Comment rooter un galaxy ace gt-s5830D
1ere méthode:
To root this is working perfectly :
SuperOneClick 2.3.3 - direct link
sources: http://forum.xda-developers.com/showthread.php?t=1598841
2eme méthode (Non testé)
Rooting the S5830D from Koodo
I've rooted this phone yesterday.
1. Using stock recovery install root zipped file AceGingerRoot.zip (see below)
2. Use BML5 method to find unlock code and use it for unlocking on this stock rom, or use market
Unlock Galaxy Ace app, which is doing the same
3. Install CWM version 4 zipped file ClockWorkModAce.zip (see below)
4. Update to CWM version 5 recovery-clockwork-5.0.2.6-galaxyace-fix.zip (see below)
Now you can install the ROM of your choice on your fully unlocked and rooted Ace.
Don't forget to nandroid all original and other ROMs so you can painlessly use the working configuration
ATTACHED FILES zip.gifAceGingerRoot.zip - [Click for QR Code] (918.3 KB, 87 views) zip.gifClockWorkModAce.zip - [Click for QR Code] (6.99 MB, 58 views) zip.gifrecovery-clockwork-5.0.2.6-galaxyace-fix.zip - [Click for QR Code] (5.42 MB, 54 views)
Sources: http://forum.xda-dev...d.php?t=1447721
Modifié par Wʎp
