Ugoboss Posté(e) 16 mars 2013 Share Posté(e) 16 mars 2013 (modifié) Bonjour à tous, J'ai créer un zip flashable mais je bloque au niveau de l'updater-script... Après l'avoir écrit le script, il m'efface le contenu de ma mémoire interne et je ne vois d'où cela peut venir.. Voici mon code : ifelse(getprop(ro.product.model)=="Nexus 4",ui_print("You have a Nexus 4... Script is continue..."),(ui_print("You haven't got a Nexus 4 ! Wipe aborted");abort())); mount("ext4", "EMMC", "/dev/block/mmcblk0p22", "/cache"); mount("ext4", "EMMC", "/dev/block/mmcblk0p23", "/data"); mount("ext4", "EMMC", "/dev/block/mmcblk0p21", "/system"); ui_print(" "); ui_print(" "); ui_print(" "); ui_print("Wiping Dalvik cache"); ui_print(" "); delete_recursive("/data/dalvik-cache"); ui_print(" "); ui_print("Dalvik cache wiped succesfully"); ui_print(" "); ui_print(" "); ui_print("Removing Media databases"); ui_print(" "); delete_recursive("/dbdata/databases/com.android.providers.media"); delete_recursive("/dbdata/databases/com.cooliris.media"); ui_print(" "); ui_print("Wiping cache"); ui_print(" "); delete_recursive("/cache"); ui_print(" "); ui_print("Cache wiped succesfully"); ui_print(" "); ui_print(" "); ui_print("Wiping data/factory reset"); ui_print(" "); delete_recursive("/data"); delete_recursive("/cache"); delete_recursive("/sd-ext"); delete_recursive("/sdcard/.android_secure"); ui_print(" "); ui_print("Data wiped succesfully"); ui_print(" "); ui_print(" "); ui_print("Removing system files from SD Card"); ui_print(" "); delete_recursive("/sdcard/.data/footprints"); delete_recursive("/sdcard/.bookmark_thumb1"); delete_recursive("/sdcard/.data/mail"); delete_recursive("/sdcard/Android/data/com.google.android.apps.genie.geniewidget.news-content-cache"); delete_recursive("/sdcard/Android/data/com.android.providers.media"); delete_recursive("/sdcard/Android/data/com.google.android.apps.maps"); delete_recursive("/sdcard/.data/navigator/Data/Temporary"); delete_recursive("/sdcard/LazyList"); delete_recursive("/sdcard/LOST.DIR"); ui_print(" "); ui_print("System files from SD Card removed"); Quelqu'un aurait-il une idée d'où cela peut venir s'il vous plaît ? Merci d'avance :) Modifié 20 mars 2013 par UgoBoss Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Romain Lohezic Therom Posté(e) 20 mars 2013 Share Posté(e) 20 mars 2013 La ligne Factory Reset je dirais. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ugoboss Posté(e) 20 mars 2013 Auteur Share Posté(e) 20 mars 2013 J'ai trouvé ma réponse c'est la ligne delete_recursive("/data") :) Merci quand même, je met résolu sur le topic ;) Avec mon HTC Magic sous Jelly Bean (¤_¤) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
