Xperia ZL
visiblement il n'y a pas de post dédié à ce modèle, et même s'il s'agit d'une variante du Z, il serait intéressant de regrouper les infos.
Look :
Caractéristiques techniques :
GENERAL 2G Network GSM 850 / 900 / 1800 / 1900 - C6502, C6503, C6506
3G Network HSDPA 850 / 900 / 1700 / 1900 / 2100 - C6502, C6506
HSDPA 850 / 900 / 2100 - C6503
4G Network LTE 700 / 850 / 1700 / 1900 / 2100 - C6506
LTE 800 / 850 / 900 / 1800 / 2100 / 2600 - C6503
SIM Micro-SIM
Announced 2013, January
Status Coming soon. Exp. release 2013, Q1
BODY Dimensions 131.6 x 69.3 x 9.8 mm (5.18 x 2.73 x 0.39 in)
Weight 151 g (5.33 oz)
DISPLAY Type TFT capacitive touchscreen, 16M colors
Size 1080 x 1920 pixels, 5.0 inches (~441 ppi pixel density)
Multitouch Yes, up to 10 fingers
Protection Shatter proof and scratch-resistant glass
- Timescape UI
- Sony Mobile BRAVIA Engine 2
SOUND Alert types Vibration; MP3 ringtones
Loudspeaker Yes
3.5mm jack Yes
MEMORY Card slot microSD, up to 64 GB
Internal 16 GB, 2 GB RAM
DATA GPRS Up to 70.4 kbps
EDGE Up to 236.8 kbps
Speed HSDPA, 42 Mbps; HSUPA, 5.76 Mbps; LTE, Cat3, 50 Mbps UL, 100 Mbps DL
WLAN Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
Bluetooth Yes, v4.0 with A2DP
NFC Yes
Infrared port Yes
USB Yes, microUSB v2.0 (MHL)
CAMERA Primary 13 MP, 4128x3096 pixels, autofocus, LED flash
Features Geo-tagging, touch focus, face detection, image stabilization, HDR, sweep panorama
Video Yes, 1080p@30fps, continuous autofocus, video light, video stabilizer
Secondary Yes, 2 MP, 1080p@30fps
FEATURES OS Android OS, v4.1.2 (Jelly Bean), planned upgrade to v4.2 (Jelly Bean)
Chipset Qualcomm MDM9215M / APQ8064
CPU Quad-core 1.5 GHz Krait
GPU Adreno 320
Sensors Accelerometer, gyro, proximity, compass, barometer (C6502 only)
Messaging SMS (threaded view), MMS, Email, IM, Push Email
Browser HTML5
Radio Stereo FM radio with RDS
GPS Yes, with A-GPS support and GLONASS
Java Yes, via Java MIDP emulator
Colors Black, White
- SNS integration
- TV-out (via MHL A/V link)
- One-touch mirroring
- IR Remote
- Active noise cancellation with dedicated mic
- MP4/H.263/H.264/WMV player
- MP3/eAAC+/WMA/WAV/Flac player
- Document viewer
- Photo viewer/editor
- Voice memo/dial
- Predictive text input
BATTERY Non-removable 2370 mAh Li-Ion battery
Stand-by Up to 500 h (2G) / Up to 500 h (3G)
Talk time Up to 10 h (2G) / Up to 13 h (3G)
Music play Up to 40 h
Source : gsmarena
Différences avec le Xperia Z :
- Matériaux : dos en plastique (vs verre), non résistant à l'eau et à la poussière.
- Taille : 131.6 x 69.3 x 9.8 mm (vs 139 x 71 x 7.9 mm), 151 g (vs 146 g)
- Trappe arrière pour la carte micro-SIM et carte micro-SD
- Bouton dédié à l'appareil photo
- Led de couleurs sous l'écran
- Port infrarouge
Vidéos de prise en main :
Xperia ZL vs Xperia Z
Informations commerciales :
Le Xperia ZL est prévu pour ce que Sony appelle des "selected market". Concrètement, il n'est pas prévu dans tous les pays où Sony Mobile est présent.
Il n'est pas prévu pour la France. Virgile (de Sony Mobile France) à confirmé qu'il allait sortir auxPhilippines, Singapour, Ukraine, Pays de l'Est, Russie, Pays Nordiques, Brésil et Allemagne. Il a été annoncé également au Canada.
Si j'ai bien tout compris, la version C6503 du ZL devrait être totalement compatible en France, y compris pour la 4G.
Pas encore de date et de prix annoncé, même s'il semble prévu pour mars.
Compléments :
Comme pour le Z, le ZL sera fourni à les écouteurs haute qualité MH-EX300AP
Par ailleurs, à l'instar du Xperia U, la led colorée du ZL changera de couleur lors du visionnage de photos :
Le coloris rouge à fait son apparition il y a quelques jours. Sur cette version, la face avant est noire.
C'est une variante intéressante à bien des égards :
- un peu moins long
- déclencheur photo
En revanche il est nettement plus épais et n'est pas ip55 / ip57.
Il ne sera pas disponible en France.
  • Auteur
Moi j'avoue que j'aime son look compact, le bouton apn, et le fait que le blanc soit aussi présent sur la face avant.
Une question : est-ce que la version commercialisée en Allemagne sera sur les même fréquences, même 4G, qu'en France? Si oui l'import sera facile.
Sausalito, tu viens d'égayer ma journée avec la version C6503 :D
  • Auteur
Concernant la fiabilité des infos présentes sur les sites de Sony Mobile, et émanant en interne de Sony Mobile France, j'émets quelques doutes : en effet, le ZL est proposé sur les sites Suisse et Belge, pour autant, Virgile de Sony Mobile France n'a pas parlé de ces pays concernant la dispo du ZL. Mais il a parlé de l'Allemagne alors que le site internet ne le présente pas.
De plus, le ZL a été officiellement annoncé pour le Canada, pays non évoqué non plus dans la liste fournie par Sony Mobile France.
Enfin, ils sont incapables de nous dire si le Xperia V sort en France, et quand, alors que le site le propose en "précommande" pour prochainement.
Bref, je pense que l'info circule mal au sein des divisions de Sony mobile, et/ou que les décisions changent vite.
Modifié par Sausalito
J'ignore pour la 4G, si la fréquence est la même que dans le pays de Goethe, alors ça ne devrait pas poser de soucis.
Pour le ZL on verra bien niveau dispo, Amazon.DE est là pour ça au pire ;)
La France aurait les bandes 800 MHz et 2,6 GHz, donc la version C6503 serait compatible :)
Modifié par ASP
il ne sera pas vendu en france d'apres test mobile
Modifié par Gall2duo
  • Auteur
Oui c'est précisé dans le premier post, rubrique Infos commerciales.
600€ :/ je m'attendais à un peu moins cher ^_^
  • Auteur
Moi aussi... même si le plus cher est sans doute les composants (identiques au Z) et non le revêtement...
Ceci dit, on trouvera TRES VITE le Z à moins de 600€, donc le ZL vers 500€ je pense (après un ou deux mois).
  • Auteur
Malgré des recherches web intensives, aucune infos encore sur la sortie et le tarif de ce modèle (dans les pays où il sera disponible).
Oui, en avril en Allemagne apparemment... -_-
Ce zl aussi me botte plus que Z pour les mêmes raisons et contrairement à beaucoup je prefere son dos en plastique car le dos en verre du Z a l'air de prendre les traces de doigts et me connaissant je finirais forcément par mettre une coque donc au final j'y perderais l'avantage du design du Z . Je suis pas fana des caches sur les ports surtout pour la prise jack je trouve pas ça esthetique et genant pour ceux qui aimer brancher leur casque audio .Pour le IP55/57 j'ai toujours fait sans jusqu'a maintenant donc ce n'est pas important pour moi .
Info : le ZL a été aperçu sur le site PhoneHouse.de à... 600 € sans abonnement (contre 650 € pour le Z).
La fiche a disparu du site depuis.
Source : http://easternmornin...ermany/1224824/
il est annoncé maintenant à 549€ sur le site phonehouse.de pour ce prix ça devient intéréssant
Ah oui, 100€ de moins que le Z, là ça commence à valoir le coup :D
Perso j'hésite encore entre les deux, mais les deux seuls avantages du Z sont son design et sa dispo française. À l'oppose les avantages du ZL sont le prix, la praticité au quotidien (pas les caches, ni les traces de doigt), le bouton APN, les dimensions réduites, la batterie un poil plus puissante, le bouton de volume mieux placé...
Après, est-ce que ça vaut le coup de le faire importer? Gros dilemme.
  • Auteur
Surtout quand on sait, par exemple, que le Xperia Z est à 649 € sur PhoneHouse.de, et 629 € chez Amazon.de.
Donc on peut même espérer que le ZL sera à moins de 549€ à sa sortie.
En tout cas j'aime vraiment son format compact er sony a réussi à faire tenir un 5" dans les dimensions d'un S3 en terme d'encombrement c'est parfait.
par contre si j'ai bien compris il sera en vente en Avril ? c'est dommage qu'ils sortent d'ici la car avec le ONE ,le galaxy S4 il y a de quoi hésiter aprés ce qui peut vraiment faire pencher la balance c'est si on le trouve à un prix attractif .
  • 5 months later...
je voulais savoir si ce Xperia ZL était compatible avec la France car j'ai vu que ce n'était seulement que le modèle C6503 et je n'arrive pas à trouver ces informations sur l'article: http://www.amazon.de/Sony-Smartphone-Touchscreen-Quad-Core-Megapixel/dp/B00BCSXOP2/ref=sr_1_1?ie=UTF8&qid=1375203334&sr=8-1&keywords=Xperia+ZL
Merci :)
Merci pour cette réponse mais je comprends pas ce que ca veut dire "900mhz et 2000/2100mhz" ^^
