Posté(e) (modifié)
ICS-Hybrid
Music Edition
Cette ROM est pour ceux qui veulent une bonne autonomie et de la stabilité!
Basée sur sur l'officiel CM7 nightly, vous rencontrerez aucun problème de performance. Le theme de cette rom est mélangé avec la rom démocratie ( http://forum.xda-dev...d.php?t=1712654 ) et une rom stock CM7.
" MUST ROM " pour les mélomanes
CARACTÉRISTIQUES :
  • Based on Official CM7 Nightly.
  • JellyBean Navigation Layout.
  • Hybrid framework of JellyBean and Stock , CM7.
  • Notification icons from stock ROM + Other CM7 ROMs
  • Adrenaline Engine.(3.3)
  • Custom statusbar icons.
  • Touch of Stock goodness.
  • Extremely stable.
  • New audio libraries.
  • Advanced Linux Audio Archives Included
  • Beats Audio
  • AudioFX Widget
  • Battery life will last you a day easily-No unnecessary power drain.
  • Dragonn's FireKernel OC
  • Included stock task manager which ignores the touchwiz launcher.
  • Choice between TouchWiz Launcher,Xperia Launcher and new ADW Launcher included.
  • AMAZING music mods by Feras.Rehman.
  • BLN support..thanks to NJosh
  • V6 SuperCharger app priority fixes.
  • JellyBean transitions thanks to DinohDroid
  • Zipaligned
  • Touchwiz 5UX themed holo launcher by -Atif-
  • Build.prop tweaks
  • ICS styled settings( with stock cm7 theme.)
AUCUN BUG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DOWNLOADS :
SCREENSHOTS :
screenshot-1350815760108.pngscreenshot-1350906254970.pngscreenshot-1350906245293.pngscreenshot-1350906224549.pngscreenshot-1350906218264.pngscreenshot-1350906192446.png2012-10-29_20.25.18.png2012-10-29_21.49.04.png2012-10-29_21.54.36.png
CHANGELOGS :
22.11.2012 - v3.0
Added JellyBean navigation layout.
Added new .png to systemUI
Added new .png to framework-res
Added new build.prop & init.d tweaks (Latest from around the web)
Refined/Polished the ROM
30.10.2012 - v2.9
Added JellyBean transitions.-LOOKS TOO COOL
New TouchwizUx themed Holo launcher.
Based on new nightly.
New bootanimation..(little different)(S2 modified)
Removed some apps as it was heavy...
Added Gmail preinstalled
Firekernel OC!!
26.10.2012 - v2.0
Added libs for BLN support- THANKS TO NJosh
Fixed statusbar transparency.. went wrong in v1.5 don't know why..
Included Xperia Cosmic Flow live wallpaper
Removed LunarUI theme
Edited XML and pngs in SystemUI.apk and framework-res.apk
22.10.2012 - v1.5
Added choice of launcher between holo, xperia and touchwiz.
Added Wallpaper picker with nice wallpapers.
Hand-picked status bar icons for battery, wifi etc.
22.10.2012 - v1.0
Torch and gallery fixed.
LunarUI themes included.
Included script manager.
CMWallpapers resolution issue fixed.
New bootanimation.
21.10.2012 - v0.9
Initial release.
BIENTÔT: Nouveau kernel de l'équipe révolution avec des fonctions " suprême " !!!
lien direct vers xda :
Modifié par Teoandro
Posté(e) (modifié)
c est pas vrai j ai bo appuier sur telecharger ca veu pas :( svp meter un lien mediafir j ai une connex de 28kbps
Modifié par akrame2012
Quelqu'un peut-il me dire comment récupérer le thème de la ROM Democracy ? (Pour que ensuite je l'applique sur cette ROM)
Merci.
  • 3 weeks later...
  • 1 month later...
