[DEV][ROM][14.05] CyanogenMod 10 (Android 4.1.2) KonstaT
ablackswan
This is my quick port of CyanogenMod 10 for ZTE atlas40 devices (Blade III, Acqua, etc). It is unofficial and unsupported by the CyanogenMod team. It's for advanced users only and mainly for testing purposes. I'm using my old CM10 source tree that I used on my Blade builds, so this build is also trimmed (mostly wallpapers and ringtones) and has quite a few additional features.
post-834050-0-32035200-1359304178_thumb.pngpost-834050-0-38872200-1359304195_thumb.pngpost-834050-0-08180600-1359304213_thumb.pngpost-834050-0-78354500-1359304237_thumb.png
cm-10-20130514-KonstaKANG-atlas40.zip
https://hotfile.com/...tlas40.zip.html
md5:1e36fd3b602437bac57f69abea2bc4f0
gapps-jb-20121011-signed.zip (goo.im/gapps)
http://goo.im/gapps/...1011-signed.zip
md5:4e9e7ec3c22b0b3471bd05d62b8a659d
Working:
  • RIL (mobile network & data)
  • Wifi
  • Bluetooth
  • GPS
  • Audio (playback/input/routing/headphones/etc)
  • Camera (photos, camcorder & panorama)
  • Hardware acceleration and OpenGL rendering
  • Hardware video decoding & encoding
  • 'Project Butter'
  • SDcard
  • USB-storage (on sdcard) & adb
  • USB-tethering
  • Wifi-tethering
  • Touchscreen/multi-touch
  • Sensors
  • LEDs
Not working:
  • FM radio (probably never)
Sources:
  • CyanogenMod team
Changelog
14.5. changelog:
  • reverted internal storage support
  • fixed speakerphone during calls
18.4. changelog:
  • add mount point for internal storage
  • possible fix for texture corruption on some rare occasions (thanks to daemond)
  • kernel optimizations and fixes to build using newer compilers (now compiled with gcc 4.6 toolchain)
  • take back some RAM (now 404MB available)
  • update kernel display/kgsl drivers
  • update adreno blobs
  • include live wallpapers & more ringtones
  • rewrite device settings
  • add option to disable button backlight
24.2. changelog:
  • fixed data usage statistics
15.2. changelog:
  • fixed native wifi tethering
  • added ROW i/o scheduler
  • Add option to enable/disable Electron Beam Animation (1,2)
6.2. changelog:
  • proximity sensor issues should be fully fixed (let's hope at least tongue.png)
    • added proximity wakelock (should fix black screen after 'long' calls)
    • changed default proximity range (proximity should now work without any workarounds)
    • removed proximity calibration (actual calibration data was never used but it was a good workaround)
    [*]fixed camera flash on Acqua
3.2. changelog:
  • harware vsync events
  • enabled few good old graphics hacks used on msm7x27
  • changed composition type to fix notification area freezes
  • updated power profile - battery stats are now displayed
  • enabled repeating ringtone
  • added workaround for proximity sensor (proximity is now automatically 'calibrated' on every reboot)
  • added support for touchscreens used in ZTE Acqua
29.1. changelog:
  • build wpa_supplicant from source
  • fix muted microphone during calls
  • change button backlight behaviour
  • enable expanded destktop feature
27.1. changelog:
  • initial release
lien original : http://www.modaco.co...10-android-412/
Modifié par ablackswan
  • 5 months later...
