[ROM][CM9]FireDroid 1.4b BOOT FIXED![03/02/2013]bootloader verouillé
Requiert :
Telechargement :
Installation:
  • Demarrer dans le CWM recovery
  • Faire une sauvegarde nandroid avant de flasher firedroid au besoin
  • Faire un factory reset -> wipe factory reset
  • Installer la "rom".zip -> flash zip from sd/ext card et ok
  • Installer Google apps -> flash zip from sd/ext card et ok
  • Reboot now!!
Demarrer dans le CWM recovery:
  • Presser le bouton on
  • Appuyer en continu sur le "bouton volume -"
  • Profitez du recovery
Voila une rom stable, bl lock pour Nos xsola qui fonctionne bien avec en prime un recovery qui gere la sd externe!!! :) ^_^
Historique des versions :
1.4 :
  • [02/02/2013]
  • Blob update
  • Audio latency
  • AGPS
  • CMFileManager
  • Ramdisk updates
  • Some minor changes
1.3:
  • [04/01/2013]
  • Video recording fixed
  • Random reboots fixes
  • Lockscreen signature deleted for requests
  • Recovery support external sdcard(Go,Sola)
  • Recovery size fixed(Go)
1.2:
  • [26/12/2012]
  • Audio recording
  • Red frame bug fixed
1.1:
  • [03/12/2012]
  • New default wallpaper by destroyy
  • Lockscreen bug fixed
  • External sdcard path fixed
  • Touch recovery deleted
  • CWM-6 recovery fixed
  • Reboot to recovery from the rom fixed
  • Hotspot fixed
  • Wifi sleep bug fixed
  • Offline charging fixed
  • Camera position fixed
  • Andyxs governors and SIO schedulers included
  • Lights updated
  • Ramdisk updated
1.0:
  • [19/11/2012]
  • Based on my modified cm9 sources
  • Support U/P/Go/sola
  • Based on latest FXP sources
  • Latest cm9
  • Dual recovery(cwm5-touch&cwm6)
  • FireDroid settings in settings
  • Center clock option in FireDroid settings
  • Builder info in "About phone"
  • Signed lockscreen
  • Reboot to recovery option deleted while can't fix it
  • Reboot to bootloader option deleted
  • Internal memory fixed(Avaliable in /sdcard, not just in /mnt/sdcard)
alpha3:
  • [09/11/2012]
  • Based on FXP-146
  • Wifi fixed, thanks to dapaua
alpha2:
  • [04/11/2012]
  • Boot fixed, don't need to tap the screen, it will boot to CyanogenMod automatically.
  • No more "type password to decrypt storage" message
  • CWM touch recovery working
alpha1:
  • [01/11/2012]
  • First release
  • Based on FXP-144b
  • Not source based now
xda
Modifié par Dragnxt
  • 1 month later...
[ROM][CM9]FireDroid 1.3 for LockedBootloader[04/01/2013]
1.3:
  • [04/01/2013]
Sans doutes la rom la plus fluide que j'ai vu, enfin utiliser, vraiment magnifique, mais y'as un petit prob avec la camera, La qualité n'est pas au rendez vous... et moi qui utilise l'appareil photo assez souvent, je ne trouve pas vraiment mon bonheur avec, mais dans l'ensemble c'est une super rom, j'attend un meilleur version avec une meilleur qualité photo
D'accord merci, la firedroid est très fluide mais je trouve qu'elle ressemble à la version froyo (surtout les icones).
C'est pour sa que j'en cherche d'autres.
Savez-vous si les rom xperia u, s ou même p passe sur le sola (sans risques de brik)??
Merci encore pour les rom, on en croise pas des masses pour le sola.
En fait je vient d'installer la infinity et j'ai brické mon tel, il reste bloqué sur l'écran sony.
Savez-vous comment je peut l'éteindre?
Réponse pour ceux qui seraient dans la même galère :
https://forum.frandroid.com/topic/128046-tuto-videodemontage-sola/
Il faut débrancher le premier petit embranchement, après le téléphone est éteint.
Ensuite merci le recovery et surtout les backups...
Merci diabaulo, j'ai vu ta réponse qu'après.
Je testerai la prochaine fois ^_^
  Le 12/01/2013 à 20:11, linuxiendepassage a dit :
Oui en effet après test repartir de zéro est mieux.
Et franchement firedroid intestable, très fluide, système bien épuré, le strict nécessaire.
Seul bémol, pour moi, l'appareil photo un peu bas de gamme et les icônes à la froyo.
Les icones change les avec desktop visualizer et photo va voir si cybershot mod est compatible avec cette rom, logiquement oui car c est pas du cyanogen pure, cm9 stock base...
tapatalked
Merci pour l'appli icônes c'est pile ce qu'il me fallait.
En fait avec plusieurs applications appareil photo et galerie les photos et vidéos ne prennent pas tout l'écran, même pris sous la stock rom, c'est peut-être parce que cette rom est pour un autre xperia à la base.
J'ai trouvé camera mx qui permet de prendre photos et video avec la bonne résolution d'écran.
Par contre j'ai pas pu restaurer l'appli photo d'origine à partir de titanium c'est bizarre, je testerai donc d'installer cybershot.
  • 1 month later...
  Le 17/02/2013 à 08:16, EowynCarter a dit :
Oui, c'est ce que quelqu'un disais. Que le bluetooth audio ne passait pas...
Y'a une rom ou tout marche ?
Ultimate v2 elle est tres bien
http://forum.xda-developers.com/showthread.php?t=2025449
tapatalked
  • 2 months later...
Après avoir essayé cette rom, j'ai aussi des problèmes avec le bluetooth. Je cherche donc une autre rom qui soit compatible avec un BL bloqué. Concernant la Ultimate V2, comme je suis un naze en anglais, je ne sais d'abord laquelle version prendre et surtout comment l'installer (peut-etre est-ce comme la FireDroid ?).
