[ROM] [19-05-2013] BinDroid XTC 11.0.0 - Jelly Bean 3.20 Sense 4+
- BinDroid XTC -
Résumé :
Skin faite par DutchDanny
Optimisation images 9patch
Icônes réalisées par DutchDanny, Wanahave & Benjamin
Base: 3.19.401.1 CL128187 release-keys
Rooted with Latest SuperSU & Latest Binairies
Latest Busybox
init.d support
Recompressed System for les stress on RAM
Zipaligned
Persistent ADB enabled
Optimized PNG's
Aroma Installer 2.56
Latest hosts file
Custom BootAnimation
Custom DownAnimation
Fully skinned rom with BinDroid Blue & Icons
Updated All Apps
A lot more...
Applications ajoutées :
Adfree
Solid Explorer
Titanium Backup (BinDroid Skinned)
WhatsApp (BinDroid Skinned)...
Images de la Rom :
Derniers changements :
BinDroid XTC One X V11.0.0
3.20.401.1 CL156838 release-keys
*Info
New Base = Fullwipe
3.20.401.1
New Kernel = You know the drill
xm_kernel_305_sense
*Rom
- Basic BinDroid SetUp
- Updated modded services.jar
- added NEW default wallpaper
- Updated fusion.apk - New NavBar
- Updated Apps
*Skin in vrtheme
- Updated skin for WhatsApp
- Updated skin for ES File Explorer
*Aroma
BinDroid XTC One X V10.0.0
3.19.401.1 CL156838 release-keys
*Info
xm_kernel_188v4_sense
Flash boot.img
fastboot erase cache
wipe dalvik cache
*Rom
- Removed PCTOOLS file
- Added Basic BinDroid Setup
- Audio is STOCK
*Aroma
- Aroma Setup Updated to: 5.1
- Updated Senseless Launchers
- Adde some Lyapota resouremanager stuff
- updated skin
BinDroid XTC One X V9.1.0
3.14.401.31 CL128187 release-keys
*Info
NEW CUSTOM BINDROID KERNEL
Flash boot.img
*Rom
- Kernel: V0.1.2
- Updated hosts file
- Stock Optimized Rom
- Updated updater-script
- Added skin to the build again
- init.d script support
- Updated all Apps
- lyapota mod pack v3.3
*Aroma
- Changed init.d script to fit BinDroid Kernel
- New Install Menu
- BinDroid ringtones
- BinDroid Bootsound
- Removed 1 disable screenshot mod (there where 2)
- Added Volume Awake mod
- Removed music landingpage mod (interfere with layapota mod)
- Added updated camera from lyapota V5.5
- Added option for brightness
- Added more Rosie options
BinDroid XTC One X V9.0.0
*Info
NEW BASE
flash new boot.img!
flash new hboot 1.39 if for your cid
*Rom
- Updated all Apps
- Previous Mods & Tweaks included
- Added landscape rosie
- Added 1% increse battery
- removed adfree
- added adaway
*New Skin
- To much to write down
*Aroma
- Basic BinDroid Rom Setup on XTCskin install
- Added XTC Skin install
- Added more skin to XTC skin
- Added more options for build.prop tweaks install
- Added more options for init.d tweaks install
- Updated Etrim Cam to 5.1
- Updated Onscreen Messages to 2.0
- Updated LongPress Kill
Téléchargement :
http://www.bindroidr...roid-XTC-One-X/
Installation :
Prérequis :
- Avoir un bootloader débloqué et un recovery custom installé (TWRP ou CWM)
- Avoir le bootloader en version 1.36 ou supérieure (pour mettre à jour votre bootloader voir ici : http://forum.frandro...e-rien-a-faire/)
1. Copier la Rom dans votre Hox
2. Éteignez votre One X et aller dans le bootloader en mode fastboot
3. Flasher le boot.img que vous trouverez à la racine du zip de la rom
4. Sans REBOOTEZ ! Aller en Recovery faites les wipes (system, data, cache, dalvik-cache)
5. Flasher la Rom avec le recovery custom
6. Enjoy :)
Vidéo d'explication de l'installation avec le Menu Aroma :
Mon avis: Énormément de tweaks à choisir dans le menu Aroma, et le skin est vraiment très joli !!!
source : http://forum.xda-dev....php?t=1627972/
http://www.bindroidroms.com/site/
Modifié par poggus
@jeyy je te conseille l'appli WidgetSoid qui est bien mieux que Extented Settings, et surtout en français et développé par un gars du forum Frandroid donc autant le soutenir :)
https://play.google.com/store/apps/details?id=com.jim2
https://www.frandroid.com/applications/54288_widgetsoid-maniez-votre-androphone-du-bout-des-doigts/
ha ouai merci elle est complètement mieux!
@pika pour la batterie en haut a gauche ça se vire facilement
menu>notifications>onglet avancé> icône de notif choisir aucun
Modifié par jeyy
Hello,
Je suis en hboot 1.36 (car pour les roms avec Sense4+ hboot 1.36 minimum).
Ce kernel marche bien pour le moment.
Seul souci c'est qu'il se connecte/déconnecte pas automatiquement d'un réseau wifi, en fait la 3G prend bien le relais en extérieur mais l’icône et dans les paramètres wifi c'est comme si on était toujours connecté, petit bug pas bien grave...
Pour baisser la luminosité de la rom (grosse économie de batterie!) et en attendant la mise à jour du patch auto brightness sur xda pour la nouvelle base en 3.14. je découvre cette appli qui est pas mal du tout : https://play.google.....vito.lux&hl=fr
Sinon j'ai ajouté quelques tweaks dans le build.prop de la rom au besoin je pourrais les balancer ici.
Modifié par poggus
Tu es sur la Bindroid Tu as flashé la version .27 dessus ?
quand je choisi agressive patch de la version .27 je ne peux plus booter ... du coup j'ai bloqué la luminosité à 30 % et je me prends plus la tête avec
Modifié par poggus
ok merci.
mais sur la Bindroid il y a un mode APM déjà intégré et avec un thème dessus à mon avis les 2 ensembles c'est pas compatible car je n'arrive plus à booter après le flash.
Sur xda les gars demandent à jotha de mettre à jour son mode pour la base .31, j'espère qu'il va le faire rapidement car ceux sur ARHD ont le même pb visiblement.
Modifié par poggus
Salut à tous !
Donc je viens d'essayer cette rom très fluide, rapide et un thème vraiment complet et magnifique mais ..... mais ..... :P
J'ai le même souci avec les version JB avec la qualité photo !!
Voila la photo :
Je vous poste la même photo prise avec la viper X 2.7.1 dan quelques minutes !!
Modifié par saboo
Salut !
Non je peux pas je l'ai acheter sur un site de vente sur le net genre le bon coin mais en Algérie !
Voila j'ai remis mon backup viper X 2.7.1 et regarder l'image !!
Qu'est ce que vous en dites ??
Modifié par saboo
