error ListView personnalisé
skywallker
Bonjour
J'ai un probléme consernant ma ListView
Je ne trouve pas l'erreur merci de votre aide
XML itemliste.xml
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="match_parent"
android:orientation="horizontal" >
<LinearLayout
 android:layout_height="80dp"
<ImageView
 android:id="@+id/itemlistimage"
 android:layout_width="60dp"
 android:layout_height="fill_parent"
 android:src="@drawable/anneau" />
<TextView
 android:id="@+id/itemlisttext"
 android:text="description"
 android:gravity="center"
</LinearLayout>
</LinearLayout>
XML:jim.xml
android:layout_width="match_parent"
android:orientation="vertical" >
<ListView
android:id="@+id/list"
android:layout_height="wrap_content"
</ListView>
</LinearLayout>
Mon activity :
package Citation.movies;
import java.io.IOException;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import Citation.movies.BDD.BDDF;
import Citation.movies.BDD.QuoteFilm;
import android.app.Activity;
import android.content.res.Resources;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.drawable.BitmapDrawable;
import android.graphics.drawable.Drawable;
import android.os.Bundle;
import android.widget.ArrayAdapter;
import android.widget.ImageView;
import android.widget.ListView;
import android.widget.SimpleAdapter;
import android.widget.TextView;
public class CitationActivity extends Activity {
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.jim);
ArrayList<HashMap<String, String>> listItem = new ArrayList<HashMap<String, String>>();
ListView lv = (ListView) findViewById(android.R.id.list);
HashMap<String, String> map;
/********* préanbule ************************/
map = new HashMap<String, String>();
// map.put("itemlistimage", String.valueOf(R.drawable.anneau));
map.put("itemlisttext", "Editeur de texte");
listItem.add(map);
map.put("itemlisttext", "Tableur");
listItem.add(map);
map.put("itemlisttext", "Logiciel de présentation");
listItem.add(map);
SimpleAdapter mSchedule = new SimpleAdapter(this, listItem,
R.layout.itemliste, new String[] { "itemlisttext" },
new int[] { R.id.itemlisttext });
lv.setAdapter(mSchedule);
Dans les log le probléme viens de "lv.setAdapter(mSchedule);"
merci de vos réponse
Et quelle erreur as-tu précisemment ? quelle exception se produit ? tu peux être plus précis ?
Comme l'indique chpil, faudrait avoir ton code d'erreur que tu trouveras dans ton LogCat. Cela dit, j'ai remarqué une erreur évidente qui est la suivante :
Tu vas chercher la classe R d'android pour récupérer l'id de liste. Chose qui n'est pas correcte puisque tu veux aller chercher l'identifiant de ta liste que tu as déclaré dans ton fichier XML. Tu dois donc changer cette ligne par :
ListView lv = (ListView) findViewById(R.id.list);
Cela dit, c'est peut-être pas la seule erreur. Pour nous aider à t'aider, il faudrait avoir ton erreur.
