[ROM] 25/01/2013 - BlueAndroid V3.0 | Clean - Fast - Stable | Blue Theme Concept !
Hi to everyone !
Welcome to the Real Blue World !
BlueAndroid - A Real Blue Theme Concept !!!
Was designed to be used in everyday life : BlueAndroid is one of the most powerful Custom Rom designed for tablet Asus TF300T while being very fast' date=' stable and with a special animation !!![/color']
Screenshots:
About :
  • Release date : 25/01/2013
  • Custom Rom - based on Stock Asus JB Firmware 10.4.2.20 - > BlueAndroid@V3.0 !
Change Log :
  • insecure kernel & root access !
  • init.d support ( run automatic all scripts in directory /system/etc/init.d - on every boot ! ) ;
  • USB debugging already enabled ;
  • activate ZRAM , for easily to implement SuperCharger !
  • enabled CLEANCACHE ;
  • enabled Control Voltage ;
  • enabled overclock CPU up to 1.6GHz !
  • device boots at 1.3 GHz to avoid any issue !
  • enabled overclock GPU up to 484MHz !
  • increase data I/O ;
  • tweaks ext4 , I/O, database & build.prop ;
  • added I/O scheduler : deadline, vr & sio !
  • added Governor : lulzactive & pegasusq !
  • added cifs.ko, md4.ko & tun.ko modules !
  • added drivers for USB Ethernet : include asix.ko, mcs7830.ko & smsc95xx.ko modules !
  • added reboot, recovery & bootloader items -> now translated into eight* languages !!!
  • added Power saving mode -> 1.0GHz, Balanced mode -> 1.3GHz & Performance mode -> 1.6GHz -> now translated into eight* languages !!!
  • added Music Player Apollo ;
  • added DSPManager instead MusicFX !
  • added Cyanogen FileManager ;
  • blue theme by surdu_petru
    • replace icon ~90%
    • windows animation
    • transparent windows
    • awesome windows blue
    • secondary text blue
Download :
Installation :
  • copy archive BlueAndroid@V3.0 in your device ;
  • go to recovery (TWRP or CWM) ;
  • wipe cache, dalvik-cache, system & factory-reset !
  • navigate to archive BlueAndroid@V3.0 and choose Install ;
  • Reboot System !
  • you can optionally install : Asus proprietary apps by installing archive asus_tf30t or Google apps by installing archive google_tf300t !
  • copy archive asus/google_tf300t in your device ;
  • wipe cache & dalvik-cache !
  • navigate to archive asus_google_tf300t and choose Install ;
  • Reboot System !
If you want to use usb ethernet****, please install archive : usb_ethernet in recovery by wiping cache & dalvik-cache !
After device boot successfully , please reboot again your device - now you are able to use usb ethernet !
[url=http://d-h.st/QuP]usb_ethernet.zip - 125.98 KB[/url]
Big THANKS to mikaole, for all Mirrors Download !
regards,
Surdu Petru !
Liens http://forum.xda-developers.com/showthread.php?t=2000542
reserved
Merci pour cette présentation...
Surdu_petru fait du super taf' ...et de + il est français ...ou vit en France ...
Maintenant, il sera intéressant d'avoir des retours dessus !
Est-elle overclock initialement ou pas ? ou bien simplement elle a la capacité de .. ?
Elle a quoi de + que la stock ? (hormis le thème bleu...)
Modifié par Fullpower
alors j'ai testé la v2 mais c'est celle que j'ai retenu sur ma tablette , je la trouve très fluide , le thème est sympa et les animations aussi , c'est avec cette rom que j'ai obtenu le score bench le plus élevé on passer à 1.6ghz facilement
Et pour ceux qui ne veulent pas overclocker ?
Y'a moyen de la laisser tourner à la fréquence initiale ?
Edit : oui simplement en selectionnant le mode d'energie ...performance, éco, équilibré... j'avais pas vu le screen shot ..
Juste que en mode équilibré qui tourne initialement a 1200 on est a 1300.
Autre chose, elle consomme environ 100mo de ram en plus que ma stock .18, je pense que c'est du aux animations et aux rajouts divers niveau U.I
Et juste un petit regret, il aurait pu changer le skin de la barre asus, ce purple zébré, ca me sort par les yeux un fond noir serait plus adapté a JB (comme la barre aosp)
Modifié par AssLicked
C'est light comme o.c, c'est la même fréquence que la Prime, ou le mode normal de la stock.
Après libérer de la ram, Android s'en charge au moment opportun mais tu le sais je pense. Tant que l'U.I est fluide et que les grosses applis mettent pas 3 plombes a se charger... :)
J'ai un bug dans les paramètres :
Le fait de vouloir désactiver les paramètres développeurs reboot la tablette, et depuis la sélection des paramètres personnalisés Asus crash l'application paramètres.
J'ai bien penser a effacer les données de l'appli paramètres, mais je ne suis pas sur que se soit sans conséquences. (?)
Edit : Bon j'ai trouvé pourquoi : j'ai viré Pc Sync et un type sur xda a fait la même erreur. Enfin pas grave.
