Device type:
1) Normal
2) Special (for example: Sony Tablet S,
Medion Lifetab)
x) Unroot
Make a choice: 1
Checking if i should run in Normal Mode or
special Sony Mode
Please connect your device with USB-
Debugging enabled now
remote object '/system/app/Backup-
Restore.apk' does not exist
remote object '/system/bin/ric' does not
exist
Normal Mode enabled!
Pushing busybox....
3989 KB/s (1085140 bytes in 0.265s)
Pushing su binary ....
2874 KB/s (91980 bytes in 0.031s)
Pushing Superuser app
3893 KB/s (996704 bytes in 0.250s)
Making busybox runable ...
Please look at your device and click
RESTORE!
If all is successful i will tell you, if not this
shell will run forever.
Running ...
Successful, going to reboot your device in
10 seconds!
Waiting for device to show up again....
Going to copy files to it's place
mount: permission denied (are you root?)
You can close all open command-prompts
now!
After reboot all is done! Have fun!
Bin4ry
Appuyez sur une touche
Je ne parvient pas a rooter mon L7, je commence a desesperer :(
