Problemes install des drivers sous XP
Bonjour a tous
j'essaye en vain depuis 48h d'installer les pilotes USB sous xp .
Le bouzin me répond que je dois etre en mode sans échec ou bien "windows installer" n'est pas
installé .
j'ai donc récuperé la derniere version du KB893803 pour voir , mais ca ne change en rien ,
échec de l'install !
quelqu'un a t'il été confronté au memes soucis que moi ?
d'avance merci ...
voici mon log de l'echec pour info :
e following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = Intel {string}
Property: [VersionNT] = 5.1.3 {version}
Running checks for package '.NET Framework 2.0', phase BuildList
Running external check with command line "C:\DOCUME~1\eric\LOCALS~1\Temp\VSDDC.tmp\dotnetfx\dotnetchk.exe"
Process exited with code 1
Setting value '1 {int}' for property 'DotNetInstalled'
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer'
Read string value '8.0.6001.18702'
Setting value '8.0.6001.18702 {string}' for property 'IEVersion'
The following properties have been set for package '.NET Framework 2.0':
Property: [DotNetInstalled] = 1 {int}
Property: [iEVersion] = 8.0.6001.18702 {string}
Running checks for command 'dotnetfx\instmsia.exe'
Result of running operator 'ValueExists' on property 'VersionNT': true
Result of checks for command 'dotnetfx\instmsia.exe' is 'Bypass'
Running checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'ValueExists' on property 'Version9x': false
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.0': true
Result of checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
Running checks for command 'dotnetfx\dotnetfx.exe'
Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': true
Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Bypass'
'.NET Framework 2.0' RunCheck result: No Install Needed
Launching Application.
Using MsiInstallProduct with package path 'C:\Documents and Settings\eric\Mes documents\Downloads\Compressed\USB_Acer_1.0_A40I_A\USB_Acer_1.0_S500\acer S500 Driver install.msi' and command line
oui , c'est exactement ceux pris sur le site ACER , apparement c'est un fichier en défaut de mon install XP .
j'avais la version 2 du " vindows installer " , j'ai récuperé la version 4.5 , la derniére en date sur Microsoft , pensant
que ca résoudrais l'échec , mais rien n'a changé ...
