handler.java:92)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.os.Looper.loop(Looper.java:130)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at android.app.ActivityThread.main(ActivityThread.java:3744)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at java.lang.reflect.Method.invokeNative(Native Method)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at java.lang.reflect.Method.invoke(Method.java:507)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
10-28 03:24:23.820: E/AndroidRuntime(16147):     at dalvik.system.NativeStart.main(Native Method)
10-28 03:24:24.882: E/Omap4ALSA(9721): called drain&close
je vais essayer de voir, mais bon je m'y connais pas beaucoup :/
Modifié par tic&tac
Essaie plutôt comme ça alors ;)
private ProgressDialog progress;
@Override
 setContentView(R.layout.horz_scroll_main);
 progress = new ProgressDialog(this);
 progress.setTitle("Patientez");
 progress.setMessage("Initialisation mediaplayer...");
 progress.setIndeterminate(true);
  @Override
  @Override
 mediaPlayer.pause();
 initMediaPlayer();
private void initMediaPlayer(){
 progress.show();
 new Thread((new Runnable() {
  @Override
  public void run() {
   try {
 mHandler.sendMessage(mHandler.obtainMessage());
 })).start();
final Handler mHandler = new Handler() {
 public void handleMessage(Message msg) {
  progress.dismiss();
@Override
 super.onpause();
@Override
protected void onDestroy() {
 super.onDestroy();
  mediaPlayer.stop();
Modifié par eridsan
  • 1 month later...
hey les amis merci pour votre aide,
donc j'ai changé le code, mais deux problèmes persistent :emo_im_undecided: :
- premièrement, lorsque l'on clique sur play et que l'on appui sur le bouton accueil du telephone l'appli est en arriere plan la aucun problème, mais lorsque l'on veu revenir dessus en cliquant sur l'icone dans la notification une autre activity se lance et on ne peut pas faire stop pour stopper la musique, je ne vois pas comment faire :o
- deuxiement, quand l'on clique sur stop pour stopper la musique et que l'on reclique sur play pour remettre la musique l'appli se ferme soudainement, je ne vois pas comment faire non plus :(
étant débutant ça commence a me déprimé :o
voici mon code:
import android.app.Notification;
import android.app.NotificationManager;
import android.app.PendingIntent;
import android.content.Context;
import android.content.Intent;
import android.media.AudioManager;
import android.widget.SeekBar;
import android.widget.TextView;
import android.widget.Toast;
 private MediaPlayer mediaPlayer = new MediaPlayer();
 private NotificationManager mNotificationManager;
	 * Initialisation des données pour le controle du volume
 AudioManager audioManager;
@Override
@Override
 audioManager = (AudioManager)getSystemService(MainActivity.AUDIO_SERVICE);
 int maxVolume = audioManager.getStreamMaxVolume(AudioManager.STREAM_MUSIC);
 int curVolume = audioManager.getStreamVolume(AudioManager.STREAM_MUSIC);
 SeekBar volControl = (SeekBar)findViewById(R.id.seekBar1);
 volControl.setMax(maxVolume);
 volControl.setProgress(curVolume);
 volControl.setonseekBarChangeListener(new SeekBar.onseekBarChangeListener() {
			 public void onstopTrackingTouch(SeekBar arg0) {
			 // TODO Auto-generated method stub
			 public void onstartTrackingTouch(SeekBar arg0) {
			 public void onprogressChanged(SeekBar arg0, int arg1, boolean arg2) {
			 audioManager.setStreamVolume(AudioManager.STREAM_MUSIC, arg1, 0);
 //bouton pour le lancement de la radio
		 try {
			 //on definit la source du stream
		 //on le prepare de façon asynchrone pour eviter l'effet de freeze
		 mediaPlayer.prepareAsync();
		 //on joue
		 // mediaPlayer.start();
		 Toast.makeText(MainActivity.this, "Préparation de la Radio, Merci de patienter...", Toast.LENGTH_LONG).show();
		 ProgressBar _Prog = (ProgressBar) findViewById(R.id.progressBar1);
						 _Prog.setVisibility(View.VISIBLE);
		 //s'il y a des soucis on garde une trace de log
		 mediaPlayer.setOnPreparedListener(new OnPreparedListener() {
								 mediaPlayer.isPlaying();
								 _Prog.setVisibility(View.INVISIBLE);
									 Toast.makeText(MainActivity.this, "Radio en Lecture", Toast.LENGTH_LONG).show();
					 TextView _Text = (TextView) findViewById(R.id.textView3);
					 _Text.setText("Lecture");
					 //Initialisation de la notification
		 mNotificationManager =
			 (NotificationManager)getSystemService(NOTIFICATION_SERVICE);
		 final Notification notifyDetails =
		 new Notification(R.drawable.playmedia,"Now playing radio",System.currentTimeMillis());
		 Context context = getApplicationContext();
		 CharSequence contentTitle = "Radio Disney Club en lecture";
		 CharSequence contentText = "Cliquer pour stopper";
		 Intent notifyIntent = new Intent(MainActivity.this, MainActivity.class);
		 PendingIntent intent =
			 PendingIntent.getActivity(MainActivity.this, 0,
			 notifyIntent, android.content.Intent.FLAG_ACTIVITY_NEW_TASK);
		 notifyDetails.setLatestEventInfo(context, contentTitle, contentText, intent);
		 mNotificationManager.notify(110, notifyDetails);
 //bouton pour stopper l'ecoute
 Button btnop1=(Button) findViewById(R.id.button2);
 btnop1.setonclickListener(new View.onclickListener() {
 if(mediaPlayer.isPlaying())
 try {
 mediaPlayer.stop();
	 mediaPlayer.reset();
	 mediaPlayer.release();
	 mNotificationManager.cancel(110);
		 _Text.setText("Radio Stop");
} catch (Exception e) {
// TODO: handle exception
 else
 Toast.makeText(MainActivity.this, "Pas de Lecture en cours", Toast.LENGTH_LONG).show();
 super.onstart();
@Override
super.onstop();
Pour le premier problème, il te faut gérer ton player dans un Service. Ton Activity communique ensuite avec ton Service pour lancer/arrêter le player. Le Service survit à la fermeture de ton Activity, donc tu peux ainsi t'assurer de ne pas relancer un deuxième player en la réaffichant
Pour le second problème, il doit te suffire de réinitialiser le player (celui-ci garde un état, et une fois arrêté complètement, il ne peut être redémarré qu'après avoir été réinitialisé)
pourtant le player se réinitialise.... enfin je croit
 try {
 mediaPlayer.stop();
Tu le réinitialises, certes, mais tu le libères ensuite ("release"), et à partir de là, tu ne peux plus utiliser ce player
Regarde la doc de MediaPlayer, il y a un beau diagramme d'état qui indique quelle action il faut effectuer par rapport à l'état du MediaPlayer
