Yonip_Scavenger_ICS_a888
********** Yonip Scavenger ICS **********
***** This is an ICS 4.0.4 Version of A888 not 4.1.9(hahah) *****
Thanks to:
Sir Rymoj Serolf for Yonip as Base and Sir Jaymar Bondoc Dela Cruz of a919
Ported By: Elias C. Desamparado Jr
***** PLEASE READ *****
!!BACKUP YOUR CURRENT ROM FIRST!!
[*] If you are not Satisfied in ths ROM .. Simple.. dont Use it.. Im not an expert in porting ROMs just sharing what im currently using.
Screen Shots Here: http://www.facebook....t=group_comment
Video tut for Touchwiz:
http://www.facebook....video_processed
*****steps in video tut
1 click on the file in your SD>launcher>
2 grant SU for Titanium backupPRO and wait til Touchwiz is found in home button
3 Force Close titanium backup in Settings>Apps(if touchwiz is now visible)
4 Open Titanim backupPRO to uninstall the other launcher(not touchwiz)
5 install a few apps(Before Reboot)(recommended to run them as test)
***note: install some(1 or 2) apps after doing video tut for touchwiz to adapt
Features:
[*] Android 4.0.4 Ice Cream Sandwich
[*] Transparent Statusbar
[*] Transparent SmS
[*] New Font Rosemary
[*] Yonip Launcher
[*] Touchwiz5 Launcher included! ***see video
[*] S3 Widgets
[*] S3 Boot Logo
[*] S3 Bootanimation
[*] S3 Boot audio
[*] Smooth
[*] Pre-Rooted
[*] Busybox
[*] Performance Tweaks
[*] Init.d Tweaks
[*] More RAM Free
[*] Youtube with dowload button in "MORE" option
[*] And Others, find out yourself ...
********** READ THE INSTRUCTION **********
Required : SD card (minimum size 30mb free)
Scavengerv3: file size 245.69MB
Link:
https://docs.google.com/file/d/0ByeD-ijTBd2lbjgwbDVVSmR5THM/edit?usp=sharing
Removed overclock
added
build tweaks(removed some)
transparent google search widget
transparent weather clock widget
Chat On Samsung S3
Working awesome Beats by Dre
Color Note
New stable launcher with labels on home apps
INSTRUCTION:
[*] Download the File ".zip"
[*] Copy the .zip to SDcard
[*] boot into your CWM/TWRP Recovery
[*] wipe data / factory reset
[*] Install .zip from SDcard >Yonip_Scavenger_a888_Fixed
[*] Reboot System
[*] Phone turns ON
[*] Reboot again using rebooter app (Recommended for tweaks and check root)
[*] Do Video tut for Touchwiz and read note
[*] Done
Download Link: (File size: 243.38)
https://docs.google....dit?usp=sharing
"Happy Flashing"
Declaimer :
I Am Not Responsible For Any Brick or Any Problem on your Device.
Flash At Your Own Risk.
Thank You.
Modifié par davidwikoPEAX
Link:
Removed overclock
added
Chat On Samsung S3
Color Note
Bon apres l'avoir flashé pour l'essayer je fais un petit retour sur cette rom.
comme la description l'indique elle ressemble a un galaxy s3 que ce soit le boot, les sons, le launcher, les icones,la font, widgets et les settings (voir photos ci dessous)
la rom est fluide et jolie, passons au benchmark :
(Pour info la rom n'est pas OC !)
Antutu : 6518
Quadrant :3406
sachant que je tourne d'habitude sur la StockRomLIte v0.9 qui elle est OC a 1,2 ghz et qui obtient 67xx sous Antutu.. donc cette rom s'en sort pas mal du tout.
les sms on un fond transparent donc on voit le wallpaper derriere
appareil photo comme les roms de spanish, c'est pas en full screen
pour l'eap sim: passage obligatoire en Anglais pour pouvoir enregistrer le reseau (retour en francais apres et ca fonctionne toujours)
niveau GPS : comme on le sait le peax n'est pas une bete de course mais la en meme pas 20sec il a fixé 5 sur 10
Pour conclure la Rom est fluide, jolie et je vais l'adopter avec quelque modif
je vous la recommande et en plus de ca elle n'est pas gourmande
2 petit bémol :
app non full screen ( au pire on en flash un autre )
le dialer n'est pas centré ( idem )
Modifié par SuperDroid
