micky51100 Posté(e) 25 février 2013 Share Posté(e) 25 février 2013 (modifié) Android Version: 4.0.4 (IceCream Sandwich) Based on: HTC One SV 1.17.401.5 HTC Sense Version: 4.1 ( Full Sense ) Version 5 : New Camera (Sense 4.1 Camera) Fixed HDR & Panorama Fixed USB Mode Added 3D Cube Animation Updated Superuser Updated SU Binary Kernel changed to Patched 3.0.67 Added init.d Tweaks Updated Google Playstore to 3.10.14 Added virtuous Setup Optimize Added Wake Up By Volume Button To Aroma Installer Fixed Build.prop tweak Improved Battery longevité Fixed service.jar Improved signal wifi and drain Updated Talkback Updated TuneIn Updated Twitter Updated YouTube Updated Facebook Improved Performance ZipAlign With Latest Android SDK Build With Latest Tools</*> Something More That I Can't Remembered Version 4 : all bug fixed exept browser alternative Opera Version 3 : Added 4EXTRecoveryUpdater Added OTA Updater Remove Deamon controler Remove DNSMasq Fixed browser resized Fixed HTC Location Fixed HTC Widget New zipalign tweak Improve UI frame rate and touch response Version 2 : Fixed CroosBreeder Boot Added Beat audio for Headset Added Uni-init v1.0 control init.d Fixed loopy_smoothness_tweak Full Wipe Recommended because CrossBreeder reinstal Version 1 : Base To One SV 1.17.401.5 Initial version Multi Devices Full sense 4.1 kernel patched 3.0.62 Added OpenVpn Support Added Init.d Tweaks Improved Performance CroosBreeder + adblock + DNS Boost Added Tweak for better battery and performances Added SuperSU Full Wipe Recommended Added in aroma rotation homescreen V5 Fixed FULL WIPE obligatoire !!! Download RunnyBattLife V5 V4 FULL WIPE DO NOT FORGET TO FLASHER CrossBreeder_Mick.zip Download The Rom Put Rom in Your SD Card Do Full Wipe Flash The Rom Flash CroosBreeder_Mick Reboot after installation : - launch Uni-unit and verify init.d actived if not so enable ( ckeck scripts run ) au premier démarrage démarré Supersu pour installé la nouvelle lib. Ensuite allé dans l'appli Universal Init.d et cliquez sur activate. ( De là le support Init.d est réactivé ) En dernier et optionnel démarré script manager activé le root et allé dans system/etc/init.d/ et lancé le script 98CkeckSetting en root et au Boot de la vous appliqué un nouveau tweak low memory killer amidabuddha for kernel idcrisis for CroosBreeder Download RunnyBattLife V3 Download RunnyBattLife V2 Download RunnyBattLife V1 Initial Version Modifié 8 avril 2013 par micky51100 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
brol Posté(e) 27 février 2013 Share Posté(e) 27 février 2013 Salut, C'est quoi le différend sur le forum xda à propos de cette ROM ? Sinon, tout fonctionne avec cette ROM ? La batterie dépasse une journée ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 27 février 2013 Auteur Share Posté(e) 27 février 2013 (modifié) Salut,C'est quoi le différend sur le forum xda à propos de cette ROM ? Sinon, tout fonctionne avec cette ROM ? La batterie dépasse une journée ? Merci Alors je vais t'expliqué et c'est très simple ! Les différents ne sont pas qu'avac moi car le sujet de Sabsa à été fermé également suite à des plaintes de la Team vipère pour avoir Kanged des fichiers de leur Rom et moi également mais accusé par Sabsa ! En gros du grand n'importe quoi ! Car personnes n'arrive à comprendre que les fichiers sont seul propriétaire d'HTC et que leur avocat ne nous aiment pas trop et ont fais une demande officiel à XDA pour retiré toutes les ROM sense du site ainsi que pour le site HTCRUU ! Si [color=red]se[/color] n'est pas appliqué il menace de poursuite judiciaire ! Bref un truc de dingue ! Pour faire juste ma ROM est basé sur le RUU HTC One SV 1.17.401.5 et il est vrais que dans la ROM on peut trouvé quelques résidu d'autres ROM mais comme toutes les rom que j'ai pu trouvé sur le net ! Sinon pour cette ROM je tiens 3 jours et quand je me sers du GPS ( Car suis livreur ) je tiens 2 jours en moyenne ! Je l'est optimisé au maximum de se qu'il étais possible de faire avec du sense 4.1 avec un kernel approprié biensurs qui est le patched 3.0.62 une perle à mes yeux ! lol Sinon pour répondre globalement Nandbackup et essais ! lol EDIT : La je test l'ODEX sur la ROM et sa la rend encore plus rapide à s'exécuté Modifié 27 février 2013 par micky51100 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ryujin Posté(e) 11 mars 2013 Share Posté(e) 11 mars 2013 Bonjour, la rom a l'air sympa ...et tu la vend bien ,lol ! ^_^ il n'y a que cette partie qui me gene (! debutant !) : - launch Uni-unit and verify init.d actived if not so enable ( ckeck scripts run ) ??? Uni-unit est une appli ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 14 mars 2013 Auteur Share Posté(e) 14 mars 2013 Je prépare une nouvelle version ! Donc le peut de problème détecté va disparaître à la longue ! La je procède à différent test sur l'appareil photo car la qualité n'est pas top pour le moment donc j'essaie de porté l'app camera du sense 3.6 vers le sense.4.1 ! Mais je rencontre un blocage sur un fichier jar. J'attend de l'aide sur xda pour résoudre le problème camera ! Sois la cam sense 3.6 sera porté ou la cam sense 4.1 fixé ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ryujin Posté(e) 14 mars 2013 Share Posté(e) 14 mars 2013 Ok ! Attendons la nouvelle version alors :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
brol Posté(e) 30 mars 2013 Share Posté(e) 30 mars 2013 Bonjour, Des nouvelles ? Merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 31 mars 2013 Auteur Share Posté(e) 31 mars 2013 (modifié) Oui je vais compilé la prochaine version dans la nuit ou demain ! J'arrive à un stade ou je ne pourrais pas plus poussé la ROM avec se qui est dispo sur la toile actuellement ! En Runny V5 je tiens facile 3 jours en utilisant le GPS 3h par soir, vue que je suis livreur également ! Tout les problèmes sont fixé sauf le login youtube sinon tout y est fonctionnel ! Même la caméra frontale, et stockage de masse ( mode USB ), tout est réparé enfin ! Prochain projet, JB + sense 4.5 du desire x pour pour le desire s ! Il ne me manque plus qu'un noyau compatible pour le desire s pour effectué les premiers test ! Modifié 31 mars 2013 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 1 avril 2013 Share Posté(e) 1 avril 2013 Au top ! Je l'attend avec impatience aussi :) ! Question subsidiaire, pour sauver la batterie, tu dois bien sacrifier des fonctionnalités, par exemple avec ta ROM il y a des choses qui ne seront pas/plus possible de faire, ou par exemple surfer sur internet sera beaucoup plus long ? Merci pour ton boulot en tout cas, courage ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 1 avril 2013 Auteur Share Posté(e) 1 avril 2013 (modifié) Non pas de perte de performance au contraire je les est optimisé ! Pur la batterie pareil optimisé en gros op du top ! Comme l'est dit je ne sais pas si je pourrais faire mieux que celle là ! Je n'est rien sacrifié sur la rom juste optimisé et porté pour le desire S ! Modifié 1 avril 2013 par micky51100 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 1 avril 2013 Share Posté(e) 1 avril 2013 Sans rentrer dans les détails, qu'est ce que tu as optimisé par exemple ? Par exemple tu empêches à Facebook de fonctionner sans qu'on le lui est demandé ? Où tu limites les envoies de positionnement à Google depuis Maps ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 1 avril 2013 Auteur Share Posté(e) 1 avril 2013 (modifié) Maps moi il est désinstallé et facebook synchro toutes les 4h ! Optimisation à partir des apk, du build.prop, de tweak init.d pour le cpu, seeder pour l'entropy et pour finir optimisation du service.jar pour la gestion des processus en arrière plan ! changelog : <b><#selectbg_g>RunnyBattLife v5.0</#></b> <*>New Camera (Sense 4.1 Camera)</*> <*>Fixed HDR & Panorama</*> <*>Fixed USB Mode</*> <*>Added 3D Cube Animation</*> <*>Updated Superuser</*> <*>Updated SU Binary</*> <*>Kernel changed to Patched 3.0.67</*> <*>Added init.d Tweaks</*> <*>Updated Google Playstore to 3.10.14</*> <*>Added virtuous Setup Optimize</*> <*>Added Wake Up By Volume Button To Aroma Installer</*> <*>Fixed Build.prop tweak </*> <*>Improved Battery longevité</*> <*>Fixed service.jar</*> <*>Improved signal wifi and drain</*> <*>Updated Talkback</*> <*>Updated TuneIn</*> <*>Updated Twitter</*> <*>Updated YouTube</*> <*>Updated Facebook</*> <*>Improved Performance</*> <*>ZipAlign With Latest Android SDK</*> <*>Build With Latest Tools</*> <*>Something More That I Can't Remembered</*> Modifié 1 avril 2013 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 <*>Improved Battery longevité</*>... <*>Something More That I Can't Remembered</*> :lol:Mais par exemple, les RUU HTC ne sont pas optimisées à fond déjà ? Moi pas comprendre :unsure: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SqueeZen Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 Tu te donne à fond, c'est génial. Je ne l'utilise pas parce que je suis allergique à Sense et que Cyanogen me convient mais merci d'assurer un tel suivi pour le Desire S ! Bonne continuation. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 2 avril 2013 Auteur Share Posté(e) 2 avril 2013 Mais par exemple, les RUU HTC ne sont pas optimisées à fond déjà ? Moi pas comprendre Et non les RUU sont pas optimisé du tout ! Sinon pourquoi en ROM stock je tiens pas plus d'1 jour et qu'avec ma rom je tiens presque 3 jours avec le GPS actif tout les jours pendant 3h. Cela dépend également du kernel ! Sur ma Rom c'est le dernier disponible avec les dernière sources google ! Donc cela dois joué énormément aussi ! Tu te donne à fond, c'est génial. Je ne l'utilise pas parce que je suis allergique à Sense et que Cyanogen me convient mais merci d'assurer un tel suivi pour le Desire S ! Bonne continuation. Je ne vois vraiment aucun intérêt d'avoir un HTC si c'est pour viré Sense ! Il y à des tel au même prix plus performant sans sense ! Donc là par contre c'est moi qui pige pas ! Sense s'est très allégé en version 4.1 et n'alourdit plus la Ram et le system ! Du moins mon ressentit est qu'il est déjà moins lourd que sense 3.6, et cela se ressent très vite ! Post 1 à jour, n'oublié pas le Full Wipe ! Sinon problème certain ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 (modifié) Je test ça ! À dans une demie heure ! (le temps que le pc s'allume :lol:) EDIT : Bon, et bien ne marche pas... Soit je reste planté sur l'écran de boot (noir clair) mais il ne se passe rien, soit avec le logo android en gris métallisé. J'ai pourtant opéré un wipe complet, rien à faire, la ROM veut pas booter... j'ai sauvegardé les log d'installation si ça t'intéresse, je te les envoie : AROMA INSTALLER version 2.56 © 2012 by amarullz xda-developers ROM Name : RunnyBattLife ROM Version : V5 ROM Author : Micky51100 Device : HTC Desire S Start at : Tue Apr 2 18:58:34 2013 Executing Full Wipe -- Erasing & formatting /cache as EXT4 about to run program [/sbin/erase_image] with 2 args Creating filesystem with parameters: Size: 152043008 Block size: 4096 Blocks per group: 32768 Inodes per group: 4640 Inode size: 256 Journal blocks: 1024 Label: Blocks: 37119 Block groups: 2 Reserved block group size: 15 Created filesystem with 11/9280 inodes and 1645/37119 blocks about to run program [/sbin/sleep] with 2 args -- Erasing & formatting /system as EXT4 unmount of /system failed; no such volume about to run program [/sbin/erase_image] with 2 args Creating filesystem with parameters: Size: 585104896 Block size: 4096 Blocks per group: 32768 Inodes per group: 7143 Inode size: 256 Journal blocks: 2232 Label: Blocks: 142847 Block groups: 5 Reserved block group size: 39 Created filesystem with 11/35715 inodes and 4603/142847 blocks about to run program [/sbin/sleep] with 2 args -- Erasing & formatting /data as EXT4 unmount of /data failed; no such volume about to run program [/sbin/erase_image] with 2 args Creating filesystem with parameters: Size: 1232076288 Block size: 4096 Blocks per group: 32768 Inodes per group: 7520 Inode size: 256 Journal blocks: 4700 Label: Blocks: 300799 Block groups: 10 Reserved block group size: 79 Created filesystem with 11/75200 inodes and 9909/300799 blocks about to run program [/sbin/sleep] with 2 args -- Erasing /boot partition unmount of /boot failed; no such volume about to run program [/sbin/erase_image] with 2 args about to run program [/sbin/sleep] with 2 args -- Removing system files from SD Card about to run program [/sbin/sleep] with 2 args -- Checking filesystems for errors about to run program [/sbin/e2fsck] with 3 args /dev/block/mmcblk0p25: clean, 11/35715 files, 4603/142847 blocks about to run program [/sbin/e2fsck] with 3 args /dev/block/mmcblk0p26: clean, 11/75200 files, 9909/300799 blocks about to run program [/sbin/e2fsck] with 3 args /dev/block/mmcblk0p27: clean, 11/9280 files, 1645/37119 blocks about to run program [/sbin/sleep] with 2 args Installing... -- Writing Data about to run program [/tmp/check_data_app] with 1 args Extract: /data/app/AdobeReader.apk Extract: /data/app/Dropbox.apk Extract: /data/app/Es_File_Explorer.apk Extract: /data/app/Facebook.apk Extract: /data/app/GMS_Maps.apk Extract: /data/app/HoloSpiral.apk Extract: /data/app/HtcLavaLiveWallpaper.apk Extract: /data/app/Locations.apk Extract: /data/app/MagicSmoke.apk Extract: /data/app/PhaseBeam.apk Extract: /data/app/PolarisOffice.apk Extract: /data/app/Teeter.apk Extract: /data/app/TuneIn.apk Extract: /data/app/Twitter.apk Extract: /data/app/YouTube.apk Extract: /data/app/cc.co.sybregunne.DaemonController-1.apk Extract: /data/app/com.androguide.ryuinferno.universal.init.d.support-1.apk Extract: /data/app/com.electricsheep.asi-1.apk Extract: /data/app/com.google.android.gm-1.apk Extract: /data/app/com.lcis.seeder-1.apk Extract: /data/app/com.oasisfeng.greenify-1.apk Extract: /data/app/ext.recovery.updater-1.apk Extract: /data/app/install_flash_player.apk Extract: /data/app/os.tools.scriptmanager-1.apk Extract: /data/app/pt.fjss.s2w-1.apk Extract: /data/app/talkback.apk set_perm: chown of /data/local to 2000 2000 failed: No such file or directory set_perm: chmod of /data/local to 771 failed: No such file or directory Creating filesystem with parameters: Size: 585104896 Block size: 4096 Blocks per group: 32768 Inodes per group: 7143 Inode size: 256 Journal blocks: 2232 Label: Blocks: 142847 Block groups: 5 Reserved block group size: 39 Created filesystem with 11/35715 inodes and 4603/142847 blocks -- Writing System Extract: /system/app/Aluminum.apk Extract: /system/app/AppSharing.apk Extract: /system/app/Automotive_Home.apk Extract: /system/app/Automotive_InternetRadio.apk Extract: /system/app/Automotive_Traffic.apk Extract: /system/app/Bluetooth.apk Extract: /system/app/BrcmBluetoothServices.apk Extract: /system/app/Browser.apk Extract: /system/app/CIMEXT9.apk Extract: /system/app/Calculator.apk Extract: /system/app/CalculatorWidget.apk Extract: /system/app/Calendar.apk Extract: /system/app/CalendarProvider.apk Extract: /system/app/CertInstaller.apk Extract: /system/app/ChromeBookmarksSyncAdapter.apk Extract: /system/app/ContactsProvider.apk Extract: /system/app/CustomizationSettingsProvider.apk Extract: /system/app/CustomizationSetup.apk Extract: /system/app/DLNAMiddleLayer.apk Extract: /system/app/DMCommandService.apk Extract: /system/app/DefaultContainerService.apk Extract: /system/app/DialerLauncher.apk Extract: /system/app/DownloadProvider.apk Extract: /system/app/DownloadProviderUi.apk Extract: /system/app/DrmProvider.apk Extract: /system/app/FMRadioService.apk Extract: /system/app/FM_Radio.apk Extract: /system/app/Facebook.apk Extract: /system/app/FacebookEngine.apk Extract: /system/app/FilePicker.apk Extract: /system/app/Flashlight.apk Extract: /system/app/Flickr.apk Extract: /system/app/FlickrEngine.apk Extract: /system/app/FriendStream.apk Extract: /system/app/GSD.apk Extract: /system/app/GenieWidget.apk Extract: /system/app/GoogleBackupTransport.apk Extract: /system/app/GoogleCalendarSyncAdapter.apk Extract: /system/app/GoogleContactsSyncAdapter.apk Extract: /system/app/GoogleLoginService.apk Extract: /system/app/GooglePartnerSetup.apk Extract: /system/app/GoogleQuickSearchBox.apk Extract: /system/app/GoogleServicesFramework.apk Extract: /system/app/GoogleTTS.apk Extract: /system/app/HTCAlbum.apk Extract: /system/app/HTCCamera.apk Extract: /system/app/HTCMediaAutoUploadSetting.apk Extract: /system/app/HTCSetupWizard.apk Extract: /system/app/HTCSyncManager.apk Extract: /system/app/HTC_IME.apk Extract: /system/app/HTC_Widget_Watch_3D.apk Extract: /system/app/HTMLViewer.apk Extract: /system/app/HomePersonalize.apk Extract: /system/app/Htc3DRichNotesWidget.apk Extract: /system/app/HtcAutoRotateWidget.apk Extract: /system/app/HtcBackgroundDataWidget.apk Extract: /system/app/HtcBeatsNotify.apk Extract: /system/app/HtcBookmarkWidget.apk Extract: /system/app/HtcCalendarWidgets.apk Extract: /system/app/HtcClockWidget.apk Extract: /system/app/HtcCompressViewer.apk Extract: /system/app/HtcContactWidgets.apk Extract: /system/app/HtcContacts.apk Extract: /system/app/HtcDLNAMiddleLayer.apk Extract: /system/app/HtcDMC.apk Extract: /system/app/HtcDTCPIPMiddleLayer.apk Extract: /system/app/HtcDTCPMiddleLayer.apk Extract: /system/app/HtcDataRoamingWidget.apk Extract: /system/app/HtcDataStripWidget.apk Extract: /system/app/HtcDialer.apk Extract: /system/app/HtcDropboxGLRPlugin.apk Extract: /system/app/HtcFMRadioWidget.apk Extract: /system/app/HtcFriendStreamWidget_3D.apk Extract: /system/app/HtcImageWallpaper.apk Extract: /system/app/HtcInternalSettingsProvider.apk Extract: /system/app/HtcLinkifyDispatcher.apk Extract: /system/app/HtcLocationService.apk Extract: /system/app/HtcLockScreen.apk Extract: /system/app/HtcMailWidgets.apk Extract: /system/app/HtcMediaCacheService.apk Extract: /system/app/HtcMediaUploader.apk Extract: /system/app/HtcMessageProvider.apk Extract: /system/app/HtcMessageUploader.apk Extract: /system/app/HtcMsgWidgets.apk Extract: /system/app/HtcMusic.apk Extract: /system/app/HtcMusicEnhancer.apk Extract: /system/app/HtcMusicWidget.apk Extract: /system/app/HtcNotes.apk Extract: /system/app/HtcNotesPainterView.apk Extract: /system/app/HtcNotesProvider.apk Extract: /system/app/HtcPhotoEnhancer.apk Extract: /system/app/HtcPhotoWidget.apk Extract: /system/app/HtcPowerStripWidget.apk Extract: /system/app/HtcProfilesWidget.apk Extract: /system/app/HtcRingtoneTrimmer.apk Extract: /system/app/HtcRingtoneWidget.apk Extract: /system/app/HtcScreenBrightnessWidget.apk Extract: /system/app/HtcScreenTimeoutWidget.apk Extract: /system/app/HtcSettingWidgets.apk Extract: /system/app/HtcSettingsProvider.apk Extract: /system/app/HtcSkydriveGLRPlugin.apk Extract: /system/app/HtcSoundEnhancerSetting.apk Extract: /system/app/HtcSoundRecorder.apk Extract: /system/app/HtcStore.apk Extract: /system/app/HtcStreamPlayer.apk Extract: /system/app/HtcSyncWidget.apk Extract: /system/app/HtcVideoPlayer.apk Extract: /system/app/HtcWeatherLiveWallpaper.apk Extract: /system/app/HtcWeatherWallpaper.apk Extract: /system/app/IMEHWRPenPower.apk Extract: /system/app/IMEXT9English.apk Extract: /system/app/IMEXT9French.apk Extract: /system/app/IdleScreen_People.apk Extract: /system/app/IdleScreen_Photo.apk Extract: /system/app/IdleScreen_Stock_Yahoo.apk Extract: /system/app/IdleScreen_Weather.apk Extract: /system/app/Idlescreen_Base.apk Extract: /system/app/Idlescreen_productivity.apk Extract: /system/app/KeyChain.apk Extract: /system/app/LMW.apk Extract: /system/app/LocationPicker.apk Extract: /system/app/LocationsInstaller.apk Extract: /system/app/Mail.apk Extract: /system/app/Matte.apk Extract: /system/app/MediaProvider.apk Extract: /system/app/MediaUploader.apk Extract: /system/app/Mms.apk Extract: /system/app/MyDropbox.apk Extract: /system/app/MyGoogleTaskPlugin.apk Extract: /system/app/MyHTC.apk Extract: /system/app/MyPen.apk Extract: /system/app/MyProvisioning.apk Extract: /system/app/MyReportAgent.apk Extract: /system/app/MySketcher.apk Extract: /system/app/MySkydrive.apk Extract: /system/app/MyTask.apk Extract: /system/app/MyTaskWidget.apk Extract: /system/app/NetworkLocation.apk Extract: /system/app/NoiseField.apk Extract: /system/app/OneTimeInitializer.apk Extract: /system/app/PCSC.apk Extract: /system/app/PDF_Viewer_F_A.apk Extract: /system/app/PartnerBookmarksProvider.apk Extract: /system/app/Phone.apk Extract: /system/app/Phonesky.apk Extract: /system/app/Picasa_GLRplugin.apk Extract: /system/app/PluginManager.apk Extract: /system/app/PrivInit.apk Extract: /system/app/PureC_ApplicationsProvider.apk Extract: /system/app/PureC_PackageInstaller.apk Extract: /system/app/PureC_UserDictionaryProvider.apk Extract: /system/app/Rosie.apk Extract: /system/app/SDCardWizard.apk Extract: /system/app/Serene.apk Extract: /system/app/Settings.apk Extract: /system/app/SettingsProvider.apk Extract: /system/app/SetupWizard.apk Extract: /system/app/SocialManager.apk Extract: /system/app/SoundSetDownloadManager.apk Extract: /system/app/Stk.apk Extract: /system/app/Stock.apk Extract: /system/app/StockWidget.apk Extract: /system/app/StreakLiveWallpaper.apk Extract: /system/app/Superuser.apk Extract: /system/app/SystemUI.apk Extract: /system/app/Talk.apk Extract: /system/app/TaskManager.apk Extract: /system/app/TelephonyProvider.apk Extract: /system/app/Transfer.apk Extract: /system/app/TrimIt.apk Extract: /system/app/Twitter.apk Extract: /system/app/TwitterEngine.apk Extract: /system/app/UpgradeSetup.apk Extract: /system/app/Usage.apk Extract: /system/app/VoiceDialer.apk Extract: /system/app/VoiceSearch.apk Extract: /system/app/VpnDialogs.apk Extract: /system/app/Watch.apk Extract: /system/app/Weather.apk Extract: /system/app/WeatherProvider.apk Extract: /system/app/WeatherSyncProvider.apk Extract: /system/app/WeatherVideo.apk Extract: /system/app/WeatherWidget.apk Extract: /system/app/WifiRouter.apk Extract: /system/app/WorldClock.apk Extract: /system/app/fusion.apk Extract: /system/app/idlescreen_shortcut.apk Extract: /system/app/idlescreen_social.apk Extract: /system/bin/.ext/.su Extract: /system/bin/adb Extract: /system/bin/akmd Extract: /system/bin/am Extract: /system/bin/aparse Extract: /system/bin/app_process Extract: /system/bin/applypatch Extract: /system/bin/awb_camera Extract: /system/bin/badblocks Extract: /system/bin/bluetoothd Extract: /system/bin/bma150_usr Extract: /system/bin/bmgr Extract: /system/bin/bootanimation Extract: /system/bin/brcmapd Extract: /system/bin/btld Extract: /system/bin/bu Extract: /system/bin/bugreport Extract: /system/bin/busybox Extract: /system/bin/cam_ins_spmo Extract: /system/bin/cand Extract: /system/bin/cat Extract: /system/bin/charging Extract: /system/bin/chmod Extract: /system/bin/chown Extract: /system/bin/cmp Extract: /system/bin/csview Extract: /system/bin/dalvikvm Extract: /system/bin/date Extract: /system/bin/dbus-daemon Extract: /system/bin/dd Extract: /system/bin/debuggerd Extract: /system/bin/dexopt Extract: /system/bin/df Extract: /system/bin/dhcpcd Extract: /system/bin/dhd Extract: /system/bin/dmesg Extract: /system/bin/dnsmasq Extract: /system/bin/drmserver Extract: /system/bin/dumpcrash Extract: /system/bin/dumpstate Extract: /system/bin/dumpsys Extract: /system/bin/e2fsck Extract: /system/bin/flash_camera Extract: /system/bin/fsck_msdos Extract: /system/bin/getevent Extract: /system/bin/getprop Extract: /system/bin/gzip Extract: /system/bin/hciattach Extract: /system/bin/hd Extract: /system/bin/hdmid Extract: /system/bin/hostapd Extract: /system/bin/htc_ebdlogd Extract: /system/bin/htcfs Extract: /system/bin/id Extract: /system/bin/ifconfig Extract: /system/bin/iftop Extract: /system/bin/ime Extract: /system/bin/input Extract: /system/bin/insmod Extract: /system/bin/installd Extract: /system/bin/ioctl Extract: /system/bin/ionice Extract: /system/bin/ip Extract: /system/bin/ip6tables Extract: /system/bin/iptables Extract: /system/bin/keystore Extract: /system/bin/kill Extract: /system/bin/l2_profile_exchange Extract: /system/bin/linker Extract: /system/bin/ln Extract: /system/bin/load-modem.sh Extract: /system/bin/log Extract: /system/bin/logcat Extract: /system/bin/logcat2 Extract: /system/bin/logwrapper Extract: /system/bin/ls Extract: /system/bin/lsc_camera Extract: /system/bin/lsmod Extract: /system/bin/lsof Extract: /system/bin/make_ext4fs Extract: /system/bin/mediaserver Extract: /system/bin/mkdir Extract: /system/bin/mke2fs Extract: /system/bin/mksh Extract: /system/bin/mm-jpeg-dec-test Extract: /system/bin/mm-jpeg-enc-test Extract: /system/bin/mm-jpeg-enc-test-client Extract: /system/bin/mm-qcamera-app Extract: /system/bin/mm-qcamera-daemon Extract: /system/bin/mm-qcamera-test Extract: /system/bin/mm-qcamera-testsuite-client Extract: /system/bin/mm-vdec-omx-test Extract: /system/bin/mm-venc-omx-test Extract: /system/bin/mm-venc-omx-test720p Extract: /system/bin/mm-video-driver-test Extract: /system/bin/mm-video-encdrv-test Extract: /system/bin/monkey Extract: /system/bin/mount Extract: /system/bin/mpdecision Extract: /system/bin/mtpd Extract: /system/bin/mv Extract: /system/bin/nandread Extract: /system/bin/ndc Extract: /system/bin/netcfg Extract: /system/bin/netd Extract: /system/bin/netsharing Extract: /system/bin/netstat Extract: /system/bin/newfs_msdos Extract: /system/bin/notify Extract: /system/bin/omx_tests Extract: /system/bin/pand Extract: /system/bin/ping Extract: /system/bin/pm Extract: /system/bin/pppd Extract: /system/bin/printenv Extract: /system/bin/ps Extract: /system/bin/racoon Extract: /system/bin/reboot Extract: /system/bin/renice Extract: /system/bin/resize2fs Extract: /system/bin/rild Extract: /system/bin/rm Extract: /system/bin/rmdir Extract: /system/bin/rmmod Extract: /system/bin/rmt_storage Extract: /system/bin/route Extract: /system/bin/run-as Extract: /system/bin/schedtest Extract: /system/bin/schedtop Extract: /system/bin/screencap Extract: /system/bin/screenshot Extract: /system/bin/sdcard Extract: /system/bin/sdptool Extract: /system/bin/sendevent Extract: /system/bin/sensorservice Extract: /system/bin/service Extract: /system/bin/servicemanager Extract: /system/bin/setconsole Extract: /system/bin/setprop Extract: /system/bin/sh Extract: /system/bin/shutdown Extract: /system/bin/simg2img Extract: /system/bin/sleep Extract: /system/bin/smd Extract: /system/bin/snd Extract: /system/bin/snd3254 Extract: /system/bin/sound Extract: /system/bin/sound7x30 Extract: /system/bin/start Extract: /system/bin/stop Extract: /system/bin/su Extract: /system/bin/surfaceflinger Extract: /system/bin/svc Extract: /system/bin/sync Extract: /system/bin/sysinit Extract: /system/bin/system_server Extract: /system/bin/test_gemini Extract: /system/bin/thermald Extract: /system/bin/toolbox Extract: /system/bin/top Extract: /system/bin/touch Extract: /system/bin/tune2fs Extract: /system/bin/udhcpd Extract: /system/bin/umount Extract: /system/bin/uptime Extract: /system/bin/vdc Extract: /system/bin/vmstat Extract: /system/bin/vold Extract: /system/bin/watchprops Extract: /system/bin/wipe Extract: /system/bin/wmdsi Extract: /system/bin/wpa_cli Extract: /system/bin/wpa_supplicant Extract: /system/bin/wpscli_test_cmd Extract: /system/customize/AAInfo.txt Extract: /system/customize/cid_map.xml Extract: /system/customize/mns_map.xml Extract: /system/customize/resource/CCInfo.txt Extract: /system/customize/resource/ConfigH.bin Extract: /system/customize/resource/ConfigP.bin Extract: /system/customize/resource/K2_PLC_187x370.png Extract: /system/customize/resource/K2_PLC_32x58.png Extract: /system/customize/resource/abraham_lake_winter_scape.jpg Extract: /system/customize/resource/aluminum.jpg Extract: /system/customize/resource/aspens_in_the_snow.jpg Extract: /system/customize/resource/beats.jpg Extract: /system/customize/resource/bird_of_a_feather.jpg Extract: /system/customize/resource/bonsai.jpg Extract: /system/customize/resource/fairytail_falls.jpg Extract: /system/customize/resource/fracture.jpg Extract: /system/customize/resource/hTC_bootup_one.zip Extract: /system/customize/resource/htc_downanimation.zip Extract: /system/customize/resource/icon_launcher_active_sync.png Extract: /system/customize/resource/icon_launcher_gmail.png Extract: /system/customize/resource/icon_launcher_hotmail.png Extract: /system/customize/resource/icon_launcher_mail.png Extract: /system/customize/resource/icon_launcher_yahoo.png Extract: /system/customize/resource/infinite.jpg Extract: /system/customize/resource/m43c57bad.jpg Extract: /system/customize/resource/m7faf9a95.jpg Extract: /system/customize/resource/m8d685676.jpg Extract: /system/customize/resource/ma3990e01.jpg Extract: /system/customize/resource/matte.jpg Extract: /system/customize/resource/nostalgia.jpg Extract: /system/customize/resource/pathway_to_the_peaks.jpg Extract: /system/customize/resource/s2dcca705.jpg Extract: /system/customize/resource/s33052e75.jpg Extract: /system/customize/resource/s3d1c37d5.jpg Extract: /system/customize/resource/s419eb377.jpg Extract: /system/customize/resource/s43a4ec7b.jpg Extract: /system/customize/resource/s43c57bad.jpg Extract: /system/customize/resource/s451373dc.jpg Extract: /system/customize/resource/s4d5e5f0e.jpg Extract: /system/customize/resource/s6c0adcc9.jpg Extract: /system/customize/resource/s7faf9a95.jpg Extract: /system/customize/resource/s8d685676.jpg Extract: /system/customize/resource/s8ef925a5.jpg Extract: /system/customize/resource/s966eeef.jpg Extract: /system/customize/resource/s96e7b93b.jpg Extract: /system/customize/resource/s980f4135.jpg Extract: /system/customize/resource/s9b99c341.jpg Extract: /system/customize/resource/sa3990e01.jpg Extract: /system/customize/resource/sb1fdb0c9.jpg Extract: /system/customize/resource/sb29cd20e.jpg Extract: /system/customize/resource/sbd5dc6f8.jpg Extract: /system/customize/resource/sc16062fb.jpg Extract: /system/customize/resource/sc681956e.jpg Extract: /system/customize/resource/sc8a1ff6b.jpg Extract: /system/customize/resource/scene_wallpaper_htc_default.jpg Extract: /system/customize/resource/scene_wallpaper_play.jpg Extract: /system/customize/resource/scene_wallpaper_social.jpg Extract: /system/customize/resource/scene_wallpaper_travel.jpg Extract: /system/customize/resource/scene_wallpaper_work.jpg Extract: /system/customize/resource/scenes_picker_01.png Extract: /system/customize/resource/scenes_picker_02.png Extract: /system/customize/resource/scenes_picker_03.png Extract: /system/customize/resource/scenes_picker_04.png Extract: /system/customize/resource/scenes_picker_05.png Extract: /system/customize/resource/scenes_picker_1_nowatch.png Extract: /system/customize/resource/scenes_picker_4_no_watch.png Extract: /system/customize/resource/scenes_picker_land_1.png Extract: /system/customize/resource/scenes_picker_land_1_no_watch.png Extract: /system/customize/resource/scenes_picker_land_2.png Extract: /system/customize/resource/scenes_picker_land_3.png Extract: /system/customize/resource/scenes_picker_land_4.png Extract: /system/customize/resource/scenes_picker_land_4_no_watch.png Extract: /system/customize/resource/scenes_picker_land_5.png Extract: /system/customize/resource/sd32a3a14.jpg Extract: /system/customize/resource/se66453a0.jpg Extract: /system/customize/resource/sef7f0242.jpg Extract: /system/customize/resource/serene.jpg Extract: /system/customize/resource/sfac50f3a.jpg Extract: /system/customize/resource/shasta_lavender.jpg Extract: /system/customize/resource/surreal_canyons_of_the_west.jpg Extract: /system/customize/resource/wallpaper_02.jpg Extract: /system/customize/resource/wallpaper_03.jpg Extract: /system/customize/resource/wallpaper_04.jpg Extract: /system/etc/DxDrmConfig_Server.txt Extract: /system/etc/DxPrdyProvisionObf.pkg Extract: /system/etc/NOTICE.html.gz Extract: /system/etc/PCTOOL.ISO Extract: /system/etc/adreno_config.txt Extract: /system/etc/agps_rm Extract: /system/etc/audio_effects.conf Extract: /system/etc/basimage_gec.bin Extract: /system/etc/basimage_gec_bt.bin Extract: /system/etc/basimage_gec_x.bin Extract: /system/etc/basimage_ibeats.bin Extract: /system/etc/basimage_ibeats_pro.bin Extract: /system/etc/basimage_ibeats_solo.bin Extract: /system/etc/basimage_ibeats_solo_x.bin Extract: /system/etc/basimage_ibeats_studio.bin Extract: /system/etc/basimage_ibeats_x.bin Extract: /system/etc/bluetooth/a2dp_avrcp.conf Extract: /system/etc/bluetooth/audio.conf Extract: /system/etc/bluetooth/auto_pairing.conf Extract: /system/etc/bluetooth/blacklist.conf Extract: /system/etc/bluetooth/input.conf Extract: /system/etc/bluetooth/network.conf Extract: /system/etc/calibration Extract: /system/etc/dbus.conf Extract: /system/etc/dhcpcd/dhcpcd-hooks/20-dns.conf Extract: /system/etc/dhcpcd/dhcpcd-hooks/95-configured Extract: /system/etc/dhcpcd/dhcpcd-run-hooks Extract: /system/etc/dhcpcd/dhcpcd.conf Extract: /system/etc/dynimage_gec.bin Extract: /system/etc/dynimage_gec_bt.bin Extract: /system/etc/dynimage_gec_x.bin Extract: /system/etc/dynimage_ibeats.bin Extract: /system/etc/dynimage_ibeats_pro.bin Extract: /system/etc/dynimage_ibeats_solo.bin Extract: /system/etc/dynimage_ibeats_solo_x.bin Extract: /system/etc/dynimage_ibeats_studio.bin Extract: /system/etc/dynimage_ibeats_x.bin Extract: /system/etc/event-log-tags Extract: /system/etc/fallback_fonts.xml Extract: /system/etc/gps.conf Extract: /system/etc/hldm.bin Extract: /system/etc/hltof.bin Extract: /system/etc/hltrd.bin Extract: /system/etc/hosts Extract: /system/etc/hsml.key Extract: /system/etc/htcfs.conf Extract: /system/etc/image_beatbox_bt.bin Extract: /system/etc/image_beats_wireless_bt.bin Extract: /system/etc/image_gec.bin Extract: /system/etc/image_gec_bt.bin Extract: /system/etc/image_htc_earbud.bin Extract: /system/etc/image_htc_midtier.bin Extract: /system/etc/image_ibeats.bin Extract: /system/etc/image_ibeats_solo.bin Extract: /system/etc/image_ibeats_solo_v2.bin Extract: /system/etc/image_ibeats_v2.bin Extract: /system/etc/init.d/08setperm.bak Extract: /system/etc/init.d/50-sweep2wake Extract: /system/etc/init.d/83oc Extract: /system/etc/init.d/87calibration Extract: /system/etc/init.d/93zipalign Extract: /system/etc/init.d/94tweaks Extract: /system/etc/init.d/94tweaks.bak Extract: /system/etc/init.d/98CheckSettings Extract: /system/etc/init.d/98CheckSettings.bak Extract: /system/etc/init.d/98swap_cache_v280 Extract: /system/etc/init.d/99complete Extract: /system/etc/init.d/99miscsettings Extract: /system/etc/init.goldfish.sh Extract: /system/etc/init.qcom.post_boot.sh Extract: /system/etc/iproute2/rt_tables Extract: /system/etc/laputa/map_data.zip Extract: /system/etc/media_profiles.xml Extract: /system/etc/mkshrc Extract: /system/etc/out.yuv Extract: /system/etc/peqimage_gec.bin Extract: /system/etc/peqimage_gec_bt.bin Extract: /system/etc/peqimage_gec_x.bin Extract: /system/etc/peqimage_ibeats.bin Extract: /system/etc/peqimage_ibeats_pro.bin Extract: /system/etc/peqimage_ibeats_solo.bin Extract: /system/etc/peqimage_ibeats_solo_x.bin Extract: /system/etc/peqimage_ibeats_studio.bin Extract: /system/etc/peqimage_ibeats_x.bin Extract: /system/etc/permissions/android.hardware.bluetooth.xml Extract: /system/etc/permissions/android.hardware.camera.flash-autofocus.xml Extract: /system/etc/permissions/android.hardware.camera.front.xml Extract: /system/etc/permissions/android.hardware.location.gps.xml Extract: /system/etc/permissions/android.hardware.sensor.accelerometer.xml Extract: /system/etc/permissions/android.hardware.sensor.compass.xml Extract: /system/etc/permissions/android.hardware.sensor.light.xml Extract: /system/etc/permissions/android.hardware.sensor.proximity.xml Extract: /system/etc/permissions/android.hardware.telephony.gsm.xml Extract: /system/etc/permissions/android.hardware.touchscreen.multitouch.distinct.xml Extract: /system/etc/permissions/android.hardware.usb.accessory.xml Extract: /system/etc/permissions/android.hardware.wifi.direct.xml Extract: /system/etc/permissions/android.hardware.wifi.xml Extract: /system/etc/permissions/android.software.live_wallpaper.xml Extract: /system/etc/permissions/android.software.sip.voip.xml Extract: /system/etc/permissions/com.android.location.provider.xml Extract: /system/etc/permissions/com.cisco.anyconnect.permissions.patch.htc.xml Extract: /system/etc/permissions/com.google.android.maps.xml Extract: /system/etc/permissions/com.google.android.media.effects.xml Extract: /system/etc/permissions/com.google.widevine.software.drm.xml Extract: /system/etc/permissions/com.htc.android.rosie.xml Extract: /system/etc/permissions/com.htc.fusion.fx.xml Extract: /system/etc/permissions/com.htc.lockscreen.fusion.xml Extract: /system/etc/permissions/com.orange.authentication.simcard.xml Extract: /system/etc/permissions/handheld_core_hardware.xml Extract: /system/etc/permissions/handheld_core_hardware_no_compass.xml Extract: /system/etc/permissions/platform.xml Extract: /system/etc/ppp/ip-up-vpn Extract: /system/etc/sdk/sdkinfo.xml Extract: /system/etc/security/FotaSign_PubKey.der Extract: /system/etc/security/KeyServer_PubKey.der Extract: /system/etc/security/cacerts/00673b5b.0 Extract: /system/etc/security/cacerts/03e16f6c.0 Extract: /system/etc/security/cacerts/0481cb65.0 Extract: /system/etc/security/cacerts/052e396b.0 Extract: /system/etc/security/cacerts/08aef7bb.0 Extract: /system/etc/security/cacerts/0c364b2d.0 Extract: /system/etc/security/cacerts/0d188d89.0 Extract: /system/etc/security/cacerts/0dbd0096.0 Extract: /system/etc/security/cacerts/0e82f83a.0 Extract: /system/etc/security/cacerts/10531352.0 Extract: /system/etc/security/cacerts/111e6273.0 Extract: /system/etc/security/cacerts/1155c94b.0 Extract: /system/etc/security/cacerts/119afc2e.0 Extract: /system/etc/security/cacerts/11a09b38.0 Extract: /system/etc/security/cacerts/11f154d6.0 Extract: /system/etc/security/cacerts/12d55845.0 Extract: /system/etc/security/cacerts/17b51fe6.0 Extract: /system/etc/security/cacerts/1920cacb.0 Extract: /system/etc/security/cacerts/19899da5.0 Extract: /system/etc/security/cacerts/1d657651.0 Extract: /system/etc/security/cacerts/1dac3003.0 Extract: /system/etc/security/cacerts/1dbdda5b.0 Extract: /system/etc/security/cacerts/1dcd6f4c.0 Extract: /system/etc/security/cacerts/1df5ec47.0 Extract: /system/etc/security/cacerts/1e8e7201.0 Extract: /system/etc/security/cacerts/1eb37bdf.0 Extract: /system/etc/security/cacerts/219d9499.0 Extract: /system/etc/security/cacerts/23f4c490.0 Extract: /system/etc/security/cacerts/27af790d.0 Extract: /system/etc/security/cacerts/2afc57aa.0 Extract: /system/etc/security/cacerts/2e8714cb.0 Extract: /system/etc/security/cacerts/2edf7016.0 Extract: /system/etc/security/cacerts/2fa87019.0 Extract: /system/etc/security/cacerts/2fb1850a.0 Extract: /system/etc/security/cacerts/33815e15.0 Extract: /system/etc/security/cacerts/343eb6cb.0 Extract: /system/etc/security/cacerts/34d760b2.0 Extract: /system/etc/security/cacerts/399e7759.0 Extract: /system/etc/security/cacerts/3a3b02ce.0 Extract: /system/etc/security/cacerts/3ad48a91.0 Extract: /system/etc/security/cacerts/3c58f906.0 Extract: /system/etc/security/cacerts/3c860d51.0 Extract: /system/etc/security/cacerts/3d441de8.0 Extract: /system/etc/security/cacerts/3e3744fd.0 Extract: /system/etc/security/cacerts/3e7271e8.0 Extract: /system/etc/security/cacerts/412bea73.0 Extract: /system/etc/security/cacerts/418595b9.0 Extract: /system/etc/security/cacerts/455f1b52.0 Extract: /system/etc/security/cacerts/46b2fd3b.0 Extract: /system/etc/security/cacerts/48478734.0 Extract: /system/etc/security/cacerts/4d654d1d.0 Extract: /system/etc/security/cacerts/4e18c148.0 Extract: /system/etc/security/cacerts/4f19d2b4.0 Extract: /system/etc/security/cacerts/4fbd6bfa.0 Extract: /system/etc/security/cacerts/5021a0a2.0 Extract: /system/etc/security/cacerts/5046c355.0 Extract: /system/etc/security/cacerts/524d9b43.0 Extract: /system/etc/security/cacerts/56b8a0b6.0 Extract: /system/etc/security/cacerts/57692373.0 Extract: /system/etc/security/cacerts/58a44af1.0 Extract: /system/etc/security/cacerts/594f1775.0 Extract: /system/etc/security/cacerts/5a3f0ff8.0 Extract: /system/etc/security/cacerts/5a5372fc.0 Extract: /system/etc/security/cacerts/5cf9d536.0 Extract: /system/etc/security/cacerts/5e4e69e7.0 Extract: /system/etc/security/cacerts/5f16ce45.0 Extract: /system/etc/security/cacerts/60afe812.0 Extract: /system/etc/security/cacerts/60f083f8.0 Extract: /system/etc/security/cacerts/613f892a.0 Extract: /system/etc/security/cacerts/635ccfd5.0 Extract: /system/etc/security/cacerts/67495436.0 Extract: /system/etc/security/cacerts/69105f4f.0 Extract: /system/etc/security/cacerts/6adf0799.0 Extract: /system/etc/security/cacerts/6b3f8240.0 Extract: /system/etc/security/cacerts/6e8bf996.0 Extract: /system/etc/security/cacerts/6fcc125d.0 Extract: /system/etc/security/cacerts/709afd2b.0 Extract: /system/etc/security/cacerts/72f369af.0 Extract: /system/etc/security/cacerts/72fa7371.0 Extract: /system/etc/security/cacerts/74c26bd0.0 Extract: /system/etc/security/cacerts/75680d2e.0 Extract: /system/etc/security/cacerts/7651b327.0 Extract: /system/etc/security/cacerts/76579174.0 Extract: /system/etc/security/cacerts/7999be0d.0 Extract: /system/etc/security/cacerts/7a481e66.0 Extract: /system/etc/security/cacerts/7a819ef2.0 Extract: /system/etc/security/cacerts/7d3cd826.0 Extract: /system/etc/security/cacerts/7d453d8f.0 Extract: /system/etc/security/cacerts/81b9768f.0 Extract: /system/etc/security/cacerts/8470719d.0 Extract: /system/etc/security/cacerts/84cba82f.0 Extract: /system/etc/security/cacerts/85cde254.0 Extract: /system/etc/security/cacerts/86212b19.0 Extract: /system/etc/security/cacerts/87753b0d.0 Extract: /system/etc/security/cacerts/87d3cf09.0 Extract: /system/etc/security/cacerts/882de061.0 Extract: /system/etc/security/cacerts/895cad1a.0 Extract: /system/etc/security/cacerts/89c02a45.0 Extract: /system/etc/security/cacerts/8ccb5f6d.0 Extract: /system/etc/security/cacerts/8f7b96c4.0 Extract: /system/etc/security/cacerts/9339512a.0 Extract: /system/etc/security/cacerts/95aff9e3.0 Extract: /system/etc/security/cacerts/9685a493.0 Extract: /system/etc/security/cacerts/9772ca32.0 Extract: /system/etc/security/cacerts/9d6523ce.0 Extract: /system/etc/security/cacerts/9dbefe7b.0 Extract: /system/etc/security/cacerts/9ec3a561.0 Extract: /system/etc/security/cacerts/9f533518.0 Extract: /system/etc/security/cacerts/9fae0770.0 Extract: /system/etc/security/cacerts/a0bc6fbb.0 Extract: /system/etc/security/cacerts/a15b3b6b.0 Extract: /system/etc/security/cacerts/a2df7ad7.0 Extract: /system/etc/security/cacerts/a3896b44.0 Extract: /system/etc/security/cacerts/a7605362.0 Extract: /system/etc/security/cacerts/a7d2cf64.0 Extract: /system/etc/security/cacerts/aaa45464.0 Extract: /system/etc/security/cacerts/ab5346f4.0 Extract: /system/etc/security/cacerts/add67345.0 Extract: /system/etc/security/cacerts/b0f3e76e.0 Extract: /system/etc/security/cacerts/b413391d.0 Extract: /system/etc/security/cacerts/b5f329fa.0 Extract: /system/etc/security/cacerts/b7db1890.0 Extract: /system/etc/security/cacerts/bc3f2570.0 Extract: /system/etc/security/cacerts/bcdd5959.0 Extract: /system/etc/security/cacerts/bda4cc84.0 Extract: /system/etc/security/cacerts/bdacca6f.0 Extract: /system/etc/security/cacerts/bf64f35b.0 Extract: /system/etc/security/cacerts/c19d42c7.0 Extract: /system/etc/security/cacerts/c215bc69.0 Extract: /system/etc/security/cacerts/c33a80d4.0 Extract: /system/etc/security/cacerts/c527e4ab.0 Extract: /system/etc/security/cacerts/c7e2a638.0 Extract: /system/etc/security/cacerts/c8763593.0 Extract: /system/etc/security/cacerts/ccb919f9.0 Extract: /system/etc/security/cacerts/ccc52f49.0 Extract: /system/etc/security/cacerts/cdaebb72.0 Extract: /system/etc/security/cacerts/ce1adacf.0 Extract: /system/etc/security/cacerts/cf701eeb.0 Extract: /system/etc/security/cacerts/d0081655.0 Extract: /system/etc/security/cacerts/d16a5865.0 Extract: /system/etc/security/cacerts/d2adc77d.0 Extract: /system/etc/security/cacerts/d537fba6.0 Extract: /system/etc/security/cacerts/d64f06f3.0 Extract: /system/etc/security/cacerts/d777342d.0 Extract: /system/etc/security/cacerts/d78a75c7.0 Extract: /system/etc/security/cacerts/d8274e24.0 Extract: /system/etc/security/cacerts/dbc54cab.0 Extract: /system/etc/security/cacerts/ddc328ff.0 Extract: /system/etc/security/cacerts/e268a4c5.0 Extract: /system/etc/security/cacerts/e48193cf.0 Extract: /system/etc/security/cacerts/e60bf0c0.0 Extract: /system/etc/security/cacerts/e775ed2d.0 Extract: /system/etc/security/cacerts/e7b8d656.0 Extract: /system/etc/security/cacerts/e8651083.0 Extract: /system/etc/security/cacerts/ea169617.0 Extract: /system/etc/security/cacerts/eb375c3e.0 Extract: /system/etc/security/cacerts/ed049835.0 Extract: /system/etc/security/cacerts/ed524cf5.0 Extract: /system/etc/security/cacerts/ed62f4e3.0 Extract: /system/etc/security/cacerts/ee7cd6fb.0 Extract: /system/etc/security/cacerts/f0a38a80.0 Extract: /system/etc/security/cacerts/f4996e82.0 Extract: /system/etc/security/cacerts/f58a60fe.0 Extract: /system/etc/security/cacerts/f61bff45.0 Extract: /system/etc/security/cacerts/f80cc7f6.0 Extract: /system/etc/security/cacerts/fac084d7.0 Extract: /system/etc/security/cacerts/facacbc6.0 Extract: /system/etc/security/cacerts/fde84897.0 Extract: /system/etc/security/cacerts/ff783690.0 Extract: /system/etc/security/cwcerts.zip Extract: /system/etc/security/otacerts.zip Extract: /system/etc/spn-conf.xml Extract: /system/etc/system_fonts.xml Extract: /system/etc/timezones.db Extract: /system/etc/updatecmds/google_generic_update.txt Extract: /system/etc/virtuous_oc/sleep_governor Extract: /system/etc/virtuous_oc/sleep_max_freq Extract: /system/etc/virtuous_oc/sleep_min_freq Extract: /system/etc/virtuous_oc/wake_governor Extract: /system/etc/virtuous_oc/wake_max_freq Extract: /system/etc/virtuous_oc/wake_min_freq Extract: /system/etc/voVidDec.dat Extract: /system/etc/voicemail-conf.xml Extract: /system/etc/vold.fstab Extract: /system/etc/vomeComp.cfg Extract: /system/etc/vomeComp_RTSP.cfg Extract: /system/etc/vomeCore.cfg Extract: /system/etc/vomeplay.cfg Extract: /system/etc/vommcodec.cfg Extract: /system/etc/vpimg Extract: /system/etc/wifi/wpa_supplicant.conf Extract: /system/etc/wifioffloadpkg.xml Extract: /system/fonts/ARDJ-KK.ttf Extract: /system/fonts/AndroidClock.ttf Extract: /system/fonts/AndroidClock_Highlight.ttf Extract: /system/fonts/AndroidClock_Solid.ttf Extract: /system/fonts/Clockopia.ttf Extract: /system/fonts/DroidNaskh-Regular.ttf Extract: /system/fonts/DroidSans-Bold.ttf Extract: /system/fonts/DroidSans.ttf Extract: /system/fonts/DroidSansArmenian.ttf Extract: /system/fonts/DroidSansEthiopic-Regular.ttf Extract: /system/fonts/DroidSansFallback.ttf Extract: /system/fonts/DroidSansGeorgian.ttf Extract: /system/fonts/DroidSansHebrew-Bold.ttf Extract: /system/fonts/DroidSansHebrew-Regular.ttf Extract: /system/fonts/DroidSansMono.ttf Extract: /system/fonts/DroidSansThai.ttf Extract: /system/fonts/DroidSerif-Bold.ttf Extract: /system/fonts/DroidSerif-BoldItalic.ttf Extract: /system/fonts/DroidSerif-Italic.ttf Extract: /system/fonts/DroidSerif-Regular.ttf Extract: /system/fonts/HTCHand.otf Extract: /system/fonts/HelveticaNeueLTPro-Cn.otf Extract: /system/fonts/HelveticaNeueLTPro35Th.ttf Extract: /system/fonts/HelveticaNeueOTS.ttf Extract: /system/fonts/Lohit-Bengali.ttf Extract: /system/fonts/Lohit-Devanagari.ttf Extract: /system/fonts/Lohit-Tamil.ttf Extract: /system/fonts/Roboto-Bold.ttf Extract: /system/fonts/Roboto-BoldItalic.ttf Extract: /system/fonts/Roboto-Italic.ttf Extract: /system/fonts/Roboto-Regular.ttf Extract: /system/fonts/gcsh00d-hkscs.ttf Extract: /system/fonts/ucsh00d_c.ttf Extract: /system/framework/HTCCommonctrl.jar Extract: /system/framework/HTCDev.jar Extract: /system/framework/HTCExtension.jar Extract: /system/framework/am.jar Extract: /system/framework/android.policy.jar Extract: /system/framework/android.test.runner.jar Extract: /system/framework/apache-xml.jar Extract: /system/framework/bmgr.jar Extract: /system/framework/bouncycastle.jar Extract: /system/framework/bu.jar Extract: /system/framework/com.android.future.usb.accessory.jar Extract: /system/framework/com.android.location.provider.jar Extract: /system/framework/com.discretix.drm.api.jar Extract: /system/framework/com.dropboxpartner.jar Extract: /system/framework/com.google.android.maps.jar Extract: /system/framework/com.google.android.media.effects.jar Extract: /system/framework/com.google.widevine.software.drm.jar Extract: /system/framework/com.htc.android.bluetooth.jar Extract: /system/framework/com.htc.android.rosie.jar Extract: /system/framework/com.htc.fusion.fx.jar Extract: /system/framework/com.htc.lockscreen.fusion.jar Extract: /system/framework/com.htc.resources.apk Extract: /system/framework/com.htc.socialnetwork.res.apk Extract: /system/framework/com.htc.videowidget.res.apk Extract: /system/framework/com.htc.weather.res.apk Extract: /system/framework/com.orange.authentication.simcard.jar Extract: /system/framework/com.scalado.caps.jar Extract: /system/framework/com.scalado.util.ScaladoUtil.jar Extract: /system/framework/core-junit.jar Extract: /system/framework/core.jar Extract: /system/framework/ext.jar Extract: /system/framework/filterfw.jar Extract: /system/framework/framework-htc-res.apk Extract: /system/framework/framework-res.apk Extract: /system/framework/framework.jar Extract: /system/framework/framework2.jar Extract: /system/framework/ime.jar Extract: /system/framework/input.jar Extract: /system/framework/javax.obex.jar Extract: /system/framework/modemwarmup.jar Extract: /system/framework/monkey.jar Extract: /system/framework/pm.jar Extract: /system/framework/services.jar Extract: /system/framework/svc.jar Extract: /system/framework/usbnet.jar Extract: /system/framework/wimax.jar Extract: /system/lib/addict.dat Extract: /system/lib/bluez-plugin/audio.so Extract: /system/lib/bluez-plugin/bluetooth-health.so Extract: /system/lib/bluez-plugin/input.so Extract: /system/lib/bluez-plugin/network.so Extract: /system/lib/chiaddict.dat Extract: /system/lib/drm/libdrmwvmplugin.so Extract: /system/lib/egl/egl.cfg Extract: /system/lib/egl/eglsubAndroid.so Extract: /system/lib/egl/libEGL_adreno200.so Extract: /system/lib/egl/libGLES_android.so Extract: /system/lib/egl/libGLESv1_CM_adreno200.so Extract: /system/lib/egl/libGLESv2_adreno200.so Extract: /system/lib/egl/libq3dtools_adreno200.so Extract: /system/lib/hw/audio.a2dp.default.so Extract: /system/lib/hw/audio.primary.default.so Extract: /system/lib/hw/audio_policy.default.so Extract: /system/lib/hw/camera.default.so Extract: /system/lib/hw/copybit.msm7x30.so Extract: /system/lib/hw/gps.default.so Extract: /system/lib/hw/gralloc.default.so Extract: /system/lib/hw/gralloc.msm7x30.so Extract: /system/lib/hw/hwcomposer.msm7x30.so Extract: /system/lib/hw/lights.msm7x30.so Extract: /system/lib/hw/sensors.saga.so Extract: /system/lib/libAudioTrimmer.so Extract: /system/lib/libC2D2.so Extract: /system/lib/libChange.so Extract: /system/lib/libDxAndroidSpecific.so Extract: /system/lib/libDxDrmCAPI.so Extract: /system/lib/libDxDrmJava.so Extract: /system/lib/libDxDtcpClient.so Extract: /system/lib/libEGL.so Extract: /system/lib/libETC1.so Extract: /system/lib/libFFTEm.so Extract: /system/lib/libGLESv1_CM.so Extract: /system/lib/libGLESv2.so Extract: /system/lib/libGLESv2_dbg.so Extract: /system/lib/libHTC_DIS.so Extract: /system/lib/libLaputaEngine.so Extract: /system/lib/libLaputaLbJni.so Extract: /system/lib/libLaputaLbProviderJni.so Extract: /system/lib/libLaputaLogJni.so Extract: /system/lib/libMLTransition.so Extract: /system/lib/libOlaEngine.so Extract: /system/lib/libOlaEngineNew.so Extract: /system/lib/libOmxCore.so Extract: /system/lib/libOmxVdec.so Extract: /system/lib/libOmxVenc.so Extract: /system/lib/libOpenMAXAL.so Extract: /system/lib/libOpenSLES.so Extract: /system/lib/libOpenVG.so Extract: /system/lib/libQcomUI.so Extract: /system/lib/libRS.so Extract: /system/lib/libSR_AudioIn.so Extract: /system/lib/libTRIM.so Extract: /system/lib/libWVStreamControlAPI_L3.so Extract: /system/lib/libWVphoneAPI.so Extract: /system/lib/libacc.so Extract: /system/lib/libaddrsdetection.so Extract: /system/lib/libalbum_util2e.so Extract: /system/lib/libandroid.so Extract: /system/lib/libandroid_runtime.so Extract: /system/lib/libandroid_servers.so Extract: /system/lib/libandroid_simlock.so Extract: /system/lib/libaricentomxplugin.so Extract: /system/lib/libaudioalsa.so Extract: /system/lib/libaudioeffect_jni.so Extract: /system/lib/libaudioeq.so Extract: /system/lib/libaudioflinger.so Extract: /system/lib/libbcc.so Extract: /system/lib/libbcc.so.sha1 Extract: /system/lib/libbcinfo.so Extract: /system/lib/libbinder.so Extract: /system/lib/libbluedroid.so Extract: /system/lib/libbluetooth.so Extract: /system/lib/libbluetoothd.so Extract: /system/lib/libbt-aptx-4.0.3.so Extract: /system/lib/libbtio.so Extract: /system/lib/libc.so Extract: /system/lib/libcamera_client.so Extract: /system/lib/libcameraface.so Extract: /system/lib/libcamerapp.so Extract: /system/lib/libcameraservice.so Extract: /system/lib/libcapsjava.so Extract: /system/lib/libcentralZoomTransition.so Extract: /system/lib/libchromatix_ov8810_default_video.so Extract: /system/lib/libchromatix_ov8810_preview.so Extract: /system/lib/libchromatix_ov8830_default_video.so Extract: /system/lib/libchromatix_ov8830_hfr.so Extract: /system/lib/libchromatix_ov8830_preview.so Extract: /system/lib/libchromatix_s5k3h1gx_default_video.so Extract: /system/lib/libchromatix_s5k3h1gx_preview.so Extract: /system/lib/libchromatix_s5k3h2yx_default_video.so Extract: /system/lib/libchromatix_s5k3h2yx_hfr.so Extract: /system/lib/libchromatix_s5k3h2yx_preview.so Extract: /system/lib/libchromatix_s5k4e1gx_default_video.so Extract: /system/lib/libchromatix_s5k4e1gx_preview.so Extract: /system/lib/libchromatix_s5k4e5yx_default_video.so Extract: /system/lib/libchromatix_s5k4e5yx_hdr.so Extract: /system/lib/libchromatix_s5k4e5yx_hfr.so Extract: /system/lib/libchromatix_s5k4e5yx_hfr_4x.so Extract: /system/lib/libchromatix_s5k4e5yx_preview.so Extract: /system/lib/libchromium_net.so Extract: /system/lib/libcimagegif-jni.so Extract: /system/lib/libclcore.bc Extract: /system/lib/libcontentZoomTransition.so Extract: /system/lib/libcpt9.so Extract: /system/lib/libcpt9core.so Extract: /system/lib/libcpt9provider.so Extract: /system/lib/libcrypto.so Extract: /system/lib/libcsd-client.so Extract: /system/lib/libctest.so Extract: /system/lib/libcubicRotateTransition.so Extract: /system/lib/libcutils.so Extract: /system/lib/libdbus.so Extract: /system/lib/libdefcontainer_jni.so Extract: /system/lib/libdiskconfig.so Extract: /system/lib/libdivxdrmdecrypt.so Extract: /system/lib/libdl.so Extract: /system/lib/libdnshostprio.so Extract: /system/lib/libdrm1.so Extract: /system/lib/libdrm1_jni.so Extract: /system/lib/libdrmframework.so Extract: /system/lib/libdrmframework_jni.so Extract: /system/lib/libdumppcm.so Extract: /system/lib/libdvm.so Extract: /system/lib/libeffects.so Extract: /system/lib/libemoji.so Extract: /system/lib/libexif.so Extract: /system/lib/libexpat.so Extract: /system/lib/libext2_blkid.so Extract: /system/lib/libext2_com_err.so Extract: /system/lib/libext2_e2p.so Extract: /system/lib/libext2_profile.so Extract: /system/lib/libext2_uuid.so Extract: /system/lib/libext2fs.so Extract: /system/lib/libext4_utils.so Extract: /system/lib/libfacelock_jni.so Extract: /system/lib/libfilterfw.so Extract: /system/lib/libfilterpack_facedetect.so Extract: /system/lib/libfilterpack_imageproc.so Extract: /system/lib/libfjcClient.so Extract: /system/lib/libfjcService.so Extract: /system/lib/libflint_engine_jni_api.so Extract: /system/lib/libfrsdk.so Extract: /system/lib/libfuse.so Extract: /system/lib/libgabi++.so Extract: /system/lib/libgcomm_jni.so Extract: /system/lib/libgemini.so Extract: /system/lib/libgenlock.so Extract: /system/lib/libglib.so Extract: /system/lib/libgsl.so Extract: /system/lib/libgui.so Extract: /system/lib/libhardware.so Extract: /system/lib/libhardware_legacy.so Extract: /system/lib/libharfbuzz.so Extract: /system/lib/libhtc_acoustic.so Extract: /system/lib/libhtc_ril.so Extract: /system/lib/libhtc_ril_switch.so Extract: /system/lib/libhtc_rilhook.so Extract: /system/lib/libhtcanipluginmanager.so Extract: /system/lib/libhtccamera.so Extract: /system/lib/libhtcflag-jni.so Extract: /system/lib/libhtcpainting.so Extract: /system/lib/libhtcsunny2engine.so Extract: /system/lib/libhtcsunnyengine.so Extract: /system/lib/libhwui.so Extract: /system/lib/libicui18n.so Extract: /system/lib/libicule.so Extract: /system/lib/libiculx.so Extract: /system/lib/libicuuc.so Extract: /system/lib/libimage-jpeg-enc-omx-comp.so Extract: /system/lib/libimage-omx-common.so Extract: /system/lib/libinput.so Extract: /system/lib/libiprouteutil.so Extract: /system/lib/libiwi.so Extract: /system/lib/libiwiOmx.so Extract: /system/lib/libiwiOmxUtil.so Extract: /system/lib/libjUPnPCP.so Extract: /system/lib/libjnigraphics.so Extract: /system/lib/libjpeg.so Extract: /system/lib/liblog.so Extract: /system/lib/liblz.so Extract: /system/lib/libm.so Extract: /system/lib/libmedia.so Extract: /system/lib/libmedia_jni.so Extract: /system/lib/libmediaplayerservice.so Extract: /system/lib/libmemalloc.so Extract: /system/lib/libmm-adspsvc.so Extract: /system/lib/libmm-color-convertor.so Extract: /system/lib/libmm-omxcore.so Extract: /system/lib/libmmcamera_faceproc.so Extract: /system/lib/libmmcamera_frameproc.so Extract: /system/lib/libmmcamera_hdr_lib.so Extract: /system/lib/libmmcamera_image_stab.so Extract: /system/lib/libmmcamera_interface2.so Extract: /system/lib/libmmcamera_rawchipproc.so Extract: /system/lib/libmmcamera_statsproc31.so Extract: /system/lib/libmmcamera_wavelet_lib.so Extract: /system/lib/libmmipl.so Extract: /system/lib/libmmjpeg.so Extract: /system/lib/libmmosal.so Extract: /system/lib/libmmparser.so Extract: /system/lib/libmmparser_divxdrmlib.so Extract: /system/lib/libmmstillomx.so Extract: /system/lib/libmode10.so Extract: /system/lib/libmode10GLES20.so Extract: /system/lib/libmode10fx.so Extract: /system/lib/libmtp.so Extract: /system/lib/libnativedocviewer.so Extract: /system/lib/libnativehelper.so Extract: /system/lib/libnetlink.so Extract: /system/lib/libnetmonitor.so Extract: /system/lib/libnetutils.so Extract: /system/lib/libnfc_ndef.so Extract: /system/lib/libnotes_jni.so Extract: /system/lib/libnotesprovider_jni.so Extract: /system/lib/liboemcamera.so Extract: /system/lib/liboma-drm1-fs.so Extract: /system/lib/liboverlay.so Extract: /system/lib/libpagecurl.so Extract: /system/lib/libpdfviewer.so Extract: /system/lib/libpicowrapper.so Extract: /system/lib/libpixelflinger.so Extract: /system/lib/libpng.so Extract: /system/lib/libpolarisoffice_Clipboard.so Extract: /system/lib/libposteffect.so Extract: /system/lib/libpower.so Extract: /system/lib/libpowermanager.so Extract: /system/lib/libpphwr.so Extract: /system/lib/libpphwrcore.so Extract: /system/lib/libpphwrprovider.so Extract: /system/lib/libprojector.so Extract: /system/lib/libqc-opt.so Extract: /system/lib/librecentappZoomTransition.so Extract: /system/lib/libril.so Extract: /system/lib/librpc.so Extract: /system/lib/librs_jni.so Extract: /system/lib/librtp_jni.so Extract: /system/lib/libsc-a2xx.so Extract: /system/lib/libscalado_htcalbum2.so Extract: /system/lib/libscaladoapi.so Extract: /system/lib/libscaladoutil.so Extract: /system/lib/libsensorservice.so Extract: /system/lib/libskia.so Extract: /system/lib/libsonivox.so Extract: /system/lib/libsoundpool.so Extract: /system/lib/libspeex_sh.so Extract: /system/lib/libspeexresampler.so Extract: /system/lib/libspeexwrapper.so Extract: /system/lib/libsqlite.so Extract: /system/lib/libsqlite_jni.so Extract: /system/lib/libsrec_jni.so Extract: /system/lib/libsrscorehtc.so Extract: /system/lib/libsrsprocessing.so Extract: /system/lib/libssl.so Extract: /system/lib/libstagefright.so Extract: /system/lib/libstagefright_amrnb_common.so Extract: /system/lib/libstagefright_avc_common.so Extract: /system/lib/libstagefright_enc_common.so Extract: /system/lib/libstagefright_foundation.so Extract: /system/lib/libstagefright_omx.so Extract: /system/lib/libstagefright_soft_aacdec.so Extract: /system/lib/libstagefright_soft_amrdec.so Extract: /system/lib/libstagefright_soft_g711dec.so Extract: /system/lib/libstagefright_soft_h264dec.so Extract: /system/lib/libstagefright_soft_mp3dec.so Extract: /system/lib/libstagefright_soft_mpeg4dec.so Extract: /system/lib/libstagefright_soft_vorbisdec.so Extract: /system/lib/libstagefright_soft_vpxdec.so Extract: /system/lib/libstagefright_yuv.so Extract: /system/lib/libstagefrighthw.so Extract: /system/lib/libstagefrighthw_swiqi.so Extract: /system/lib/libstdc++.so Extract: /system/lib/libstlport.so Extract: /system/lib/libstream_core.so Extract: /system/lib/libsurfaceflinger.so Extract: /system/lib/libsurfaceflinger_client.so Extract: /system/lib/libswipeCubicTransition.so Extract: /system/lib/libswiqisettinghelper.so Extract: /system/lib/libsystem_server.so Extract: /system/lib/libsysutils.so Extract: /system/lib/libt9.so Extract: /system/lib/libtcpfinaggr.so Extract: /system/lib/libthread_db.so Extract: /system/lib/libtilerenderer.so Extract: /system/lib/libtipsani.so Extract: /system/lib/libtunein.dec.so Extract: /system/lib/libtunein.ffmpeg.so Extract: /system/lib/libtunein.mms.so Extract: /system/lib/libtunein.oem.so Extract: /system/lib/libui.so Extract: /system/lib/libusbhost.so Extract: /system/lib/libusbnetjni.so Extract: /system/lib/libutils.so Extract: /system/lib/libv8.so Extract: /system/lib/libvariablespeed.so Extract: /system/lib/libvideochat_jni.so Extract: /system/lib/libvideochat_stabilize.so Extract: /system/lib/libvideoeditor_jni.so Extract: /system/lib/libvideoeditorplayer.so Extract: /system/lib/libvoicesearch.so Extract: /system/lib/libvorbisidec.so Extract: /system/lib/libwebcore.so Extract: /system/lib/libwebkitaccel.so Extract: /system/lib/libwebrtc_audio_preprocessing.so Extract: /system/lib/libwilhelm.so Extract: /system/lib/libwivu.so Extract: /system/lib/libwlwpscli.so Extract: /system/lib/libwpa_client.so Extract: /system/lib/libwsp.so Extract: /system/lib/libwsp_jni.so Extract: /system/lib/libwvdrm_L3.so Extract: /system/lib/libwvm.so Extract: /system/lib/libz.so Extract: /system/lib/libzoomTransition.so Extract: /system/lib/modules/bcmdhd.ko Extract: /system/lib/modules/frandom.ko Extract: /system/lib/modules/kineto_gan.ko Extract: /system/lib/plugins/com.adobe.flashplayer/libflashplayer.so Extract: /system/lib/plugins/com.adobe.flashplayer/libstagefright_froyo.so Extract: /system/lib/plugins/com.adobe.flashplayer/libstagefright_honeycomb.so Extract: /system/lib/plugins/com.adobe.flashplayer/libysshared.so Extract: /system/lib/pp_proc_plugin.so Extract: /system/lib/qnet-plugin.so Extract: /system/lib/soundfx/libaudiopreprocessing.so Extract: /system/lib/soundfx/libbeatsbass.so Extract: /system/lib/soundfx/libbundlewrapper.so Extract: /system/lib/soundfx/libreverbwrapper.so Extract: /system/lib/soundfx/libsrsfx.so Extract: /system/lib/soundfx/libvisualizer.so Extract: /system/lib/soundfx/libxloudwrapper.so Extract: /system/lib/tcp-connections.so Extract: /system/media/GPU/ContrastCurveSet.bmp Extract: /system/media/GPU/CurveCold.bmp Extract: /system/media/GPU/CurveCross.bmp Extract: /system/media/GPU/CurveSepia.bmp Extract: /system/media/GPU/CurveWarm.bmp Extract: /system/media/GPU/dot_mask.bmp Extract: /system/media/GPU/dot_mask_0.bmp Extract: /system/media/GPU/dot_mask_1.bmp Extract: /system/media/GPU/dot_mask_128x128.bmp Extract: /system/media/GPU/dot_mask_16x16.bmp Extract: /system/media/GPU/dot_mask_2.bmp Extract: /system/media/GPU/dot_mask_3.bmp Extract: /system/media/GPU/header32bpp.bmp Extract: /system/media/GPU/header8bpp.bmp Extract: /system/media/GPU/mask_vignette_legacy.bmp Extract: /system/media/GPU/mask_vignette_wide.bmp Extract: /system/media/GPU/stylizeColorRamp.bmp Extract: /system/media/GPU/stylizeContrastRamp.bmp Extract: /system/media/GPU/twoToneMaskH.bmp Extract: /system/media/GPU/twoToneMaskV.bmp Extract: /system/media/LMprec_508.emd Extract: /system/media/PFFprec_600.emd Extract: /system/media/audio/alarms/12th_hour.mp3 Extract: /system/media/audio/alarms/Pendulum.mp3 Extract: /system/media/audio/alarms/beeps.mp3 Extract: /system/media/audio/alarms/cape_breeze.mp3 Extract: /system/media/audio/alarms/chambered.mp3 Extract: /system/media/audio/alarms/classic.mp3 Extract: /system/media/audio/alarms/contrails.mp3 Extract: /system/media/audio/alarms/cylindrical.mp3 Extract: /system/media/audio/alarms/four_stringer.mp3 Extract: /system/media/audio/alarms/harp_arp.mp3 Extract: /system/media/audio/alarms/light.mp3 Extract: /system/media/audio/alarms/meniscus.mp3 Extract: /system/media/audio/alarms/progressive.mp3 Extract: /system/media/audio/alarms/snooze.mp3 Extract: /system/media/audio/alarms/tides.mp3 Extract: /system/media/audio/alarms/very_high.mp3 Extract: /system/media/audio/notifications/Content.mp3 Extract: /system/media/audio/notifications/Daybook.mp3 Extract: /system/media/audio/notifications/Hint.mp3 Extract: /system/media/audio/notifications/Notice.mp3 Extract: /system/media/audio/notifications/Venture.mp3 Extract: /system/media/audio/notifications/activate.mp3 Extract: /system/media/audio/notifications/ascending.mp3 Extract: /system/media/audio/notifications/berring.mp3 Extract: /system/media/audio/notifications/blipper.mp3 Extract: /system/media/audio/notifications/chimes.mp3 Extract: /system/media/audio/notifications/ding.mp3 Extract: /system/media/audio/notifications/double_agent.mp3 Extract: /system/media/audio/notifications/droplet.mp3 Extract: /system/media/audio/notifications/eve.mp3 Extract: /system/media/audio/notifications/flare.mp3 Extract: /system/media/audio/notifications/glockenspiel.mp3 Extract: /system/media/audio/notifications/gullatic.mp3 Extract: /system/media/audio/notifications/harp_major.mp3 Extract: /system/media/audio/notifications/level_up.mp3 Extract: /system/media/audio/notifications/link.mp3 Extract: /system/media/audio/notifications/meta.mp3 Extract: /system/media/audio/notifications/new_game.mp3 Extract: /system/media/audio/notifications/nova.mp3 Extract: /system/media/audio/notifications/now.mp3 Extract: /system/media/audio/notifications/opto.mp3 Extract: /system/media/audio/notifications/out.mp3 Extract: /system/media/audio/notifications/robi.mp3 Extract: /system/media/audio/notifications/sci_fi.mp3 Extract: /system/media/audio/notifications/si.mp3 Extract: /system/media/audio/notifications/simple_low.mp3 Extract: /system/media/audio/notifications/slider.mp3 Extract: /system/media/audio/notifications/stalactite.mp3 Extract: /system/media/audio/notifications/statements.mp3 Extract: /system/media/audio/notifications/stormy.mp3 Extract: /system/media/audio/notifications/stratus.mp3 Extract: /system/media/audio/notifications/striking.mp3 Extract: /system/media/audio/notifications/talkative.mp3 Extract: /system/media/audio/notifications/taptastic.mp3 Extract: /system/media/audio/notifications/twangster.mp3 Extract: /system/media/audio/notifications/warm_piano.mp3 Extract: /system/media/audio/notifications/wisdom.mp3 Extract: /system/media/audio/notifications/yep.mp3 Extract: /system/media/audio/notifications/zip.mp3 Extract: /system/media/audio/ringtones/8-bit_love.mp3 Extract: /system/media/audio/ringtones/Sense.mp3 Extract: /system/media/audio/ringtones/after_hours.mp3 Extract: /system/media/audio/ringtones/air_candy.mp3 Extract: /system/media/audio/ringtones/alki_drive.mp3 Extract: /system/media/audio/ringtones/alvord.mp3 Extract: /system/media/audio/ringtones/anthem.mp3 Extract: /system/media/audio/ringtones/apartment.mp3 Extract: /system/media/audio/ringtones/bass_dubbed.mp3 Extract: /system/media/audio/ringtones/carry_on.mp3 Extract: /system/media/audio/ringtones/chicka_chicka.mp3 Extract: /system/media/audio/ringtones/chinchilla.mp3 Extract: /system/media/audio/ringtones/cloud_level.mp3 Extract: /system/media/audio/ringtones/color_wheel.mp3 Extract: /system/media/audio/ringtones/contemplate.mp3 Extract: /system/media/audio/ringtones/copperpot.mp3 Extract: /system/media/audio/ringtones/cray_cray.mp3 Extract: /system/media/audio/ringtones/crunched.mp3 Extract: /system/media/audio/ringtones/curve.mp3 Extract: /system/media/audio/ringtones/defined.mp3 Extract: /system/media/audio/ringtones/docked.mp3 Extract: /system/media/audio/ringtones/dream_boat.mp3 Extract: /system/media/audio/ringtones/dusty_boots.mp3 Extract: /system/media/audio/ringtones/fog_lifter.mp3 Extract: /system/media/audio/ringtones/glider.mp3 Extract: /system/media/audio/ringtones/grit_kit.mp3 Extract: /system/media/audio/ringtones/harp_diminished.mp3 Extract: /system/media/audio/ringtones/heat_seeking.mp3 Extract: /system/media/audio/ringtones/heat_synth.mp3 Extract: /system/media/audio/ringtones/hit_it.mp3 Extract: /system/media/audio/ringtones/insight.mp3 Extract: /system/media/audio/ringtones/kiddle.mp3 Extract: /system/media/audio/ringtones/lexicon.mp3 Extract: /system/media/audio/ringtones/lily_pad.mp3 Extract: /system/media/audio/ringtones/magnifique.mp3 Extract: /system/media/audio/ringtones/marched.mp3 Extract: /system/media/audio/ringtones/modem.mp3 Extract: /system/media/audio/ringtones/modulate.mp3 Extract: /system/media/audio/ringtones/moments.mp3 Extract: /system/media/audio/ringtones/moon_light.mp3 Extract: /system/media/audio/ringtones/morse.mp3 Extract: /system/media/audio/ringtones/multiverse.mp3 Extract: /system/media/audio/ringtones/old_phone.mp3 Extract: /system/media/audio/ringtones/portal.mp3 Extract: /system/media/audio/ringtones/quietly_brilliant.mp3 Extract: /system/media/audio/ringtones/rhododendron.mp3 Extract: /system/media/audio/ringtones/riverrock.mp3 Extract: /system/media/audio/ringtones/spyglass.mp3 Extract: /system/media/audio/ringtones/standard_1.mp3 Extract: /system/media/audio/ringtones/standard_2.mp3 Extract: /system/media/audio/ringtones/standard_3.mp3 Extract: /system/media/audio/ringtones/standard_4.mp3 Extract: /system/media/audio/ringtones/standard_5.mp3 Extract: /system/media/audio/ringtones/standard_6.mp3 Extract: /system/media/audio/ringtones/standard_7.mp3 Extract: /system/media/audio/ringtones/stop_start.mp3 Extract: /system/media/audio/ringtones/summer_love.mp3 Extract: /system/media/audio/ringtones/suspended.mp3 Extract: /system/media/audio/ringtones/teleport.mp3 Extract: /system/media/audio/ringtones/then_some.mp3 Extract: /system/media/audio/ringtones/thistle.mp3 Extract: /system/media/audio/ringtones/turnpike.mp3 Extract: /system/media/audio/ringtones/uppy.mp3 Extract: /system/media/audio/ringtones/valencia.mp3 Extract: /system/media/audio/ringtones/vineyard.mp3 Extract: /system/media/audio/ringtones/wind_chimes.mp3 Extract: /system/media/audio/ringtones/woodblock.mp3 Extract: /system/media/audio/ringtones/zen.mp3 Extract: /system/media/audio/ui/Effect_Tick.ogg Extract: /system/media/audio/ui/KeypressDelete.ogg Extract: /system/media/audio/ui/KeypressReturn.ogg Extract: /system/media/audio/ui/KeypressSpacebar.ogg Extract: /system/media/audio/ui/KeypressStandard.ogg Extract: /system/media/audio/ui/Lock.ogg Extract: /system/media/audio/ui/LowBattery.ogg Extract: /system/media/audio/ui/Unlock.ogg Extract: /system/media/audio/ui/VideoRecord.ogg Extract: /system/media/audio/ui/Volume-1.aac Extract: /system/media/audio/ui/Volume-2.aac Extract: /system/media/audio/ui/Volume-3.aac Extract: /system/media/audio/ui/Volume-4.aac Extract: /system/media/audio/ui/Volume-5.aac Extract: /system/media/audio/ui/Volume-6.aac Extract: /system/media/audio/ui/Volume-7.aac Extract: /system/media/audio/ui/camera_click.ogg Extract: /system/media/mms/atis_tia_cmas_alert.mp3 Extract: /system/media/mms/kddi_earthquake_alert.mp3 Extract: /system/media/video/AndroidInSpace.240p.mp4 Extract: /system/media/video/AndroidInSpace.480p.mp4 Extract: /system/media/video/Disco.240p.mp4 Extract: /system/media/video/Disco.480p.mp4 Extract: /system/media/video/Sunset.240p.mp4 Extract: /system/media/video/Sunset.480p.mp4 Extract: /system/media/weather/weather_clear.mp4 Extract: /system/media/weather/weather_cloudy_day.mp4 Extract: /system/media/weather/weather_cloudy_night.mp4 Extract: /system/media/weather/weather_fog_day.mp4 Extract: /system/media/weather/weather_fog_night.mp4 Extract: /system/media/weather/weather_hot.mp4 Extract: /system/media/weather/weather_partly_cloud.mp4 Extract: /system/media/weather/weather_partly_cloud_night.mp4 Extract: /system/media/weather/weather_partly_sunny.mp4 Extract: /system/media/weather/weather_rain.mp4 Extract: /system/media/weather/weather_rain_night.mp4 Extract: /system/media/weather/weather_snow_day.mp4 Extract: /system/media/weather/weather_snow_night.mp4 Extract: /system/media/weather/weather_sunny.mp4 Extract: /system/media/weather/weather_thunderstorm_day.mp4 Extract: /system/media/weather/weather_thunderstorm_night.mp4 Extract: /system/media/weather/weather_windy_day.mp4 Extract: /system/media/weather/weather_windy_night.mp4 Extract: /system/usr/icu/icudt46l.dat Extract: /system/usr/idc/atmel-touchscreen.idc Extract: /system/usr/idc/projector_input.idc Extract: /system/usr/idc/qwerty.idc Extract: /system/usr/idc/qwerty2.idc Extract: /system/usr/idc/synaptics-rmi-touchscreen.idc Extract: /system/usr/keychars/Generic.kcm Extract: /system/usr/keychars/Virtual.kcm Extract: /system/usr/keychars/qwerty.kcm Extract: /system/usr/keychars/qwerty.kcm.bin Extract: /system/usr/keychars/qwerty2.kcm Extract: /system/usr/keychars/qwerty2.kcm.bin Extract: /system/usr/keychars/spade-keypad.kcm.bin Extract: /system/usr/keylayout/AVRCP.kl Extract: /system/usr/keylayout/Generic.kl Extract: /system/usr/keylayout/Vendor_045e_Product_028e.kl Extract: /system/usr/keylayout/Vendor_046d_Product_c216.kl Extract: /system/usr/keylayout/Vendor_046d_Product_c294.kl Extract: /system/usr/keylayout/Vendor_046d_Product_c299.kl Extract: /system/usr/keylayout/Vendor_046d_Product_c532.kl Extract: /system/usr/keylayout/Vendor_054c_Product_0268.kl Extract: /system/usr/keylayout/Vendor_05ac_Product_0239.kl Extract: /system/usr/keylayout/Vendor_22b8_Product_093d.kl Extract: /system/usr/keylayout/cy8c-touchscreen.kl Extract: /system/usr/keylayout/h2w_headset.kl Extract: /system/usr/keylayout/qwerty.kl Extract: /system/usr/share/bmd/RFFspeed_501.bmd Extract: /system/usr/share/bmd/RFFstd_501.bmd Extract: /system/usr/share/zoneinfo/zoneinfo.dat Extract: /system/usr/share/zoneinfo/zoneinfo.idx Extract: /system/usr/share/zoneinfo/zoneinfo.version Extract: /system/usr/srec/config/en.us/baseline.par Extract: /system/usr/srec/config/en.us/baseline11k.par Extract: /system/usr/srec/config/en.us/baseline8k.par Extract: /system/usr/srec/config/en.us/dictionary/basic.ok Extract: /system/usr/srec/config/en.us/dictionary/cmu6plus.ok.zip Extract: /system/usr/srec/config/en.us/dictionary/enroll.ok Extract: /system/usr/srec/config/en.us/g2p/en-US-ttp.data Extract: /system/usr/srec/config/en.us/grammars/VoiceDialer.g2g Extract: /system/usr/srec/config/en.us/grammars/boolean.g2g Extract: /system/usr/srec/config/en.us/grammars/phone_type_choice.g2g Extract: /system/usr/srec/config/en.us/models/generic.swiarb Extract: /system/usr/srec/config/en.us/models/generic11.lda Extract: /system/usr/srec/config/en.us/models/generic11_f.swimdl Extract: /system/usr/srec/config/en.us/models/generic11_m.swimdl Extract: /system/usr/srec/config/en.us/models/generic8.lda Extract: /system/usr/srec/config/en.us/models/generic8_f.swimdl Extract: /system/usr/srec/config/en.us/models/generic8_m.swimdl Extract: /system/xbin/[ Extract: /system/xbin/[[ Extract: /system/xbin/acpid Extract: /system/xbin/add-shell Extract: /system/xbin/addgroup Extract: /system/xbin/adduser Extract: /system/xbin/adjtimex Extract: /system/xbin/arp Extract: /system/xbin/arping Extract: /system/xbin/ash Extract: /system/xbin/awk Extract: /system/xbin/base64 Extract: /system/xbin/basename Extract: /system/xbin/beep Extract: /system/xbin/blkid Extract: /system/xbin/blockdev Extract: /system/xbin/bootchartd Extract: /system/xbin/brctl Extract: /system/xbin/bunzip2 Extract: /system/xbin/busybox Extract: /system/xbin/bzcat Extract: /system/xbin/bzip2 Extract: /system/xbin/cal Extract: /system/xbin/cat Extract: /system/xbin/catv Extract: /system/xbin/chat Extract: /system/xbin/chattr Extract: /system/xbin/chgrp Extract: /system/xbin/chmod Extract: /system/xbin/chown Extract: /system/xbin/chpasswd Extract: /system/xbin/chpst Extract: /system/xbin/chroot Extract: /system/xbin/chrt Extract: /system/xbin/chvt Extract: /system/xbin/cksum Extract: /system/xbin/clear Extract: /system/xbin/cmp Extract: /system/xbin/comm Extract: /system/xbin/cp Extract: /system/bin/rmt_storage Extract: /system/bin/vold Extract: /system/bin/wpa_cli Extract: /system/bin/wpa_supplicant -- Setting symlinks symlink: failed to symlink /system/xbin/bb/ifconfig to /system/xbin/ifconfig: No such file or directory symlink: failed to symlink /system/xbin/bb/route to /system/xbin/route: No such file or directory -- Setting permissions set_perm: chown of /system/etc/pre-init.d to 0 0 failed: No such file or directory set_perm: chmod of /system/etc/pre-init.d to 755 failed: No such file or directory set_perm: chown of /system/xbin/openvpn to 1000 1000 failed: No such file or directory set_perm: chmod of /system/xbin/openvpn to 755 failed: No such file or directory about to run program [/tmp/installbusybox] with 1 args Flashing GPS fix -- Europe specific GPS configuration Extract: /system/etc/gps.conf Extract: /tmp/virtuous-optimize_ext4 about to run program [/tmp/virtuous-optimize_ext4] with 1 args tune2fs 1.41.6 (30-May-2009) /dev/block/mmcblk0p26: Inode 7834 has an invalid extent node (blk 5827, lblk 0) /dev/block/mmcblk0p26: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) tune2fs 1.41.6 (30-May-2009) /dev/block/mmcblk0p27: Adding dirhash hint to filesystem. /dev/block/mmcblk0p27: Unconnected directory inode 4641 (/???) /dev/block/mmcblk0p27: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) tune2fs 1.41.6 (30-May-2009) /dev/block/mmcblk0p28: 334/9728 files (0.3% non-contiguous), 35074/38912 blocks run_program: child exited with status 1 -- Unmounting Partition unmount of /data failed; no such volume unmount of /cache failed; no such volume Installing Done script result was [@Installing Done] Installer Sucessfull (Status 0) End at : Tue Apr 2 19:01:36 2013 Je retourne sur ma ROM d'origine, après si tu as une solution, je suis preneur :) ! Modifié 2 avril 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 2 avril 2013 Auteur Share Posté(e) 2 avril 2013 Alors la rom s'install correctement ? Car j'ai pas testé le zip compilé cause de calibration batterie Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 Voir plus haut ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 2 avril 2013 Auteur Share Posté(e) 2 avril 2013 Merci pour ton test est sincère excuse je n'est pas du assez allégé la rom ! ou trop je vais testé sa et corrigé des que possible plus que 1 cycle et j'ai fini ma calibration je pourrais y regardé de plus près ! Sinon petite question 4ext recovery ? Tactile, non tactile ? Et à tu essayé en faisant un full wipe de 4ext et de laissé en normal à l'installation ? évité le full wipe de l'aroma voir s'il est en cause Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 (modifié) Alors j'ai 4ext non tactile, et j'ai fais le full Wipe via 4ext + Aroma, je me suis dis qu'au moins, on pourra pas dire que j'ai pas wipé :P Je vais essayé ce que tu me dis, je te tiens au courant de suite. EDIT : des suggestions pour l'installation de certains "gadget" à l'installation de la ROM ? Peut etre que ça change qqch ça aussi non ? EDIT : Je reste bloqué sur le bootanimation android, malheureusement... Modifié 2 avril 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SqueeZen Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 Je ne vois vraiment aucun intérêt d'avoir un HTC si c'est pour viré Sense ! Il y à des tel au même prix plus performant sans sense ! Donc là par contre c'est moi qui pige pas ! Sense s'est très allégé en version 4.1 et n'alourdit plus la Ram et le system ! Du moins mon ressentit est qu'il est déjà moins lourd que sense 3.6, et cela se ressent très vite ! C'est une question d'ergonomie et d'apparence. Donc une question de goût à l'usage. Je ne nie pas que Sense 4.1 est plus performant qu'Android sans surcouche, je n'ai pas essayé. Voilà, et je respect ce que tu fais. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Umut37 Posté(e) 3 avril 2013 Share Posté(e) 3 avril 2013 EDIT : Je reste bloqué sur le bootanimation android, malheureusement... +1 :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 3 avril 2013 Auteur Share Posté(e) 3 avril 2013 Je suis sur la correction de la rom, des que je l'est essayé et quel est fonctionnel la réupload dans la foulé ( je pense dans la nuit ! Au pire demain. ). Encore désolé d'avoir voulu allé trop vite j'aurais du attendre de la testé avant de vous faire une fausse joie ! Mais je vous r'assure je pense savoir d'ou viens le problème ! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 6 avril 2013 Auteur Share Posté(e) 6 avril 2013 (modifié) La V5 corrigé sera la dernière ROM pour le HTC desire S que je ferais. Je change de tel dans la journée pour le HTC ONE S cela va me changé un peut d'avoir jb + sense 4.5 sur un dual core avec 1go de ram ! Modifié 6 avril 2013 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 6 avril 2013 Share Posté(e) 6 avril 2013 (modifié) Mais du coup elle est corrigée là ? Tu vas assurer un "SAV" par la suite ? ^^ Modifié 6 avril 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
