feefou3593 Posté(e) 14 mars 2013 Share Posté(e) 14 mars 2013 Bonjour, Je souhaiterai rooter d'une manière simple mon téléphone pour pouvoir jouer à Ingress en utilisant un fake GPS (https://play.google....a.fakegps&hl=fr) Oui je sais, c'est pas beau de tricher ;-) J'ai donc contacter le support de unlockroot.com car j'avais cette erreur (voir PJ) Malheureusement, ils ne peuvent rien faire pour moi. Voir ci-dessous le mail d'échange avec le support : Hi, Sorry, but if it is Android 4.0.4, then you are unable to root your device by UnlockRoot/ Pro. The support list is generated by computer according to the success. Some user may have done additional operations to make their devices rooted successfully by UnlockRoot. We are unable to make most Android 4.0.4 or above rooted by simple operations. Best regards, UnlockRoot support@unlockroot.com From: unFreenaute Date: 2013-03-13 18:05 To: support Subject: Re: Xperia Mini Pro SK17 / Bootloader unlocked: No Thanks for your answer. So i try free version of UnlockRoot to root my phone but i've got this error (see attached file) I don't understant because my phone is listed in this page : http://unlockroot.com/unlockroot3.php (Sony Ericsson SK17i 4.0.4 4.1.B.0.587) What can i do ? Thanks for your answer. Best regards. 2013/3/13 support@unlockroot.com <support@unlockroot.com> Hi, Thank you for your support! This means your phone is unable to unlock the bootloader (unlock the bootloader is different from root). If it is Android 2.2-2.3, 4.0.0-4.0.3, then you may try the free version of UnlockRoot to root it. Best regards, UnlockRoot support@unlockroot.com From: unFreenaute Date: 2013-03-12 18:22 To: support Subject: Xperia Mini Pro SK17 / Bootloader unlocked: No Hello, I'm French user, sorry for my poor english. So i have a Xperia Mini Pro SK17. I do the manipulation : http://soft.unlockroot.com/soft/unlockphone_manual_sony.pdf (page 3) but it shows : Bootloader unlocked: No So is there a simply solution to root my phone ? Thanks for answer. Regards. J'aimerai donc savoir, s'il existe une autre méthode "simple" pour rooter son téléphone ? (ou alors une méthode permettant à Ingress de ne pas détecter les "mock location") Merci d'avance. PS : je suis sous Xperia mini pro SK17i android 4.0.4 build 4.1.B.0.587 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 15 mars 2013 Share Posté(e) 15 mars 2013 Oui il y a moyen de le faire, mais en tant que joueur d'ingress je ne peut pas t'aider. C'est ridicule de tricher. Le but c'est de jouer dans les règles, sinon on joue à un jeu en solo comme GTA. Lien vers le commentaire Partager sur d’autres sites More sharing options...
feefou3593 Posté(e) 18 mars 2013 Auteur Share Posté(e) 18 mars 2013 Merci quand même. En fait, j'habite en campagne et je n'ai accès à quasiment aucun portail d'ou ma demande ;-) Peux tu juste m'indiquer si la manip que tu connais est "simple" ? PS : ta correction devrait être plutôt "je ne VEUX pas t'aider" ;-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
