Xpredator Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Bonsoir, j'ai flashé mon Xperia T il y a peu, je crois qu'il est bien flashé mais j'ai l'impression qu'il y a des problèmes sur ceci : 05/048/2012 17:48:16 - INFO - <- This level is successfully initialized 05/048/2012 17:48:16 - INFO - Flashtool Version 0.9.6.0 built on 2012-09-17 22:32:25 05/048/2012 17:48:16 - INFO - You can drag and drop ftf files here to start flashing them 05/048/2012 17:48:17 - INFO - Device disconnected 05/056/2012 17:56:11 - INFO - Device connected with USB debugging off 05/056/2012 17:56:11 - INFO - For 2011 devices line, be sure you are not in MTP mode 05/004/2012 18:04:08 - INFO - Device disconnected 05/015/2012 18:15:32 - INFO - Selected Xperia T LT30p_4.0.4 _Generic.ftf 05/015/2012 18:15:32 - INFO - Preparing files for flashing 05/016/2012 18:16:15 - INFO - Please connect your device into flashmode. 05/018/2012 18:18:42 - INFO - Opening device for R/W 05/018/2012 18:18:43 - ERROR - Drivers need to be installed for connected device. 05/018/2012 18:18:43 - ERROR - You can find them in the drivers folder of Flashtool. 05/018/2012 18:18:45 - INFO - Start Flashing 05/018/2012 18:18:45 - INFO - Processing loader 05/018/2012 18:18:45 - INFO - Checking header 05/018/2012 18:18:45 - INFO - Ending flash session 05/018/2012 18:18:45 - ERROR - 05/018/2012 18:18:45 - ERROR - Error flashing. Aborted 05/018/2012 18:18:45 - INFO - Device connected in flash mode 05/018/2012 18:18:54 - INFO - Device disconnected 05/019/2012 18:19:02 - INFO - Device connected with USB debugging off 05/019/2012 18:19:02 - INFO - For 2011 devices line, be sure you are not in MTP mode 05/019/2012 18:19:44 - INFO - Device disconnected 05/020/2012 18:20:54 - INFO - Selected Xperia T LT30p_4.0.4 _Generic.ftf 05/020/2012 18:20:54 - INFO - Preparing files for flashing 05/021/2012 18:21:10 - INFO - Please connect your device into flashmode. 05/021/2012 18:21:50 - INFO - Device connected in flash mode 05/021/2012 18:21:50 - INFO - Opening device for R/W 05/021/2012 18:21:50 - INFO - Reading device information 05/021/2012 18:21:50 - INFO - Phone ready for flashmode operations. 05/021/2012 18:21:50 - INFO - Start Flashing 05/021/2012 18:21:50 - INFO - Processing loader 05/021/2012 18:21:51 - INFO - Checking header 05/021/2012 18:21:51 - INFO - Flashing data 05/021/2012 18:21:53 - INFO - Loader : S1_Root_7054 - Version : R5F001 / Bootloader status : NOT_ROOTABLE 05/021/2012 18:21:53 - INFO - Processing partition-image.sin 05/021/2012 18:21:53 - INFO - Checking header 05/021/2012 18:21:53 - INFO - Flashing data 05/021/2012 18:21:53 - WARN - This file is ignored : simlock.ta 05/021/2012 18:21:53 - INFO - Processing kernel.sin 05/021/2012 18:21:53 - INFO - Checking header 05/021/2012 18:21:53 - INFO - Flashing data 05/021/2012 18:21:56 - INFO - Processing fotakernel.sin 05/021/2012 18:21:56 - INFO - Checking header 05/021/2012 18:21:56 - INFO - Flashing data 05/021/2012 18:21:58 - INFO - Processing amss_fsg.sin 05/021/2012 18:21:58 - INFO - Checking header 05/021/2012 18:21:58 - INFO - Flashing data 05/021/2012 18:21:58 - INFO - Processing amss_fs_1.sin 05/021/2012 18:21:58 - INFO - Checking header 05/021/2012 18:21:58 - INFO - Flashing data 05/021/2012 18:21:59 - INFO - Processing amss_fs_2.sin 05/021/2012 18:21:59 - INFO - Checking header 05/021/2012 18:21:59 - INFO - Flashing data 05/021/2012 18:21:59 - INFO - Processing apps_log.sin 05/021/2012 18:21:59 - INFO - Checking header 05/021/2012 18:21:59 - INFO - Flashing data 05/022/2012 18:22:00 - INFO - Processing system.sin 05/022/2012 18:22:00 - INFO - Checking header 05/022/2012 18:22:01 - INFO - Flashing data 05/026/2012 18:26:48 - INFO - Processing userdata.sin 05/026/2012 18:26:48 - INFO - Checking header 05/026/2012 18:26:48 - INFO - Flashing data 05/027/2012 18:27:01 - INFO - Processing cache.sin 05/027/2012 18:27:01 - INFO - Checking header 05/027/2012 18:27:01 - INFO - Flashing data 05/027/2012 18:27:04 - INFO - Ending flash session 05/027/2012 18:27:04 - INFO - Flashing finished. 05/027/2012 18:27:04 - INFO - Please unplug and start your phone 05/027/2012 18:27:04 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 05/027/2012 18:27:04 - INFO - Device connected in flash mode Si Quelqu'un pouvait me dire si tout va bien, ou si il y a un problème je lui en serais reconnaissant. J'aurais aussi aimé savoir si je fais une restauration du système que j'avais faite avant de downgrader mon telephone cela va t'il poser un problème et si oui comment faire pour remettre au moins partiellement les anciennes données. Ha au faite j'aurais aimé savoir si c'est grave, je me suis trompé lors des étapes de différents tutos, j'ai downgrader en utilisant le rom générique mais après je me suis tromper de tuto et j'ai directement rooté avec la "procédure ultra simple" je suis donc root sous version 7.0.1.303 cela va t'il me poser des problèmes ? Merci d'avance. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Pour la partie flash, ça c'est bien déroulé. Avec quoi as tu effectué ta sauvegarde? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xpredator Posté(e) 5 décembre 2012 Auteur Share Posté(e) 5 décembre 2012 Merci pour cette réponse rapide. J'ai effectué la sauvegarde avec"sauvegarde et reparation". Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Tu n'auras pas de problèmes, tu peux même sélectionner les types de données à restaurer. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xpredator Posté(e) 5 décembre 2012 Auteur Share Posté(e) 5 décembre 2012 En effet tout fonctionne à merveille. Merci encore pour ta réponse. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 De rien. :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
