[ROM][2.3.6]M'rage Rom V3.0[01.06.2013][Epicness]
This inst a mirage its M'rage ROM
This is a official built to ACE inspired of the M'rage Rom from Gio. Its simple, highly customizable and with a EPIC LAYOUT biggrin.gif
Again like my policy: the aim of this rom is stability, performance and of course beauty smile.gif
Download end of Post 3
Features:
-Ext4 filesystem
-Battey Extender Kernel
-New Awesome Orange Theme (ICS+JB+Miui)
-JB statusbar layout
-Aroma Installer
-Deodexed and zipaligned
-Adrenaline Engine & Boost
-Batterybar
-Beats audio
-Bravia engine
-Long press tos skip music in the stock player
-20 working toggles in notification panel
-Adreno libs, for best performance on games
-Settings modded with tabs
- Bla bla bla... See the screeshots!
Bugs/Issues
rien
Changelog
M'rage V3: [01/06/2013]
-Aroma installer only to choose icons... Simple way to dont have any more problems
-Removed unusefull apps
-*Hot* New awesome statusbar
[inspared in FlymeOS]
-New Alarm (DeskClock) app
-Moddified callscreen
-Quickpic as default gallery
-Many changes on theme [Awesome]
-Fixed and improved Pin/Pattern lockscreen
-Improved performance and battery live
-Now framework folder Odexed for better performance
-And much more...-Nothing except some little problems with colors but u wont notice
The shortcut of launcher inst working. I will fix soon
Changelog
Patch V2.1: [03/03/2013]
-Improved theme
-New lockscreen Pattern and Password [similar to ics]
-Improved Mms app
-Some improvements on launcher
-Minimal fixes
M'rage V2: [25.02.2013]
-4.2.2 Statsbar
-31 toggles working toggles
-New mensage layout
-Fixed Aroma installer
-New dialer
-SpaceCaker Kernel
-Fixed lag
-Improved Contacts
-TW Launcher
-New awesome music app theme
-Center clock option in statusbar
-Clock position on Note Lockscreen
-MegaBass Audio tweak
-Improved Brightness Slider
-And more
  • Installation Guide
  1. Download M'rage Rom
  2. Put the zip file in your root sd card
  3. Run zip file from your recovery
  4. Choose your options on aroma installer
  5. Install
  6. Wait 4/5mint while is booting
  7. Go to Settings->Parts->Statusbar->Clock Tweaks, and select a color for the clock
  8. Go to Settings->Parts->Statusbar->Battery Tweaks, and enable CM Battery
  9. Now your system is fully operational
  10. Reboot & enjoy
ScreenShot Version 3
Q&A
Q:
My contacts pictures are in low definition. How to fix?
A:
That's because the contact pictures are from your google contacts, if u want it in HD u most add one by one from ur SD Card
Q:
Why i can see my clock?
A:
See the installation guide, there is the steps to follow
Q:
I cant see the battery icon in the toggle.
A:
Q:
Can i add an picture in the contacts image on statusbar?
A:
Yes you can, check bellow
Q:
How to change Clock Layout on Note Lockscreen?
A:
Go to settings->display->lockscreen and fonts->clock position
Q:
This is a stock 2.3.6?
A:
Yes it is...
Q:
Can i use some of your mods?
A:
Maybe yes maybe no, ask me first.
Q:
I found a bug or problem. How to report?
A:
Send pm to me
Your Pic on Statusbar
First of all download this zip file ->
  1. Open the zip file
  2. Go to ur_pic_bymatz.zip\matz\system\app\SystemUI.apk\res \drawable-mdpi
  3. Replace the mypicture.png by your picture (Must be in .png extension)
  4. Close the zip file and move it to your SD Card
  5. Go to recovery and install te zip file
Downloads:
M'rage ROM V3:
RLT Patch fix:
Check the install instructions before install
M'rage ROM V2:
M'rage ROM:[Outdated]
Modifié par android akram
  • 1 month later...
