Teoandro Posté(e) 4 mai 2013 Share Posté(e) 4 mai 2013 (modifié) CyanogenMod 10.1 for Galaxy Ace Salut à tous, je vais vous présenter la rom CM10.1 par l'équipe androidarmsv6 qui est la suite officiel de la rom de Wayland_Ace ( http://forum.frandro...-beta-7-212113/ ) Changelog: Nightly builds : Builded throug jenkins CM 10 sources updated Androidarmv6 sources updated Updates of 2-5 days [01.06.2013] RC 4 : Fixed Bluetooth again Fixed USB mass storage, both working Added Radio app (Effem) Working Effem due to Bluetooth Working. CyanogenMod Source Updated (RC3 and RC4) Androidarmv6 Sources updated as well. Stable ROM builded by jenkins (RC4) Some apps (DSP Manager, email, echange...) Are found inside ZIP, folder extras. Place it on system/app to flash what you want of them. [04.05.2013] RC3 :Le bluetooth ne marche pas... Il faut placer le kernel de la N1 sur le package de la RC2 pour fixer l'usb mass storage & co USB mass storage fixed Some fixes on overlay (mdpi-common) cLock layout fixed (showing weather) Init and libaudio improvments on msm7x27 devices Added Effem support. New playstore and Google apps. 4.0.27 CM10.1 Sources and androidarmv6 sources updated [17.04.2013] RC 2 : Fixed SD card permissions Fixed Battery Status Fixed some more layouts Improved libaudio (Audio routing is still an isssue) Updated libpower Bring back Apollo Bring back Email and Exchange Bring back Terminal emulator Added live wallpapers cLock from CM added CM10.1 Sources updated (CyanogenMod 10.1 M3 many changes) Androidarmv6 sources updated Builded through jenkins - Thanks erikas for teach me :P [19.03.2013] RC 1 : Builded by me on my PC Fixed dimens.xml on launcher (even with search bar) Fixed CRT Animation Added Ring tone loop Updated some memory handlers in kernel A lot of changes in androidarmv6 frameworks New superuser app and options All erikcas changes in their nightlies are included Androidarmv6 sources updated CM sources updated [17.02.2013] Beta 7 : Android 4.2.2 CM sources update [21.01.2013] Beta 6 : All proprietaries libs are updated to latest stock ROM versions Audio HAL updated Camera HAL updated (Better preview handling) Offline charging fix Gmail app removed (can be installed from marked) BLN support disabled by default, can be enabled by BLN Controll app. some kernel updates and improvements kernel: deprecated compcache removed, new zram is added default wifi sleep policy changed to never (you can choose it in wi-fi settings) triple buffering disabled now GPS updates: HAL is builded from sources, updated gps.conf, faster GPS lock CM & androidarmv6 latest sources Other changes... [06.01.2013] Beta 5 : Applications added: Google Talk, chrome bookmarks sync, Setup wizard OMX libs fixed: Youtube controls bug fixed, camera crash fixed, camcoder works in HW mode Source based liblight with BLN support, BLN enabled by default Superuser settings crash fixed Surface dithering disabled by default for more perfomance Added lagloose's force repeat ringtone hack Other fixes, that I forgot Latest CM and androidarmv6 sources [31.12.2012] Beta 4 : Wifi enhancements: signal indicator is working, faster connecting to AP, tethering (unstable) Network location fix (A-GPS is working now) Lockscreen improvement: date is too visible UI improvements (again little speedup) Some OMX libs improvements CM and androidarmv6 sources updates [28.12.2012] Beta 3 : Gallery issue is fixed (Thanks CM team) Lockscreen issue with cutted clocks is fixed GPS improved Added LiveWallpapers picker, so u can install any livewallpaper if u want ALL locales and languages support init.d script is working now UI responsibility is improved CM sources updated [24.12.2012] Beta 2 : Added language locales: en_GB fr_FR it_IT de_DE es_ES ru_RU Added predefined APN list (for mobile data) Added back ThemeChooser Google search box disabled by default, can be enabled in Settings CM sources updated [23.12.2012] Beta 1 : native USB tethering fixed bluetooth fixed CM sources update Backported USB gadget stuff from kernel 3.0 (USB functions do not use legacy stuff anymore) Video recording Quick search box added Other changes Note: ADB must be enabled in development settings [19.12.2012] Alpha 5 : Camera preview & taking pictures is working Removed second camera app (LegacyCamera is not used anymore) Updated CM sources. [18.12.2012] Alpha 4 : wifi fixed, switched to wpa_supplicant version 0.8 mobile data is working keyboard size is fixed keyboard new swipe ability does not cause crash anymore updated cm sources Torch application is added Readded developer options is settings. [29.11.2012] Alpha 3 : USB mass storage is fixed new hw QCOM modules Telephony fixed Better stability Android 4.2.1 [26.11.2012] Alpha 2 : new notification bar buttons fixed added CM10 bootanimation instead of CM9 animation audio playback fixed (missing media_codecs.xml) was added added lockscreen Hardware "Home" button is fixed [26.11.2012] Alpha 1 : Initial version (very unstable) Ce qui marche : GPS Camera preview && taking pictures Playstore Gmail Wifi Mobile data Booting Audio HW accel Touch (with multitouch) Sensors USB mass storage Telephony Bluetooth Camera recording Bug : Audio routing issue: in some cases audio routes to handset instead of headset Secure wifi AP Compass Downloads: NIghtly Builds: http://android.cas-o....tlies-jenkins/ : faite bien attention a choisir la version pour cooper!! OLD VERSIONS: RC 4 MD5 Sum: 3d1bfad98ce8f8bff552cd2f72e2a028 RC3 MD5 Sum: 2ec55c53c293520aa2ccf55f534dbbc RC 2 MD5 Sum: 2c2f70792866810251781de19beb61fc RC 1 MD5 Sum: 34442b20caf613724f9637118bdd20f3 Beta 7 Beta 6 SHA1 Checksum: 911e4719f0dfc0ebe7ac258dbfe73b9234a982d4 Beta 5 SHA1 Checksum: 909f336d0d5dcf6039c6e5efae78d162a4673000 Beta 4 SHA1 Checksum: eabbbe337be008bd87a08379923155cc614b73f8 Beta 3 SD-card edition Beta 3 SHA1 Checksum: 890980df5efdb7f87c2d0d24a503dc6a635df001 Beta 2 SHA1 Checksum: b95a0368bea050d9e31312f2418554a476f9d65a Beta 1 SHA1 Checksum: eb52e20fcc731bc49b89c8a590b50298e719cf41 Alpha 5 SHA1 Checksum: b25454c19178205da35b356a5fedf31412315d3a Alpha 4 SHA1 Checksum: 60c6575429e193e4b1f8e7a0161b1110f81777fb Alpha 3 SHA1 Checksum:272292ebf4b35c65d900b9d088d556612b0eeb58 Alpha 2 SHA1 Checksum:c44483ec90feba6d191df8419859bae0b0807398 Alpha 1 SHA1 Checksum:f795c18de6cde49b4e92679ac6338ab7f169e8f7 Retour perso : La meilleur rom CM10.1 :D Source : http://forum.xda-dev...d.php?t=2199575 Modifié 15 juin 2013 par Teoandro Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GaLaXyAcE Posté(e) 4 mai 2013 Share Posté(e) 4 mai 2013 Le bluetooth ne marche pas sur la N1... Il faut placer le kernel de la N1 sur le package de la RC2 pour fixer l'usb mass storage & co. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 4 mai 2013 Auteur Share Posté(e) 4 mai 2013 (modifié) A oui effectivement je rajoute ça :-) merci Modifié 4 mai 2013 par Teoandro Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GaLaXyAcE Posté(e) 2 juin 2013 Share Posté(e) 2 juin 2013 RC4 up Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 Enfin post mise a jour et bonne nouvelle : la rom est mise a jour tout les 2 à 3 jours!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
acehelper97 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 super je vais l essayer en attendon l appli QuickSettings - v1.2.6.1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 Moi ça sera, je pense, ma rom définitive :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
acehelper97 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 et tes retoures a toi ils sont bien? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 Très bon :) avec le script fly on mod, tout marche parfaitement :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akrame2012 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) edite:ok pour le scripte jai vue sur le poste que il falais faire quelque chose de special pour jb et ics? Modifié 15 juin 2013 par android akram Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 Oui c'est ça ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akrame2012 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 faudre juste metre le lien directe de telechargement parceque la je men sort pas et pui les nouvau pourai se tremper il est ou le lien pour telecharger je le trouve pas? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 Oui mais ça vas changer tout les 2 jours... C'est facile il faut juste trouver ça : android cm_cooper-userdebug-cm-10.1 (stable) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akrame2012 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) ah sayer jai trouver merci Modifié 15 juin 2013 par android akram Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Braamss Posté(e) 5 juillet 2013 Share Posté(e) 5 juillet 2013 Bonsoir, je souhaite installer fly on mod avec cette rom, comme elle est Jelly bean j'ai telecharger et flasher un patch avec le services.jar sur xda mais au redémarrage mon téléphone reste bloquer sur le boot. Pouvez vous m'aidez svp ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GaLaXyAcE Posté(e) 5 juillet 2013 Share Posté(e) 5 juillet 2013 Tu as pris ce sujet ? http://forum.xda-developers.com/showthread.php?t=2298898 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Braamss Posté(e) 5 juillet 2013 Share Posté(e) 5 juillet 2013 Tu as pris ce sujet ? http://forum.xda-dev...d.php?t=2298898 Oui exactement celui la ! Et j'ai pris le patch flashable Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GaLaXyAcE Posté(e) 5 juillet 2013 Share Posté(e) 5 juillet 2013 Prends bien celui qui te convient (il y un patch pour la RC4 et un pour les nightlies) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Braamss Posté(e) 5 juillet 2013 Share Posté(e) 5 juillet 2013 J'ai pris celui pour les nightlies aussi Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GaLaXyAcE Posté(e) 6 juillet 2013 Share Posté(e) 6 juillet 2013 J'ai pris celui pour les nightlies aussi Et tu es sur quoi ? la RC4 ou une nightly ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Braamss Posté(e) 7 juillet 2013 Share Posté(e) 7 juillet 2013 Non c'est bon je suis allé sur la 10.1 de Maclaw mdr Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sylver7 Posté(e) 11 juillet 2013 Share Posté(e) 11 juillet 2013 Les accusés de réception marchent ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
