[Résolu] Problème --> InflateException ....
chris2a
Bonjour tout le monde,
voilà mon problème, j'ai une exception qui est levée au démarrage de mon application par contre elle ne plante pas... Du coup je ne vois pas du tout d'où peut venir le soucis...
Erreur visible dans le logcat :
05-26 11:44:19.762: WARN/WindowManager(567): Exception when adding starting window
05-26 11:44:19.762: WARN/WindowManager(567): android.view.InflateException: Binary XML file line #29: Error inflating class java.lang.reflect.Constructor
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.createView(LayoutInflater.java:512)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.internal.policy.impl.PhoneLayoutInflater.onCreateView(PhoneLayoutInflater.java:56)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:562)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.rInflate(LayoutInflater.java:617)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.rInflate(LayoutInflater.java:620)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.inflate(LayoutInflater.java:407)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.inflate(LayoutInflater.java:320)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.inflate(LayoutInflater.java:276)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.internal.policy.impl.PhoneWindow.generateLayout(PhoneWindow.java:2149)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.internal.policy.impl.PhoneWindow.installDecor(PhoneWindow.java:2203)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.internal.policy.impl.PhoneWindow.getDecorView(PhoneWindow.java:1442)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.internal.policy.impl.PhoneWindowManager.addStartingWindow(PhoneWindowManager.java:648)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.server.WindowManagerService$H.handleMessage(WindowManagerService.java:7092)
05-26 11:44:19.762: WARN/WindowManager(567): at android.os.Handler.dispatchMessage(Handler.java:99)
05-26 11:44:19.762: WARN/WindowManager(567): at android.os.Looper.loop(Looper.java:123)
05-26 11:44:19.762: WARN/WindowManager(567): at com.android.server.WindowManagerService$WMThread.run(WindowManagerService.java:440)
05-26 11:44:19.762: WARN/WindowManager(567): Caused by: java.lang.reflect.InvocationTargetException
05-26 11:44:19.762: WARN/WindowManager(567): at android.widget.TextView.(TextView.java:308)
05-26 11:44:19.762: WARN/WindowManager(567): at java.lang.reflect.Constructor.constructNative(Native Method)
05-26 11:44:19.762: WARN/WindowManager(567): at java.lang.reflect.Constructor.newInstance(Constructor.java:446)
05-26 11:44:19.762: WARN/WindowManager(567): at android.view.LayoutInflater.createView(LayoutInflater.java:499)
05-26 11:44:19.762: WARN/WindowManager(567): ... 15 more
05-26 11:44:19.762: WARN/WindowManager(567): Caused by: android.content.res.Resources$NotFoundException: Resource is not a ColorStateList (color or path): TypedValue{t=0x2/d=0x101009a a=1}
05-26 11:44:19.762: WARN/WindowManager(567): at android.content.res.Resources.loadColorStateList(Resources.java:1731)
05-26 11:44:19.762: WARN/WindowManager(567): at android.content.res.TypedArray.getColorStateList(TypedArray.java:289)
05-26 11:44:19.762: WARN/WindowManager(567): at android.widget.TextView.(TextView.java:367)
05-26 11:44:19.762: WARN/WindowManager(567): ... 19 more
Quelqu'un a déjà eu ce genre d'erreur ? merci !
La stack trace indique clairement que tu as un problème de définition d'une couleur qu'il ne comprend pas sur une TextView de ton layout.
Avec le détail du xml de ton layout on pourra t'en dire un peu plus.
je pense qu'il a trouvé par lui même :)
